Hi all! I'm a new poster here. So if I posted in the wrong place please forgive me. I need some help with a couple of error codes! Bought the Philips 12794UNIX2 X-tremeUltinon (H8/H11/H16) LED Fog Light twin-pack Kit for my 2007 Audi A3 2.0tfsi Quattro Sportback. They gave me 2 problem codes (L/R Fog light out) and 1 dash lamp out icon. Got in touch with Philips support and was told I needed to buy their 18954C2 Philips LED Headlight CANbus Adapters (Twin Packs) that fits H8 /H11/H16. And run them piggy-back! (Which I thought was strange! Because 12794UNIX2 supposedly has CABbus adapters built inline.) Well… they DIDN’T WORK eaither!!!! I even went in with my VCDS and unchecked the Fog light Cold lamp diagnosis under 09-Cent Electrics -> Coding 07 -> Long Coding Helper -> Byte 18. Worked fine until I turn them on! The codes come back and have to use VCDS to clear the codes all over again. Any clues on how to get these to work right? And one last question... Under 09-Cent Electrics -> Coding 07 -> Long Coding Helper -> Byte 17 -> Bit 3 Does anyone know what Terminal 50 is?
Thursday,11,July,2019,12:39:42:39263
VCDS Version: 19.6.1.0 (x64)
VIN: WAUZZZ8P67A189838 License Plate: FJL770
Mileage: 115520km-71780mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72
VIN: WAUZZZ8P67A189838 Mileage: 115520km-71780miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8P0 907 115 K HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: 5BH16--- Serial number: AUX7Z0G2FNF0KJ
Coding: 01030003180F0160
Shop #: WSC 79155 156 452199
VCID: 3A7B483B75C6C69F97-806E
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0021122
Shop #: WSC 06314 000 00000
VCID: 72EBA01B6D367EDF9F-8026
Part No SW: 8P0 820 043 AD HW: 8P0 820 043 AD
Component: KlimavollautomatH19 0360
Revision: 066987 Serial number: 8P0820043AD
VCID: 6ED3B46B790E5A3F7B-803A
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000006841896
Coding: 0D8E4B019014100000160000160000000009EB175A0600
Shop #: WSC 06314 123 08192
VCID: 408F3AD3131A9C4FD9-8014
Subsystem 1 - Part No: 8P1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 252
Mileage: 115524 km
Date: 2019.07.11
Time: 12:36:00
Voltage: 14.35 V
Reset counter: 252
Mileage: 115524 km
Date: 2019.07.11
Time: 12:36:00
Voltage: 14.30 V
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H13 4260
Revision: 91H13426 Serial number: 003620G4AW4Y
Coding: 0071612
VCID: 428B30DB1D168E5FCF-8016
Subsystem 1 - Serial number: 6332DRB404C3881DW
Subsystem 2 - Serial number: 6342DRB404C4931FW
Subsystem 3 - Serial number: 63528RB40226B0EBQ
Subsystem 4 - Serial number: 63628RB40228FCED4
Subsystem 5 - Serial number: 63729RB4023E39E1T
Subsystem 6 - Serial number: 63829RB4023E3987U
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0000042
VCID: 41893FD718109547D6-8014
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 931 B HW: 8P0 920 931 B
Component: KOMBIINSTR. VDO H20 0570
Revision: D0H20004 Serial number: 2242G004012619
Coding: 0005118
Shop #: WSC 53858 001 1048576
VCID: 326B601BADB63EDF5F-8066
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 330010730901DD
Coding: FD3F034007002102
VCID: 2F6D696FBE84133730-807A
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
VCID: 36635C0B41DE22FF73-8062
Revision: D0H20004 Serial number: AUX7Z0G2FNF0KJ
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0000248
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.079 H07 1806
VCID: 3467660357A230EF4D-8060
Part No: 8P0 959 433 F
Component: KSG H08 0070
Coding: 9880202002586D250F0FC80FCE77
Shop #: WSC 06314 123 12345
VCID: 3F8D392F6EE4E3B7A0-806A
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000248
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Coding: 0000012
VCID: 3D71432764E8F1A7B2-8068
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 G HW: 8P0 035 186 G
Component: R Concert2+ H16 0221
Revision: 00H16000 Serial number: AUZ1Z3G9098069
Coding: 0030001
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 D
Component: Tuer-SG 020 0070
Coding: 0000216
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 D
Coding: 0000216
End-------------------------(Elapsed Time: 02:08)--------------------------
Address 09,8P0 907 279 F,recoded (Long Coding),from,0D8E4B019014100000160000160000000009EB175A0600,to,0D8E4F019014100000160000160000000009EB175A0600,(06314/123/08192),
Address 09: DTCs cleared
