Seat Alhambra/ VW Sharan ACC retrofit
andy_911
Austria
C?ID=149628
Hello @ all,
I started to retrofit ACC to a 2016 Seat Alhambra!
To retrofit the sensor and the cabeling was very easy, component protection was no problem too - the Seat workshop was able to disable component protection easily!
A "russian friend" did the thing with the SWAP code - it took him 15 minutes.
Now I had to wait for 2 month, to get the right ACC/GRA switch (because the VW Sharan has the buttons on the steerig Wheel).
Now there is still one fault code in the ACC module.
I think that I'll have to change the ABS too - but I don't know what part number is the right one for my car?!
there are About 15 different ABS modules for that modell year. The only difference betweent the part numbers is PR-8T0, PR-8T2 vs. PR-8T3, PR-8T5 (GRA vs. ACC)!
Could it work with the part number 5N0614109CK, what is from a car without automatic transmission?
And what will be the correct CODING??
Here you can see the actual autoscan with ACC:
Fahrzeugtyp: 7N-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 25 2B 36 3C 42 44 46
          4C 4F 52 53 55 5F 61 62 69 6C 6D 72 A5 BE BF
Fahrzeug-Ident.-Nr.: VSSZZZ7NZGV708020   Kilometerstand: 151470km
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
18-Standheizung -- Status: Fehler 0010
19-Diagnoseinterface -- Status: i.O. 0000
25-Wegfahrsperre -- Status: i.O. 0000
2B-Lenksäulenverrieg. -- Status: i.O. 0000
36-Sitzverst. Fahr. -- Status: i.O. 0000
3C-Spurwechsel -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
46-Komfortsystem -- Status: i.O. 0000
4C-Reifendruck II -- Status: i.O. 0000
4F-Zentralelektrik II -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
53-Feststellbremse -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
61-Batterieregelung -- Status: i.O. 0000
62-Türelektr. hi. li. -- Status: i.O. 0000
69-Anhänger -- Status: i.O. 0000
6C-Rückfahrkamera -- Status: i.O. 0000
6D-Heckklappe -- Status: i.O. 0000
72-Türelektr. hi. re. -- Status: i.O. 0000
A5-Front-/Vorfeldkamera -- Status: i.O. 0000
BE-Schiebetür hinten links -- Status: i.O. 0000
BF-Schiebetür hinten rechts -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CUWA)       Labeldatei:. DRV\04L-907-309-V1.clb
   Teilenummer SW: 04L 906 016 CK    HW: 04L 907 309 K
   Bauteil: R4 2,0L EDC   H20 1737
   Revision: 8AH20---
   Codierung: 011D001A047401083000
   Betriebsnr.: WSC 00020 999 12345
   ASAM Datensatz: EV_ECM20TDI01104L906016CK 001004
   ROD: EV_ECM20TDI01104L906016BJ_001.rod
   VCID: 74B02B69AE3ED9F78A5-8020
Adresse 02: Getriebe        Labeldatei: DRV\02E-927-770.clb
   Teilenummer SW: 02E 300 063 C    HW: 02E 927 770 AL
   Bauteil: GSG DSG AG6     531 4902
   Revision: 06253104    Seriennummer: 00001507232976
   Codierung: 0000020
   Betriebsnr.: WSC 44551 111 44551
   VCID: 167431E194826BE7541-8042
Adresse 03: Bremsenelektronik (J104)       Labeldatei: DRV\5N0-614-109-V1.clb
   Teilenummer SW: 5N0 614 109 CD    HW: 5N0 614 109 CD
   Bauteil: ESC-EBC460iV1 H10 0012
   Seriennummer: A00WLIN
   Codierung: 12F0449A0920C2740877480222C3904310391700F00B4895
   Betriebsnr.: WSC 00020 999 00000
   ASAM Datensatz: EV_Brake1ESCEPBTRW 006353
   VCID: 6FBA2405C718FA2F777-803A
Adresse 05: Zugangs-/Startber. (J518)       Labeldatei:| DRV\5K0-959-434.clb
   Teilenummer SW: 5K0 959 434 E    HW: 5K0 959 434
   Bauteil: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Seriennummer: 0375621325
   Codierung: 03100C
   Betriebsnr.: WSC 00020 999 39850
   ASAM Datensatz: EV_KESSYPQ35G A02717
   ROD: EV_KESSYPQ35G_A02_VW36.rod
   VCID: 372ADC65FFC872EF6F7-8062
Adresse 08: Klima-/Heizungsel. (J255)       Labeldatei:| DRV\5K0-907-044.clb
   Teilenummer SW: 7N0 907 044 AC    HW: 7N0 907 044 AC
   Bauteil: Clima-Sharan  H02 0606
   Revision: 00001K04
   Codierung: 021010C549
   ASAM Datensatz: EV_ClimatronicSharan A01005
   VCID: 71BE227DD12CECDF613-8024
   Slave 1:
   Subsystem 1 - Teilenummer SW: 7N0 907 049 C    HW: 7N0 907 049 C
   Bauteil: KBT-H  004 0103
   Seriennummer: 20150817000000016318
Adresse 09: Zentralelektrik (J519)       Labeldatei:. DRV\1K0-937-08x-09.clb
   Teilenummer SW: 5K0 937 086 T    HW: 5K0 937 086 T
   Bauteil: BCM PQ35 M    122 0183
   Revision: BC122001
   Codierung: 60590A3B892508C4508800C8B400897403D50008676D2DB26484C720A2C1
   Betriebsnr.: WSC 00020 790 00000
   VCID: 45D6A6ADB5A4107FEDB-8010
   Subsystem 1 - Teilenummer SW: 7N1 955 119 B    HW: 7N1 955 119 B  Labeldatei: DRV\1KX-955-119.CLB
   Bauteil: WWS428 110715  024 0644
   Seriennummer: 15070906072131
   Codierung: 004DBD
   Subsystem 2 - Teilenummer SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labeldatei: DRV\5Q0-955-547.CLB
   Bauteil: RLHS  037 0059
   Seriennummer: S2Y15M09D08H00M15S01
   Codierung: 0228BB
Adresse 10: Einparkhilfe 2 (J791)       Labeldatei:| DRV\5Q0-919-294.clb
   Teilenummer SW: 1K8 919 472 B    HW: 5Q0 919 294 A
   Bauteil: PARKHILFE 8K  H03 0479
   Revision: --------    Seriennummer: 39331524102160
   Codierung: 0071155211
   ASAM Datensatz: EV_EPHVA18VW364GP00 001006
   VCID: 3634D161F8C28BE7741-8062
Adresse 13: Distanzregelung (J428)       Labeldatei:| DRV\7N0-907-572.clb
   Teilenummer SW: 7N0 907 572 B    HW: 7N0 907 572
   Bauteil: ACC Bosch PQx H03 0120
   Seriennummer: 17111577091554
   Codierung: 00001900FE0739
   ASAM Datensatz: EV_ACCBEGVW361 001005
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: 3536D66DE5C480FF7DB-8060
1 Fehler gefunden:
1058 - Datenbus empfangener Fehlerwert
          U1123 00 [009] - -
          [FAULT_CIS_ECD_NOTAVAILABLE]
          bestätigt - geprüft seit letzter Löschung
             Umgebungsbedingungen:
                    Fehlerstatus: 00000001
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 23
                    Kilometerstand: 151470 km
                    Datum: 2019.07.08
                    Zeit: 20:48:38
                    Steuergerätetemperatur: 35 °C
                    Spannung Klemme 15: 12.2 V
                    Fahrzeuggeschwindigkeit: 0.00 m/s
                    Beschleunigung: 0.00 m/s²
Adresse 15: Airbag (J234)       Labeldatei:| DRV\5K0-959-655.clb
   Teilenummer SW: 7N0 959 655 D    HW: 7N0 959 655 D
   Bauteil: VW10Airbag10X H15 0016
   Seriennummer: 003PWPHJML0Z
   Codierung: 003058
   ASAM Datensatz: EV_AirbaVW10TS6VW428 A01010
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 40D8B7B9AA063557DED-8014
   Subsystem 1 - Teilenummer SW: ---            HW: ---
   Bauteil: S.Sens.Fahr.V  --- ---
   Seriennummer: 3493ETS60DA6FB11B9DE
   Codierung: 000000
   Subsystem 2 - Teilenummer SW: ---            HW: ---
   Bauteil: S.Sens.Beif.V  --- ---
   Seriennummer: 3503ETS605DEDB41B9DA
   Codierung: 000000
   Crashsensor für Seitenairbag hinten Fahrerseite:
   Subsystem 3 - Teilenummer SW: ---            HW: ---
   Bauteil: S.Sens.Fahr.H  --- ---
   Seriennummer: 3513ETS600D8BB21B9D$
   Codierung: 000000
   Crashsensor für Seitenairbag hinten Beifahrerseite:
   Subsystem 4 - Teilenummer SW: ---            HW: ---
   Bauteil: S.Sens.Beif.H  --- ---
   Seriennummer: 3523ETS60B5E7B11B9D1
   Codierung: 000000
   Subsystem 5 - Teilenummer SW: ---            HW: ---
   Bauteil: F.Sens.Fahr  --- ---
   Seriennummer: 35540TS6094A8A31BDDX
   Codierung: 000000
Adresse 16: Lenkradelektronik (J527)       Labeldatei:| DRV\5K0-953-569.clb
   Teilenummer SW: 5K0 953 501 DQ    HW: 5K0 953 569 AP
   Bauteil: LENKS.MODUL   016 0180
   Revision: FF010042    Seriennummer: 20150902100965
   Codierung: 3112A40000
   ASAM Datensatz: EV_VW360SteerWheelUDS A03004
   VCID: 7CA00349866E91B7C25-8028
   Steuergerät für Multifunktionslenkrad:
   Subsystem 1 - Teilenummer SW: 7N5 919 719     HW: 7N5 919 719   Labeldatei: DRV\3C8-959-537.CLB
   Bauteil: E221__MFL-PR6  H04 0130
   Seriennummer: 000000000B0049300715
   Codierung: 011000
Adresse 17: Schalttafeleinsatz (J285)       Labeldatei:| DRV\5K0-920-xxx-17.clb-SRI1
   Teilenummer SW: 7N5 920 880 A    HW: 7N5 920 880 A
   Bauteil: KOMBI         H04 1007
   Seriennummer: 00000000000000
   Codierung: 140F010000
   ASAM Datensatz: EV_Kombi_UDS_VDD_RM09 A05730
Adresse 18: Standheizung        Labeldatei: DRV\1K0-815-071.clb
   Teilenummer: 7N0 963 271 G
   Bauteil: Standheizer     051 3041
   Revision: 00051000    Seriennummer: 09028242000000
   Codierung: 0001042
   VCID: 3828DF59FE567D9766D-806C
1 Fehler gefunden:
02245 - Verbindung Funkfernbedienung
            004 - kein Signal/Kommunikation
                    Fehlerstatus: 01100100
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 23
                    Zeitangabe: 0
                    Datum: 2019.07.08
                    Zeit: 20:48:37
Adresse 19: Diagnoseinterface (J533)       Labeldatei:. DRV\7N0-907-530-V2.clb
   Teilenummer SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
   Bauteil: J533  Gateway H56 1663
   Revision:   H56       Seriennummer: 230815F1001301
   Codierung: 468232
   Betriebsnr.: WSC 00020 790 12345
   VCID: 72BC2D71D4AAD7C7989-8026
Adresse 25: Wegfahrsperre (J334)       Labeldatei:| DRV\5K0-920-xxx-25.clb
   Teilenummer SW: 5K0 953 234     HW: 5K0 953 234
   Bauteil: IMMO          H04 1007
   Seriennummer:
   Codierung: 000007
   ASAM Datensatz: EV_Immo_UDS_VDD_RM09 A03710
   VCID: 6A8C3511FCFA1F07209-803E
Adresse 2B: Lenksäulenverrieg. (J764)       Labeldatei:* DRV\5K0-905-861.clb
   Teilenummer SW: 5K0 905 861 C    HW: 5K0 905 861 C
   Bauteil: ELV-PQ35      H21 0240
   Revision: 00000000    Seriennummer: 15000190810005
   Codierung: 4900000000000000
   ASAM Datensatz: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3038E7791AA6A5D72ED-8064
Adresse 36: Sitzverst. Fahr. (J810)       Labeldatei: 3C0-959-760.lbl
   Teilenummer SW: 3C8 959 760 F    HW: 3C8 959 760 F
   Bauteil: Sitzmemory    H02 1301
   Revision: 00H02000
   Codierung: 000018
   Betriebsnr.: WSC 12336 024 394758
   VCID: 3828DF59F2567D9766D-806C
Adresse 3C: Spurwechsel (J1086)       Labeldatei:| DRV\5Q0-907-686.clb
   Teilenummer SW: 5Q0 907 686 B    HW: 5Q0 907 686 B
   Bauteil: HRE_Master    H11 0071
   Seriennummer: 0378307517
   Codierung: 02011102
   ASAM Datensatz: EV_HREntryHella 001028
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3C20C349C6EE51B7825-8068
   Steuergerät 2 für Spurwechselassistent:
   Subsystem 1 - Teilenummer SW: 5Q0 907 685 B    HW: 5Q0 907 685 B
   Bauteil: HRE_Slave  H11 0071
   Seriennummer: 0378415333
   Codierung: 020111
Adresse 42: Türelektr. Fahrer (J386)       Labeldatei:. 7N0-959-793.clb
   Teilenummer SW: 7N0 959 793 J    HW: 7N0 959 793 G
   Bauteil: TSG FA        H04 0561
   Revision:             Seriennummer: 0000163734024
   Codierung: 01112F209E00411001
   VCID: 49CEAA9D99BCF41F093-801C
Adresse 44: Lenkhilfe        Labeldatei: DRV\5N1-909-144.clb
   Teilenummer SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Bauteil: J500__APA-BS KL.325 1401
   Revision: 1BH04739    Seriennummer: 00152040223701
   Codierung: 0000258
   VCID: 41DEB2BDAD8C3C5FD13-8014
Adresse 4F: Zentralelektrik II (J520)       Labeldatei:. DRV\1K0-907-532.clb
   Teilenummer SW: 7N0 907 532     HW: 7N0 907 530 AN
   Bauteil: EZE_2         H56 1663
   Codierung: 050B0501
   VCID: 6FBA2405C798FA2F777-803A
   Subsystem 1 - Teilenummer SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Bauteil: J245EE04SKB03  H04 0090
   Seriennummer: 0123456789ABCDEFGHIJ
   Subsystem 2 - Teilenummer SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Bauteil: J394EE04SKB03  H04 0090
Adresse 52: Türelektr. Beifahr. (J387)       Labeldatei:. 7N0-959-792.clb
   Teilenummer SW: 7N0 959 792 J    HW: 7N0 959 792 G
   Bauteil: TSG BF        H04 0561
   Revision:             Seriennummer: 0000163681524
   Codierung: 01112D209E00411001
   VCID: 48C8AF9982B60D1716D-801C
Adresse 55: Leuchtweitenreg. (J745)       Labeldatei:. DRV\5M0-907-357-V3.clb
   Teilenummer SW: 5M0 907 357 F    HW: 7L6 907 357 C
   Bauteil: AFS-ECU       H05 0111
   Revision: --------    Seriennummer: --------------
   Codierung: 068200000B000000
   ASAM Datensatz: EV_HeadlRegulVWAFSPt 002016
   Subsystem 1 - Teilenummer: 1T0 941 329 B  Labeldatei: 3D0-941-329.CLB
   Subsystem 2 - Teilenummer: 1T0 941 329 B  Labeldatei: 3D0-941-329.CLB
Adresse 5F: Informationselek. I (J794)       Labeldatei:| DRV\5F0-035-MIB-STD2.clb
   Teilenummer SW: 7N5 035 680 B    HW: 7N5 035 680 B
   Bauteil: MU-S-N-ER     H20 0240
   Seriennummer: SEZAZ2R0241952
   Codierung: 04240801FF00000011110001000808001F0100840020010086
   ASAM Datensatz: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 323CED7114AA97C7589-8066
   Datenträger:
   Subsystem 1 - Teilenummer SW: 5F0 060 884 BN    HW: -----------
   Bauteil: ECE AS 19/20  --- 1115
   Seriennummer: --------------------
Adresse 61: Batterieregelung (J840)       Labeldatei:. DRV\1K0-907-534.clb
   Teilenummer SW: 7N0 907 534     HW: 7N0 907 530 AN
   Bauteil: Batt.regelung H56 1663
   Codierung: 030F7873
   VCID: 71BE227DD1ACECDF613-8024
   Subsystem 1 - Teilenummer SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Bauteil: J367-BDM  H07 0180
   Seriennummer: 42242M55401491566675
Adresse 62: Türelektr. hi. li. (J388)       Labeldatei:. 7N0-959-794.clb
   Teilenummer SW: 7N0 959 794 L    HW: 7N0 959 794 H
   Bauteil: TSG HL        H02 0561
   Revision:             Seriennummer: 0000163856216
   Codierung: 01006D200000411001
   VCID: 4CC0938996CEE137325-8018
Adresse 69: Anhänger (J345)       Labeldatei:. DRV\7N0-907-383.clb
   Teilenummer SW: 7N0 907 383     HW: 7N0 907 383
   Bauteil: Anhaenger     H09 0101
   Revision: 3I001002    Seriennummer: 00008130005327
   Codierung: 410C040001000000
   Betriebsnr.: WSC 00049 770 00119
   VCID: 73B22875ABB0DECF93F-8026
Adresse 6C: Rückfahrkamera (J772)       Labeldatei:| 5Q0-907-441.clb
   Teilenummer SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Bauteil: VW428 RVC Mid H04 0040
   Codierung: 012408012301000700
   ASAM Datensatz: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAVW428.rod
Adresse 6D: Heckklappe (J605)       Labeldatei:| DRV\7N0-959-107.clb
   Teilenummer SW: 7N0 959 107 G    HW: 7N0 959 107 A
   Bauteil: HDSG-Modul    H11 0250
   Revision: 41011001    Seriennummer: 222500791
   Codierung: 0733334002
   ASAM Datensatz: EV_HDSGVW428 201138
   ROD: EV_HDSGVW428_VW36.rod
   VCID: 3B22C055C3E0568F8BF-806E
Adresse 72: Türelektr. hi. re. (J389)       Labeldatei:. 7N0-959-794.clb
   Bauteil: TSG HR        H02 0561
   Revision:             Seriennummer: 0000163856444
Adresse A5: Front-/Vorfeldkamera (R242)       Labeldatei:| DRV\3Q0-980-65X-A5.clb
   Teilenummer SW: 3Q0 980 654     HW: 3Q0 980 654
   Bauteil: MQB_B_MFK     H04 0010
   Seriennummer: 24081511P10705
   Codierung: 0304020800000401002613068080400090000E100020
   ASAM Datensatz: EV_MFKBoschMQBB 001001
Adresse BE: Schiebetür hinten links (J558)       Labeldatei: 7N0-959-244.clb
   Teilenummer SW: 7N0 959 244 B    HW: 7N0 959 244 B
   Bauteil: Schiebetuer_l 005 2414
   Seriennummer: 15334958
   ASAM Datensatz: EV_AST A03704
   ROD: EV_AST.rod
   VCID: 3828DF59F2D67D9766D-806C
Adresse BF: Schiebetür hinten rechts (J731)       Labeldatei: 7N0-959-244.clb
   Bauteil: Schiebetuer_r 005 2414
   Seriennummer: 15335197
   ROD: EV_AST.rod
andy_911
Austria
C?ID=149628
The next question is, could it be possible to flash an other .sgo to the existing ABS module? Does anybody know what's the difference of the Hardware?
It would be much easier to help if you install the English version of VCDS (it can be installed in parallel with your German version) AND posted the FULL UNEDITED VCDS Auto-Scan (you have removed the important header above).
andy_911
Austria
C?ID=149628
Thanks a lot, I will do so in the evening ..... regards
andy_911
Austria
C?ID=149628
Here is the new, full Auto Scan in english.
Maybe can anybody help me with this information.
The fault Code Limited Visibility comes from the wrong Seat logo, because I did not get the right one until yet. I tested without Logo and the visibility fault code is not active.
Tuesday,09,July,2019,19:17:17:24421
VIN: VSSZZZ7NZGV708020   License Plate:
Mileage: 151490km-94131mi   Repair Order:
Chassis Type: 7N-VW36 (7N0)
VIN: VSSZZZ7NZGV708020   Mileage: 151490km-94131miles
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-CUWA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 CK    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 1737
   Revision: 8AH20---
   Coding: 011D001A047401083000
   Shop #: WSC 00020 999 12345
   ASAM Dataset: EV_ECM20TDI01104L906016CK 001004
   ROD: EV_ECM20TDI01104L906016BJ_001_VW36.rod
   VCID: 74B02B69AE3ED9F7DE1-8020
   Part No SW: 02E 300 063 C    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4902
   Revision: 06253104    Serial number: 00001507232976
   Shop #: WSC 44551 111 44551
   VCID: 167431E194826BE7005-8042
Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
   Part No SW: 5N0 614 109 CD    HW: 5N0 614 109 CD
   Component: ESC-EBC460iV1 H10 0012
   Serial number: A00WLIN
   Coding: 12F0449A0920C2740877480222C3904310391700F00B4895
   Shop #: WSC 00020 999 00000
   VCID: 6FBA2405C718FA2F233-803A
   Revision: 00092000    Serial number: 0375621325
   Coding: 03100C
   Shop #: WSC 00020 999 39850
   VCID: 372ADC65FFC872EF3B3-8062
   Part No SW: 7N0 907 044 AC    HW: 7N0 907 044 AC
   Component: Clima-Sharan  H02 0606
   Revision: 00001K04
   Coding: 021010C549
   VCID: 71BE227DD12CECDF357-8024
   Slave 1:
   Subsystem 1 - Part No SW: 7N0 907 049 C    HW: 7N0 907 049 C
   Component: KBT-H  004 0103
   Serial number: 20150817000000016318
   Part No SW: 5K0 937 086 T    HW: 5K0 937 086 T
   Component: BCM PQ35 M    122 0183
   Revision: BC122001
   Coding: 60590A3B892508C4508800C8B400897403D50008676D2DB26484C720A2C1
   Shop #: WSC 00020 790 00000
   VCID: 45D6A6ADB5A4107FB9F-8010
   Subsystem 1 - Part No SW: 7N1 955 119 B    HW: 7N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS428 110715  024 0644
   Serial number: 15070906072131
   Coding: 004DBD
   Component: RLHS  037 0059
   Serial number: S2Y15M09D08H00M15S01
   Coding: 0228BB
   Part No SW: 1K8 919 472 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0479
   Revision: --------    Serial number: 39331524102160
   Coding: 0071155211
   ASAM Dataset: EV_EPHVA18VW364GP00 001006
   VCID: 3634D161F8C28BE7205-8062
   Part No SW: 7N0 907 572 B    HW: 7N0 907 572
   Component: ACC Bosch PQx H03 0120
   Serial number: 17111577091554
   Coding: 00001900FE0739
   ASAM Dataset: EV_ACCBEGVW361 001005
   VCID: 3536D66DE5C480FF29F-8060
1058 - Databus
                    Reset counter: 23
                    Mileage: 151470 km
                    Date: 2019.07.08
                    Time: 20:48:38
                    Control Module temperature: 35 °C
                    Voltage terminal 15: 12.2 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1130 - Sensor for Automatic Distance Control
          [FAULT_SENSOR_NO_FREE_SIGHT]
                    Fault Priority: 9
                    Reset counter: 64
                    Mileage: 151482 km
                    Date: 2019.07.09
                    Time: 14:50:30
                    Control Module temperature: 26 °C
                    Voltage terminal 15: 12.3 V
1132 - Sensor for Automatic Distance Control
          [FAULT_SYSTEM_DISTURBED]
                    Fault Priority: 9
                    Reset counter: 23
                    Mileage: 151480 km
                    Date: 2019.07.09
                    Time: 14:23:42
                    Control Module temperature: 33 °C
                    Voltage terminal 15: 14.1 V
                    Vehicle speed: 18.77 m/s
                    Acceleration: -0.91 m/s²
1131 - Sensor for Automatic Distance Control
          [FAULT_SYSTEM_NO_FREE_SIGHT]
                    Fault Priority: 9
                    Reset counter: 64
                    Mileage: 151482 km
                    Date: 2019.07.09
                    Time: 14:50:30
1542 - Sensor for Automatic Distance Control
          [FAULT_SENSOR_BLIND]
                    Reset counter: 64
                    Mileage: 151480 km
                    Date: 2019.07.09
                    Time: 14:24:40
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 14.3 V
                    Vehicle speed: 10.68 m/s
                    Acceleration: 0.02 m/s²
1545 - Sensor for Automatic Distance Control
          [FAULT_SYSTEM_BLIND]
                    Reset counter: 64
                    Mileage: 151480 km
                    Date: 2019.07.09
                    Time: 14:24:40
   Part No SW: 7N0 959 655 D    HW: 7N0 959 655 D
   Component: VW10Airbag10X H15 0016
   Serial number: 003PWPHJML0Z
   Coding: 003058
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
   VCID: 40D8B7B9AA0635578A9-8014
   Subsystem 1 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.V  --- ---
   Serial number: 3493ETS60DA6FB11B9DE
   Subsystem 2 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.V  --- ---
   Serial number: 3503ETS605DEDB41B9DA
   Subsystem 3 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.H  --- ---
   Serial number: 3513ETS600D8BB21B9D$
   Subsystem 4 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.H  --- ---
   Serial number: 3523ETS60B5E7B11B9D1
   Subsystem 5 - Part No SW: ---            HW: ---
   Component: F.Sens.Fahr  --- ---
   Serial number: 35540TS6094A8A31BDDX
   Part No SW: 5K0 953 501 DQ    HW: 5K0 953 569 AP
   Revision: FF010042    Serial number: 20150902100965
   Coding: 3112A40000
   VCID: 7CA00349866E91B7961-8028
   Subsystem 1 - Part No SW: 7N5 919 719     HW: 7N5 919 719   Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000B0049300715
   Coding: 011000
   Part No SW: 7N5 920 880 A    HW: 7N5 920 880 A
   Component: KOMBI         H04 1007
   Coding: 140F010000
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 7N0 963 271 G
   Component: Standheizer     051 3041
   Revision: 00051000    Serial number: 09028242000000
   Coding: 0001042
   VCID: 3828DF59FE567D97329-806C
02245 - Connection; RF Remote Control
                    Reset counter: 23
                    Mileage: 151470 km
                    Date: 2019.07.08
                    Time: 20:48:37
   Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1663
   Revision:   H56       Serial number: 230815F1001301
   Coding: 468232
   Shop #: WSC 00020 790 12345
   VCID: 72BC2D71D4AAD7C7CCD-8026
   Component: IMMO          H04 1007
   Coding: 000007
   VCID: 6A8C3511FCFA1F0774D-803E
   Revision: 00000000    Serial number: 15000190810005
   Coding: 4900000000000000
   VCID: 3038E7791AA6A5D77A9-8064
   Part No SW: 3C8 959 760 F    HW: 3C8 959 760 F
   Component: Sitzmemory    H02 1301
   Revision: 00H02000
   Coding: 000018
   Shop #: WSC 12336 024 394758
   VCID: 3828DF59F2567D97329-806C
   Component: HRE_Master    H11 0071
   Serial number: 0378307517
   Coding: 02011102
   VCID: 3C20C349C6EE51B7D61-8068
   Component: HRE_Slave  H11 0071
   Serial number: 0378415333
   Coding: 020111
   Part No SW: 7N0 959 793 J    HW: 7N0 959 793 G
   Component: TSG FA        H04 0561
   Revision:             Serial number: 0000163734024
   Coding: 01112F209E00411001
   VCID: 49CEAA9D99BCF41F5D7-801C
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.325 1401
   Revision: 1BH04739    Serial number: 00152040223701
   Coding: 0000258
   VCID: 41DEB2BDAD8C3C5F857-8014
   Component: EZE_2         H56 1663
   Coding: 050B0501
   VCID: 6FBA2405C798FA2F233-803A
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
   Part No SW: 7N0 959 792 J    HW: 7N0 959 792 G
   Component: TSG BF        H04 0561
   Revision:             Serial number: 0000163681524
   Coding: 01112D209E00411001
   VCID: 48C8AF9982B60D17429-801C
   Component: AFS-ECU       H05 0111
   Coding: 068200000B000000
   Subsystem 1 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 7N5 035 680 B    HW: 7N5 035 680 B
   Component: MU-S-N-ER     H20 0240
   Serial number: SEZAZ2R0241952
   Coding: 04240801FF00000011110001000808001F0100840020010086
   VCID: 323CED7114AA97C70CD-8066
   Subsystem 1 - Part No SW: 5F0 060 884 BN    HW: -----------
   Component: ECE AS 19/20  --- 1115
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AN
   Component: Batt.regelung H56 1663
   Coding: 030F7873
   VCID: 71BE227DD1ACECDF357-8024
   Component: J367-BDM  H07 0180
   Serial number: 42242M55401491566675
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 L    HW: 7N0 959 794 H
   Component: TSG HL        H02 0561
   Revision:             Serial number: 0000163856216
   Coding: 01006D200000411001
   VCID: 4CC0938996CEE137661-8018
Address 69: Trailer (J345)       Labels:. 7N0-907-383.clb
   Part No SW: 7N0 907 383     HW: 7N0 907 383
   Component: Anhaenger     H09 0101
   Revision: 3I001002    Serial number: 00008130005327
   Coding: 410C040001000000
   Shop #: WSC 00049 770 00119
   VCID: 73B22875ABB0DECFC7B-8026
   Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Component: VW428 RVC Mid H04 0040
   Coding: 012408012301000700
   ASAM Dataset: EV_CamSysRearPANAVW428 002002
Address 6D: Trunk Elect. (J605)       Labels:| 7N0-959-107.clb
   Part No SW: 7N0 959 107 G    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0250
   Revision: 41011001    Serial number: 222500791
   Coding: 0733334002
   ASAM Dataset: EV_HDSGVW428 201138
   VCID: 3B22C055C3E0568FDFB-806E
Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
   Component: TSG HR        H02 0561
   Revision:             Serial number: 0000163856444
   Part No SW: 3Q0 980 654     HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0010
   Serial number: 24081511P10705
   Coding: 0304020800000401002613068080400090000E100020
Address BE: Slid. Door Rear Left (J558)       Labels: 7N0-959-244.clb
   Part No SW: 7N0 959 244 B    HW: 7N0 959 244 B
   Component: Schiebetuer_l 005 2414
   Serial number: 15334958
   ASAM Dataset: EV_AST A03704
   ROD: EV_AST.rod
   VCID: 3828DF59F2D67D97329-806C
Address BF: Slid. Door Rear Right (J731)       Labels: 7N0-959-244.clb
   Component: Schiebetuer_r 005 2414
   Serial number: 15335197
   ROD: EV_AST.rod
End----------(Elapsed Time: 02:10, VBatt start/end: 12.3V/12.4V)-----------
andy_911
Austria
C?ID=149628
Now I tried the 5N0614109CK ABS Module, and the one fault Code in the ACC is gone (but there are 100 others ;-))
I think, the Problem is really the ABS
Now I Need new rear ABS sensors, thats not a realy big Problem.
BUT, can anyone help me by the CODING of the new ABS Module??
The coding is normaly done by SVM, and the old coding doesnt work.
This is the new Autoscan with the used ABS Module connected ….
Friday,12,July,2019,20:34:38:24421
Mileage: 151530km-94156mi   Repair Order:
VIN: VSSZZZ7NZGV708020   Mileage: 151530km-94156miles
   Revision: 8AH20---
4815 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [167] - -
          [ABS brake control moduleRead out DTC]
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:45
                    Coolant temperature: 32 °C
                    Intake air temperature: 31 °C
                    Ambient air pressure: 960 mbar
                    Voltage terminal 30: 12.280 V
                    Requested transmission torque: 1000.0 Nm
                    Limitation: accelerator pedal: 126.6 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    selected gear-Bits 0-7: 0
                    Transmission torque intervention status-Bits 0-7: 80
                    Transmission torque intervention status-Bits 0-7: 0
                    Calculated reducing transmission intervention torque: 1000.0 Nm
14413 - Implausible Data Received from ABS Control Module
          U0415 00 [039] - -
          [Invalid Data Received FromAnti-Lock Brake System Control Module]
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:45
                    Voltage terminal 30: 12.300 V
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:45
                    Longitudinal acceleration: raw value: 32.767 m/s²
                    Vehicle inclination acceleration angle: raw value: 2.452 m/s²
                    Status: incline angle-Bits 0-7: 0
                    Longitudinal acceleration: 0.000 m/s²
                    Longitudinal acceleration sensor: status-Bits 0-7: 1
                    Vehicle lateral acceleration: raw value: 327.67 g
                    Vehicle lateral acceleration: 0.00 g
   Part No SW: 5N0 614 109 CG    HW: 5N0 614 109 CK
   Component: ESC-EBC460iV1 H10 0013
   Serial number: A01BURS
   Coding: 000000000000000000000000000000000000000000000000
   VCID: 72BC2D71D42AD7C7CCD-8026
8 Faults Found:
0388 - Rear Left Wheel Speed Sensor
          C101C 4A [137] - Incorrect component(s) installed
                    Reset counter: 27
                    Date: 2019.07.12
                    Time: 00:09:48
                    Additional_Codes: 00 00 00 0C 49 1E 00 0B 0A
                    DTC: 00 01 84
                    Additional2: 00 06 01 02 05 22 E1 00 E1 00
0389 - Rear Right Wheel Speed Sensor
          C101D 4A [137] - Incorrect component(s) installed
                    Reset counter: 27
                    Date: 2019.07.12
                    Time: 00:09:47
                    Additional_Codes: 00 00 00 0C 41 1E 00 0A 0A
                    DTC: 00 01 85
                    Additional2: 02 06 01 02 05 22 E1 00 E1 00
0773 - TPMS Display
          C1146 F2 [136] - EEPROM Malfunction
                    Reset counter: 67
                    Date: 2019.07.12
                    Time: 00:09:43
                    Additional_Codes: 00 00 00 0C 50 1E 00 0F 0A
                    DTC: 00 03 05
                    Additional2: 02 0B 01 02 05 22 E2 00 E2 00
0383 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
0360 - Steering angle sensor
0408 - Control Module
          C104A F0 [137] - Incorrect VIN
0522 - Inertial Sensor Package
          C115E 54 [137] - Missing Calibration / Basic Setting
0559 - No Basic Setting
          B2010 00 [137] - -
          [PBC_EVENT_PBC_IN_ASSEMBLY_MODE]
                    Reset counter: 27
                    Date: 2019.07.12
                    Time: 00:09:43
                    Additional_Codes: 00 00 00 0C 49 1E 00 0F 0A
                    DTC: 00 02 2F
                    Additional2: 02 01 01 02 05 22 E2 00 E2 00
   Coding: 03100C
   Revision: 00001K04
   Coding: 021010C549
   Slave 1:
   Revision: BC122001
   Coding: 004DBD
   Coding: 0228BB
   Coding: 0071155211
13688835 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:48
9 Faults Found:
1070 - Databus
          [FAULT_CIS_AXV_FAIL]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:43
                    Voltage terminal 15: 12.1 V
1064 - Databus
          [FAULT_CIS_BPRESSURE_FAIL]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:43
1058 - Databus
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:52
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:52
1544 - Function restriction
          C10C2 00 [008] - -
          [FAULT_REFERENCE_VELOCITY_NOT_AVAILABLE]
                    Reset counter: 67
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:43
                    Vehicle speed: 0.63 m/s
                    Acceleration: 0.27 m/s²
1043 - Automatic Distance Control
          B10E7 F0 [009] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:52
1118 - Databus
          [FAULT_CIS_WHEEL_PULSE_FAIL]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:43
1081 - Databus
          [FAULT_CIS_WHEEL_RPM_FAIL]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:43
1074 - Databus
          [FAULT_CIS_YAW_FAIL]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:43
   Coding: 003058
   Coding: 3112A40000
   Coding: 011000
   Coding: 140F010000
   Coding: 0001042
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:41
   Coding: 468232
   Coding: 000007
   Revision: 00H02000
   Coding: 000018
   Coding: 02011102
   Coding: 020111
337664 - Databus
          [mBremse_5::BR5_Sta_Gierrate- no signal/no communication]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:43
337888 - Databus
          [mBremse_10::B10_QB_Wegimp_HL - Ersatz_Init_oder_Fehlerwert]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:48
337904 - Databus
          [mBremse_10::B10_QB_Wegimp_HR - Ersatz_Init_oder_Fehlerwert]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:47
   Coding: 0000258
01316 - ABS Control Module
                    Fault Status: 11101101
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:41
                        Term 15 On
                    (no units): 4.0
                    Voltage: 12.20 V
   Coding: 050B0501
13705985 - Databus
          [Fehlerwert im Signal BR3_Rad_kmh_HL]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:48
13705987 - Databus
          [Fehlerwert im Signal BR3_Rad_kmh_HR]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:47
   Coding: 030F7873
13706048 - Databus
          [Undervoltage or Errorvalue-monitoring mBremse_10.B10_Wegimp_HL]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:47
                    passive
13706049 - Databus
          [Undervoltage or Errorvalue-monitoring mBremse_10.B10_Wegimp_HR]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:47
                    passive
   Coding: 0733334002
0280 - Databus
          [mBremse_2_BR2_Querbeschl_Qbit]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:44
                    Control Module temperature: 30 °C
                    Outside air temperature: 23.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 494.4 s
                    Voltage terminal 15: 12.0 V
                    mid: 02 CC
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
0290 - Databus
          [mBremse_3_BR3_Rad_kmh_HL]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:48
                    System run time: 498.8 s
                    mid: 02 D3
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
0289 - Databus
          [mBremse_3_BR3_Rad_kmh_HR]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:48
                    System run time: 498.6 s
                    mid: 02 D4
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
0034 - Databus
          [mBremse_5_BR5_Bremsdruck]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:44
                    System run time: 494.3 s
                    mid: 02 D0
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
0032 - Databus
          [mBremse_5_BR5_Giergeschw]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:44
                    mid: 02 D1
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
0033 - Databus
          [mBremse_8_BR8_Laengsbeschl_Qbit]
                    Reset counter: 27
                    Mileage: 151539 km
                    Date: 2019.07.12
                    Time: 00:09:44
                    mid: 02 DA
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 0
                    Software_Info_1: 0
   ROD: EV_AST.rod
   ROD: EV_AST.rod
End----------(Elapsed Time: 02:23, VBatt start/end: 12.3V/12.3V)-----------
It would be great, if anyone could help me to come to the next step at the Project :-)
Is the -CG an appropriate replacement for the -CD?
What error message do you get when "coding doesnt work"?
andy_911
Austria
C?ID=149628
The CG ABS Unit is one from a car with acc, and the same model year, therefore I thought I'll try this one first.
The error message I get is coding rejected!
Is there any way to get coding Information of the ABS unit, because the Long coding helper says, coding is normaly done by svm.
Spacewalker
C?ID=159607
CG not accept genuine coding from CD ?
andy_911
Austria
C?ID=149628
The CG ABS doesn't accept the original coding, thats right. Would it be neccessary to enter a login before coding? The coding of the used CG ABS was empty (00000000000000000.....) when I read it out the first time after I connected it to the car - is this a normal thing? I thought i would see the old coding from the spender car with ACC.
downtime
C?ID=280813
ABS loses it's coding the second it is fired up on a car with different VIN.
The ABS coding contains parts of the cars VIN in it so copying a code from another car won't work. And you cannot go the official SVM as the factory will not probably accept the ABS block as it's not been installed to your car officially and it's not the official replacement part.
andy_911
Austria
C?ID=149628
Thank's for your answer, but copying the code from the original ABS doesn't work too! Why? In the original coding should be the right VIN.
downtime
C?ID=280813
Is the new ABS blocks byte size exactly the same? Also ESP100 and IPB ABS modules have different formulation of ABS coding. Means the bytes have different meaning.
Also to make things more fun, the abs coding has part of the coding as checksum bytes. Means for example that byte 3 has byte 11 as checksum byte. If you change byte 3, you need also change byte 11 accordingly so that it matches.
dnoermann
C?ID=358118
Normly you should be abel to copy your coding to the new ABS.
VIN Info will be the same, if the new ABS does have the same coding for VIN.
Since you posted your original old config and the new empty, i see:
Coding
Old: 12F0449A0920C2740877480222C3904310391700F00B4895
New: 000000000000000000000000000000000000000000000000
ABS-Type
Old: ESC-EBC460iV1 H10 0012
New: ESC-EBC460iV1 H10 0013
Coding is is the same Size
And Type is Identical
So it should work.
Login is not needed for coding ABS, it is only needed for "Grundeinstellung" and i think that is done after coding.
Are you abel to get the original coding from the "NEW" abs. We can try to change the VIN there, and work from that coding on ...
Ore try a different tool for coding.
I searched month for a strange error in my setup, because ECU coding did not work with VCDS.
After i tried it with VCP, it just worked ....
In general i like to get in contact to your russian friend, to solve my own SWAP issue, i myself have to deal with a similar problem with my T5 ACC retrofit.
downtime
C?ID=280813
Based on that, the coding should be valid.
One thing that comes to mind is that if the latter ABS block is for ACC and the original is for normal cruise. Maybe the new one does not accept the cruise control coding. You would need to change it to ACC coding.
andy_911
Austria
C?ID=149628
Unfortunately I don't have the coding from spender car, only the VIN.
I have only from an other similar car (but no automatic, ....) with ACC an autoscan. Does anyone think that could help?
I have the VCP tool, but I did not try to code the ABS until yet - it's a good idea!
The problem is, that it is not so easy to connect the new ABS and the car is needed. I will try next week with vcp.
The magic work with the SwaP can be done by VAGserp. The only thing is, it's not for free ;-)
andy_911
Austria
C?ID=149628
Here the Autoscan from a car with ACC, and same as new ABS
Freitag,12,April,2019,17:45:08:24421
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x64
VCDS Version: DRV 18.9.0.2  HEX-V2 CB: 0.4436.4
Datenstand: 20181017 DS296.0
www.Ross-Tech.de
Fahrzeug-Ident.-Nr.: WVWZZZ7NZGV245291   KFZ-Kennzeichen:
Kilometerstand: 61880km   Reparaturauftrag:
Scan: 01 03 08 09 10 13 15 16 17 18 19 25 42 44 46 4C 52 53 55 5F
          61 62 6D 72 A5 BE BF
Fahrzeug-Ident.-Nr.: WVWZZZ7NZGV245291   Kilometerstand: 61880km
18-Standheizung -- Status: Fehler 1010
19-Diagnoseinterface -- Status: Fehler 0010
55-Leuchtweitenreg. -- Status: Fehler 0010
Adresse 01: Motorelektronik (J623-DFLA)       Labeldatei:. DRV\04L-907-309-V1.clb
   Teilenummer SW: 04L 906 016 HD    HW: 04L 907 309 K
   Bauteil: R4 2,0L EDC   H20 1623
   Revision: 8AH20---
   Codierung: 0119001A044411082000
   ASAM Datensatz: EV_ECM20TDI01104L906016HD 001003
   ROD: EV_ECM20TDI01104L906016HD_001.rod
   VCID: 72BC2D71D42AD7C7981-8026
1 Fehler gefunden:
25147 - Ansteuerung für Pumpe 1 für Reduktionsmittel
          P208B 00 [096] - unplausibles Signal
          Sporadisch - unbestätigt - geprüft seit letzter Löschung
   Teilenummer SW: 5N0 614 109 CG    HW: 5N0 614 109 CG
   Bauteil: ESC-EBC460iV1 H10 0013
   Seriennummer: A0165DQ
   Codierung: 12F0449A0924C2710879480922C49043103117F400014084
   Teilenummer SW: 7N0 907 044 AN    HW: 7N0 907 044 AN
   Bauteil: Clima-Sharan  H03 0606
   Revision: 00001K05
   Codierung: 021000C449
   VCID: 7CA00349866E91B7C2D-8028
   Revision: BC122001
   Codierung: 60590A3B812508C4508800C89400117403D50008626D2D22E480872000C9
   VCID: 45D6A6ADB5A4107FED3-8010
   Bauteil: WWS428 060416  024 0644
   Seriennummer: 16040403012361
   Codierung: 004DBD
   Seriennummer: S5Y16M05D11H08M14S40
   Codierung: 0228BB
   Revision: --------    Seriennummer: 39331613302719
   Codierung: 0031051001
   VCID: 3634D161F8C28BE7749-8062
   Seriennummer: 01051604400704
   Codierung: 00000100FE0739
   VCID: 3536D66DE5C480FF7D3-8060
   Seriennummer: 003PWP8T7JW8
   Codierung: 003058
   VCID: 40D8B7B9AA063557DE5-8014
   Seriennummer: 3493ETS6033A27E1CDD2
   Codierung: 000000
   Seriennummer: 3503ETS604605781CDDS
   Codierung: 000000
   Seriennummer: 3513ETS603AA27E1CDD2
   Codierung: 000000
   Seriennummer: 3523ETS602AEC771C9D5
   Codierung: 000000
   Seriennummer: 35540TS600BF0921C9DN
   Codierung: 000000
   Teilenummer SW: 5K0 953 501 CP    HW: 5K0 953 569 AK
   Revision: FF010042    Seriennummer: 20160511201173
   Codierung: 1182C40008
   VCID: 7AAC05518C5AAF87D01-802E
   Subsystem 1 - Teilenummer SW: 6C0 959 442 B    HW: 6C0 959 442 B  Labeldatei: DRV\3C8-959-537.CLB
   Bauteil: E221__MFL-TAT  H06 0023
   Seriennummer: 1021615230501665AF2B
   Codierung: 2C0000
   Teilenummer SW: 7N0 920 870 N    HW: 7N0 920 870 N
   Bauteil: KOMBI         H04 1008
   VCID: 3D26CE4DDDF458BFB53-8068
   Codierung: 0001042
   VCID: 3828DF59FE567D97665-806C
1 Fehler gefunden:
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 42
                    Verlernzähler: 28
                    Kilometerstand: 58767 km
                    Zeitangabe: 0
                    Datum: 2019.02.21
                    Zeit: 14:00:37
   Teilenummer SW: 7N0 907 530 BG    HW: 7N0 907 530 AN
   Bauteil: J533  Gateway H56 1673
   Revision:   H56       Seriennummer: 080516F1000783
   Codierung: 468032
   VCID: 76B41161B8C2CBE7B49-8022
1 Fehler gefunden:
01207 - Steuergerät für Zusatzheizung (J364)
            004 - kein Signal/Kommunikation - Sporadisch
                    Fehlerstatus: 00110100
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 2
                    Verlernzähler: 54
                    Kilometerstand: 60421 km
                    Zeitangabe: 0
                    Datum: 2019.03.03
                    Zeit: 16:16:25
   Bauteil: IMMO          H04 1008
   Seriennummer:
   Codierung: 000000
   VCID: 6A8C3511FCFA1F07201-803E
   Teilenummer SW: 7N0 959 793 H    HW: 7N0 959 793 F
   Bauteil: TSG FA        H05 0561
   Revision:             Seriennummer: 0000198560160
   Codierung: 01102F208000411011
   VCID: 47CAACA58FA8026F1FF-8012
   Teilenummer SW: 5N1 909 144 S    HW: 5N1 909 148 K
   Bauteil: J500__APA-BS KL.324 1501
   Revision: 1BH04740    Seriennummer: 00161030263701
   Codierung: 0000258
   VCID: 42DCBDB1A88A2747C81-8016
   Teilenummer SW: 7N0 959 792 H    HW: 7N0 959 792 F
   Bauteil: TSG BF        H05 0561
   Revision:             Seriennummer: 0000198570798
   Codierung: 01102D208000411011
   VCID: 46D4A1A188A21B67E49-8012
   Codierung: 058200104F000200
   VCID: 372ADC65FFC872EF6FF-8062
   Subsystem 1 - Teilenummer: 1T0 941 329 A  Labeldatei: 3D0-941-329.CLB
   Subsystem 2 - Teilenummer: 1T0 941 329 A  Labeldatei: 3D0-941-329.CLB
1 Fehler gefunden:
13705995 - Datenbus empfangener Fehlerwert
          U1123 00 [008] - -
          [Fehlerwert im Signal FDD_Funktionsstatus]
          Sporadisch - bestätigt - geprüft seit letzter Löschung
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 2
                    Verlernzähler: 59
                    Kilometerstand: 59588 km
                    Datum: 2019.02.26
                    Zeit: 07:14:00
Adresse 5F: Informationselek. I (J794)       Labeldatei:| 5G0-035-MIB-STD2.clb
   Teilenummer SW: 5C0 035 680 B    HW: 5C0 035 680 B
   Bauteil: MU-S-N-ER     H22 0245
   Seriennummer: VWZAZ2S5096985
   Codierung: 02240801FF00000011110001000808001F0100C4002001008F
   VCID: 201817394A461557BE5-8074
   Datenträger:
   Subsystem 1 - Teilenummer SW: 3G0 919 866 BC    HW: -----------
   Bauteil: ECE1 2017/18  --- 0820
   Bauteil: Batt.regelung H56 1673
   Codierung: 030F7873
   VCID: 71BE227DD1ACECDF61B-8024
   Seriennummer: 43127048071491101806
   Bauteil: TSG HL        H03 0561
   Revision:             Seriennummer: 0000198284840
   VCID: 4CC0938996CEE13732D-8018
   Revision: 41011001    Seriennummer: 109600017
   VCID: 3B22C055C3E0568F8B7-806E
   Bauteil: TSG HR        H03 0561
   Revision:             Seriennummer: 0000198287279
   Teilenummer SW: 3Q0 980 654 C    HW: 3Q0 980 654
   Bauteil: MQB_B_MFK     H04 0023
   Seriennummer: 02051611K11151
   Codierung: 0004020800000401002613048080400010000E100040
   Seriennummer: 16188135
   ROD: EV_AST.rod
   VCID: 3828DF59F2D67D97665-806C
   Seriennummer: 16186851
   ROD: EV_AST.rod
Ende--(Dauer: 01:39, Batt.-Spannung Start/Ende: 11.9V/11.9V. VIgn 11.8V)---
dnoermann
C?ID=358118
You have to gather more Scans and compare them.
Here is a list of what i found:
WVWZZZ7NZGV224770 ACC   5N0 614 109 CG 12F0449A4922C270087E480722C3924310314FF400014084
VSSZZZ7NZGV708020 NoACC 5N0 614 109 CD 12F0449A0920C2740877480222C3904310391700F00B4895
WVWZZZ7NZJV008092 ACC   5N0 614 109 CM 12F0449A0920C2740877480922C59043103917F800014884
VIN Unknown 7N0   ACC   5N0 614 109 CG 12F0449A2922426F087A480322C89442103913F8F00B4893
WVWZZZ7NZHV218426 ACC   5N0 614 109 CG 11F0469AA921C274087B880262C99543103913F800014881
WVWZZZ7NZGV245291 ACC   5N0 614 109 CG 12F0449A0924C2710879480922C49043103117F400014084
I can tell you that the Last 5 Digits of VIN are codes in Bytes 5,7,9,11,13 of the coding, with some simple Coding :)
So copy them and try to find the difference.
From my analysis of other ABS, the ACC coding is somewhere @ the End, and this coding is not redundant in two different bytes, like other settings.
Looking deeper into it i would propose that ACC Coding is done in Byte 19.
I Assume:
00 no ACC
F4 means Manual Gearbox with ACC
F8 Automatic Gearbox with ACC
