- Joined
- Sep 22, 2017
- Messages
- 16
- Reaction score
- 7
- Location
- Wakefield, West Yorkshire, U.K
- VCDS Serial number
- C?ID=257024
Hi guys,
could anyone try help point me in the right direction here - i'm lost with this one
2005 audi A8 3.0tdi ASB engine code
vehicle has no communication with nearly every modules
insert key and try start, engine cranks and runs for a few seconds then cuts out - like a vehicle with immo problems - guessing due to the no communication to modules
check fuses and can't find any problems there
instrument cluster does not illuminate or wake up at all - nothing there - i've had the clocks tested and all o.k - although i get CP active - the owner is 110% adamant these clocks are the ori clocks and have NOT been replaced at all
car was fine and would just not start one morning
i have removed front seats and checked under the carpets around the kessy unit to look for water ingress and can't find any
any help on where to start would be great - TIA
here is autoscan
here is autoscan
Friday,12,July,2019,13:01:43:47411
VCDS Version: 19.6.1.0
Dealer/Shop Name: JHM
Mileage: 325600km-202318mi Repair Order: a8l 2005 no comms
Chassis Type: XX (4E0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 1E 25 34 36 37 38 42
46 47 4F 52 53 56 61 62 67 72 76 77
VIN: XXXXXXXXXXXXXXXXX Mileage: 325600km-202318miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: Cannot be reached 1100
06-Seat Mem. Pass -- Status: Cannot be reached 1100
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Cannot be reached 1100
09-Cent. Elect. -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: Cannot be reached 1100
18-Aux. Heat -- Status: Cannot be reached 1100
1E-Media Player 2 -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Cannot be reached 1100
34-Level Control -- Status: Cannot be reached 1100
36-Seat Mem. Drvr -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Cannot be reached 1100
46-Central Conv. -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
67-Voice Control -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
76-Park Assist -- Status: Cannot be reached 1100
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
Address 05: Acc/Start Auth.
Address 06: Seat Mem. Pass
Address 07: Control Head
Address 08: Auto HVAC
Address 09: Cent. Elect.
Address 15: Airbags
Address 16: Steering wheel
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 P HW: 4E0 920 950 P
Component: KOMBIINSTR. VDO H71 0400
Revision: D02 Serial number: AUDID3F0000798
Coding: 0000413
Shop #: WSC 06795 067 57207
VCID: 31694EF8A89069C726-8064
Fault Status: 00000011
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:13
Address 18: Aux. Heat
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H11 0090
Revision: 11 Serial number: 20003061028103
Coding: FCFE5BDE2B7104
Shop #: WSC 02313 785 00200
VCID: 275DA0A096542777F8-8072
20 Faults Found:
01312 - Powertrain Data Bus
014 - Defective
Fault Status: 01101110
Fault Frequency: 20
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:14
01964 - Control Module for Seat & Steering Column Memory (J136)
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:15
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:15
01308 - Control Module for Roof Electronics (J528)
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:15
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:15
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:15
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:15
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:15
00456 - Control Module for Access and Start Control (J518)
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:15
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:15
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:15
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:15
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:16
01207 - Control Module for Auxiliary Heater (J364)
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:16
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:19
02103 - Control Module 2 for Vehicle Electrical System (J520)
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:19
00461 - Control Module for Seat Memory; Passenger (J521)
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:19
01327 - Control Module for Parking Aid (J446)
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:19
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:12:19
00384 - Optical Databus
Reset counter: 73
Mileage: 325608 km
Date: 2017.08.28
Time: 01:28:53
Address 1E: Media Player 2
Address 25: Immobilizer
Address 34: Level Control
Address 36: Seat Mem. Drvr
Address 37: Navigation
Address 38: Roof Electronics
Address 46: Central Conv.
Address 47: Sound System
Address 4F: Centr. Electr. II
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Address 56: Radio
Address 61: Battery Regul.
Address 62: Door, Rear Left
Address 67: Voice Control
Address 72: Door, Rear Right
Address 76: Park Assist
Address 77: Telephone
End-------------------------(Elapsed Time: 03:49)--------------------------
