Results 1 to 5 of 5
Thread: Audi Q7 2012. 3.0 TDi 245hk
    Jul 2019
    Norway
    Hello!
    Wondering if you could help me with these codes?
    Also preheat (Glow plug light) is flashing.
    Do you have any idea?
    Saturday,06,July,2019,13:34:44:04159
    VCDS Version: Releasen 19.6.1 (x64) Running on Windows 10 x64
                    Address 02: Auto Trans       Labels: 0C8-927-750.clb
    Control Module Part Number: 0C8 927 750 AL    HW: 0C8 927 750 AL
      Component and/or Version: AL1000 AISIN  001 1977
               Software Coding: 001578
                Work Shop Code: WSC 31414 790 00001
                  ASAM Dataset: EV_TCMAL991031 001001 (AU56)
                           ROD: EV_TCMAL991031_001_AU56.rod
                          VCID: 76B51AAC18463E47E05-8022
    12782 - Transmission Range Sensor (F125)
              P0706 00 [032] - Implausible Signal
                        Reset counter: 32
                        Engine speed: 690.0 /min
                        Transmission input speed: 630 /min
                        Engine torque: -12 Nm
                        Transmission fluid temperature: 58 C
                        Accelerator position: 0.0 %
                        Clutch_C1: Open
                        Clutch_C2: Open
                        Clutch_C3: Open
                        Clutch_C4: Open
                        Clutch_B1: Open
                        Clutch_B2: Open
                        Lock Up Clutch: Open
                        EOP failure status 2: Normalcy
                        EOP target revolution: 0 /min
                        EOP actual revolution: 65279 /min
                        Engine Speed signal Current: 65279 /min
                        EOP failure status with EOP without HV 1: Motor normal stop
                        EOP target current: 65278 mA
    12753 - Valve for Transmission Fluid Cooler
              P2755 00 [237] - Short to Plus
                        Reset counter: 43
                        Engine speed: 1800.0 /min
                        Transmission input speed: 1800 /min
                        Transmission output speed: 1470 /min
                        Engine torque: 120 Nm
                        Transmission fluid temperature: 34 C
                        Accelerator position: 22.8 %
                        Clutch_C1: Close
                        Clutch_C2: Close
                        Clutch_C3: Open
                        Clutch_C4: Open
                        Clutch_B1: Open
                        Clutch_B2: Open
                        Lock Up Clutch: Close
    Have you checked wiring diagrams to see what the Transmission Range Sensor (F125) and the Valve for Transmission Fluid Cooler have in common?
    Jul 2019
    Norway
    Do you know where I can find wiring diagrams for my car?
    Nebrot
    Jul 2019
    Norway
    Coolant leak from solenoid valve through the electrical wires. The car wouldn’t start at the end. Tried to clean, and dry it but only more alarms. Sendt it to Audi. Wonder how much this gonna cost me???
