Unknown19
New Member
I'm a newb and in need of some guidance/help.
2013 VW CC Rline 6spd.
Ran Evap and SAI to set readiness, closed out vcds and now when i start the car and release the parking brake to drive I have the ABS, Traction Control and Airbag lights all on. Did a scan and below is what I got. Multiple malfunctions.
Monday,08,July,2019,18:30:28:12016
VCDS Version: 19.6.0.6 (x64)
VIN: WVWAP7AN6DE558088 License Plate:
Chassis Type: AN-VW46 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 55 56 62
65 72
VIN: WVWAP7AN6DE558088 Mileage: 59920km-37232miles
65-Tire Pressure -- Status: Not registered 0011
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 06J 906 027 FD HW: 06J 907 309 B
Component: MED17.5.2 TFSI 2 06 3951
Revision: PAH04--- Serial number: VWZCZ000000000
Coding: 0404010818070160
Shop #: WSC 05314 000 00000
VCID: 72E12EF26D81D1DF93-8026
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 000 -
Mileage: 1118481 km
Date: 2004.04.08
Time: 17:04:34
RPM: 1995 /min
Load: 22.7 %
Speed: 17.0 km/h
Temperature: 99.0°C
Temperature: 46.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.843 V
000319 - Oxygen (Lambda) Sensor B1 S2
P013F - 000 - Response too Slow Lean to Rich
Date: 2020.13.09
Time: 21:14:38
RPM: 1666 /min
Load: 7.1 %
Speed: 83.0 km/h
Temperature: 98.0°C
Temperature: 47.0°C
Voltage: 13.716 V
Readiness: 0010 0000
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AP HW: 3AA 614 109 AP
Component: J104 C2 450M V401 0030
Revision: --H07--- Serial number: 00000006697677
Coding: 0000396
Shop #: WSC 05311 000 00000
VCID: 7BFF03D63ACB9097C0-802E
Part No SW: 3AA 907 044 AN HW: 3AA 907 044 AN
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0010001048
Shop #: WSC 00015 115 00000
VCID: 7CFD00CAF7C597AFC9-8028
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 J HW: 3AA 937 087 J
Component: BCM PQ47 H++ 421 0465
Revision: BD421001
Coding: 0008000000000000008802819400094C2055000840200D20E484402400C0
VCID: 4183B13ED8A73A47DA-8014
Subsystem 1 - Part No SW: 3C8 955 119 F HW: 3C8 955 119 F Labels: 1KX-955-119.CLB
Component: WWS464 030113 010 0604
Serial number: 030113
Coding: 00B795
Component: RLFS 024 0042
Serial number: Y13M02D12H21M26S56S1
Coding: 0228DD
Part No SW: 5N0 959 655 T HW: 5N0 959 655 T
Component: J234__713 VW10 HI 2118
Revision: 25018000 Serial number: 003LDPQGGU2N
Coding: 0012595
VCID: 4E999A02D9F9D53F57-801A
Subsystem 1 - Part No: 3C8 959 339 A
Component: BF-Gewichtsens. 003 0001
Subsystem 2 - Serial number: 0000000000D9XQ
Subsystem 3 - Serial number: 0017.01.130000300000650081ÿ†63
Subsystem 4 - Serial number: 650081ÿ†6332MTS640240193 ÿ†63
Subsystem 5 - Serial number: 40193 ÿ†6342MTS636570213 ÿ†63
Subsystem 6 - Serial number: 70213 ÿ†6351HTS6KF9POBKR ÿ†63
Subsystem 7 - Serial number: POBKR ÿ†6361HTS6L9RRPBKJ ÿ†63
Subsystem 8 - Serial number: RPBKJ ÿ†63727TS6RO7FPBKJ ÿ†63
Subsystem 9 - Serial number: FPBKJ ÿ†63827TS62AS9PBKR ÿ
Subsystem 10 - Serial number: 9PBKR ÿ
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C5 953 501 BN HW: 5K0 953 569 AB
Revision: FF010041 Serial number: 20130206201881
Coding: 018A270000
VCID: 72E12EF2A581D1DF93-8026
Component: E221__MFL-TK6 H07 0022
Coding: E20000
Part No SW: 3C8 920 971 B HW: 3C8 920 971 B
Component: KOMBI H05 0705
Coding: 240F00
Shop #: WSC 05314 115 00000
VCID: 2C5DF08A4725C72F19-8078
Part No SW: 7N0 907 530 AJ HW: 7N0 907 530 AJ
Component: J533 Gateway H51 1634
Revision: H51 Serial number: 310113F2000377
Coding: 469006
VCID: 78F51CDACBFDBB8FAD-802C
Mileage: 33805 km
Date: 2016.07.15
Time: 12:14:34
Part No SW: 3AA 959 433 C HW: 3AA 959 433 C
Component: IMMO 042 0404
Revision: 00042000 Serial number: VWZCZ000000000
VCID: 3973D9DE7077628792-806C
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664272727
Coding: 020100
VCID: 2A51F69245D1D91FEB-807E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 D HW: 1K0 035 274 D
Component: RNS315-NAR H58 0319
Serial number: VWZAZ2N0089903
Coding: 0400040104000F000001100A
ASAM Dataset: EV_RNS315NARV2UDS 001705
ROD: EV_RNS315NARV2UDS_VW46.rod
VCID: 254B05AE24CFF667C6-8070
Subsystem 1 - Part No: 3AA 919 866 B
Component: NAR_V3_(0037) 0037
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0555
Revision: 12110009 Serial number: 0006481942
Coding: 0004B7
Shop #: WSC 05311 115 00000
VCID: 6DDB3D8EBCBF0E274E-8038
Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 703 D HW: 3C8 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0501
Serial number: 00000003347905
Coding: 010490
Part No SW: 5N1 909 144 P HW: 5N1 909 148 J
Component: J500__APA-BS KL.302 1202
Revision: 1BH04737 Serial number: 00130360118301
Coding: 0000258
VCID: 3F87B7C66E534CB7AC-806A
01316 - ABS Control Module
Fault Status: 00101101
Reset counter: 41
Mileage: 59901 km
Date: 2013.11.28
Time: 05:44:16
Term 15 On
RPM: 2032 /min
Speed: 17.0 km/h
(no units): 7.0
Voltage: 13.80 V
Component: KSG PQ47 ELV 042 0638
Coding: 1B910F8001862E521204141FF08A0F0E107C00
Part No SW: 7N0 907 532 HW: 7N0 907 530 AJ
Component: EZE_2 H51 1634
Coding: 00000008
VCID: 6FE72786BEB3FC377C-803A
Subsystem 1 - Part No SW: 3C8 919 204 A HW: 3C8 919 204 A
Component: Analoguhr 005 0004
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0555
Revision: 14110009 Serial number: 0006475714
Coding: 0004B6
VCID: 6ED93A82B1B9F53F77-803A
Slave Passenger:
Subsystem 1 - Part No SW: 3C8 959 704 D HW: 3C8 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0501
Serial number: 00000003339020
Coding: 010490
Revision: H19 Serial number: 00000000769835
Coding: 0022156
VCID: 3669D2E241698DFF7F-8062
00532 - Supply Voltage B+
Reset counter: 213
Mileage: 58932 km
Date: 2013.10.09
Time: 10:06:43
Voltage: 8.30 V
Count: 48
Hex Value: 0x1260
Hex Value: 0x0001
Hex Value: 0x0101
Reset counter: 41
Mileage: 59901 km
Date: 2013.11.28
Time: 05:37:11
Voltage: 13.70 V
Count: 104
Speed: 6.0 km/h
Hex Value: 0x12E0
Hex Value: 0x0001
Hex Value: 0x0101
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 071200010B000400
VCID: 3777DFE68E6374F764-8062
Subsystem 1 - Part No SW: 1T0 941 329 HW: 1T0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0007
Coding: 350000
Subsystem 2 - Part No SW: 1T0 941 329 HW: 1T0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0007
Coding: 350000
13705985 - Databus
Fault Frequency: 7
Reset counter: 41
Mileage: 59901 km
Date: 2019.07.08
Time: 05:37:10
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 D HW: 3AA 907 273 D
Component: RDKBERU30 H09 0010
Serial number: 10000000196471
ASAM Dataset: EV_RDKBERU30 003012
ROD: EV_RDKBERU30_003.rod
VCID: 356BD5EE946F86E776-8060
12652544 - Supply voltage
Reset counter: 40
Mileage: 58932 km
Date: 2019.05.19
Time: 10:11:24
End-------------------------(Elapsed Time: 03:00)--------------------------
