Hi, I am looking for some advice on a vehicle which should have AFS headlamps installed however they have been replaced with non-AFS units after accident damage. The instrument panel currently displays "Audi Adaptive lights Malfunction", I would like to code out the AFS thus removing the error. I would be grateful if anyone could advise me on how to do this correctly, I have attached an Autoscan of the vehicle, please bear in mind that this is a facelift B8.5 and thus doesn't have the separate headlamp range control module (55) and it is instead part of the Central Electrics Control Module (09) which has an extremely long long coding...
Thanks In Advance
Mark
Thursday,11,July,2019,20:53:42:21133
VCDS Version: 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
Dealer/Shop Name: Jon-Son Motors
Workshop Code: 210 01642 000002
VIN: WUAZZZ8K6DA900167 License Plate: RS4
Mileage: 52080km-32361mi Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 1B 22 30 42 44 46 47 52 53
56 5F 62 72
VIN: WUAZZZ8K6DA900167 Mileage: 52080km-32361miles
Address 01: Engine (------CFSA) Labels:. 079-907-560-CFS.clb
Part No SW: 8T2 907 560 HW: 8T1 907 560
Component: 4.2l V8HDZ / H04 0003
Revision: NAH04---
Coding: 1225003225A6080A2000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM42FSI0118T2907560 001006
ROD: EV_ECM42FSI0118T2907560.rod
VCID: 79BA3E4DF88BDF87DE-802C
4366 - ROD - Unknown Error Code
- 00 [032]
Mileage: 52087 km
Date: 2019.07.09
Time: 17:02:22
Engine speed: 1631.50 /min
Normed load value: 63.9 %
Coolant temperature: 29 °C
Intake air temperature: 27 °C
Voltage terminal 30: 13.075 V
CAN status - engine control module-Bits 0-7: 00000000
CAN status - transmission control module-Bits 0-7: 00000000
CAN status - brake control module 1-Bits 0-7: 00000000
CAN status - brake control module 2-Bits 0-7: 00000000
selected gear-Bits 0-7: 00000010
Cruise control switch actuation-Bits 0-7: 00000000
5523 - Engine Start Blocked by Immobilizer
P1570 00 [040] - -
Mileage: 51985 km
Date: 2019.06.27
Time: 22:27:38
Engine speed: 1935.50 /min
Normed load value: 29.8 %
Coolant temperature: 45 °C
Intake air temperature: 37 °C
Voltage terminal 30: 11.449 V
AFS dm: 34.3 kg/h
Median injection timing: 0.581 ms
Engine operating condition-Channel 87: Idling
Relative load value: 13.36 %
Tumg: 18.8 °C
Psr w: 306.41 hPa
Engine torque: 30.3 Nm
Readiness: 0010 0000
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8K5 927 156 HW: 0B5 927 156 J
Component: 0B5 42 FSIRdW H01 0003
Revision: --H01---
Coding: 000001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001010
ROD: EV_TCMDL501021.rod
VCID: 76A03571C995B0FFB3-8022
17598 - Selector Lever Sensor
P179E 00 [032] - Electrical Malfunction
Reset counter: 34
Mileage: 52056 km
Date: 2019.06.29
Time: 22:31:09
Engine speed: 4820 /min
Transmission input speed: 4820 /min
Transmission output speed: 939 /min
Engine torque: -92 Nm
Transmission fluid temperature: 93 °C
Accelerator position: 0.0 %
Clutch status: Kupplung 2 kann Moment übertragen
Unlearning counter according OBD: 34
Part No SW: 8T0 907 379 F HW: 8T0 907 379 F
Component: ESP8 quattro H09 0100
Coding: 346D6A
VCID: 45C282BDCCF36B67EA-8010
02214 - Tire Pressure Warning
Reset counter: 92
Mileage: 52050 km
Date: 2019.06.29
Time: 22:22:01
Hex Value: 0x1A00
Hex Value: 0x4006
Hex Value: 0x1223
Hex Value: 0x18B3
Hex Value: 0x0000
01771 - Control Module for Headlight Range (J431)
Reset counter: 98
Mileage: 52087 km
Date: 2019.07.09
Time: 16:16:19
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x0021
Hex Value: 0x4093
Hex Value: 0x0000
Part No SW: 8K0 907 064 GE HW: 8K0 907 064 FE
Component: BCM2 2.0 H11 0621
Coding: 01924000000000000000
VCID: 79BA3E4DF08BDF87DE-802C
Subsystem 1 - Part No SW: 8K0 959 754 CD HW: 8K0 959 754 CD
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0512000079101009
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2312000126463013
Part No SW: 8K2 820 043 T HW: 8K2 820 043 T
Revision: D1000000 Serial number: 01050720120314
Coding: 4804000000
VCID: 3A38E141B50D149F97-806E
Reset counter: 94
Mileage: 51945 km
Date: 2019.06.26
Time: 11:17:20
Temperature: 24.0°C
Temperature: 100.0°C
Absolute Pres.: 1.2 bar
RPM: 640 /min
Current: 0.000 A
Temperature: 27.0°C
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000444855201
Coding: 260000108034AFC00081400300001D0D0F1D438827090201000008004400030200000034000000
Shop #: WSC 01642 210 00002
VCID: 7AB82141F58DD49FD7-802E
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110712 H06 0080
Serial number: SWF12070115447
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 20409522
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AQ HW: 8K0 941 531 AQ
Component: E1 - LDS H03 0031
Serial number: 00000000002506120085
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: F2688936000000000001
03977 - Local Data Bus 5
Reset counter: 58
Mileage: 52087 km
Date: 2019.07.11
Time: 20:30:51
02658 - Power Output Stage for Left Headlight (J667); Incorrectly Coded
Reset counter: 58
Mileage: 52087 km
Date: 2019.07.11
Time: 20:50:14
02659 - Power Output Stage for Right Headlight (J668); Incorrectly Coded
Reset counter: 58
Mileage: 52087 km
Date: 2019.07.11
Time: 20:50:14
02233 - Left Headlight Power Output Stage (J667)
Reset counter: 58
Mileage: 52087 km
Date: 2019.07.11
Time: 20:50:17
Reset counter: 58
Mileage: 52087 km
Date: 2019.07.11
Time: 20:50:17
Address 14: Susp. Elect. Labels: None
Part No SW: 8T0 907 376 HW: 8T0 907 376 A
Component: J250 DRC FahrwerH01 0020
Revision: 00000000 Serial number: 00875000259800
Coding: 0000000
Shop #: WSC 05912 003 1048576
VCID: 7CB427593FB9EAAFC5-8028
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Serial number: 003KFD949GNQ
Coding: 30544435363030303030554A3052384B3053
Shop #: WSC 57638 001 1048576
VCID: 48DC8B89F3E1760F11-801C
Serial number: 6334MSME423C6C3CR
Serial number: 6344MSME71436B006
Serial number: 6352QSME1D1B3668Q
Serial number: 6362QSME001A3972A
Serial number: 63732SME5F5F1C7CS
Serial number: 63832SME5D5F1E5CR
Mileage: 51945 km
Date: 2019.06.26
Time: 11:17:24
9438491 - Igniter for Driver head airbag
B1005 1B [137] - Resistance Too High
Mileage: 51945 km
Date: 2019.06.26
Time: 11:17:24
9438235 - Igniter for Front passenger's Head Curtain Airbag
B1004 1B [137] - Resistance Too High
Mileage: 51945 km
Date: 2019.06.26
Time: 11:17:24
Part No SW: 8R0 953 568 S HW: 8R0 953 568 S
Component: Lenks.Modul H07 0171
Revision: 00000000 Serial number: 20120716000406
Coding: 000037
VCID: 51EAA6ED08BBB7C746-8004
Component: E221 - MFL H03 0003
Part No SW: 8K0 920 982 J HW: 8K0 920 982 J
Component: KOMBIINSTR. H35 0553
Revision: 00000000 Serial number: RBZ394C7D
Coding: 33AF1100B3012600010000
VCID: 3B36E445BA372D978C-806E
Part No SW: 8R0 907 468 H HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0051
Revision: 1Y050025 Serial number: 2541Y127020419
Coding: 80E3031600
VCID: 44C49FB9C7C9526FFD-8010
Serial number: 5532867701
Reset counter: 98
Mileage: 52087 km
Date: 2019.07.11
Time: 19:10:46
Bin. Bits: 10111
Voltage: 11.60 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 J HW: 8K0 907 144 J
Component: DYNAMIKLENK. H06 0690
Revision: 52001005 Serial number: --------------
Coding: 030000
VCID: 3620F5718115F0FF73-8062
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H13 0100
Serial number: 000107120001000
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
VCID: 2F2EC015764FC13730-807A
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 B HW: 8K0 907 440
Component: STS H04 0020
Revision: S0H04000 Serial number: 00000000063191
Coding: 01010101000000000001000102
VCID: 2D12DA1D7443B32702-8078
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0305
Coding: 011C02205C21410001
VCID: 56E055F12155D0FF93-8002
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0029547542
Coding: 010000010001
Shop #: WSC 06324 000 00000
ROD: EV_RCEPSAU48X_008.rod
VCID: 3424CF799F69E2EF4D-8060
Revision: 00002001 Serial number: 0180054560
Coding: 013B062220B908808030023280000000
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813004601102
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0506
Revision: Serial number: 0000033966898
VCID: 4ED0BD911985A83F5B-801A
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 20000000116374
ROD: EV_ParkiBrake_AU48.rod
VCID: 383CFB498301068F61-806C
Part No SW: 4G0 035 061 E HW: 4G0 035 061
Component: Radio U DAB H60 0099
Revision: AB001007 Serial number: 109G-0C7571641
Coding: 010103010000000001
VCID: 1F0E30D50EEF51B780-804A
Part No SW: 8R2 035 670 C HW: 8R2 035 670 C
Component: H-BNT-EU H44 0524
Revision: -------- Serial number: 208GU0C7501570
Coding: 120101010306A1FF05808B5E00000403040000000000000000
VCID: 3424CF799769E2EF4D-8060
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130G80CS209382
Subsystem 3 - Part No SW: 8T0 919 611 H HW: 8T0 919 611 H
Component: E0380 Bedient H02 0020
Serial number: 00000001206095
Component: CD-Database 3638
Reset counter: 98
Mileage: 52087 km
Date: 2019.07.11
Time: 20:30:20
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 10000000
Part No SW: 8K0 959 795 D HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000034133757
Coding: 010C02204021210001
VCID: 43C69CA5C2C75557C4-8016
00447 - Function Limitation due to Over-Voltage
Reset counter: 91
Mileage: 52030 km
Date: 2019.06.28
Time: 18:48:39
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HR H07 0305
VCID: 59FA5ECD504BFF87BE-800C
End----(Elapsed Time: 01:56, VBatt start/end: 11.5V/11.5V. VIgn 11.6V)-----
Thanks In Advance
Mark
