- Joined
- Dec 5, 2014
- Messages
- 524
- Reaction score
- 260
- Location
- Windsor UK
- VCDS Serial number
- C?ID=334979
As you can see from the scan this has been through the wars.
Lots of faults but my job is to just code the ABS. It may have had a new module but I'm not sure.
Strange thing the coding is set at all Zero's
Can anyone help me with this.
thanks.
thanks.
Thursday,11,July,2019,15:51:27:36704
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4505.4
VIN: WVWZZZAUZGW047602 License Plate: DG65RXF
Mileage: 104232km-64766mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZGW047602 Mileage: 104232km-64766miles
44-Steering Assist -- Status: Cannot be reached 0100
Address 01: Engine (2D2D2-CXXB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 056 CL HW: 04L 907 445 B
Component: R4 1.6l TDI H06 2370
Revision: 22004001
Coding: 0111401243451D092000
ASAM Dataset: EV_ECM16TDI03004L906056CL 002005
ROD: EV_ECM16TDI03004L906056_002_VW37.rod
VCID: 79AF11A11951A4CF8D7-802C
25807 - No Communication with ABS Brake Control Module
U0121 00 [163] - -
[Lost Communication WithAnti-Lock Brake System (ABS) Control Module]
Mileage: 104232 km
Date: 2019.07.10
Time: 00:43:07
Coolant temperature: 24 °C
Intake air temperature: 30 °C
Voltage terminal 30: 12.500 V
Accelerator pedal travel: raw value: 0.00 %
Cruise Control System (CCS): status: ERROR
selected gear: Shifting process active
25809 - Power Steering Control Module
U101D 00 [035] - No Communication
[Power steering control moduleNo communication]
Mileage: 104232 km
Date: 2019.07.10
Time: 00:43:07
14095 - Implausible Data Received from Parking Brake Control Module
U0417 00 [035] - -
Mileage: 104232 km
Date: 2019.07.10
Time: 00:43:06
Camshaft speed (RPM): 0 /min
Camshaft adaptation intake bank 1: phase position: -0.4 °
23902 - Diesel Particle Filter
P2463 00 [163] - Excessive Soot Accumulation
Mileage: 104232 km
Date: 2019.07.10
Time: 00:43:07
Voltage terminal 30: 12.492 V
Counter for regeneration time of diesel particle filter: 4082 s
Particle filter: kilometers since last regeneration: 6553.5
Particle filter: soot mass measured: 0.43 g
Particle filter: soot mass calculated: 59.99 g
Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: -1.8 mbar
Particle filter: field regeneration lock status: 0
Readiness: N/A
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 61755000001691
Shop #: WSC 00078 790 12345
11 Faults Found:
0166 - Steering angle sensor
B1168 31 [137] - No Signal
Reset counter: 14
Date: 2019.07.10
Time: 00:43:05
0195 - Control module not coded
U1013 00 [137] - -
[ECU marked as Not Configured because vehicle ID is invalid]
Reset counter: 14
Date: 2019.07.10
Time: 00:43:05
0212 - Longitudinal Acceleration Sensor
C1017 54 [137] - Missing Calibration / Basic Setting
Reset counter: 14
Date: 2019.07.10
Time: 00:43:05
0270 - Lateral Acceleration Sensor
C1079 54 [137] - Missing Calibration / Basic Setting
Reset counter: 14
Date: 2019.07.10
Time: 00:43:05
0279 - Brake Pressure Sensor 1
C107A 54 [137] - Missing Calibration / Basic Setting
Reset counter: 14
Date: 2019.07.10
Time: 00:43:05
0295 - Steering angle sensor
Reset counter: 14
Date: 2019.07.10
Time: 00:43:05
4161 - Coding invalid
U10DA 00 [008] - -
[mismatch between VIN on CAN and VIN in coding word]
Reset counter: 54
Mileage: 104232 km
Date: 2019.07.10
Time: 00:45:43
8306 - Databus
U1122 00 [137] - Implausible Message
[FCAN: Unplausible VIN number]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:43:10
8308 - Control Module Incorrectly Coded
U1014 00 [009] - -
[FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
Reset counter: 14
Date: 2019.07.10
Time: 00:43:05
8314 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [009] - -
[FCAN: Coding of ESP and TSK does not fit together]
Reset counter: 14
Date: 2019.07.10
Time: 00:43:05
32848 - Control Module for Electric Parking Brake
C10E2 F1 [137] - Switches/Motors Detected
Reset counter: 14
Date: 2019.07.10
Time: 00:43:05
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 T HW: 5G0 907 426 T
Component: AC Manuell H02 1001
Revision: 00001K06
Coding: 00120104202100001000000000000002
VCID: 3C21C8B556E351E7D61-8068
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AQ HW: 5Q0 937 084 AL
Component: BCM MQBAB M H24 0173
Serial number: 01061517302012
Coding: 03000842C241027B0BA44080B10403281000000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 074B67595FA5C23F8B3-8052
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150610 042 0551
Serial number: 150617010331
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S2Y15M06D29H16M55S41
Coding: 90A8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 006 0326
Serial number: 000000000ZY151392L95
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000032653150
555285 - Databus
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:49:35
556053 - Databus
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:49:35
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391517504168
Coding: 0071051001
VCID: 43D3B3492B1D2E1F97B-8016
12658704 - Databus
[Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:43:05
13637426 - Databus
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:43:05
13638913 - Databus
[Steuergerät für Lenkhilfe-J500 - LH_EPS_03 - kein Signal/keine Kommunikation]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:43:05
13638914 - Databus
[Steuergerät für Lenkhilfe-J500 - LWI_01 - kein Signal/keine Kommunikation]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:43:05
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 23051503212853
Coding: 00000300FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
VCID: 3A2DCEAD5CD76FD7C4D-806E
6 Faults Found:
1071 - Databus
[FAULT_CIS_AXV_INVALID]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:43:04
Control Module temperature: 31 °C
Voltage terminal 15: 12.1 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1058 - Databus
[FAULT_CIS_ECD_NOTAVAILABLE]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:43:04
1059 - Databus
[FAULT_CIS_ESP_FAIL]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:43:04
0261 - Databus
[FAULT_CIM_TIMEOUT_EPB_01]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:43:04
0275 - Databus
[FAULT_CIM_TIMEOUT_LWI_01]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:43:04
1043 - Automatic Distance Control
B10E7 F0 [009] - Disconnected
[FAULT_CIS_TSK_IRREV_FAIL]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:43:04
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 015 0388
Serial number: 003MLR0W7V2G
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 7F5BFFB907758AFFB33-802A
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34169677B29061541029
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34169676B29061511418
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 306 15
Serial number: 35767000000FF821351Z
Subsystem 4 - Part No SW: ----------- HW: 480 002 306 15
Serial number: 358670000006CA4DF418
Subsystem 5 - Part No SW: ----------- HW: 480 402 306 15
Serial number: 3516502991A14CC3E04F
Subsystem 6 - Part No SW: ----------- HW: 480 402 306 15
Serial number: 3526502AD1C52F3303FJ
Subsystem 7 - Part No SW: ----------- HW: 480 401 706 15
Serial number: 3556502BB1B5A872D15P
9682162 - Multiple collision brake
B13BC F2 [137] - No function
Mileage: 104232 km
Date: 2019.07.10
Time: 00:49:53
1049093 - Databus
[NWD: 0x101 ESP_02 error value ESP_Querbeschleunigung]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:49:53
1050112 - Databus
[NWD: 0x086 LWI_01 Timeout]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:49:53
1049094 - Databus
[NWD: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:49:53
1049095 - Databus
[NWD: 0x101 ESP_02 error value ESP_Gierrate]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:49:53
Part No SW: 5Q0 953 507 GK HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 24061504400249
Coding: 0C00
ROD: EV_SMLSKLOMQB_010_VW37.rod
VCID: 05576D5165A9D02FF9F-8050
Part No SW: 5G1 920 941 A HW: 5G1 920 941 A
Component: KOMBI 207 7640
Coding: 27A41A002780260001882A011400000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009005
ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
VCID: 270B07D9BF65E23FAB3-8072
16776967 - Databus
[EPB_02 keine Kommunikation]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:43:04
16776973 - Databus
[RKA_01 keine Kommunikation]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:43:04
16776978 - Databus
[LH_EPS_01 keine Kommunikation]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:43:05
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1224
Revision: -------- Serial number: 0003649936
Coding: 030100041F087300FB00005C080F00010001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 75B71D913549C0AFE9F-8020
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0040
Serial number: 29150001335990025264
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 2411587003
131602 - Power Steering Control Module
U101D 00 [009] - No Communication
[Timeout Knoten 0x12 / 44 - Steuergerät für Lenkhilfe]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:47:47
Supply voltage: Terminal 30: 12.3 V
Terminal 15: On
Component: TSG FS 020 0041
Serial number: 040615BF20771A
Coding: 00310220D001048000001000
Serial number: 00000000000001499227
Coding: 1D0000
Address 44: Steering Assist
Component: TSG BFS 020 0041
Serial number: 260615BFQ05425
Coding: 00310020DE01048000801000
VCID: 42DDB64D340727179CD-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000006538310
Coding: 150000
Part No SW: 3Q0 035 820 A HW: 3Q0 035 820 A
Component: MU-S-D-ER 523 0627
Coding: 02730000FF00000051111101008808001F0100C60120010001
ROD: EV_MUStd4CDELP_VW37.rod
Subsystem 1 - Part No SW: 3G0 919 605 HW: 3G0 919 605
Component: ABT_Std-2 H52 1031
Serial number: VWZ8Z9REL005NB
7175 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:47:13
Voltage terminal 30: 12.4 V
BAP-BAP_Function_ID: 02
7206 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 14
Mileage: 104232 km
Date: 2019.07.10
Time: 00:47:13
End----------(Elapsed Time: 01:29, VBatt start/end: 12.5V/12.5V)-----------
