Results 1 to 10 of 14
Thread: Looks like Miss Tiggy is going for service again! 2010 Tiguan SEL 2.0L Auto
    Near Philadelphia, PA, USA
    Well Miss Tiggy just had an oil change and full service 3 weeks ago. This week, she is going bonkers and running really rich. Here are the fuel trims:
                    Address 01: Engine  (06J 906 026 DP)
    15:31:29 Group 032: Lambda Control (Mixture Adaptation)
      1.1 %  Adaptation (Idle) Bank 1 Sensor 1
      3.1 %  Adaptation (Partial) Bank 1 Sensor 1
    15:31:29 Group 033: Lambda Control
      -9.4 %  Lambda Control Bank 1 Sensor 1
      0.45 V  Sensor Voltage Bank 1 Sensor 1
    Wednesday,10,July,2019,15:32:09
    VCDS Release 19.6.1 (x64):  Generic OBD2
    Mode 1:Read Data
    06:Short Term Trim - Bank 1     -1.6 %
    07:Long Term Trim - Bank 1     6.3 %
    I suspect based on the fuel trims we have a coolant temp sensor going, or an input air temp sensor, or maybe even a vacuum leak.
    Here is the Autoscan... looks like the fan controller is going or has gone.
    Symptoms: Can barely idol at start in the morning... has to have help with go pedal... Once fully warmed, it will run but it is getting 10-12mpg in town.
    We need to find which sensor has gone up or where the vacuum leak lays...
    Wednesday,10,July,2019,15:31:04:52622
    Chassis Type: AX-VW36 (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 22 25 2E 36 37 42 44 46 47 4F 52
              53 55 56 62 65 6C 72 77
    VIN: WVGBV7AX9AW510081   Mileage: 142300km-88421miles
    Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
       Part No SW: 06J 906 026 DP    HW: 06J 906 026 DA
       Component: MED17.5 TFSI 2,0    8220
       Revision: AAH07---    Serial number:
       Coding: 0423010A190F0160
       Shop #: WSC 39837 001 1048576
       VCID: FBB6B1BABA286E974C-80AE
    006469 - Control Module 1 for Cooling Fan
                   P1945 - 000 - Output Short Circuit - Intermittent
                        Fault Frequency: 14
                        Mileage: 140216 km
                        Date: 2013.10.09
                        Time: 12:32:36
                        RPM: 2757 /min
                        Load: 61.2 %
                        Speed: 119.0 km/h
                        Temperature: 90.0C
                        Temperature: 38.0C
                        Absolute Pres.: 1000.0 mbar
    006481 - Radiator Fan 2 (V177)
                   P1951 - 000 - Movement Restricted / Jammed - Intermittent
                        Fault Frequency: 28
                        Mileage: 140222 km
                        Date: 2013.10.09
                        Time: 12:35:36
                        RPM: 2773 /min
                        Load: 48.2 %
                        Speed: 120.0 km/h
                        Temperature: 92.0C
                        Temperature: 38.0C
    006480 - Radiator Fan (V7)
                   P1950 - 000 - Movement Restricted / Jammed - Intermittent
                        Fault Frequency: 25
                        Mileage: 140255 km
                        Date: 2013.10.09
                        Time: 12:52:26
                        RPM: 2792 /min
                        Load: 27.4 %
                        Speed: 121.0 km/h
                        Temperature: 91.0C
                        Temperature: 43.0C
                        Absolute Pres.: 990.0 mbar
       Part No SW: 09G 927 750 KN    HW: 09G 927 750 KN
       Component: AQ 250 6F           1704
       Revision: 00H76000    Serial number:
       Coding: 0000840
       Shop #: WSC 06485 444 64721
       VCID: 875EDD4AF6E03A7758-80D2
    18253 - Please check DTC Memory of Steering Electronics (J527)
                P1845 - 000 -  - Intermittent
                        Reset counter: 197
                        Mileage: 79105 km
                        Date: 2010.01.08
                        Time: 08:59:51
    Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
       Part No SW: 5N0 614 517 N    HW: 5N0 614 517 N
       Component: J104    C2 450 V2   0008
       Revision: --H13---    Serial number: 00000002168669
       Coding: 0002332
       VCID: B93A6BB2F0949C871E-80EC
       Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
       Component: ClimatronicPQ35 133 1213
       Revision: 00133024    Serial number: 00000000000000
       VCID: ED928FE2F45CF027C2-80B8
       Part No SW: 5K0 937 087 C    HW: 5K0 937 087 C
       Component: BCM PQ35 H+   008 0019
       Revision: BL008001
       Coding: 6D580A3BF8232EC48088008534000D0441555186536D8D605C8000000000
       VCID: B52267821C8C78E7FA-80E0
       Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels:  1KX-955-119.CLB
       Component: Wischer 14080  012 0203
       Serial number: N1955119   203!
       Coding: 009795
       Component: RLS 250809 05  54  0402
       Coding: 07304D
       Part No SW: 5N0 959 655 K    HW: 5N0 959 655 K
       Component: J234__200 VW10 HI   1916
       Revision: 20013000    Serial number: 003E3PF8STTP
       Coding: 0012336
       VCID: C5C217428C6CE8676A-8090
       Subsystem 1 - Part No: 5N0 959 339 A
       Component: BF-Gewichtsens. 001 0004
       Subsystem 2 - Serial number: 00000000004N1T
       Subsystem 3 - Serial number: 0014.07.090000100000660049 63
       Subsystem 4 - Serial number: 660049 6332MTS666071909  63
       Subsystem 5 - Serial number: 71909  6342MTS614721929  63
       Subsystem 6 - Serial number: 21929  6351HTS6IDMNV8KR  63
       Subsystem 7 - Serial number: NV8KR  6361HTS6ODC4V8KR  63
       Subsystem 8 - Serial number: 4V8KR  63727TS6L56526KR  63
       Subsystem 9 - Serial number: 526KR  63827TS6JV0626KJ
       Subsystem 10 - Serial number: 626KJ
       Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
       Component: J0527           056 0111
       Coding: 0001332
       VCID: FAB8B4BEB512579F57-80AE
       Component: E0221           002 0030
    00194 - Ignition Key Removal Lock
       Part No SW: 5N0 920 971 A    HW: 5N0 920 971 A
       Component: KOMBI         H05 0206
       Coding: 210F00
       VCID: B02C5696EBEE5DCFA9-80E4
       Part No: 1K0 907 530 AE
       Component: J533  Gateway   H06 0110
       Revision:   H06 01    Serial number: 100809F2000398
       Coding: FD83FF07504613006002
       VCID: EA9884FEC5B2E71FA7-80BE
       Part No SW: 0AY 907 554 C    HW: 0AY 907 554 C
       Component: Haldex 4Motion      0041
       Coding: 0000005
       VCID: CBD6217AAA081E17BC-809E
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H05 0206
       Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
       Component: SG EXT.PLAYER H13 0090
       Revision: A1001003    Serial number: 7667540744
       VCID: A600B0CED12A037F43-80F2
       Part No SW: 5N0 959 760 A    HW: 5N0 959 760 A
       Component: MEM-FS        H04 0032
       Revision: AA000000    Serial number: 00001001322296
       Coding: 20581300000044440011
       VCID: B83C6EB60B9E858FE1-80EC
       Part No SW: 3C0 035 684 C    HW: 3C0 035 684 A
       Component: RNS-MID       H02 1040
       Revision: AB001001    Serial number: VWZ6Z7J8154076
       Coding: 040500000100008600
       VCID: A306A9DAA218F65724-80F6
                        Reset counter: 211
                        Mileage: 133592 km
    00862 - Antenna for GPS Navigation (R50/R52)
                        Fault Status: 00100111
                        Reset counter: 251
                        Mileage: 141770 km
                        Date: 2013.10.15
                        Time: 14:01:06
       Part No SW: 5N0 959 701 C    HW: 5N0 959 701 C
       Component: Tuer-SG         008 2005
       Coding: 0005567
       VCID: B5226782DC8C78E7FA-80E0
       Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.163 0703
       Revision: 1AH03273    Serial number: 00091830417102
       Coding: 0000258
       VCID: BA3874BEF592979F17-80EE
       Part No SW: 5K0 035 456     HW: 5K0 035 456
       Component: KonzernAmp 8K H06 0340
       Revision: --------    Serial number: BP218198613481
       VCID: E79EFDCA1EA0DA77B8-80B2
       Part No SW: 1K0 907 532     HW: 1K0 907 951
       Component: EZE_2         H06 0110
       Coding: 050B0500
       VCID: E680F0CE11AAC37F83-80B2
       Component: J245EE19SKB12  H01 0220
       Component: J394EE19SKB12  H01 0220
       Part No SW: 5N0 959 702 C    HW: 5N0 959 702 C
       Coding: 0005566
       VCID: B620608EC18A73FFF3-80E2
       Part No SW: 5N0 907 801 E    HW: 5N0 907 801 E
       Component: J540 EPB3  VW-13948 0008
       Revision:   H10       Serial number: 00000000035057
       Coding: 0000057
       VCID: B12A539228E454C7A6-80E4
       Component: AFS-Steuergeraet    0142
       Coding: 1356998
       VCID: B4245A86D7F661EFCD-80E0
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000020
       Coding: 00000020
                        Reset counter: 211
                        Mileage: 133592 km
                        Reset counter: 251
                        Mileage: 141770 km
                        Date: 2013.10.15
                        Time: 14:01:06
       Part No SW: 5N0 959 703 C    HW: 5N0 959 703 C
       Component: Tuer-SG         007 2001
       Coding: 0001168
       Shop #: WSC 01357 011 1012552
       VCID: B73E6D8AC6808AF7E8-80E2
    Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
       Component: RDK           008 0817
       Coding: 018705
       Part No SW: 5N0 907 441     HW: 5N0 907 441
       Component: J772__Rearview      0021
       Revision: 00H05000    Serial number:    PA8 J973108
       Coding: 0100010
       VCID: EC9482E6CF46F92FD5-80B8
       Part No SW: 5N0 959 704 C    HW: 5N0 959 704 C
       Coding: 0001168
       VCID: B83C6EB6CB9E858FE1-80EC
    Address 77: Telephone        Labels: 5P0-862-335.lbl
       Part No SW: 1Z0 035 729 C    HW: 1Z0 035 729 C
       Component: FSE_2P8x        H35 0170
       Revision: 00000000    Serial number: 00000005074112
       Coding: 0011070
    End----------(Elapsed Time: 02:23, VBatt start/end: 13.6V/13.5V)-----------
    This Tiguan with 88,400 on it will be leaving the family soon. It's been maintained at the highest level... never a service missed. If there is interest and you are in the Lansdale area, you know where to find me.
  2. Likes jyoung8607 liked this post
  3. #2
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by Bruce View Post
    Don't hold out on us, what will be replacing it?
    Silence gives consent.
    I'm thinking about a "Taco" as Uwe has named it... a Toyota Tacoma TRD - not sure of the trim level yet. There is a 2017 used one available with everything I would ever want. Gonna try to see it today.
    I am not in favored status at RT with this decision! Oh well!
    If the Amarok were available in the US, I would consider a lease on an Amarok. I did ride in one of those a lot in South Africa. Very nice machine.
    I'm not thrilled with the cost of maintaining a VAG car. in the 10 years I have owned Miss Tiggy, Maintenance of the vehicle has cost over $20k - and most of that coming in the last 6 years... I choose to not turn the wrenches on the cars myself. Tractors, lawn equipment and such - I'll all down on that. But I don't want to be turning wrenches on my daily ride. Lazy? Yep. At 63, I don't really want to be climbing around on and under and frankly, I never had great interest in cars... Can't really say why. Put a farm machine - lawn machine - and I am all about that... go figure... weird is what I am!
    Have loved driving Miss Tiggy. She's been a lot of fun. She's done a lot of service. But I think it is time to try something different and to have it paid for before I hit 67!
  5. Likes jyoung8607, Mike@Gendan, Dana liked this post
  6. #4
    I did not go the Taco route. I went with a Honda Ridgeline. So far I love it.
    On the last service of Miss Tiggy, the problem was not a VAG problem. The Gulf gas station where I buy all of the fuel locally for Miss Tiggy, had an issue where their supplier dumped diesel into the gas tanks. While they had the tanks pumped out on July 4, I bought gas from them on July 8. Miss Tiggy ran terribly.
    Roth Auto Repair, checked everything involved with fueling, then decided it was bad fuel. Called the Gulf station and learned the above. They drained the tank, put fresh gas in, added injector cleaner, and ran her for a bit. She was running fine when I picked her up.
    She has been sold. May the new owner have happy days with her. She is a good machine but she is like many women - high maintenance!
  7. Likes jyoung8607, Mike@Gendan, D-Dub, Dana liked this post
  8. #5
    Jun 2014
    Swansea, UK
    Will Uwe still let you play with the full-size Tonka toys on the mountain if you've bought a non-VAG car though?
    Apparently I should put something witty or profound in here...
  9. Likes Uwe, Bruce liked this post
  10. #6
    I'll keep it parked away from the approved vehicles. I am doing the same at the office. Hopefully that allows some acceptance and tolerance.
  11. Likes Mike@Gendan, Andy liked this post
  12. #7
    ^^^ Bruce: congratulations on the new car.
    Clearly you are of the type that likes to "personalize" their vehicles (there are lots of folk that have this trait - IME (in my experience).
    Personally, I'm not of this ilk - to me it's just a lump of metal with a more interesting control protocol and very easy emotionally to change if I so desire.
    But - without intending any offense, or judgement - I never cease to be amazed at man-kind's tenancy to anthropomorphize every thing that is not a sentient human. Probably a consequence of our capacity to be empathic - which says much about your personality and alas it also speaks volumes about mine!!!
  13. Likes Bruce liked this post
  14. #8
    Don, you are much too hard on yourself...
    As to naming my rides, I do it to make it easy for people to know which ride I am speaking of. Haven't come up with a handle on the truck - or psuedo-truck as some have called the Ridgeline. I find it a truck and I like it's useful ways such as the copious storage space for bringing things to Ross Mountain. It's towing capacity is just like that of T-Reg. It's payload in the bed is pretty good at 1500lbs.. I think it will serve my needs.
    In my career, I used to have to deal with machines on production floors. Whenever I had to go and learn of a problem, I pushed the management people away and asked to sit with the operators. They always talk to their machines as if the machine were sentient. They always assigned names. From that Don, I have come to the conclusion that these things are not just hunks metal hung together under the control of linkages and electrons. Rather, by some means, they get a personality. Most likely that means the human working with them assign a personality but I can tell weird stuff happens with machines that often I have been left wanting an explanation. Scoff as you might, I became a believer in the idea and treat my machines as if they were a person - doing my best to treat them as I would want to be treated.. never abused.. always encouraged to keep on keeping on.
    Here on the mountain, I talk to the big machines.. Yep I am nuts.. certifiable. The Massey Tractor and I have gotten to know each other but have not formed a personal name as yet. The Massimo Buck - He is a buck.. and he likes to buck! The Great Dane mower - that bad boy likes to run.. don't get in front of him cause he is quick and goes like a bat out of hell - whatever that expression really means.
    So yeah, I do personalize machines.. guilty as charged...
  15. Likes jyoung8607, Mike@Gendan, DV52 liked this post
  16. #9
    Uhm, no.
    All T'regs are rated to tow 7700 lbs (3500 kg)
    Ridgeline 2WD: 3500 lbs
    Ridgeline 4WD: 5000 lbs
  17. #10
    I stand corrected. I went by my memory of what I thought I was told back in the day about your T-Reg when we pulled a trailer to Waterfest. My Ridgeline is 4WD and rated 5000 lbs.
    Just more JapCrap - right Uwe?
