Seat Alhambra/ VW Sharan ACC retrofit
   #21
andy_911
Austria
C?ID=149628
Ok, i will next week look for other scans.
Do you think i have only to chnange the ACC setting in original coding and it could work?
   #22
dnoermann
C?ID=358118
Not shure, from my tests i always could set ACC to off in coding of ABS and that coding was accepted.
So probably it is a different setting that prevents the coding.
I am not aware of a coding for GRA that influences the ABS, so GRA needs not to be disabled in your coding.
   #23
andy_911
Austria
C?ID=149628
Are you sure about the thing with the last 5 digits of the VIN? When i look at the VIN's and coding's of your post, I can't see that. Or I don't understand what you mean.
   #24
dnoermann
C?ID=358118
I am very shure.
Probably you are looking from the wrong side on this.
Coding is always numbered from most left Byte to the right, dont ask me why.
Lets look into your VIN: VSSZZZ7NZGV708020 last 5 Digits: 08020
And your Coding: 12F0449A0920C2740877480222C3904310391700F00B4895
Byte 05 = 0x20 - Offset 0x20 ==> 0
Byte 07 = 0x74 - Offset 0xBE ==> 8
Byte 09 = 0x77 - Offset 0x77 ==> 0
Byte 11 = 0x02 - Offset 0x00 ==> 2
Byte 13 = 0xC3 - Offset 0xC3 ==> 0
The position and offset values are different beetween differen ABS generations, but same inside one Version of ABS.
They are easily found once you look together into different Codings
   #25
andy_911
Austria
C?ID=149628
Thank you very much for explaining me, I did first count the Byte 00 as 01.
Do you mean there is a specific ofset per byte? I see.
Because of the rest of the coding: Do you think that the ABS is coded to a normal GRA? How could I find the GRA bit?
   #26
dnoermann
C?ID=358118
As already said :p
Meaning: I dont know a coding for GRA inside the ABS.
   #27
andy_911
Austria
C?ID=149628
I tried to change the original coding with the value of ACC and auto transmission, and what schould I say - it worked.
The Faults of the wrong rear ABS sensors are gone?
Here you can see the actual Autoscan
Sunday,14,July,2019,18:06:50:24421
VIN: VSSZZZ7NZGV708020   License Plate:
Mileage: 151600km-94199mi   Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 25 2B 36 3C 42 44 46
          4C 4F 52 53 55 5F 61 62 69 6C 6D 72 A5 BE BF
VIN: VSSZZZ7NZGV708020   Mileage: 151600km-94199miles
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-CUWA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 CK    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 1737
   Revision: 8AH20---
   Coding: 011D001A047401083000
   Shop #: WSC 00020 999 12345
   ASAM Dataset: EV_ECM20TDI01104L906016CK 001004
   ROD: EV_ECM20TDI01104L906016BJ_001_VW36.rod
   VCID: 74B02B69AE3ED9F7DE1-8020
4815 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [167] - -
          [ABS brake control moduleRead out DTC]
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:47
                    Coolant temperature: 55 °C
                    Intake air temperature: 54 °C
                    Ambient air pressure: 960 mbar
                    Voltage terminal 30: 12.360 V
                    Requested transmission torque: 1000.0 Nm
                    Limitation: accelerator pedal: 126.6 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    selected gear-Bits 0-7: 0
                    Transmission torque intervention status-Bits 0-7: 80
                    Transmission torque intervention status-Bits 0-7: 0
                    Calculated reducing transmission intervention torque: 1000.0 Nm
14413 - Implausible Data Received from ABS Control Module
          U0415 00 [039] - -
          [Invalid Data Received FromAnti-Lock Brake System Control Module]
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:47
10065 - Mass Air Flow Sensor (G70)
          P0104 00 [167] - Intermittent
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:47
                    Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
                    Standardized airflow ratio: filtered: 3.9999
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 1.75 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
                    Charge air pressure specified value: 0 hPa
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 960.4 hPa
                    Mean injection quantity: 0.00 mg/stroke
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:47
                    Longitudinal acceleration: raw value: 32.767 m/s²
                    Vehicle inclination acceleration angle: raw value: -0.197 m/s²
                    Status: incline angle-Bits 0-7: 0
                    Longitudinal acceleration: 0.000 m/s²
                    Longitudinal acceleration sensor: status-Bits 0-7: 1
                    Vehicle lateral acceleration: raw value: 327.67 g
                    Vehicle lateral acceleration: 0.00 g
   Part No SW: 02E 300 063 C    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4902
   Revision: 06253104    Serial number: 00001507232976
   Shop #: WSC 44551 111 44551
   VCID: 167431E194826BE7005-8042
Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
   Part No SW: 5N0 614 109 CG    HW: 5N0 614 109 CK
   Component: ESC-EBC460iV1 H10 0013
   Serial number: A01BURS
   Coding: 12F0449A0920C2740877480222C39043103917F8F00B4895
   ASAM Dataset: EV_Brake1ESCEPBTRW 006353
   ROD: EV_Brake1ESCEPBTRW_006.rod
   VCID: 72BC2D71D42AD7C7CCD-8026
9 Faults Found:
0383 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
0360 - Steering angle sensor
0402 - Overboost Adapation Not Performed
          C1140 00 [009] - -
0522 - Inertial Sensor Package
          C115E 54 [137] - Missing Calibration / Basic Setting
0636 - Databus
          [MSG_RCTA_01_STATUS_FAULT]
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:18:15
                    Additional_Codes: 00 00 00 0C 6E 1E 00 0A 0A
                    DTC: 00 02 7C
                    Additional2: 02 06 01 02 05 66 3C 00 3C 00
0566 - Left Parking Brake Motor
          C100F 00 [137] - Movement Difficult
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:45
                    Additional_Codes: 00 00 00 0C 67 1E 00 0A 0A
                    DTC: 00 02 36
                    Additional2: 02 06 01 02 05 66 3D 00 3D 00
0565 - Right Parking Brake Motor
          C1010 00 [137] - Movement Difficult
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:45
                    DTC: 00 02 35
0559 - No Basic Setting
          B2010 00 [137] - -
          [PBC_EVENT_PBC_IN_ASSEMBLY_MODE]
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:45
                    DTC: 00 02 2F
0818 - Parking Brake Motors
          C10E1 29 [137] - Signal Implausible
          [PBC_EVENT_BRAKE_STATE_UNKNOWN]
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:45
                    Additional_Codes: 00 00 00 0C 5F 1E 00 0A 0A
                    DTC: 00 03 32
                    Additional2: 02 06 01 07 05 66 3D 00 3D 00
   Revision: 00092000    Serial number: 0375621325
   Coding: 03100C
   Shop #: WSC 00020 999 39850
   VCID: 372ADC65FFC872EF3B3-8062
   Part No SW: 7N0 907 044 AC    HW: 7N0 907 044 AC
   Component: Clima-Sharan  H02 0606
   Revision: 00001K04
   Coding: 021010C549
   Shop #: WSC 00020 999 00000
   VCID: 71BE227DD12CECDF357-8024
   Slave 1:
   Subsystem 1 - Part No SW: 7N0 907 049 C    HW: 7N0 907 049 C
   Component: KBT-H  004 0103
   Serial number: 20150817000000016318
   Part No SW: 5K0 937 086 T    HW: 5K0 937 086 T
   Component: BCM PQ35 M    122 0183
   Revision: BC122001
   Coding: 60590A3B892508C4508800C8B400897403D50008676D2DB26484C720A2C1
   Shop #: WSC 00020 790 00000
   VCID: 45D6A6ADB5A4107FB9F-8010
   Subsystem 1 - Part No SW: 7N1 955 119 B    HW: 7N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS428 110715  024 0644
   Serial number: 15070906072131
   Coding: 004DBD
   Component: RLHS  037 0059
   Serial number: S2Y15M09D08H00M15S01
   Coding: 0228BB
   Part No SW: 1K8 919 472 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0479
   Revision: --------    Serial number: 39331524102160
   Coding: 0071155211
   ASAM Dataset: EV_EPHVA18VW364GP00 001006
   VCID: 3634D161F8C28BE7205-8062
13688835 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:18:15
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 B    HW: 7N0 907 572
   Component: ACC Bosch PQx H03 0120
   Serial number: 17111577091554
   Coding: 00001900FE0739
   ASAM Dataset: EV_ACCBEGVW361 001005
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: 3536D66DE5C480FF29F-8060
8 Faults Found:
1070 - Databus
          [FAULT_CIS_AXV_FAIL]
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:45
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 12.2 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1064 - Databus
          [FAULT_CIS_BPRESSURE_FAIL]
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:45
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:54
1061 - Databus
          [FAULT_CIS_EPB_ACTUATOR_FAIL]
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:54
1060 - Databus
          [FAULT_CIS_EPB_FAIL]
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:54
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:54
1043 - Automatic Distance Control
          B10E7 F0 [009] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:54
1074 - Databus
          [FAULT_CIS_YAW_FAIL]
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:45
   Part No SW: 7N0 959 655 D    HW: 7N0 959 655 D
   Component: VW10Airbag10X H15 0016
   Serial number: 003PWPHJML0Z
   Coding: 003058
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 40D8B7B9AA0635578A9-8014
   Subsystem 1 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.V  --- ---
   Serial number: 3493ETS60DA6FB11B9DE
   Subsystem 2 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.V  --- ---
   Serial number: 3503ETS605DEDB41B9DA
   Subsystem 3 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.H  --- ---
   Serial number: 3513ETS600D8BB21B9D$
   Subsystem 4 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.H  --- ---
   Serial number: 3523ETS60B5E7B11B9D1
   Subsystem 5 - Part No SW: ---            HW: ---
   Component: F.Sens.Fahr  --- ---
   Serial number: 35540TS6094A8A31BDDX
   Part No SW: 5K0 953 501 DQ    HW: 5K0 953 569 AP
   Revision: FF010042    Serial number: 20150902100965
   Coding: 3112A40000
   VCID: 7CA00349866E91B7961-8028
   Subsystem 1 - Part No SW: 7N5 919 719     HW: 7N5 919 719   Labels: 3C8-959-537.CLB
   Serial number: 000000000B0049300715
   Coding: 011000
   Part No SW: 7N5 920 880 A    HW: 7N5 920 880 A
   Component: KOMBI         H04 1007
   Coding: 140F010000
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 7N0 963 271 G
   Component: Standheizer     051 3041
   Revision: 00051000    Serial number: 09028242000000
   Coding: 0001042
   VCID: 3828DF59FE567D97329-806C
02245 - Connection; RF Remote Control
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:48
   Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1663
   Revision:   H56       Serial number: 230815F1001301
   Coding: 468232
   Shop #: WSC 00020 790 12345
   VCID: 72BC2D71D4AAD7C7CCD-8026
   Component: IMMO          H04 1007
   Coding: 000007
   VCID: 6A8C3511FCFA1F0774D-803E
   Revision: 00000000    Serial number: 15000190810005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3038E7791AA6A5D77A9-8064
Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760 F    HW: 3C8 959 760 F
   Component: Sitzmemory    H02 1301
   Revision: 00H02000
   Coding: 000018
   Shop #: WSC 12336 024 394758
   VCID: 3828DF59F2567D97329-806C
   Component: HRE_Master    H11 0071
   Serial number: 0378307517
   Coding: 02011102
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3C20C349C6EE51B7D61-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H11 0071
   Serial number: 0378415333
   Coding: 020111
337664 - Databus
          [mBremse_5::BR5_Sta_Gierrate- no signal/no communication]
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:45
Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
   Part No SW: 7N0 959 793 J    HW: 7N0 959 793 G
   Component: TSG FA        H04 0561
   Revision:             Serial number: 0000163734024
   Coding: 01112F209E00411001
   VCID: 49CEAA9D99BCF41F5D7-801C
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.325 1401
   Revision: 1BH04739    Serial number: 00152040223701
   Coding: 0000258
   VCID: 41DEB2BDAD8C3C5F857-8014
   Component: EZE_2         H56 1663
   Coding: 050B0501
   VCID: 6FBA2405C798FA2F233-803A
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
   Part No SW: 7N0 959 792 J    HW: 7N0 959 792 G
   Component: TSG BF        H04 0561
   Revision:             Serial number: 0000163681524
   Coding: 01112D209E00411001
   VCID: 48C8AF9982B60D17429-801C
   Component: AFS-ECU       H05 0111
   Coding: 068200000B000000
   ROD: EV_HeadlRegulVWAFSPt_VW32.rod
   Subsystem 1 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 7N5 035 680 B    HW: 7N5 035 680 B
   Component: MU-S-N-ER     H20 0240
   Serial number: SEZAZ2R0241952
   Coding: 04240801FF00000011110001000808001F0100840020010086
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 323CED7114AA97C70CD-8066
   Subsystem 1 - Part No SW: 5F0 060 884 BN    HW: -----------
   Component: ECE AS 19/20  --- 1115
   Component: Batt.regelung H56 1663
   Coding: 030F7873
   VCID: 71BE227DD1ACECDF357-8024
   Component: J367-BDM  H07 0180
   Serial number: 42242M55401491566675
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 L    HW: 7N0 959 794 H
   Component: TSG HL        H02 0561
   Revision:             Serial number: 0000163856216
   Coding: 01006D200000411001
   VCID: 4CC0938996CEE137661-8018
Address 69: Trailer (J345)       Labels:. 7N0-907-383.clb
   Part No SW: 7N0 907 383     HW: 7N0 907 383
   Component: Anhaenger     H09 0101
   Revision: 3I001002    Serial number: 00008130005327
   Coding: 410C040001000000
   Shop #: WSC 00049 770 00119
   VCID: 73B22875ABB0DECFC7B-8026
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
   Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Component: VW428 RVC Mid H04 0040
   Coding: 012408012301000700
   ASAM Dataset: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAVW428.rod
Address 6D: Trunk Elect. (J605)       Labels:| 7N0-959-107.clb
   Part No SW: 7N0 959 107 G    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0250
   Revision: 41011001    Serial number: 222500791
   Coding: 0733334002
   ASAM Dataset: EV_HDSGVW428 201138
   ROD: EV_HDSGVW428_VW36.rod
   VCID: 3B22C055C3E0568FDFB-806E
Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
   Component: TSG HR        H02 0561
   Revision:             Serial number: 0000163856444
   Part No SW: 3Q0 980 654     HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0010
   Serial number: 24081511P10705
   Coding: 0304020800000401002613068080400090000E100020
0280 - Databus
          [mBremse_2_BR2_Querbeschl_Qbit]
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:45
                    Control Module temperature: 34 °C
                    Outside air temperature: 19.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 435.8 s
                    Voltage terminal 15: 12.1 V
                    mid: 02 CC
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
0034 - Databus
          [mBremse_5_BR5_Bremsdruck]
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:45
                    mid: 02 D0
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
0032 - Databus
          [mBremse_5_BR5_Giergeschw]
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:45
                    mid: 02 D1
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
0033 - Databus
          [mBremse_8_BR8_Laengsbeschl_Qbit]
                    Reset counter: 30
                    Mileage: 151607 km
                    Date: 2019.07.14
                    Time: 00:17:45
                    mid: 02 DA
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
Address BE: Slid. Door Rear Left (J558)       Labels: 7N0-959-244.clb
   Part No SW: 7N0 959 244 B    HW: 7N0 959 244 B
   Component: Schiebetuer_l 005 2414
   Serial number: 15334958
   ASAM Dataset: EV_AST A03704
   ROD: EV_AST.rod
   VCID: 3828DF59F2D67D97329-806C
Address BF: Slid. Door Rear Right (J731)       Labels: 7N0-959-244.clb
   Component: Schiebetuer_r 005 2414
   Serial number: 15335197
   ROD: EV_AST.rod
End----------(Elapsed Time: 02:22, VBatt start/end: 12.3V/12.3V)-----------
   #28
downtime
C?ID=280813
Hey hey. Now just do the basic settings. After that you will see what errors you still have left
   #29
andy_911
Austria
C?ID=149628
Today I will change the ABS block and do so, until yet I've only connected it electrically .....
I let you know, when I've done the next step ;-)
   #30
rhinopower
C?ID=58979
Why change the block? Just bolt the ecu to the old block
   #31
andy_911
Austria
C?ID=149628
@ rhinopower: The ABS unit is mounted in a way, that I can't change the ecu without removing it. Therefore I thought I'll change the whole ABS block.
@ all: Thanks a lot for your help! Everything is now working fine!
It was a little bit tricky to do the basic Setting of the ABS in the end - I was only with ODIS-service able to do it.
Here you can see the actual Autoscan:
Monday,15,July,2019,18:39:49:24421
Mileage: 151660km-94237mi   Repair Order:
VIN: VSSZZZ7NZGV708020   Mileage: 151660km-94237miles
   Revision: 8AH20---
   Coding: 03100C
   Revision: 00001K04
   Coding: 021010C549
   Slave 1:
   Revision: BC122001
   Coding: 004DBD
   Coding: 0228BB
   Coding: 0071155211
   Coding: 003058
   Coding: 3112A40000
   Coding: 011000
   Coding: 140F010000
   Coding: 0001042
                    Reset counter: 31
                    Mileage: 151629 km
                    Date: 2019.07.15
                    Time: 01:43:14
   Coding: 468232
   Coding: 000007
   Revision: 00H02000
   Coding: 000018
   Coding: 02011102
   Coding: 020111
   Coding: 0000258
   Shop #: WSC 00046 000 00000
   Coding: 050B0501
   Coding: 030F7873
   Coding: 0733334002
   ROD: EV_AST.rod
   ROD: EV_AST.rod
End----------(Elapsed Time: 02:09, VBatt start/end: 12.7V/12.4V)-----------
   #32
dnoermann
C?ID=358118
Congratulations :popcorn:
I did send you a PM, can you look into it please.
Greetings
Dennis
   #33
andy_911
Austria
C?ID=149628
It would be interesting what's the difference between the ABS ecu's.
Maybe I'll try to flash the CG Software over my old ABS ecu, when I've time ...
   #34
golfi_vend
Tartu, Estonia
C?ID=195131
Most likely a bit somewhere in eeprom or flash like with Passat ABS.
   #35
ghost
C?ID=139898
   Revision: 8AH20---
   Coding: 03100C
   Revision: 00001K04
   Coding: 021010C549
   Slave 1:
   Revision: BC122001
   Coding: 004DBD
   Coding: 0228BB
   Coding: 0071155211
   Coding: 003058
   Coding: 3112A40000
   Coding: 011000
   Coding: 140F010000
   Coding: 0001042
                    Reset counter: 31
                    Mileage: 151629 km
                    Date: 2019.07.15
                    Time: 01:43:14
   Coding: 468232
   Coding: 000007
   Revision: 00H02000
   Coding: 000018
   Coding: 02011102
   Coding: 020111
   Coding: 0000258
   Coding: 050B0501
   Coding: 030F7873
   Coding: 0733334002
   ROD: EV_AST.rod
   ROD: EV_AST.rod
Hi
What is the part number on stalks you fitted, if you don't mind. Struggling to find correct stalks for this upgrade on Alhambra.
VW ACC works of the steering wheel, as I understand Seat has stalk setup
Regards
