Results 1 to 10 of 10
Thread: MFD Issue
    Mar 2018
    MFD Issue
    I have a 2014 Golf 7 GTD with discover pro and the MFD is starting to irritate me, the issue is that I prefer to have the digital speed in the MFD but if the phone rings the display then goes to phone which is fine but then doesn’t go back to the digital speed after the call has finished and I have to cycle back through the options to bring it back up
    My previous A3 8v didn’t do this and I’m wondering if it’s a feature of the car, a coding issue or maybe a software issue
    No faults showing in the instrument cluster
    Any advice appreciated
    ^^^ Does the failure to go-back to digital speed only happen for mobile phone case?
    I understand your reticence to include autoscan (because "no faults showing in the instrument cluster"- I assume), but posting a copy does tell those considering your problem what equipment is installed in the vehicle and how the modules are coded. Might help to illicit responses - maybe?
  3. Likes PetrolDave liked this post
    Exactly, the Auto-Scan doesn't just show faults it also shows the hardware and software versions of modules fitted which can be a VERY important clue to any problems being experienced.
    So no Auto-Scan often means no help is possible...
  5. Likes Uwe liked this post
  6. #4
    Mar 2018
    Apologies for the delay - here is the auto scan
    Now I have an 02 sensor code - funnily enough after the car was recalled to have another one changed grrr
    what ive noticed is that the issue only happens when accepting the call using the steering wheel button which is odd but still irritating, the other bit of background to this is that the dealer had the car back in April to fix the issue I had with the radio having no DAB and they updated the software and applied a patch from the factory to get the DAB working, as I'd just got the car I cant see if the issue existed prior to having the radio fixed.
    Any advice appreciated before I ring the dealer as although I have a licensed version of ODIS as well as VCDS but I dont have SVM access to update all of the modules on the car,
    Friday,19,July,2019,15:23:39:17347
    VCDS Version: 19.6.1.0 (x64)
    VIN: WVWZZZAUZFW153245   License Plate: XXXXEJO
    Mileage: 125791km-78162mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 2B 42 44 47 52 55 5F
              A9
    VIN: WVWZZZAUZFW153245   Mileage: 125791km-78162miles
    Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 EQ    HW: 04L 907 309 A
       Component: R4 2,0L EDC   H22 7540
       Revision: 81H22---
       Coding: 011D0012036505083000
       ASAM Dataset: EV_ECM20TDI01104L906021EQ 002008
       ROD: EV_ECM20TDI01104L906021ER.rod
       VCID: 78F8497EC390888FA1-802C
    18111 - Oxygen (Lambda) Sensor B1 S1
              P2237 00 [096] - Pump Current Open Circuit
                        Mileage: 122366 km
                        Date: 2019.04.30
                        Time: 09:44:24
                        Engine speed: 3394.50 /min
                        Normed load value: 99.6 %
                        Vehicle speed: 79 km/h
                        Coolant temperature: 90 °C
                        Intake air temperature: 115 °C
                        Voltage terminal 30: 13.760 V
                        Unlearning counter according OBD: 27
                        Oxyg.sens.bank 1 before oxi cat: sign. qual. pump curr.regul.: 14
                        Oxyg.sensor bank 1 before oxi cat: signal quality temp regulat.: 6
                        O2 sen. bank 1 upstrm oxi cat: elec. correct. pump current: 0.0000000 A
                        Oxygen sensor bank 1 before oxi cat: heater activation: 90.128 %
                        O2 sen. bank 1 upstrm oxi cat: elec. corrected Urie sen. value: 0.4829 V
                        Oxygen sensor bank 1 before oxi cat: adjustable resistor: 74.1 Ohm
                        Oxyg.sensor bank 1 before oxi cat: curr.pump curr.adaptation: 1.0000
       Part No SW: 0D9 300 041 Q    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4504
       Revision: 05853104    Serial number: TFK01410060431
       ROD: EV_TCMDQ250021.rod
       VCID: 2644570659A4CE7FC3-8072
       Part No SW: 5Q0 907 379 M    HW: 5Q0 907 379 H
       Component: ESC           H31 0571
       Revision: 00000000    Serial number: 62874000000185
       Coding: 01FA8AA13425096F0379060441C82980512C90C0608294F5F8625078C209
       VCID: 4684F786F9E42E7FE3-8012
       Revision: 00021000    Serial number: 0349298287
       Coding: 030C0C
       VCID: 3A7C9376BD1C5A9F97-806E
       Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
       Component: Climatronic   H03 0907
       Revision: 00001K08
       Coding: 00120114202400011005000200101000
       VCID: 73E27E52DAF6EBD794-8026
       Component: BCM MQBAB H   H18 0137
       Serial number: 01011428902739
       Coding: 03111B66C20122FB0B244080B10C07281800000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 0008219E9B40C04F99-8054
       Component: WWS    141010  042 0551
       Serial number:         141013164524
       Component: RLHS  037 0059
       Serial number: S4Y14M10D23H15M38S35
       Coding: 00A8EE
       Serial number: 000000000ZY1426125LA
       Serial number: 00000000000060660992
       Sun Roof:
       Component: J245 PS73.404  H02 0003
       Serial number: 0000FST00007HRF00000
       Coding: 181901
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39331428209346
       Coding: 0071051011
       VCID: 3D76986AAC326DA7B2-8068
       Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
       Component: ACC Bosch MQB H05 0304
       Serial number: 16101403272545
       Coding: 001C1300FE0739
       VCID: 3878897E8310488F61-806C
       Component: AirbagVW20    014 0386
       Serial number: 003MLR09LPHG
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 7F0AA262E6BEBFB7E0-802A
       Belt Pretensioner left:
       Component: BeltPretRevFL  H35 0341
       Serial number: 34169661C06101440307
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H35 0341
       Serial number: 34169662C02101470074
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 001 810 14
       Serial number: 357670000008B420311F
       Subsystem 4 - Part No SW: -----------    HW: 480 001 810 14
       Serial number: 3586700000085781311K
       Subsystem 5 - Part No SW: -----------    HW: 480 400 910 14
       Serial number: 3516502A1175A9258251
       Subsystem 6 - Part No SW: -----------    HW: 480 400 910 14
       Serial number: 3526502C5175A9055231
       Subsystem 7 - Part No SW: -----------    HW: 480 401 610 14
       Serial number: 3556502AB18166B231EE
    Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
       Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 16101404220629
       Coding: 0C10
       ROD: EV_SMLSKLOMQB_010_VW37.rod
       VCID: 7BF25672F2A6A397CC-802E
    No ASAM data for: "EV_SMLSKLOMQB" (VW37)
       Part No SW: 5G1 920 957     HW: 5G1 920 957
       Component: KOMBI         301 4270
       Coding: 27AD01182F80260001886A011400000000000000
       VCID: 6DD6682ABCD23D2742-8038
       Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1188
       Revision: --------    Serial number: 0002605074
       Coding: 030100040B087300EF00027E1C0F00010001050000000000000000000000
       ASAM Dataset: EV_GatewLear 011016
       ROD: EV_GatewLear_011.rod
       VCID: 428CEB96D5CC125FCF-8016
       Component: E221__MFL-DC1  H10 0038
       Serial number: 29140002220950014414
       Coding: 2DFFFF
       Serial number: 4522884703
    Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
       Part No SW: 5G0 857 511 D    HW: 5G0 857 511 D
       Component: FLA           H05 0002
       Revision: AA001001
       Coding: 02028867727261565623393E01
       VCID: 2B52A6324246F3171C-807E
       Revision: 00000000    Serial number: 14000285865004
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3460BD4E9F78ACEF4D-8060
       Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
       Serial number: 26091402090200
       Coding: 003F1220D001048100001000
       Coding: 8103
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 3566804A9402B5E77A-8060
    Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
       Part No SW: 5G0 035 456     HW: 5G0 035 456
       Component: MIB_lite_amp  H40 0060
       Serial number: VWZ8Z1EC401SPW0
       Coding: 120000008AAA8A0000
       ASAM Dataset: EV_AMPMst12C1ALPI 001005
       ROD: EV_AMPMst12C1ALPI.rod
       VCID: 63C20E126A167B57E4-8036
       Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
       Serial number: 06101401101769
       Coding: 003F1020DE01048100801000
       VCID: 418EE49AD0CA0947D6-8014
       Coding: 029E01000B010200
       VCID: 4088E19EDBC0004FD9-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
       Part No SW: 5G0 035 020 D    HW: 5G0 035 020 D
       Component: MU-H-ND-EU    H43 0407
       Serial number: A310J0EB006645
       Coding: 027300010000000011111202000800031F0202F60100010057
       ASAM Dataset: EV_MUHig4CHBAS 001040
       ROD: EV_MUHig4CHBAS_VW37.rod
       VCID: 1A3C73F61DDC7A9F77-804E
       Component: ABT_High  H61 0030
       Serial number: VWZ8Z9PS100WKE
       Subsystem 2 - Part No SW: V03 959 806 ET    HW: -----------
       Component: ECE 2019  --- 0175
       Component: Gracenote  --- 1010
    1556 - Internal Control Module Memory Check Sum Error
              B2000 87 [009] - Missing message
                        Reset counter: 71
                        Mileage: 125791 km
                        Date: 2019.07.19
                        Time: 15:17:06
                        Voltage terminal 30: 12.4 V
                        Software module: status-SW_Status_Consistency: 00 20 00
                        Software module: status-SW_Status_DevName: Dab
       Serial number: 140909200868
       VCID: 6BD2663282C633175C-803E
    End-------------------------(Elapsed Time: 04:53)--------------------------
    There are some adaptation channels in that cluster, all under IDE13607. They are labelled "Lock display contents" and there are individual ones for various things that can be locked. I don't know exactly what these do though. One of them is:
    IDE13607-MAS16700 -- Lock display contents - Lock MFA displays
    If you're brave, you could try playing with that/those.
    GXCars: In addition to Uwe's suggestion, I wonder if the SVM DTC could be implicated? Given your comment, I suspect that you may not be aware of the non-ODIS method for dealing with SVM errors.
    The trick to clearing SVM errors is to apply the setting in the channel IDE02502-Confirmation of installation change to a simple exclusive-or calculation using the decryption key hex- C9D2 as the second variable. There are lots of ways of doing this calculation (I like doing the calc manually - because I'm strange), but using an online application is probably easiest
    Try this:
    1. Copy the setting from the hex 5F module, channel IDE02502-Confirmation of installation change (this is a 4 x digit hex number)
    2. go to the on-line Exclusive-OR calculator:https://xor.pw/# (it may take some time to load - websites that use TSL handshaking are always slow in my experience)
    3. change both I input: and II Input: to Hexadecimal (base 16)
    4. Enter the hex number from the adaptation channel into I Input:
    5. Enter the decryption key C9D2 into II Input:
    6. Press Calculate
    7. Copy the hex number in III Output: hexadecimal (base 16)
    8. Go back to the hex5F module- Enter the SA and go to Adaptation
    9. Enter the copied "Output" number into IDE02502-Confirmation of installation change
    10. Press the magic Doit!! button
    11. Clear the hex 5F DTC
    What am I missing here? I see no SVM DTC.
  10. #8
    hmm...... now I'm worried about my sanity - again!!!
                        Reset counter: 71
                        Mileage: 125791 km
                        Date: 2019.07.19
                        Time: 15:17:06
  11. #9
    B201A -- "Check Software Version Management " is normally the fault that the procedure you posted will fix.
  12. Likes DV52 liked this post
  13. #10
    Mar 2018
    Thanks for everyone’s help so far, I’ve tried those channels Uwe suggested but it just says not available, unless I need some security access to change them?
    I also tried turning off the phone display in the cluster and that seemed to kill the steering wheel phone button as it just says phone not available in the cluster.
    I’m wondering if the cluster software is not fully compatible with the MIB unit which Citygate Volkswagen updated as the cluster is the key holder to the whole component protection system and acts as a gateway between the steering wheel and MIB
    When the car had the radio fixed I asked the technician if he also updated the cluster as a friend of mine had all sorts of issues with his A3 8v which were resolved by a reflash of the cluster. He said it wasn’t necessary but they did the bare minimum.
    I’m wondering at this point if to take the car back to the dealer and ask them to reflash every out of date module in the car, if I had a Geko account that’s where I would start as I believe ODIS can create a test plan and go through and update the modules.
    If anyone has any ideas let me know
    Thanks in advance
    Ian
