Looking for some guidance.
Just installed a CJAA/DSG (FWD) from a 2012 Jetta into a 2012 Tiguan (TSI/4mo automatic).
Malone did the tune. Engine is working fine with the exception of a P0381 code which I cannot find on Wiki. Have checked for power and signal wires from ECU. Only thought on this would be that I have the gasser instrument cluster installed. I have a cluster from a Euro Tig TDI but have not installed it yet.
My second issue is with ABS coding. The tig was a 4 motion with Aisin 6 speed automatic. I removed prop shaft and disconnected the Haldex unit.
I have tried all the codes from this list and the closest I come to getting rid of the errors is 5185. The scan is with the 5185 code.
Any advice, pointers, direction, would be much appreciated on either the P0381 or the ABS coding
engine and transmission combination: 4096
1029 - 1.4tsi 75 - 100kW front-wheel drive manual transmission 1029 5125
1032 - 1.4tsi 75 - 100kW front-wheel drive manual transmission (China) 1032 5128
1035 - 1.4tsi 101 - 130kW front-wheel drive manual transmission 1035 5131
1038 - 1.4tsi 101 - 130kW manual transmission 4Motion 1038 5134
1041 - 1.8tsi 105 - 130kW front-wheel drive manual transmission (China) 1041 5137
1044 - 1.8tsi 105 - 130kW front-wheel drive automatic (China) 1044 5140
1047 - 1.8tsi 105 - 130kW automatic transmission 4Motion (China) 1047 5143
1050 - 2.0tsi 125 - 160kW automatic transmission 4Motion (China) 1050 5146
1053 - 1.4tsi 101 - 130kW DSG front-wheel drive (NAR) 1053 5149
1056 - 2.0tsi 125 - 160kW DSG 4Motion (CCZD motor 132kW) 1056 5152
1059 - 2.0tsi 125 - 160kW front-wheel drive manual transmission (NAR) 1059 5155
1062 - 2.0tsi 125 - 160kW front-wheel drive automatic (NAR) 1062 5158
1065 - 2.0tsi 125 - 160kW automatic transmission 4Motion (NAR) 1065 5161 original
1068 - 2.0tsi 125 - 160kW manual transmission 4Motion 1068 5164
1071 - 2.0tsi 125 - 160kW DSG 4Motion 1071 5167
1074 - 2.0tsi 125 - 160kW automatic transmission 4Motion 1074 5170
1077 - 2.0tsi 125 - 160kW front-wheel drive manual transmission (NAR) 1077 5173
1080 - 2.0tdi 70 - 90kW front-wheel drive manual transmission 1080 5176
1083 - 2.0tdi 91 - 110kW front-wheel drive manual transmission 1083 5179
1086 - 2.0tdi 91 - 110kW manual transmission 4Motion 1086 5182
1089 - 2.0tdi 91 - 110kW DSG 4Motion 1089 5185
1092 - 2.0tdi 91 - 110kW automatic transmission 4Motion 1092 5188
1095 - 2.0tdi 111 - 130kW DSG 4Motion 1095 5191
1098 - 2.0tdi 111 - 130kW manual transmission 4Motion 1098 5194
1101 - 1.4tsi 101 - 130kW DSG front-wheel drive 1101 5197
Monday,08,July,2019,23:11:59:45329
VCDS Version: 19.6.0.4 (x64)
VIN: 3VWJL7AJXAM022708 License Plate:
Mileage: 196150km-121881mi Repair Order: 7-8-19 Tiguan TDI
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 4F 52 53 56 62 72
VIN: 3VWJL7AJXAM022708 Mileage: 196150km-121881miles
25-Immobilizer -- Status: Not registered 0001
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 CM HW: 03L 906 022 TS
Component: R4 2,0L EDC G000AG 9971
Revision: 12H02--- Serial number:
Coding: 0350078
Shop #: WSC 26214 051 00000
VCID: 78F4F3A30B625A8FAF-802C
000897 - Glow Plug/Heater Indicator Circuit
P0381 - 000 - Implausible Signal
Mileage: 196158 km
Date: 2013.11.28
Time: 00:26:32
Temperature: 27.9°C
Voltage: 12.31 V
Bin. Bits: 00000000
Torque: 219.0 Nm
Temperature: 42.3°C
Part No SW: 02E 300 057 A HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2705
Revision: 05351112 Serial number: 00001011130184
Coding: 0000024
Shop #: WSC 01286 386 08256
VCID: 1736D01F263CB5F746-8042
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 AP HW: 5N0 614 109 AP
Component: J104 C6 450M VDE2 0005
Revision: --H07--- Serial number: 00000005590526
Coding: 0005185
VCID: 79F2F6A730684387D0-802C
Reset counter: 226
Mileage: 196158 km
Date: 2013.11.28
Time: 01:33:08
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.00 V
Bin. Bits: 00011111
Count: 215
Hex Value: 0x0000
Reset counter: 226
Mileage: 196158 km
Date: 2013.11.28
Time: 01:33:08
01324 - Control Module for All Wheel Drive (J492)
Reset counter: 226
Mileage: 196158 km
Date: 2013.11.28
Time: 01:33:08
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0404
Revision: 00001018
Coding: 0000001002
VCID: 00049B439BB2124F97-8054
B10AB F0 [009] - Too Low
Reset counter: 226
Mileage: 196155 km
Date: 2019.07.08
Time: 04:22:08
Part No SW: 5K0 937 086 N HW: 5K0 937 086 N
Component: BCM PQ35 M 021 0064
Revision: BJ021001
Coding: 6F180A1B80232EC4008800C11000854448010086524D8D60648040000040
VCID: 3F8658BFAECCADB7AE-806A
Subsystem 1 - Part No: 5N1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS 030412 03 32 0010
Coding: 009795
Reset counter: 226
Mileage: 196158 km
Date: 2013.11.28
Time: 01:40:32
Term 15 On
Voltage: 12.00 V
01259 - Fuel Pump Relay (J17)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 226
Mileage: 196158 km
Date: 2013.11.28
Time: 00:25:43
Term 15 On
Voltage: 12.30 V
Part No SW: 5N0 959 655 S HW: 5N0 959 655 S
Component: J234__20G VW10 HI 2118
Revision: 24017000 Serial number: 003L6P5XHBJB
Coding: 0012359
VCID: 4D9A7277D4600F272C-8018
Subsystem 1 - Part No: 5N0 959 339 B
Component: BF-Gewichtsens. 003 0001
Subsystem 2 - Serial number: 00000000008A6T
Subsystem 3 - Serial number: 0005.03.120000300000650055ÿ†63
Subsystem 4 - Serial number: 650055ÿ†6332MTS635430842 ÿ†63
Subsystem 5 - Serial number: 30842 ÿ†6342MTS665450852 ÿ†63
Subsystem 6 - Serial number: 50852 ÿ†6351HTS6FJI51AKR ÿ†63
Subsystem 7 - Serial number: 51AKR ÿ†6361HTS6RFPF1AKR ÿ†63
Subsystem 8 - Serial number: F1AKR ÿ†63727TS65Q7U0AKR ÿ†63
Subsystem 9 - Serial number: U0AKR ÿ†63827TS6JIOSMAKJ ÿ
Subsystem 10 - Serial number: SMAKJ ÿ
03551 - Functional Restriction of Seat Occupied Recognition
000 - - - MIL ON
Fault Status: 11100000
Fault Frequency: 18
Mileage: 196155 km
Date: 2013.11.28
Time: 00:35:36
Part No SW: 5K0 953 501 AT HW: 5K0 953 569 H
Revision: FF010041 Serial number: 20120410301432
Coding: 198A140000
VCID: 7CFCEFB3F75A76AFCB-8028
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0033
Coding: 820000
617735 - Selector Lever Park Position Lock Switch
B1162 11 [008] - Short to Ground
Fault Frequency: 17
Reset counter: 11
Mileage: 196155 km
Date: 2019.07.08
Time: 00:01:31
Part No SW: 5N0 920 972 E HW: 5N0 920 972 E
Component: KOMBI H04 0617
Coding: 211F00
VCID: 356A3A9794F067E774-8060
Part No SW: 7N0 907 530 P HW: 1K0 907 951
Component: J533 Gateway H40 1623
Revision: H40 Serial number: 260312F2000812
Coding: 356002
VCID: 3D7A22B7A4C0BFA7BC-8068
Mileage: 196158 km
Date: 2013.11.28
Time: 01:38:19
Component: IMMO H04 0617
VCID: 6AD0D9EB8DCEF81F29-803E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 B HW: 1K0 035 274 B
Component: RNS315-NAR H35 0265
Serial number: VWZAZ2M4214383
Coding: 0400040104000C000000100A
ASAM Dataset: EV_RNS315NARV2UDS A01004
ROD: EV_RNS315NARV2UDS.rod
VCID: 234EF4CF2A64E957AA-8076
Subsystem 1 - Part No: 3AA 919 866 B
Component: NAR_V2 0002
1048629 - Aux IN Socket
B1104 13 [009] - Open Circuit
Reset counter: 226
Mileage: 196155 km
Date: 2019.07.08
Time: 04:24:40
1048652 - Telephone Microphone
B1048 13 [009] - Open Circuit
Reset counter: 226
Mileage: 196155 km
Date: 2019.07.08
Time: 04:24:40
1048669 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Reset counter: 226
Mileage: 196155 km
Date: 2019.07.08
Time: 04:24:40
1048642 - Internal Control Module Memory Check Sum Error
B2000 42 [009] - General memory failure
Mileage: 196158 km
Date: 2019.07.08
Time: 01:18:56
Part No SW: 5N0 959 701 F HW: 3C0 959 793 B
Component: TUER-SG FT 002 0503
Revision: 13110009 Serial number: 0004683325
Coding: 0004B4
VCID: 387433A383E29A8F6F-806C
Slave Driver:
Subsystem 1 - Part No SW: 5N0 959 703 G HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 008 1504
Serial number: 00000006629752
Coding: 000490
B11EC 54 [009] - Missing Calibration / Basic Setting
B11EE 54 [009] - Missing Calibration / Basic Setting
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.286 1002
Revision: 1AH03836 Serial number: 00120870104201
Coding: 0000258
VCID: 3C7C2FB37FDAB6AF8B-8068
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1623
Coding: 050B0500
VCID: 6FE6C8FFBE2C1D377E-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H03 0220
Part No SW: 5N0 959 702 F HW: 3C0 959 792 B
Component: TUER-SG BT 002 0503
Revision: 15110009 Serial number: 0004672738
Coding: 0004B4
VCID: 397236A7B8E8838790-806C
Slave Passenger:
Subsystem 1 - Part No SW: 5N0 959 704 G HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 008 1504
Serial number: 00000006662726
Coding: 000490
Revision: H19 Serial number: 00000000097111
Coding: 0026156
VCID: 36683D9B41F66CFF7D-8062
Fault Status: 01110000
Reset counter: 226
Voltage: 11.90 V
Count: 101
Hex Value: 0x1270
Hex Value: 0x0082
Hex Value: 0x0101
End-------------------------(Elapsed Time: 02:36)--------------------------
