Greetings! I am looking to enable the hidden menu on my 2018 Audi S5 Sportback and am having issues locating instructions relevant to my model/year. The RT forum entries and A50C forum entries provide instructions for older generations of MMI (e.g. MMI 3G), but the older instructions don't apply to my car. While VCDS lets me interact with the 5F module, there is no "Channel 6" in Adaptation to enable as there is on previous generation vehicles with MMI 3G. Does anyone have instructions that include the name of the channel that needs to be enabled? Thanks for any advice! ~Mike
I've included the VCDS scan of my car below:
Friday,12,July,2019,08:11:15:35744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 19.6.1.0 (x64)
VIN: WAUC4CF53JA016644 License Plate: UPTIME (S5)
Mileage: 21679km-13470mi Repair Order:
Chassis Type F5-AU49 (8W8)
Scan: 01 02 03 08 09 13 15 16 17 19 1B 29 32 36 39 3C 42 44 46 47
52 5F 6C 6D 74 81 82 8B A5 A9 BB BC CA CF D6 D7
VIN: WAUC4CF53JA016644 Mileage: 21679km-13470miles
29-Left Light -- Status: INTERFACE NOT COMPATIBLE
39-Right Light -- Status: INTERFACE NOT COMPATIBLE
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: INTERFACE NOT COMPATIBLE
D7-Light Ctrl Right 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CWGD) Labels:. 07K-907-309-V1.clb
Part No SW: 8W0 907 559 H HW: 06M 907 309 D
Component: V6 3.0l TFSI H21 0005
Revision: B2H21000
Coding: 1A2A00322366010E34280000000000000000000000000000
Shop #: WSC 06334 790 00001
ASAM Dataset: EV_ECM30TFS0118W0907559H 001006
ROD: N/A
VCID: 4A9BBF8EED34A91F07-801F
4515 - Radiator Fan (V7)
P1950 00 [000] - Movement Restricted / Jammed
0000 - ROD - Unknown Error Code
- 00 [000]
Address 02: Auto Trans (J217) Labels:* Redir Fail!
Part No SW: 8W0 927 158 C HW: 0D5 927 156 H
Component: 0D5 30TSIUSA H05 1003
Revision: --H05---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011.rod
VCID: 428B97AED504715FCF-8017
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PRE-V1.clb
Part No SW: 8W0 907 379 M HW: 8W0 907 379 D
Component: ESP9 Premium H13 0767
Coding: 1CAA149A30A30A9C11A44895408158A2E4259A38280C508812021A4527A459
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: 4FADAE9A16568C3750-801B
417024 - TPMS Warning; Rear Right Tire
C105A 00 [032] - Pressure too Low
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H55 Klima Zone 3 H55 02050205
Coding: 1608050D5544010D10020100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: N/A
VCID: 448791B6CF107F6FFD-8011
Subsystem 1 - Part No SW: 4M1 820 021 A HW: 4M1 820 021 A
Component: J126 FLuftV H08 0003
Serial number: 00000000000001603260
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_ª H01 0006
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
131078 - Reference Voltage
B10AD 16 [009] - Voltage Too Low
Reset counter: 230
Mileage: 16733 km
Date: 2019.05.05
Time: 17:47:43
Voltage terminal 30: 14.68 V
Outside air temperature: 31.00 °C
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07500363E0691CCD050D511918AC9CB9110B3D040000000000000000200016010A69012B825709
VCID: 020B57AE9584B15F8F-8057
Subsystem 1 - Part No SW: 8W6 955 119 HW: 8W6 955 119 Labels: 1KX-955-119.CLB
Component: 494 LL 050417 036 0471
Serial number: 00000001704030303602
Coding: 5FC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 204 559 99X 81A HW: 4M0 941 531 T
Component: E1 - LDS H06 0008
Serial number: 24 02 2017 00793706
Subsystem 4 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H04 0050
Serial number: 0000009600335Z0CQ602
Coding: 350000
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20170427095627 00273
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE123031723610109
Interior Light Module:
Subsystem 7 - Part No SW: 8W0 947 135 CS HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: Q00291848
Subsystem 8 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2617000031920006
Subsystem 9 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J873 MKS_FSv H03 0033
Serial number: 7008174235B171434596
Coding: BF0500
Subsystem 10 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J872 MKS_BFSv H03 0033
Serial number: 7008174235B171433231
Coding: B30500
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 8W0 907 561 C HW: 8W0 907 561
Component: LRR4 H10 0330
Coding: B4779FF258FFEC05757A61A1
ASAM Dataset: EV_ACCBOSCHAU49X 003022
ROD: EV_ACCBOSCHAU49X.rod
VCID: 3E73E35EA1FC15BFAB-806B
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 J HW: 8W0 959 655 J
Component: Airbag10.44 H09 Airbag10.44 H09 01040104
Serial number: 003US0006CPI
Coding: BFCCF0C000800000A0000033D24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005015
ROD: N/A
VCID: 50AFADE60B6893CF49-8005
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2033
Serial number: 8W0857705G0149R00679
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2033
Serial number: 8W0857706J0144R01614
Coding: 80000D
Occupant Detection:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J170007BBLG0A
Subsystem 4 - Part No SW: ----------- HW: 442 061 305 17
Serial number: 3577Y009F2414141236M
Subsystem 5 - Part No SW: ----------- HW: 442 061 305 17
Serial number: 3587Y009F2414143218P
1C7
Serial number: 3517700A52674E13E09C
Subsystem 7 - Part No SW: ----------- HW: 442 0B1 305 17
Serial number: 35277009B2674E142334
Subsystem 8 - Part No SW: ----------- HW: 442 0C1 105 17
Component: FrontSensor_D 1C5 014A
Serial number: 3557500AB22BF493612F
Front Sensor Passenger:
Subsystem 9 - Part No SW: --- HW: 442 0C1 105 17
Component: FrontSensor_P 1C5 014A
Serial number: 3567500AB22BF495909R
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 GG HW: 4M0 907 129 GG
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 7BF52A4AF26EC097CC-802F
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 890 D HW: 8W5 920 890 D
Component: FBenUSA 0371
Coding: 09CF49CB7CA8CF0502B3E9601800400008000000
ASAM Dataset: EV_DashBoardAU736 001027
Address 19: CAN Gateway
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8W0 907 144 E HW: 8W0 907 144 C
Component: SCU_MLBevo H03 0706
Coding: 40
ASAM Dataset: EV_SCUZFLSAU49X 002014
ROD: EV_SCUZFLSAU49X_002.rod
VCID: 3D71E452ACFA0EA7B2-8069
Address 29: Left Light
Interface not compatible.
Address 32: Differential Locks (J187) Labels: None
Part No SW: 8W0 907 163 HW: 8W0 907 163
Component: QSP QCU Gen2 H07 0040
Revision: 5WK12700 Serial number: 605721701252007
Coding: 0001
ASAM Dataset: EV_TVDCQSP22 001007
ROD: EV_TVDCQSP22.rod
VCID: 79F93042F852F287DE-802D
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M1 959 760 HW: 4M1 959 760
Component: MEM-FS 008 0031
Serial number: 00000259079390
Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
VCID: 76E33B7EC94C9DFFB3-8023
Address 39: Right Light
Control Module Part Number: 8W5 035 880 A
Component and/or Version: MU-P-LNS-US 034 1118
Software Coding: 019453020000000053220002041A00102F0012E501700904BE
Work Shop Code: WSC 06335
Advanced Identification/FAZIT
Serial number: A798E0HB032395
Identification: JTB-074
Date: 25.05.17
Manufacturer number: 1184
Test stand number: 0281
Flash Status
Programming Attempts(application): 0/0
Programming Attempts(data): 65535/1/1/1/1/1/0/0/0/1/65535/65535/65535/0/0/0/1/0/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535
Successful Attempts(data): 65535/1/1/1/1/1/0/0/0/1/65535/65535/65535/0/0/0/1/0/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535
Flash Date: 00.01.01
Flash Tool Code(data): 00001 790 06335
Misc.
Hardware number: 8W5 035 880
Workshop System Name: J794
Equipment/PR Code: 000002C87F239694D2E799FC
Dataset Number: 8W2909545H
Dataset Version: 0034
ASAM Dataset: EV_MUHig6C3Gen2HBAS
ASAM Dataset Revision: 001115
Car Info
Chassis Number: WAUC4CF53JA016644
VCDS Info:
Labels: 8W0-035-MIB-HGH2.clb
Date: 25.05.17
Flash Status
Misc.
Car Info
VCDS Info:
