Results 1 to 10 of 10
Thread: Tiguan TDI conversion ABS help needed
    Jun 2016
    Looking for some guidance.
    Just installed a CJAA/DSG (FWD) from a 2012 Jetta into a 2012 Tiguan (TSI/4mo automatic).
    Malone did the tune. Engine is working fine with the exception of a P0381 code which I cannot find on Wiki. Have checked for power and signal wires from ECU. Only thought on this would be that I have the gasser instrument cluster installed. I have a cluster from a Euro Tig TDI but have not installed it yet.
    My second issue is with ABS coding. The tig was a 4 motion with Aisin 6 speed automatic. I removed prop shaft and disconnected the Haldex unit.
    I have tried all the codes from this list and the closest I come to getting rid of the errors is 5185. The scan is with the 5185 code.
    Any advice, pointers, direction, would be much appreciated on either the P0381 or the ABS coding
    engine and transmission combination: 4096
    1029 - 1.4tsi 75 - 100kW front-wheel drive manual transmission 1029 5125
    1032 - 1.4tsi 75 - 100kW front-wheel drive manual transmission (China) 1032 5128
    1035 - 1.4tsi 101 - 130kW front-wheel drive manual transmission 1035 5131
    1038 - 1.4tsi 101 - 130kW manual transmission 4Motion 1038 5134
    1041 - 1.8tsi 105 - 130kW front-wheel drive manual transmission (China) 1041 5137
    1044 - 1.8tsi 105 - 130kW front-wheel drive automatic (China) 1044 5140
    1047 - 1.8tsi 105 - 130kW automatic transmission 4Motion (China) 1047 5143
    1050 - 2.0tsi 125 - 160kW automatic transmission 4Motion (China) 1050 5146
    1053 - 1.4tsi 101 - 130kW DSG front-wheel drive (NAR) 1053 5149
    1056 - 2.0tsi 125 - 160kW DSG 4Motion (CCZD motor 132kW) 1056 5152
    1059 - 2.0tsi 125 - 160kW front-wheel drive manual transmission (NAR) 1059 5155
    1062 - 2.0tsi 125 - 160kW front-wheel drive automatic (NAR) 1062 5158
    1065 - 2.0tsi 125 - 160kW automatic transmission 4Motion (NAR) 1065 5161 original
    1068 - 2.0tsi 125 - 160kW manual transmission 4Motion 1068 5164
    1071 - 2.0tsi 125 - 160kW DSG 4Motion 1071 5167
    1074 - 2.0tsi 125 - 160kW automatic transmission 4Motion 1074 5170
    1077 - 2.0tsi 125 - 160kW front-wheel drive manual transmission (NAR) 1077 5173
    1080 - 2.0tdi 70 - 90kW front-wheel drive manual transmission 1080 5176
    1083 - 2.0tdi 91 - 110kW front-wheel drive manual transmission 1083 5179
    1086 - 2.0tdi 91 - 110kW manual transmission 4Motion 1086 5182
    1089 - 2.0tdi 91 - 110kW DSG 4Motion 1089 5185
    1092 - 2.0tdi 91 - 110kW automatic transmission 4Motion 1092 5188
    1095 - 2.0tdi 111 - 130kW DSG 4Motion 1095 5191
    1098 - 2.0tdi 111 - 130kW manual transmission 4Motion 1098 5194
    1101 - 1.4tsi 101 - 130kW DSG front-wheel drive 1101 5197
     Monday,08,July,2019,23:11:59:45329
    VCDS Version: 19.6.0.4 (x64)
    VIN: 3VWJL7AJXAM022708   License Plate:
    Mileage: 196150km-121881mi   Repair Order: 7-8-19 Tiguan TDI
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 4F 52 53 56 62 72
    VIN: 3VWJL7AJXAM022708   Mileage: 196150km-121881miles
    25-Immobilizer -- Status: Not registered 0001
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 906 019 CM    HW: 03L 906 022 TS
       Component: R4 2,0L EDC G000AG  9971
       Revision: 12H02---    Serial number:
       Coding: 0350078
       Shop #: WSC 26214 051 00000
       VCID: 78F4F3A30B625A8FAF-802C
    000897 - Glow Plug/Heater Indicator Circuit
                   P0381 - 000 - Implausible Signal
                        Mileage: 196158 km
                        Date: 2013.11.28
                        Time: 00:26:32
                        Temperature: 27.9C
                        Voltage: 12.31 V
                        Bin. Bits: 00000000
                        Torque: 219.0 Nm
                        Temperature: 42.3C
       Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2705
       Revision: 05351112    Serial number: 00001011130184
       Coding: 0000024
       Shop #: WSC 01286 386 08256
       VCID: 1736D01F263CB5F746-8042
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 AP    HW: 5N0 614 109 AP
       Component: J104   C6 450M VDE2 0005
       Revision: --H07---    Serial number: 00000005590526
       Coding: 0005185
       VCID: 79F2F6A730684387D0-802C
                        Reset counter: 226
                        Mileage: 196158 km
                        Date: 2013.11.28
                        Time: 01:33:08
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 12.00 V
                        Bin. Bits: 00011111
                        Count: 215
                        Hex Value: 0x0000
                        Reset counter: 226
                        Mileage: 196158 km
                        Date: 2013.11.28
                        Time: 01:33:08
                        Reset counter: 226
                        Mileage: 196158 km
                        Date: 2013.11.28
                        Time: 01:33:08
       Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
       Component: AC Manuell    H19 0404
       Revision: 00001018
       Coding: 0000001002
       VCID: 00049B439BB2124F97-8054
              B10AB F0 [009] - Too Low
                        Reset counter: 226
                        Mileage: 196155 km
                        Date: 2019.07.08
                        Time: 04:22:08
       Part No SW: 5K0 937 086 N    HW: 5K0 937 086 N
       Component: BCM PQ35 M    021 0064
       Revision: BJ021001
       Coding: 6F180A1B80232EC4008800C11000854448010086524D8D60648040000040
       VCID: 3F8658BFAECCADB7AE-806A
       Subsystem 1 - Part No: 5N1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS 030412 03  32  0010
       Coding: 009795
                        Reset counter: 226
                        Mileage: 196158 km
                        Date: 2013.11.28
                        Time: 01:40:32
                        Voltage: 12.00 V
    01259 - Fuel Pump Relay (J17)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 226
                        Mileage: 196158 km
                        Date: 2013.11.28
                        Time: 00:25:43
                        Voltage: 12.30 V
       Part No SW: 5N0 959 655 S    HW: 5N0 959 655 S
       Component: J234__20G VW10 HI   2118
       Revision: 24017000    Serial number: 003L6P5XHBJB
       Coding: 0012359
       VCID: 4D9A7277D4600F272C-8018
       Subsystem 1 - Part No: 5N0 959 339 B
       Subsystem 2 - Serial number: 00000000008A6T
       Subsystem 3 - Serial number: 0005.03.120000300000650055†63
       Subsystem 4 - Serial number: 650055†6332MTS635430842 †63
       Subsystem 5 - Serial number: 30842 †6342MTS665450852 †63
       Subsystem 6 - Serial number: 50852 †6351HTS6FJI51AKR †63
       Subsystem 7 - Serial number: 51AKR †6361HTS6RFPF1AKR †63
       Subsystem 8 - Serial number: F1AKR †63727TS65Q7U0AKR †63
       Subsystem 9 - Serial number: U0AKR †63827TS6JIOSMAKJ
       Subsystem 10 - Serial number: SMAKJ
    03551 - Functional Restriction of Seat Occupied Recognition
                000 - - - MIL ON
                        Fault Status: 11100000
                        Fault Frequency: 18
                        Mileage: 196155 km
                        Date: 2013.11.28
                        Time: 00:35:36
       Part No SW: 5K0 953 501 AT    HW: 5K0 953 569 H
       Revision: FF010041    Serial number: 20120410301432
       Coding: 198A140000
       VCID: 7CFCEFB3F75A76AFCB-8028
       Component: E221__MFL-TAS  H31 0033
       Coding: 820000
    617735 - Selector Lever Park Position Lock Switch
              B1162 11 [008] - Short to Ground
                        Fault Frequency: 17
                        Reset counter: 11
                        Mileage: 196155 km
                        Date: 2019.07.08
                        Time: 00:01:31
       Part No SW: 5N0 920 972 E    HW: 5N0 920 972 E
       Coding: 211F00
       VCID: 356A3A9794F067E774-8060
       Part No SW: 7N0 907 530 P    HW: 1K0 907 951
       Component: J533  Gateway H40 1623
       Revision:   H40       Serial number: 260312F2000812
       Coding: 356002
       VCID: 3D7A22B7A4C0BFA7BC-8068
                        Mileage: 196158 km
                        Date: 2013.11.28
                        Time: 01:38:19
       VCID: 6AD0D9EB8DCEF81F29-803E
       Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
       Component: RNS315-NAR    H35 0265
       Serial number: VWZAZ2M4214383
       Coding: 0400040104000C000000100A
       ASAM Dataset: EV_RNS315NARV2UDS A01004
       ROD: EV_RNS315NARV2UDS.rod
       VCID: 234EF4CF2A64E957AA-8076
       Component: NAR_V2  0002
    1048629 - Aux IN Socket
              B1104 13 [009] - Open Circuit
                        Reset counter: 226
                        Mileage: 196155 km
                        Date: 2019.07.08
                        Time: 04:24:40
    1048652 - Telephone Microphone
              B1048 13 [009] - Open Circuit
                        Reset counter: 226
                        Mileage: 196155 km
                        Date: 2019.07.08
                        Time: 04:24:40
    1048669 - Tuner for Satellite Radio
              B11CF 53 [009] - Deactivated
                        Reset counter: 226
                        Mileage: 196155 km
                        Date: 2019.07.08
                        Time: 04:24:40
    1048642 - Internal Control Module Memory Check Sum Error
              B2000 42 [009] - General memory failure
                        Mileage: 196158 km
                        Date: 2019.07.08
                        Time: 01:18:56
       Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0503
       Revision: 13110009    Serial number: 0004683325
       Coding: 0004B4
       VCID: 387433A383E29A8F6F-806C
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  008 1504
       Serial number: 00000006629752
       Coding: 000490
              B11EC 54 [009] - Missing Calibration / Basic Setting
    131584 - Motor for Rear Window Regulator
              B11EE 54 [009] - Missing Calibration / Basic Setting
       Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.286 1002
       Revision: 1AH03836    Serial number: 00120870104201
       Coding: 0000258
       VCID: 3C7C2FB37FDAB6AF8B-8068
       Component: EZE_2         H40 1623
       Coding: 050B0500
       VCID: 6FE6C8FFBE2C1D377E-803A
       Component: J245EE20SKB13  H03 0220
       Component: J394EE20SKB13  H03 0220
       Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0503
       Revision: 15110009    Serial number: 0004672738
       Coding: 0004B4
       VCID: 397236A7B8E8838790-806C
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  008 1504
       Serial number: 00000006662726
       Coding: 000490
       Revision:   H19       Serial number: 00000000097111
       Coding: 0026156
       VCID: 36683D9B41F66CFF7D-8062
                        Fault Status: 01110000
                        Reset counter: 226
                        Voltage: 11.90 V
                        Count: 101
                        Hex Value: 0x1270
                        Hex Value: 0x0082
                        Hex Value: 0x0101
    End-------------------------(Elapsed Time: 02:36)--------------------------
    2005 Passat Wagon TDI 5 speed manual
    2000 Audi TT
    2012 Tiguan TDI/DSG
    2011 BMW X35d
    I would guess that the gasoline cluster is the reason behind the P0381 code. That cluster likely has no provision for diesel-specific warning light (the "glow plug" light). I'm skeptical that there's actually a physical circuit for this. I would guess it's more likely a virtual circuit implemented via CAN messages, but the net result is the same: The ECU knows it can't turn that warning light on.
  3. Likes Jetta ,97 liked this post
    Jun 2014
    Poland
    100 % not cluster issue
    you can install Petrol cluster to Diesel , and in reverse way ...no problem with that
    First - your GW show incorrect coding
    2nd - what VIN you keep in ECU ?
    Did you adapt that ECU to your VIN, or just did IMMO OFF? to start engine
    3rd - not use if Jetta talk good with EPB as she never see that in PQ35 , and you also have issue in EPB
    Some errors will go if you write proper VIN to new ECU,.
    similar is with PQ35 ABS , when VIN is a part of coding , and Engine type too
    Even if ABS is use Cluster VIN, ECU still broadcasting VIN
    If VIN is mismach - ABS can freak out because it see different platform
    at the end .... if you not fix it , better use Passat ECU ...or Sharan , but B6/CC Passat with EPB, not NMS Passat US....
    they use TRW ABS system and EPB
    you can definitely stay away from cluster , this only "display "
  5. Likes Uwe liked this post
  6. #4
    Quote Originally Posted by Spacewalker View Post
    Well, I did say, "I would guess". And I've been known to guess wrong!
  7. Likes Jetta ,97, dieseltje liked this post
  8. #5
    Dallas (McKinney) ,TX ,USA
    @Spacewalker
    P0381 Glow Plug/Heater Indicator Circuit Malfunction
    UWE you are correct , Cluster is problem because missing Glow plug signal in cluster . I told him this last time that cluster has to be modified to work with TDI ECU when he did other Tiguan conversion few years ago.
    As far as VIN you can see since he has VIN form Jetta so ABS will complain about this .Most likely he has Immo off
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  9. Likes Uwe liked this post
  10. #6
    Jun 2014
    Poland
    Did hundreds of cluster swap, some Petrol have no LED for DPF , and they working after SW conversion to diesel, and ECU not show any error
    dont think so
    I am almost 100% sure LED is on the PCB, just need proper EEprom from Diesel , so is much easier to play with that cluster , just with proper SW
  11. #7
    Jun 2016
    Quote Originally Posted by Jetta ,97 View Post
    @Spacewalker
    Thank you Jetta, 97 and Spacewalker for your replies. It seems like you are contradicting each other on the cluster. The last conversion Jetta, 97 combined parts of the donor Golf IC with the Tig IC as they were fairly common to each other. On this conversion the donor Jetta's cluster was very basic and did not look the same. That's why I picked up a cluster from a Euro Tig TDI. My thinking is that would solve issues with the dual gas tank senders, have the correct tach and the GP light.
    Changing the VIN in the ECU makes since to try and clear up the GW and possibly the ABS. Will the cluster need the VIN correction too?
    2000 Audi TT
    2012 Tiguan TDI/DSG
    2011 BMW X35d
  12. #8
    dont think so
    Correct, but still have Gasoline Sw in it , that why I said need to be MODIFIED.
    Immobilizer/ECU
  13. Likes Uwe liked this post
  14. #9
    Quote Originally Posted by vwztips View Post
    5N0 920 972 E is Gasoline cluster form your Scan.
    Immobilizer/ECU
  15. Likes Uwe liked this post
  16. #10
    Jun 2016
    Just a follow up to my issues. Marin (Jetta, 97 helped me work through the issues and now everything is working and talking to each other as they should.
    Just a few notes:
    Needed Tiguan VIN # in donor Jetta ECU
    Used stock Tiguan IC which Marin reworked with Passat TDI foils, so the tach and GP lights are correct. Also required some internal coding to work with the electronic brake
    Coded ABS module with 5185 code
    Now it is all good. Just have to get used to driving a DSG...…...
    2000 Audi TT
    2012 Tiguan TDI/DSG
    2011 BMW X35d
  17. Likes Uwe, Jetta ,97 liked this post
