Hello please could someone tell me is this fault which is coming up is anything to worry about as when I clear it it come back on.
Thanks.
Thanks.
Thursday,11,July,2019,15:25:32:05033
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVGZZZ5NZGW812109 License Plate: MD16LYU
Mileage: 25283km-15710mi Repair Order: Getting autohvac fault
Chassis Type: 5N-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 39 42 44 52 55
5F 6C 6D 82 A5 BB BC CA D6 D7
VIN: WVGZZZ5NZGW812109 Mileage: 25283km-15710miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFGA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 EH HW: 04L 907 309 M
Component: R4 2.0l TDI H23 2950
Revision: B4H23---
Coding: 0125003203671D083000
ASAM Dataset: EV_ECM20TDI01104L906026EH 004002
ROD: EV_ECM20TDI01104L906026EF_004.rod
VCID: 74B1DD4B1E3A1537DE1-8020
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0DL 300 011 A HW: 0DE 927 711
Component: GSG DQ500 H12 1406
Revision: 00H12V32
VCID: 2615F703986637A7905-8072
Part No SW: 5Q0 614 517 BH HW: 5Q0 614 517 AD
Component: ESC H25 0507
Revision: 00000000 Serial number: 60956000001281
Coding: 0AEE929A34210B6E4778670062CC4950492CD0E2E646927D38625078C22A02
VCID: 78A9E97B02527157F29-802C
Part No SW: 3Q0 959 435 C HW: 3Q0 959 435 C
Component: VWKESSYMQB 036 0710
Revision: 00036000 Serial number: 0401705353
Coding: 030C0C0F03
ASAM Dataset: EV_KessyHellaMQBAB 004032
VCID: 3A2D33737CDEA347C4D-806E
Subsystem 1 - Part No SW: 3G0 962 243 A HW: 3G0 962 243 A
Component: GEB.F.Heckoef H17 0903
Serial number: 98025967
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 5NC 907 044 HW: 5NC 907 044
Component: AC Automat H34 3902
Revision: 20K07000 Serial number: 00000B00101934
Coding: 00120124202110011105100C0010110A
ASAM Dataset: EV_ACClimaPrehVW37X 002013
ROD: EV_ACClimaPrehVW37X.rod
VCID: 7EA5FF6320764F67B85-802A
Subsystem 1 - Part No SW: 3G0 907 049 E HW: 3G0 907 049 E
Component: E265KlimaHeck H02 0201
Serial number: 00000000000000000000
263425 - Air Quality Sensor
B10AF 04 [009] - Internal System Fault
Reset counter: 193
Mileage: 25272 km
Date: 2019.07.11
Time: 13:29:23
Outside air temperature: 19.5 °C
Voltage terminal 30: 14.3 V
System run time-Engine running time: 253 s
System run time-Terminal 15 on: 253 s
Air quality status: ERROR
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 BQ HW: 5Q0 937 084 BQ
Component: BCM MQBAB H H32 0212
Serial number: 00021611100453
Coding: 03D11E46C24112FB17844094B11C172C1880000000000000000000000000
ASAM Dataset: EV_BCMMQB 016001
ROD: EV_BCMBOSCH_016_VW37.rod
VCID: 084999BB72B201D7829-805C
Subsystem 1 - Part No SW: 5NC 955 119 HW: 5NC 955 119 Labels: 1KX-955-119.CLB
Component: 326 RL 160319 033 0372
Serial number: 00000001603160302585
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y16M04D28H11M25S16
Coding: 00A8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY1608213BL
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000065695698
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 3Q0 919 298 HW: 3Q0 919 298
Component: PLA 3.0 12K H09 0152
Serial number: 002004167478070
Coding: 0331263851
ASAM Dataset: EV_EPHBO2CVW3260000 010015
ROD: EV_EPHBO2CVW3260000.rod
VCID: 7AADF3733C5E634784D-802E
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 H HW: 2Q0 907 572 B
Component: ACCCONTIMQB H01 0155
Coding: 320147C358FF8728749C806D304085
ASAM Dataset: EV_ACCMRRCONTIVW376 001010
ROD: EV_ACCMRRCONTIVW376_001.rod
VCID: 392F2C7F79D8A85FCD7-806C
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0317
Serial number: 003TDR2HR82%
Coding: 98CCC0C00C0000005C5400CF008800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 1079B1DB0AE249175A9-8044
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1032
Serial number: 5NC857705C0113Q01277
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 5NC857706C0112Q00388
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 002 004 16
Serial number: 357000000002F25C9A1S
Subsystem 4 - Part No SW: ----------- HW: 480 002 304 16
Serial number: 358000000008F7BCBA15
Subsystem 5 - Part No SW: ----------- HW: 480 402 004 16
Serial number: 3510001B9209F101055P
Subsystem 6 - Part No SW: ----------- HW: 480 402 004 16
Serial number: 3520001B9209F105344V
Subsystem 7 - Part No SW: ----------- HW: 480 402 004 16
Component: FrontSensor_D 000 6149
Serial number: 3550001C520A94F4232$
Pedestrian Protection Driver:
Subsystem 8 - Part No SW: ----------- HW: 480 402 504 16
Component: PedP_Sensor_D 000 6149
Serial number: 2280001B72080C23B85$
Subsystem 9 - Part No SW: ----------- HW: 480 402 504 16
Component: PedP_Sensor_P 000 6149
Serial number: 2290001BB2080C21D5D6
Pedestrian Protection Center:
Subsystem 10 - Part No SW: ----------- HW: 480 402 504 16
Component: PedP_Sensor_C 000 6149
Serial number: 2300001BB2080C21939V
Subsystem 11 - Part No SW: ----------- HW: 480 001 104 16
Component: PedPSensor_D2 001 0887
Serial number: I0M00000000A80348A1+
Subsystem 12 - Part No SW: ----------- HW: 480 001 104 16
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000633F06A1%
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 3Q0 953 521 AN HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0205
Revision: FF034034 Serial number: 20160413501553
Coding: 0C10
ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
ROD: EV_SMLSVALEOMQBLRH.rod
VCID: 7CA1F56B366A5D77961-8028
Part No SW: 5NA 920 791 HW: 5NA 920 791
Component: KOMBI 119 1443
Coding: 27A50018EF84260001886B031401000000000000
VCID: 55F780CFF5806C3FC9F-8000
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 F
Component: GW MQB High 128 1244
Revision: -------- Serial number: 0004784583
Coding: 030500041F087300FB03225E1E0F00010001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 79AFEC7F3958685F8D7-802C
Subsystem 2 - Part No SW: 5TA 959 442 B HW: 5TA 959 442 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0023
Serial number: 0981609395901168AP2B
Coding: 2F0000
Subsystem 3 - Part No SW: 5QA 915 181 B HW: 5QA 915 181 B
Component: J367-BDMHella H10 9052
Serial number: 8278749903
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00009.03.16
Coding: 0101
VCID: 4ACD63B32C3E33C754D-801E
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH05 0012
VCID: 45D7508F0520DCBFB9F-8010
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000078756014
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BFD45F6128201F357-8024
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Component: TSG FS 020 0041
Serial number: 220316ECJ10115
Coding: 003F1A20D001048000001000
VCID: 43D34E970B14E28F97B-8016
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 128 1072
Coding: 9307
ROD: EV_SteerAssisMQB_013.rod
Component: TSG BFS 020 0041
Serial number: 020416ED130411
Coding: 003F1020DE01048000001000
VCID: 42DD4B93140EEB879CD-8016
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0051
Coding: 08AE00104B210201
ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
VCID: 41DF449F1108F09F857-8014
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 020 C HW: 3G0 035 020
Component: MU-H-ND-EU H50 0343
Serial number: A682D0GB020222
Coding: 02730601FF00000051111101008808001F0100E6012000009F
VCID: 176BCAC72F0C9E2F1B3-8042
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL00Q1Y
Subsystem 2 - Part No SW: V03 959 800 QT HW: -----------
Component: ECE 2018/2019 --- 0169
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1012
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 5Q0 907 556 A HW: 5Q0 907 556
Component: Areaview 2 H11 0422
Serial number: C854706JG015035
Coding: 01230601A20F200000204014
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 005013
ROD: EV_CamSysRVAV2ARCE2MQBAB_005_VW37.rod
VCID: 372B2A474FCCBE2F3B3-8062
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30636838400000
Coding: 0A08
ASAM Dataset: EV_DeckLidCONTIAU736 001012
VCID: 3FDB426767FC866FF33-806A
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 5NA 919 608 A HW: 5NA 919 608 A
Component: HeadupDisplay 015 0207
Coding: 574060
ASAM Dataset: EV_HeadUpDisplContiVW481 001013
ROD: EV_HeadUpDisplContiVW481.rod
VCID: 46D557833826D7A7B05-8012
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 F HW: 3Q0 980 654
Component: MQB_B_MFK H06 0220
Serial number: 19041611P22768
Coding: 000307060000040100022344C050A10094000E200040
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 110316EC90271C
Coding: 002A10200100048000001000
Component: TSG HBFS 020 0041
Serial number: 100316EC90233C
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 D HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Coding: 308040732602
ASAM Dataset: EV_SunRoofCONTIAU736 004008
ROD: EV_SunRoofCONTIAU736_004.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 1675C7C32806A727005-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0003
ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End----------(Elapsed Time: 02:09, VBatt start/end: 12.9V/12.9V)-----------
