Results 1 to 4 of 4
Thread: Audi 09 B8 All kinds of issues all at once out of no where
    Apr 2017
    So I drive my B8 2009 Audi Avant 2.0T to work the other day and I get just about every light on the dash on and my radio is cutting in and out plus my HVAC is doing the same thing. No turn signals but the car is driving ok with normal power. I thought my car just got possessed by a demon or something. ABS, Traction control, Steering, EPC were all on. Engine light already on have a race cat and need to do APR Stage 2 yet. Anyway I keep going to work because halfway there and I turn off the MMI. This stops the radio issue and HVAC issue of going on and off. It was like a short or something. It did rain that last night. So right before I get to work I turn on MMI again and it is fine HVAC is fine ABS light goes off and turn signals work again. SO I made it to work. Going home all drove well but Traction control, Steering, and EPC light remain. Below is my scan of what was on there and it is long. I cleared and rescaned. I have not driven it really been driving my other Audi. So what I get from this is my steering module but there could be other things brewing in this mess so if any one might know what to fix first I would be glad to know. A little overwhelming and if it is not the steering module would be great since they are around 400 new.
    Thanks for your help!
    Tuesday,09,July,2019,09:20:03:01898
    VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4411.4
    VIN: WAUXF78K49A064039   License Plate: JMW6290
    Mileage: 249560km-155069mi   Repair Order: 5
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 02 03 05 07 08 09 0E 0F 10 14 15 16 17 19 1B 1E 36 37 3C
              42 46 47 52 53 55 56 62 65 67 6C 6D 72 77
    VIN: WAUXF78K49A064039   Mileage: 249560km-155069miles
    05-Acc/Start Auth. -- Status: Malfunction 1010
    08-Auto HVAC -- Status: Malfunction 1010
    09-Cent. Elect. -- Status: Sporadic communication error 1000
    0E-Media Player 1 -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Cannot be reached 1100
    1B-Active Steering -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: Malfunction 1010
    42-Door Elect, Driver -- Status: Malfunction 1010
    46-Central Conv. -- Status: Malfunction 1010
    52-Door Elect, Pass. -- Status: Malfunction 1010
    62-Door, Rear Left -- Status: Sporadic communication error 1000
    65-Tire Pressure -- Status: Malfunction 1010
    67-Voice Control -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: Malfunction 1010
    6D-Trunk Elect. -- Status: Malfunction 1010
    72-Door, Rear Right -- Status: Sporadic communication error 1000
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H12 0001
       Revision: E1H12---
       Coding: 010C010A190F0160
       Shop #: WSC 06449 444 84029
       ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
       ROD: EV_ECM20TFS0118K2907115AL.rod
       VCID: 79BA3080F8DE388C60-802C
    10 Faults Found:
              U1113 00 [047] - -
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:56
                        Engine speed: 1873.00 /min
                        Normed load value: 40.0 %
                        Vehicle speed: 92 km/h
                        Coolant temperature: 79 °C
                        Intake air temperature: 24 °C
                        Voltage terminal 30: 13.617 V
              U1113 00 [047] - -
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:56
    7135 - Body Control Module (Central Electric)
              U0140 00 [168] - No Communications
                        Fault Frequency: 50
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:52
                        Engine speed: 1694.00 /min
                        Normed load value: 27.5 %
                        Vehicle speed: 83 km/h
                        Coolant temperature: 78 °C
                        Voltage terminal 30: 13.640 V
    5558 - Body Control Module (Central Electric 2)
              U0141 00 [040] - No Communications
                        Fault Frequency: 17
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:56
    5615 - Door Control Module - Driver's Door
              U0199 00 [040] - No Communications
                        Fault Frequency: 90
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:51
                        Engine speed: 1736.00 /min
                        Normed load value: 33.3 %
                        Vehicle speed: 80 km/h
                        Coolant temperature: 77 °C
                        Voltage terminal 30: 13.735 V
    7150 - Please Check DTC Memory of Steering Wheel Electronics
              P1698 00 [040] - -
                        Fault Frequency: 63
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:56:02
                        Engine speed: 1594.00 /min
                        Normed load value: 4.3 %
                        Vehicle speed: 78 km/h
                        Coolant temperature: 81 °C
                        Intake air temperature: 23 °C
                        Voltage terminal 30: 13.782 V
    4708 - No Communications with HVAC Control Module (J301)
              U0164 00 [040] - -
                        Fault Frequency: 154
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:51
                        Engine speed: 1723.00 /min
                        Normed load value: 32.9 %
    4720 - Body Control Module (Central Electric 2)
                        Fault Frequency: 95
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:50
                        Engine speed: 1675.00 /min
                        Normed load value: 30.6 %
                        Vehicle speed: 79 km/h
    4025 - Oxygen (Lambda) Sensor B1 S2
              P0140 00 [104] - No Activity
                        Fault Frequency: 80
                        Mileage: 246933 km
                        Date: 2019.04.08
                        Time: 23:26:11
                        Engine speed: 3099.50 /min
                        Normed load value: 27.8 %
                        Vehicle speed: 122 km/h
                        Coolant temperature: 94 °C
                        Voltage terminal 30: 13.923 V
    4201 - Fuel Level too Low
              P1250 00 [096] - -
    Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
       Part No SW: 8K0 927 158 C    HW: 0B6 927 156
       Component: 0B6 20TFSIUSA H04 0020
       Revision: --H04---
       Coding: 001002
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_TCMAL651 A01004
       ROD: EV_TCMAL651.rod
       VCID: 3620FBBC894017F4CD-8062
    2505 - Torque Management Feedback Signal A
              P2637 00 [040] - -
                        Fault Frequency: 38
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:56:26
                        Engine speed: 1927.00 /min
                        Transmission input speed: 1885 /min
                        Transmission output speed: 1649 /min
                        Engine torque: 60 Nm
                        Transmission fluid temperature: 34 °C
                        Accelerator position: 10.0 %
                        Clutch status: 1
    4774 - Body Control Module (Central Electric 2)
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:51
                        Engine speed: 1673.00 /min
                        Transmission input speed: 1652 /min
                        Transmission output speed: 2391 /min
                        Engine torque: 112 Nm
                        Transmission fluid temperature: 32 °C
                        Accelerator position: 16.4 %
                        Clutch status: 2
       Part No SW: 8K0 907 379 AD    HW: 8K0 907 379 AD
       Component: ESP8 quattro  H04 0060
       Coding: 152500
       VCID: 7BB62A88FAE20A9C72-802E
    10 Faults Found:
                        Fault Status: 00101101
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:51
                        Hex Value: 0x4F00
                        Hex Value: 0x4006
                        Hex Value: 0x1216
                        Hex Value: 0x02AE
                        Hex Value: 0x00FF
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:56
                        Hex Value: 0x5C00
                        Hex Value: 0x4006
                        Hex Value: 0x1226
                        Hex Value: 0x7AAD
                        Hex Value: 0x00FF
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:56
                        Hex Value: 0x5C00
                        Hex Value: 0x4006
                        Hex Value: 0x1245
                        Hex Value: 0x62AD
                        Hex Value: 0x00FF
    03110 - Active Steering Control Module (J792)
                        Fault Status: 01101101
                        Reset counter: 227
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:57
                        Hex Value: 0x5C00
                        Hex Value: 0x4206
                        Hex Value: 0x120C
                        Hex Value: 0x16AB
                        Hex Value: 0x00FF
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:56:02
                        Hex Value: 0x5000
                        Hex Value: 0x4206
                        Hex Value: 0x120A
                        Hex Value: 0x46AE
                        Hex Value: 0x00FF
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:56:30
                        Hex Value: 0x3E40
                        Hex Value: 0x6206
                        Hex Value: 0x121A
                        Hex Value: 0x33AE
                        Hex Value: 0x00FF
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:56
                        Hex Value: 0x5C00
                        Hex Value: 0x4006
                        Hex Value: 0x1226
                        Hex Value: 0x7AAD
                        Hex Value: 0x00FF
                        Reset counter: 10
                        Mileage: 249513 km
                        Date: 2019.06.07
                        Time: 09:59:42
                        Hex Value: 0x0600
                        Hex Value: 0x4202
                        Hex Value: 0x0226
                        Hex Value: 0x23A3
                        Hex Value: 0x00FF
                        Fault Frequency: 7
                        Reset counter: 10
                        Mileage: 249513 km
                        Date: 2019.06.07
                        Time: 09:59:43
                        Hex Value: 0x0900
                        Hex Value: 0x6202
                        Hex Value: 0x021A
                        Hex Value: 0x1BA3
                        Hex Value: 0x00FF
    01794 - Control Module - Incorrect Chassis (VIN) Number
                000 -  -  - Intermittent - MIL ON
                        Fault Status: 10100000
                        Reset counter: 10
                        Mileage: 249513 km
                        Date: 2019.06.07
                        Time: 09:59:45
                        Hex Value: 0x0D00
                        Hex Value: 0x4202
                        Hex Value: 0x123C
                        Hex Value: 0x13A3
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 AH    HW: 8K0 907 064 AH
       Component: BCM2 1.1      H71 0134
       Coding: 0D0200
       VCID: 76A03BBCC1C057F40D-8022
       Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
       Component: ELVAUDIB8  H35 0039
       Serial number: 0208000025573003
    6 Faults Found:
                        Reset counter: 167
                        Mileage: 246915 km
                        Date: 2019.04.05
                        Time: 11:26:38
    03286 - Sensor for Contact with Door Handle; Front Right
                        Fault Status: 00101011
                        Reset counter: 4
                        Mileage: 246915 km
                        Date: 2019.04.05
                        Time: 15:33:30
    03285 - Sensor for Contact with Door Handle; Front Left
                        Fault Status: 00100111
                        Reset counter: 235
                        Mileage: 246920 km
                        Date: 2019.04.08
                        Time: 09:40:13
                        Reset counter: 4
                        Mileage: 248551 km
                        Date: 2019.05.19
                        Time: 10:15:45
    00956 - Key 2
                        Reset counter: 5
                        Mileage: 248964 km
                        Date: 2019.05.27
                        Time: 10:02:11
                        Fault Frequency: 63
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:56
    Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
       Part No SW: 8T0 035 729 M    HW: 4E0 035 729 A
       Component: Interfacebox    H43 4610
       Revision: 00000000    Serial number: 340EO087506824
       Coding: 0001003
       VCID: 43C692680292B25C7A-8016
       Subsystem 1 - Part No: 8T0 919 609 D
       Component: E0380 BedienteilH08 0100
       Subsystem 2 - Serial number: 00000000104612
       Subsystem 3 - Serial number: 0124.06.080000000100010680˙
       Subsystem 4 - Serial number: 010680˙
                        Fault Frequency: 7
                        Reset counter: 11
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:58
                        Fault Frequency: 7
                        Reset counter: 11
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:58
                        Reset counter: 166
                        Mileage: 246915 km
                        Date: 2019.04.05
                        Time: 09:36:13
                        Bin. Bits: 00111110 10000010
                        Bin. Bits: 00000100 10000001
                        Bin. Bits: 00000000 00000000
       Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
       Component: KLIMA 3 ZONEN H06 0140
       Revision: C1000000    Serial number: 0127.06.081044
       Coding: 64002000
       VCID: 72A807ACADA84BD421-8026
                        Reset counter: 11
    00898 - Control Circuit A/C compressor
                        Reset counter: 40
                        Current: 0.000 A
                        Current: 0.510 A
                        Voltage: 13.70 V
                        Reset counter: 11
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Component: BCM1 1.0      H22 0253
       Revision: 05022001    Serial number: 00000000069120
       Coding: 26001091063CAF311F00080300003D0D0F9CC64800010161000000
       VCID: 302CCDA4632439C497-8064
       Subsystem 1 - Part No SW: 8K1 955 119     HW: 8T1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 260608  H06 0060
       Serial number: SWFBIE 0000143
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10171098
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
       Serial number: 00000000000507081035
       Subsystem 4 - Part No SW: 8K0 907 410 A    HW: 8K0 907 410 A
       Component: UGDO HL US  H04 0060
       Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
       Component: MP3-Changer     H42 0390
       Revision: 00042002    Serial number: AUZ5ZBH8483029
       VCID: 2A18DFCC85F8431459-807E
    02261 - Data Medium
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 183
                        Mileage: 247667 km
                        Date: 2019.04.19
                        Time: 13:34:03
                        Text: 00000000
                        Fault Frequency: 7
                        Reset counter: 11
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:56:18
    Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
       Part No SW: 4E0 910 593 M    HW: 4E0 035 593 F
       Component: SDAR SIRIUS     H07 0160
       Revision: 00000000    Serial number: AUZ4Z7H0355295
       Coding: 0000100
       VCID: 312AC8A0A82E30CC98-8064
                        Reset counter: 173
                        Mileage: 247010 km
                        Date: 2019.04.10
                        Time: 07:32:37
    Address 10: Park/Steer Assist
    Address 14: Susp. Elect. (J250)       Labels: None
       Part No SW: 8K0 907 364     HW: 8K0 907 364
       Component: DAEMPFUNGS-SG H08 0052
       Revision: 00000000    Serial number: 04060800280003
       Coding: 050181
       Shop #: WSC 06449 444 54051
       VCID: 70AC0DA4A3A479C4D7-8024
                        Fault Frequency: 15
                        Reset counter: 11
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:51
                        Bin. Bits: 00000000 00000010
                        Fault Frequency: 33
                        Reset counter: 11
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:56:01
                        Bin. Bits: 00000000 00000001
    03155 - Functionality limited due to Initialization
                        Fault Frequency: 23
                        Reset counter: 11
                        Mileage: 249511 km
                        Date: 2019.06.07
                        Time: 09:57:00
                        Bin. Bits: 00000001 00000000
       Part No SW: 8K0 959 655 C    HW: 8K0 959 655 C
       Component: AirbagVW-AU10 H26 0410
       Serial number: 0039GD126BEW
       Coding: 303836354230303030304A55304C384B3053
       VCID: 3D32E490AC76C4AC0C-8068
       Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
       Component: BF-Gewichtss.  H01 0030
       Serial number: 5810000R0800000J90
       Serial number: 6334MSME32070B130
       Serial number: 6344MSME32063205
       Serial number: 6352QSME6A563253H
       Serial number: 6362QSME722E470FT
       Serial number: 63732SME770B1C6BB
       Serial number: 63832SME6B72310B+
    12670208 - Body Control Module (Central Electric)
              U0140 00 [008] - No Communications
                        Reset counter: 11
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:52
       Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
       Component: Lenks.Modul   H12 0013
       Revision: --------    Serial number: 90315HEV0000M
       Coding: 000017
       VCID: 3E30E39CA970DFB415-806A
    6 Faults Found:
                        Fault Frequency: 14
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:49
                        Fault Frequency: 50
                        Reset counter: 40
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:49
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:49
                        Fault Frequency: 44
                        Reset counter: 10
                        Fault Status: 00100101
                        Reset counter: 10
                        (no units): 44.0
                        Text: 2C8FFFFFFFFF00C0FF
                        Ign. Timing: 323.9°
                        Raw, Index/Key Err.: 255 255 000
                        Text: 1E82FFFF2920FE1700
                        Current: 25.400 A
                        Charge: 8414 Ah
                        Duty Cycle: 0.0 %
                        Fault Status: 00101110
                        Reset counter: 40
       Part No SW: 8K0 920 980 A    HW: 8K0 920 980 A
       Component: KOMBIINSTR.   H15 0221
       Revision: 00200000    Serial number: 7BW34FM58
       Coding: 8B1611003300D705020000
    7 Faults Found:
                        Fault Frequency: 46
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:52
                        Fault Frequency: 18
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:56
                        Fault Frequency: 27
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:56
                        Reset counter: 10
                        Mileage: 249513 km
                        Date: 2019.06.07
                        Time: 09:59:31
                        Reset counter: 10
                        Mileage: 249513 km
                        Date: 2019.06.07
                        Time: 09:59:31
    00471 - Control Module for Elect. Regulated Dampers (J250)
                        Reset counter: 10
                        Mileage: 249513 km
                        Date: 2019.06.07
                        Time: 09:59:31
                        Reset counter: 10
                        Mileage: 249513 km
                        Date: 2019.06.07
                        Time: 09:59:32
       Part No SW: 8T0 907 468 L    HW: 8T0 907 468 L
       Component: GW-BEM 5CAN-M H10 0092
       Revision: FB402044    Serial number: 4400F0851981FE
       Coding: 000303
       VCID: 4AD8BF4CE5B86314B9-801E
       Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
       Component: J367-BDM  H04 0150
       Serial number: 18029CAF140608
    17 Faults Found:
    01327 - Control Module for Parking Aid (J446)
                        Reset counter: 166
                        Mileage: 246915 km
                        Date: 2019.04.05
                        Time: 09:24:13
    02256 - Quiescent Current
                        Fault Status: 00100001
                        Reset counter: 230
                        Mileage: 248110 km
                        Date: 2019.05.10
                        Time: 15:57:00
                        Fault Frequency: 60
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:51
                        Fault Frequency: 105
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:51
    01964 - Control Module for Seat & Steering Column Memory (J136)
                        Fault Frequency: 84
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:51
                        Fault Frequency: 92
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:51
                        Fault Frequency: 156
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:51
                        Fault Frequency: 92
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:51
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:51
    00456 - Control Module for Access and Start Control (J518)
                        Fault Frequency: 55
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:52
                        Fault Frequency: 46
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:52
    00317 - Rear Lid Control Module (J605)
                        Fault Frequency: 91
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:52
                        Reset counter: 10
                        Mileage: 249530 km
                        Date: 2019.06.07
                        Time: 10:12:25
                        Fault Frequency: 78
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:54
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:54
                        Fault Frequency: 27
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:55
                        Fault Frequency: 160
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:53
       Part No SW: 8K0 907 144 B    HW: 8K0 907 144 B
       Component: DYNAMIKLENK.  H05 0490
       Revision: 50000003    Serial number: --------------
       Coding: 0C0000
       Shop #: WSC 06334 000 00000
       VCID: 2E10D3DC79102F3485-807A
                        Fault Frequency: 68
                        Reset counter: 11
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:56
                        Count: 41
                        Count: 1
                        Hex Value: 0x0287
                        Hex Value: 0x8808
                        Hex Value: 0x0500
                        Hex Value: 0x9404
                        Fault Frequency: 65
                        Reset counter: 11
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:57
                        Count: 47
                        Count: 52
                        Hex Value: 0x0284
                        Hex Value: 0x850B
                        Hex Value: 0x3100
                        Hex Value: 0xFFFF
                        Fault Frequency: 63
                        Reset counter: 11
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:56:02
                        Count: 40
                        Count: 1
                        Hex Value: 0x05D4
                        Hex Value: 0x05D0
                        Hex Value: 0x1399
                        Hex Value: 0x8800
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:56:02
                        Count: 56
                        Count: 1
                        Hex Value: 0x0088
                        Hex Value: 0x8912
                        Hex Value: 0x0100
                        Hex Value: 0xFFFF
                        Reset counter: 11
                        Mileage: 249513 km
                        Date: 2019.06.07
                        Time: 09:59:42
                        Count: 81
                        Count: 1
                        Hex Value: 0x027E
                        Hex Value: 0x801A
                        Hex Value: 0xFFFF
                        Hex Value: 0xFFFF
    Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
       Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
       Component: SG ext.Player H15 0850
       Revision: 00000000
       Coding: 020000
       VCID: 2B16DAC84A025A1CA2-807E
       Part No SW: 8K0 959 760     HW: 8K0 959 760
       Component: MEM-FS        H05 0043
       Revision: AA000000    Serial number: 00001001101844
       Coding: 00581B00000000000000
       VCID: 77BE36B8C6CA2EFC16-8022
                        Fault Frequency: 157
                        Reset counter: 11
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:49
                        Reset counter: 11
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:56:34
       Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
       Component: MNS US          H51 1100
       Revision: 00000000    Serial number: 341FI087509120
       Shop #: WSC 06342 000 00000
       VCID: 383CF5844B54E184DF-806C
       Part No SW: 8K0 907 566 B    HW: 4L0 907 566 B
       Component: J0769_SWA_MasterH01 0040
       Revision: 00H01000    Serial number: 6PZ 009 014-13
       VCID: 3620FBBC414017F4CD-8062
       Subsystem 1 - Part No: 8K0 907 568 B
       Component: J0770_SWA_Slave_H01 0040
       Subsystem 2 - Serial number: 6PZ 009 014-33
       Subsystem 3 - Serial number: 5F09.07.0800H010003CD10270˙
       Subsystem 4 - Serial number: D10270˙
    01024 - Rain Sensor (G213)
                        Fault Frequency: 51
                        Reset counter: 11
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:52
                        Fault Frequency: 30
                        Reset counter: 11
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:52
                        Fault Frequency: 28
                        Reset counter: 11
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:56:08
       Part No SW: 8K0 959 793 B    HW: 8K0 959 793
       Component: TSG FA        H10 0170
       Revision:             Serial number: 0000007395592
       Coding: 011C13204E00410001
       VCID: 3FCE9E98AE7AD6BC1E-806A
                        Fault Frequency: 145
                        Reset counter: 11
                        Fault Frequency: 115
                        Reset counter: 11
                        Fault Frequency: 66
                        Reset counter: 11
                        Fault Frequency: 74
                        Reset counter: 11
                        Fault Frequency: 13
                        Reset counter: 11
       Revision: 00002001    Serial number: 0112218012
       Coding: 0126023A207A741500B002
       Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
       Component: GTO BF  H06 0040
       Serial number: 00000000000000037994
       Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J245 PS127  H06 0037
       Subsystem 4 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J394 PS221  H06 0037
    11 Faults Found:
    02771 - Bulb for Left Brake / Turn Signal / Tail Lamp (M69)
                012 - Electrical Fault in Circuit - MIL ON
                        Fault Status: 11101100
                        Reset counter: 166
                        Mileage: 246915 km
                        Date: 2019.04.05
                        Time: 09:27:10
    02772 - Bulb for Right Brake / Turn Signal / Tail Lamp (M70)
                        Reset counter: 189
                        Mileage: 246915 km
                        Date: 2019.04.05
                        Time: 09:27:12
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 167
                        Mileage: 246915 km
                        Date: 2019.04.05
                        Time: 09:42:14
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 198
                        Mileage: 246915 km
                        Date: 2019.04.05
                        Time: 11:13:45
                        Reset counter: 10
                        Mileage: 249520 km
                        Date: 2019.06.07
                        Time: 10:06:07
                        Fault Frequency: 59
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:56
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:56
                        Fault Frequency: 11
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:56:34
                        Reset counter: 10
                        Mileage: 249511 km
                        Date: 2019.06.07
                        Time: 09:57:18
                        Reset counter: 10
                        Mileage: 249511 km
                        Date: 2019.06.07
                        Time: 09:57:18
                        Reset counter: 10
                        Mileage: 249523 km
                        Date: 2019.06.07
                        Time: 10:07:54
       Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
       Component: DSP Prem      H14 0400
       Revision: 00H14003    Serial number: 34814005010101
       Coding: 030101
       Shop #: WSC 12336 024 394758
    00003 - Control Module
                014 - Defective
                        Date: 2064.00.00
                        Time: 00:03:32
                        Voltage: 13.70 V
                        Temperature: 28.0°C
                        Temperature: 28.0°C
                        Bin. Bits: 00000100
                        Bin. Bits: 00000100
                        Bin. Bits: 00000000
                        Reset counter: 11
                        Mileage: 249515 km
                        Date: 2019.06.07
                        Time: 10:01:32
                        Voltage: 13.90 V
                        Temperature: 32.0°C
                        Temperature: 33.0°C
                        Bin. Bits: 00000100
       Part No SW: 8K0 959 792 B    HW: 8K0 959 792
       Component: TSG BF        H10 0170
       Revision:             Serial number: 0000007399202
                        Reset counter: 249
                        Mileage: 246915 km
                        Date: 2019.04.05
                        Time: 09:42:14
                        Fault Frequency: 134
                        Reset counter: 11
                        Fault Frequency: 159
                        Reset counter: 11
                        Fault Frequency: 21
                        Reset counter: 11
                        Fault Frequency: 26
                        Reset counter: 11
       Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
       Component: EPB Audi B8   H05 0060
       Revision: 00000003    Serial number: 10000000054830
       VCID: 312AC8A0682E30CC98-8064
                        Fault Frequency: 107
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:56:03
                        Voltage: 13.90 V
                        Count: 58
                        Speed: 76.0 km/h
                        Hex Value: 0x0270
                        Hex Value: 0x0004
                        Hex Value: 0x0101
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:51
                        Voltage: 13.90 V
                        Count: 86
                        Speed: 80.0 km/h
                        Hex Value: 0x0270
                        Hex Value: 0x0004
                        Hex Value: 0x0101
                        Fault Frequency: 53
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:51
                        Voltage: 13.90 V
                        Count: 68
                        Speed: 78.0 km/h
                        Hex Value: 0x0260
                        Hex Value: 0x0004
                        Hex Value: 0x0101
       Part No: 8K0 907 357 B
       Component: Dynamische LWR  H01 0030
       Coding: 0000005
       VCID: 3424C1B4573C05E4F3-8060
                        Reset counter: 11
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:54
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 N
       Revision: 00000000    Serial number: 357EQ087505243
       Part No SW: 8K0 959 795     HW: 8K0 959 795
       Component: TSG HL        H06 0170
       Revision:             Serial number: 0000007388581
       Coding: 010C13204000210001
       VCID: 7F4EDE98EEFA16BC5E-802A
    Address 65: Tire Pressure (J502)       Labels:. 8K0-907-273.clb
       Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
       Component: J502-RDK      H03 0250
       Revision: 00001001    Serial number: 12926780826357
       Coding: 0CD154
                        Reset counter: 12
                            Not Recogn.
                        Bin. Bits: 00001000 00100101
                        Voltage: 14.00 V
                        Text:   -50°C;n.erkannt;     n.erkannt
       Component: SDS 3501 US     H46 0630
       Revision: 00000000    Serial number: 00000806240066
                        Fault Status: 00110100
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:57
                        Fault Status: 00110000
                        Reset counter: 10
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:57
       Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
       Component: J772__Rearview      0070
       Revision: --H12---    Serial number: 525PA8-J889143
       Coding: 1000006
       Shop #: WSC 02145 785 00200
       VCID: 373EF6B8464AEEFCD6-8062
                        Reset counter: 11
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:49
                            Reverse OFF
                        Count: 3
       Part No SW: 8K9 827 851     HW: 8K9 827 851
       Component: J605  Master  H24 0220
       Revision: --------    Serial number: 8K9827851
       Subsystem 1 - Part No SW: 8K9 827 852     HW: 8K9 827 852
       Component: J756  Slave  H24 0220
       Serial number: 8K9827852
    16347 - Control Module - EEPROM Error
                014 - Defective
                        Reset counter: 166
                        Mileage: 246915 km
                        Date: 2019.04.05
                        Time: 09:25:59
                        Fault Frequency: 38
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:49
                        Fault Frequency: 28
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:49
                        Mileage: 249510 km
                        Date: 2019.06.07
                        Time: 09:55:49
                        Fault Frequency: 162
       Part No SW: 8K0 959 794     HW: 8K0 959 795
       Component: TSG HR        H06 0170
       Revision:             Serial number: 0000007350547
       VCID: 7EB0239CE9F01FB455-802A
       Part No SW: 4F0 910 336 G    HW: 4E0 862 335
       Component: Handyvorb2      H20 1120
       Revision: 00000000    Serial number: 00000005046533
       Coding: 0010900
       VCID: 271E26F896EA7E7C46-8072
    End----------(Elapsed Time: 02:37, VBatt start/end: 12.1V/12.1V)-----------
    After clearing codes I get this.
    Thursday,11,July,2019,01:20:46:01898
    VIN:    License Plate: REDAUDI
                    Address 01: Engine       Labels: 06H-907-115-CAB.clb
    Control Module Part Number: 8K2 907 115 AL    HW: 8K2 907 115 D
      Component and/or Version: 2.0l R4/4V TF H12 0001
               Software Coding: 010C010A190F0160
                Work Shop Code: WSC 06449 444 84029
                  ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001 (AU48)
                          VCID: 79BA3080F8DE3887DE-802C
    6 Faults Found:
              U1113 00 [039] - -
                        Mileage: 249561 km
                        Date: 2019.06.10
                        Time: 00:32:43
                        Coolant temperature: 25 °C
                        Intake air temperature: 25 °C
                        Voltage terminal 30: 12.015 V
              U1113 00 [039] - -
                        Mileage: 249561 km
                        Date: 2019.06.10
                        Time: 00:32:43
              U0140 00 [038] - No Communications
                        Mileage: 249561 km
                        Date: 2019.06.10
                        Time: 01:08:13
                        Voltage terminal 30: 11.921 V
              U0199 00 [038] - No Communications
                        Mileage: 249561 km
                        Date: 2019.06.10
                        Time: 01:08:12
              U0164 00 [038] - -
                        Mileage: 249561 km
                        Date: 2019.06.10
                        Time: 01:08:11
              U0141 00 [038] - No Communications
                        Mileage: 249561 km
                        Date: 2019.06.10
                        Time: 01:08:11
    Readiness: 1110 0101
                    Address 16: Steering wheel       Labels: 8K0-953-568.clb
    Control Module Part Number: 8K0 953 568 G    HW: 8K0 953 568 G
      Component and/or Version: Lenks.Modul   H12 0013
               Software Coding: 000017
                Work Shop Code: WSC 06335 000 00000
                          VCID: 3E30E39CA970DFBFAB-806A
                        Reset counter: 11
                        Mileage: 249561 km
                        Date: 2019.06.10
                        Time: 01:08:10
                        Reset counter: 11
                        Mileage: 249561 km
                        Date: 2019.06.10
                        Time: 01:08:10
                        Reset counter: 11
                        Mileage: 249561 km
                        Date: 2019.06.10
                        Time: 01:08:10
                        Reset counter: 11
    My money is on some kind of power problem, perhaps a power supply relay being wonky. But I don't see enough of a pattern to be able to narrow it down much. If it were mine, I would start by investigating why module 10-Park/Steer Assist is off-line completely.
    Apr 2017
    Ok I will look into this tomorrow. I am very green with the VCDS but will give it a go!
    New User
    Aug 2019
    NJ, USA
  5. Likes Uwe liked this post
