Hi
2006 Passat PASSAT (3C5) 44 - Steering Assist
vin nr :WVWZZZ3CZ6E160421
has problems with controller -44
it will not accept code 40168
[44 - Steering Assist]
[Coding-II - 11] or if that function is not available then use [Sec.Access - 16] instead
Enter 40168, to enable the basic setting.
is there any other coder?
in Basic Settings
I am not allowed to make any changes
and is it DSR on this car, Have EPS
in Basic Settings
Tuesday,09,July,2019,13:26:38:52538
VCDS Version: 19.6.0.6 (x64) HEX-NET CB: 0.4505.4
Dealer/Shop Name: ole
VIN: WVWZZZ3CZ6E160421 License Plate: HZ25363
Mileage: 371740km-230988mi Repair Order: steering 44 falut
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 53 56 62 69 72
VIN: WVWZZZ3CZ6E160421 Mileage: 371740km-230988miles
Address 01: Engine Labels: 03G-906-018-BKP.clb
Part No SW: 03G 906 018 CD HW: 03G 906 018 CD
Component: R4 2.0l PPD1.5 G 9627
Revision: --H05--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00440 218 82820
VCID: 699A4CED40B4D80722-803C
Readiness: N/A
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0658555437
Coding: 0029986
Shop #: WSC 05311 000 00000
VCID: 302CE189A3EE69CF25-8064
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AC HW: 3C0 907 044 AC
Component: ClimatronicPQ46 050 0404
Revision: 00050005 Serial number: 00000000000000
VCID: 62885BC1BD828B5FE3-8036
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 H HW: 3C0 937 049 H
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000002231124
Coding: 088A8F0700041A00000A00000F000000000959435C0000
VCID: 2E10FFF1B9DA7F3F37-807A
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 05311
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 J HW: 3C0 909 605 J
Component: 04 AIRBAG VW8 029 2521
Revision: 09029000 Serial number: 003A2PS58735
Coding: 0012340
VCID: 2D12F8FDB4DC04270E-8078
Subsystem 1 - Serial number: 6332MSME0D445825
Subsystem 2 - Serial number: 6342MSME0D680964
Subsystem 3 - Serial number: 6351HTS61IKE1783
Subsystem 4 - Serial number: 6361HTS61IKQEO83
Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
Component: J0527 0015
Revision: 00005000 Serial number: 3C9953507P
Coding: 0000114
Component: E0221 007 0050
Part No SW: 3C0 920 860 H HW: 3C0 920 860 H
Revision: X0014000 Serial number: 00000000000000
Coding: 0005105
Shop #: WSC 00011 888 96745
VCID: 271E0AD596202E77F4-8072
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 1K0 815 071 P
Component: Zuheizer 031 1312
Revision: A Serial number: 09010046
Coding: 0000011
VCID: 3228EB81ADE25BDF53-8066
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C05C1507E8
Coding: 3DFD8C04CA2002
Shop #: WSC 05311 123 12345
VCID: 210A14CDF804D047BA-8074
Part No SW: 3C0 959 433 K HW: 3C0 959 433 K
Component: IMMO 038 0367
Revision: 00038000 Serial number: VWZCZ000000000
Shop #: WSC 00520 218 86920
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2365
Coding: 0000181
VCID: 3620D791418A47FF7F-8062
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.1 D06 1701
VCID: 3326EE8552F852D758-8066
02546 - Steering Limit Stop
Mileage: 1720 km
Temperature: 15.0∞C
Voltage: 12.70 V
Voltage: 12.50 V
00573 - Steering Torque Sensor (G269)
Component: KSG PQ46 ELV 038 0455
Coding: 0091020851030E763804941570084F0B603C80
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000180
VCID: 373EDA954680BEF764-8062
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000012
Part No: 1K0 035 186 P
Component: Radio GR0 015 0019
Revision: 0001503S Serial number: VWZ2Z2E3229743
Coding: 0040400
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 3C9 959 703
Component: Tuer-SG 021 2505
Coding: 0000144
VCID: 70AC2189636E29CF65-8024
Address 69: Trailer Labels: 1K0-907-383-V1.clb
Part No SW: 1K0 907 383 HW: 1K0 907 383
Component: ANHAENGERELEKTR 001 0020
Shop #: WSC 05314 000 00000
VCID: 6A9833E145B2D31F2B-803E
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 3C9 959 704
Coding: 0000144
VCID: 71AA248D686420C76A-8024
End----------(Elapsed Time: 01:09, VBatt start/end: 14.4V/14.4V)-----------
