Hello @ all,
I started to retrofit ACC to a 2016 Seat Alhambra!
To retrofit the sensor and the cabeling was very easy, component protection was no problem too - the Seat workshop was able to disable component protection easily!
A "russian friend" did the thing with the SWAP code - it took him 15 minutes.
Now I had to wait for 2 month, to get the right ACC/GRA switch (because the VW Sharan has the buttons on the steerig Wheel).
Now there is still one fault code in the ACC module.
I think that I'll have to change the ABS too - but I don't know what part number is the right one for my car?!
there are About 15 different ABS modules for that modell year. The only difference betweent the part numbers is PR-8T0, PR-8T2 vs. PR-8T3, PR-8T5 (GRA vs. ACC)!
Could it work with the part number 5N0614109CK, what is from a car without automatic transmission?
And what will be the correct CODING??
Here you can see the actual autoscan with ACC:
Fahrzeugtyp: 7N-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 25 2B 36 3C 42 44 46
4C 4F 52 53 55 5F 61 62 69 6C 6D 72 A5 BE BF
Fahrzeug-Ident.-Nr.: VSSZZZ7NZGV708020 Kilometerstand: 151470km
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
18-Standheizung -- Status: Fehler 0010
19-Diagnoseinterface -- Status: i.O. 0000
25-Wegfahrsperre -- Status: i.O. 0000
2B-Lenksäulenverrieg. -- Status: i.O. 0000
36-Sitzverst. Fahr. -- Status: i.O. 0000
3C-Spurwechsel -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
46-Komfortsystem -- Status: i.O. 0000
4C-Reifendruck II -- Status: i.O. 0000
4F-Zentralelektrik II -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
53-Feststellbremse -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
61-Batterieregelung -- Status: i.O. 0000
62-Türelektr. hi. li. -- Status: i.O. 0000
69-Anhänger -- Status: i.O. 0000
6C-Rückfahrkamera -- Status: i.O. 0000
6D-Heckklappe -- Status: i.O. 0000
72-Türelektr. hi. re. -- Status: i.O. 0000
A5-Front-/Vorfeldkamera -- Status: i.O. 0000
BE-Schiebetür hinten links -- Status: i.O. 0000
BF-Schiebetür hinten rechts -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CUWA) Labeldatei:. DRV\04L-907-309-V1.clb
Teilenummer SW: 04L 906 016 CK HW: 04L 907 309 K
Bauteil: R4 2,0L EDC H20 1737
Revision: 8AH20---
Codierung: 011D001A047401083000
Betriebsnr.: WSC 00020 999 12345
ASAM Datensatz: EV_ECM20TDI01104L906016CK 001004
ROD: EV_ECM20TDI01104L906016BJ_001.rod
VCID: 74B02B69AE3ED9F78A5-8020
Adresse 02: Getriebe Labeldatei: DRV\02E-927-770.clb
Teilenummer SW: 02E 300 063 C HW: 02E 927 770 AL
Bauteil: GSG DSG AG6 531 4902
Revision: 06253104 Seriennummer: 00001507232976
Codierung: 0000020
Betriebsnr.: WSC 44551 111 44551
VCID: 167431E194826BE7541-8042
Adresse 03: Bremsenelektronik (J104) Labeldatei: DRV\5N0-614-109-V1.clb
Teilenummer SW: 5N0 614 109 CD HW: 5N0 614 109 CD
Bauteil: ESC-EBC460iV1 H10 0012
Seriennummer: A00WLIN
Codierung: 12F0449A0920C2740877480222C3904310391700F00B4895
Betriebsnr.: WSC 00020 999 00000
ASAM Datensatz: EV_Brake1ESCEPBTRW 006353
ROD: EV_Brake1ESCEPBTRW_006.rod
VCID: 6FBA2405C718FA2F777-803A
Adresse 05: Zugangs-/Startber. (J518) Labeldatei:| DRV\5K0-959-434.clb
Teilenummer SW: 5K0 959 434 E HW: 5K0 959 434
Bauteil: VWKESSYPQ35GP 092 1202
Revision: 00092000 Seriennummer: 0375621325
Codierung: 03100C
Betriebsnr.: WSC 00020 999 39850
ASAM Datensatz: EV_KESSYPQ35G A02717
ROD: EV_KESSYPQ35G_A02_VW36.rod
VCID: 372ADC65FFC872EF6F7-8062
Adresse 08: Klima-/Heizungsel. (J255) Labeldatei:| DRV\5K0-907-044.clb
Teilenummer SW: 7N0 907 044 AC HW: 7N0 907 044 AC
Bauteil: Clima-Sharan H02 0606
Revision: 00001K04
Codierung: 021010C549
ASAM Datensatz: EV_ClimatronicSharan A01005
VCID: 71BE227DD12CECDF613-8024
Slave 1:
Subsystem 1 - Teilenummer SW: 7N0 907 049 C HW: 7N0 907 049 C
Bauteil: KBT-H 004 0103
Seriennummer: 20150817000000016318
Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\1K0-937-08x-09.clb
Teilenummer SW: 5K0 937 086 T HW: 5K0 937 086 T
Bauteil: BCM PQ35 M 122 0183
Revision: BC122001
Codierung: 60590A3B892508C4508800C8B400897403D50008676D2DB26484C720A2C1
Betriebsnr.: WSC 00020 790 00000
VCID: 45D6A6ADB5A4107FEDB-8010
Subsystem 1 - Teilenummer SW: 7N1 955 119 B HW: 7N1 955 119 B Labeldatei: DRV\1KX-955-119.CLB
Bauteil: WWS428 110715 024 0644
Seriennummer: 15070906072131
Codierung: 004DBD
Subsystem 2 - Teilenummer SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labeldatei: DRV\5Q0-955-547.CLB
Bauteil: RLHS 037 0059
Seriennummer: S2Y15M09D08H00M15S01
Codierung: 0228BB
Adresse 10: Einparkhilfe 2 (J791) Labeldatei:| DRV\5Q0-919-294.clb
Teilenummer SW: 1K8 919 472 B HW: 5Q0 919 294 A
Bauteil: PARKHILFE 8K H03 0479
Revision: -------- Seriennummer: 39331524102160
Codierung: 0071155211
ASAM Datensatz: EV_EPHVA18VW364GP00 001006
VCID: 3634D161F8C28BE7741-8062
Adresse 13: Distanzregelung (J428) Labeldatei:| DRV\7N0-907-572.clb
Teilenummer SW: 7N0 907 572 B HW: 7N0 907 572
Bauteil: ACC Bosch PQx H03 0120
Seriennummer: 17111577091554
Codierung: 00001900FE0739
ASAM Datensatz: EV_ACCBEGVW361 001005
ROD: EV_ACCBEGVW361_VW32.rod
VCID: 3536D66DE5C480FF7DB-8060
1 Fehler gefunden:
1058 - Datenbus empfangener Fehlerwert
U1123 00 [009] - -
[FAULT_CIS_ECD_NOTAVAILABLE]
bestätigt - geprüft seit letzter Löschung
Umgebungsbedingungen:
Fehlerstatus: 00000001
Fehlerpriorität: 6
Fehlerhäufigkeit: 1
Verlernzähler: 23
Kilometerstand: 151470 km
Datum: 2019.07.08
Zeit: 20:48:38
Steuergerätetemperatur: 35 °C
Spannung Klemme 15: 12.2 V
Fahrzeuggeschwindigkeit: 0.00 m/s
Beschleunigung: 0.00 m/s²
Adresse 15: Airbag (J234) Labeldatei:| DRV\5K0-959-655.clb
Teilenummer SW: 7N0 959 655 D HW: 7N0 959 655 D
Bauteil: VW10Airbag10X H15 0016
Seriennummer: 003PWPHJML0Z
Codierung: 003058
ASAM Datensatz: EV_AirbaVW10TS6VW428 A01010
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 40D8B7B9AA063557DED-8014
Crashsensor für Seitenairbag Fahrerseite:
Subsystem 1 - Teilenummer SW: --- HW: ---
Bauteil: S.Sens.Fahr.V --- ---
Seriennummer: 3493ETS60DA6FB11B9DE
Codierung: 000000
Crashsensor für Seitenairbag Beifahrerseite:
Subsystem 2 - Teilenummer SW: --- HW: ---
Bauteil: S.Sens.Beif.V --- ---
Seriennummer: 3503ETS605DEDB41B9DA
Codierung: 000000
Crashsensor für Seitenairbag hinten Fahrerseite:
Subsystem 3 - Teilenummer SW: --- HW: ---
Bauteil: S.Sens.Fahr.H --- ---
Seriennummer: 3513ETS600D8BB21B9D$
Codierung: 000000
Crashsensor für Seitenairbag hinten Beifahrerseite:
Subsystem 4 - Teilenummer SW: --- HW: ---
Bauteil: S.Sens.Beif.H --- ---
Seriennummer: 3523ETS60B5E7B11B9D1
Codierung: 000000
Crashsensor für Frontairbag Fahrerseite:
Subsystem 5 - Teilenummer SW: --- HW: ---
Bauteil: F.Sens.Fahr --- ---
Seriennummer: 35540TS6094A8A31BDDX
Codierung: 000000
Adresse 16: Lenkradelektronik (J527) Labeldatei:| DRV\5K0-953-569.clb
Teilenummer SW: 5K0 953 501 DQ HW: 5K0 953 569 AP
Bauteil: LENKS.MODUL 016 0180
Revision: FF010042 Seriennummer: 20150902100965
Codierung: 3112A40000
ASAM Datensatz: EV_VW360SteerWheelUDS A03004
VCID: 7CA00349866E91B7C25-8028
Steuergerät für Multifunktionslenkrad:
Subsystem 1 - Teilenummer SW: 7N5 919 719 HW: 7N5 919 719 Labeldatei: DRV\3C8-959-537.CLB
Bauteil: E221__MFL-PR6 H04 0130
Seriennummer: 000000000B0049300715
Codierung: 011000
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\5K0-920-xxx-17.clb-SRI1
Teilenummer SW: 7N5 920 880 A HW: 7N5 920 880 A
Bauteil: KOMBI H04 1007
Seriennummer: 00000000000000
Codierung: 140F010000
ASAM Datensatz: EV_Kombi_UDS_VDD_RM09 A05730
Adresse 18: Standheizung Labeldatei: DRV\1K0-815-071.clb
Teilenummer: 7N0 963 271 G
Bauteil: Standheizer 051 3041
Revision: 00051000 Seriennummer: 09028242000000
Codierung: 0001042
VCID: 3828DF59FE567D9766D-806C
1 Fehler gefunden:
02245 - Verbindung Funkfernbedienung
004 - kein Signal/Kommunikation
Fehlerstatus: 01100100
Fehlerpriorität: 6
Fehlerhäufigkeit: 1
Verlernzähler: 23
Zeitangabe: 0
Datum: 2019.07.08
Zeit: 20:48:37
Adresse 19: Diagnoseinterface (J533) Labeldatei:. DRV\7N0-907-530-V2.clb
Teilenummer SW: 7N0 907 530 BC HW: 7N0 907 530 AN
Bauteil: J533 Gateway H56 1663
Revision: H56 Seriennummer: 230815F1001301
Codierung: 468232
Betriebsnr.: WSC 00020 790 12345
VCID: 72BC2D71D4AAD7C7989-8026
Adresse 25: Wegfahrsperre (J334) Labeldatei:| DRV\5K0-920-xxx-25.clb
Teilenummer SW: 5K0 953 234 HW: 5K0 953 234
Bauteil: IMMO H04 1007
Seriennummer:
Codierung: 000007
ASAM Datensatz: EV_Immo_UDS_VDD_RM09 A03710
VCID: 6A8C3511FCFA1F07209-803E
Adresse 2B: Lenksäulenverrieg. (J764) Labeldatei:* DRV\5K0-905-861.clb
Teilenummer SW: 5K0 905 861 C HW: 5K0 905 861 C
Bauteil: ELV-PQ35 H21 0240
Revision: 00000000 Seriennummer: 15000190810005
Codierung: 4900000000000000
ASAM Datensatz: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 3038E7791AA6A5D72ED-8064
Adresse 36: Sitzverst. Fahr. (J810) Labeldatei: 3C0-959-760.lbl
Teilenummer SW: 3C8 959 760 F HW: 3C8 959 760 F
Bauteil: Sitzmemory H02 1301
Revision: 00H02000
Codierung: 000018
Betriebsnr.: WSC 12336 024 394758
VCID: 3828DF59F2567D9766D-806C
Adresse 3C: Spurwechsel (J1086) Labeldatei:| DRV\5Q0-907-686.clb
Teilenummer SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Bauteil: HRE_Master H11 0071
Seriennummer: 0378307517
Codierung: 02011102
ASAM Datensatz: EV_HREntryHella 001028
ROD: EV_HREntryHella_VW32.rod
VCID: 3C20C349C6EE51B7825-8068
Steuergerät 2 für Spurwechselassistent:
Subsystem 1 - Teilenummer SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Bauteil: HRE_Slave H11 0071
Seriennummer: 0378415333
Codierung: 020111
Adresse 42: Türelektr. Fahrer (J386) Labeldatei:. 7N0-959-793.clb
Teilenummer SW: 7N0 959 793 J HW: 7N0 959 793 G
Bauteil: TSG FA H04 0561
Revision: Seriennummer: 0000163734024
Codierung: 01112F209E00411001
VCID: 49CEAA9D99BCF41F093-801C
Adresse 44: Lenkhilfe Labeldatei: DRV\5N1-909-144.clb
Teilenummer SW: 5N1 909 144 R HW: 5N1 909 148 J
Bauteil: J500__APA-BS KL.325 1401
Revision: 1BH04739 Seriennummer: 00152040223701
Codierung: 0000258
VCID: 41DEB2BDAD8C3C5FD13-8014
Adresse 4F: Zentralelektrik II (J520) Labeldatei:. DRV\1K0-907-532.clb
Teilenummer SW: 7N0 907 532 HW: 7N0 907 530 AN
Bauteil: EZE_2 H56 1663
Codierung: 050B0501
VCID: 6FBA2405C798FA2F777-803A
Subsystem 1 - Teilenummer SW: 7N0 959 591 B HW: 7N0 959 591 B
Bauteil: J245EE04SKB03 H04 0090
Seriennummer: 0123456789ABCDEFGHIJ
Subsystem 2 - Teilenummer SW: 7N0 959 591 B HW: 7N0 959 591 B
Bauteil: J394EE04SKB03 H04 0090
Adresse 52: Türelektr. Beifahr. (J387) Labeldatei:. 7N0-959-792.clb
Teilenummer SW: 7N0 959 792 J HW: 7N0 959 792 G
Bauteil: TSG BF H04 0561
Revision: Seriennummer: 0000163681524
Codierung: 01112D209E00411001
VCID: 48C8AF9982B60D1716D-801C
Adresse 55: Leuchtweitenreg. (J745) Labeldatei:. DRV\5M0-907-357-V3.clb
Teilenummer SW: 5M0 907 357 F HW: 7L6 907 357 C
Bauteil: AFS-ECU H05 0111
Revision: -------- Seriennummer: --------------
Codierung: 068200000B000000
ASAM Datensatz: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt_VW32.rod
Subsystem 1 - Teilenummer: 1T0 941 329 B Labeldatei: 3D0-941-329.CLB
Subsystem 2 - Teilenummer: 1T0 941 329 B Labeldatei: 3D0-941-329.CLB
Adresse 5F: Informationselek. I (J794) Labeldatei:| DRV\5F0-035-MIB-STD2.clb
Teilenummer SW: 7N5 035 680 B HW: 7N5 035 680 B
Bauteil: MU-S-N-ER H20 0240
Seriennummer: SEZAZ2R0241952
Codierung: 04240801FF00000011110001000808001F0100840020010086
ASAM Datensatz: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 323CED7114AA97C7589-8066
Datenträger:
Subsystem 1 - Teilenummer SW: 5F0 060 884 BN HW: -----------
Bauteil: ECE AS 19/20 --- 1115
Seriennummer: --------------------
Adresse 61: Batterieregelung (J840) Labeldatei:. DRV\1K0-907-534.clb
Teilenummer SW: 7N0 907 534 HW: 7N0 907 530 AN
Bauteil: Batt.regelung H56 1663
Codierung: 030F7873
VCID: 71BE227DD1ACECDF613-8024
Subsystem 1 - Teilenummer SW: 1K0 915 181 H HW: 1K0 915 181 A
Bauteil: J367-BDM H07 0180
Seriennummer: 42242M55401491566675
Adresse 62: Türelektr. hi. li. (J388) Labeldatei:. 7N0-959-794.clb
Teilenummer SW: 7N0 959 794 L HW: 7N0 959 794 H
Bauteil: TSG HL H02 0561
Revision: Seriennummer: 0000163856216
Codierung: 01006D200000411001
VCID: 4CC0938996CEE137325-8018
Adresse 69: Anhänger (J345) Labeldatei:. DRV\7N0-907-383.clb
Teilenummer SW: 7N0 907 383 HW: 7N0 907 383
Bauteil: Anhaenger H09 0101
Revision: 3I001002 Seriennummer: 00008130005327
Codierung: 410C040001000000
Betriebsnr.: WSC 00049 770 00119
VCID: 73B22875ABB0DECF93F-8026
Adresse 6C: Rückfahrkamera (J772) Labeldatei:| 5Q0-907-441.clb
Teilenummer SW: 7N0 907 441 B HW: 7N0 907 441 B
Bauteil: VW428 RVC Mid H04 0040
Codierung: 012408012301000700
ASAM Datensatz: EV_CamSysRearPANAVW428 002002
ROD: EV_CamSysRearPANAVW428.rod
Adresse 6D: Heckklappe (J605) Labeldatei:| DRV\7N0-959-107.clb
Teilenummer SW: 7N0 959 107 G HW: 7N0 959 107 A
Bauteil: HDSG-Modul H11 0250
Revision: 41011001 Seriennummer: 222500791
Codierung: 0733334002
ASAM Datensatz: EV_HDSGVW428 201138
ROD: EV_HDSGVW428_VW36.rod
VCID: 3B22C055C3E0568F8BF-806E
Adresse 72: Türelektr. hi. re. (J389) Labeldatei:. 7N0-959-794.clb
Bauteil: TSG HR H02 0561
Revision: Seriennummer: 0000163856444
Adresse A5: Front-/Vorfeldkamera (R242) Labeldatei:| DRV\3Q0-980-65X-A5.clb
Teilenummer SW: 3Q0 980 654 HW: 3Q0 980 654
Bauteil: MQB_B_MFK H04 0010
Seriennummer: 24081511P10705
Codierung: 0304020800000401002613068080400090000E100020
ASAM Datensatz: EV_MFKBoschMQBB 001001
Adresse BE: Schiebetür hinten links (J558) Labeldatei: 7N0-959-244.clb
Teilenummer SW: 7N0 959 244 B HW: 7N0 959 244 B
Bauteil: Schiebetuer_l 005 2414
Seriennummer: 15334958
ASAM Datensatz: EV_AST A03704
ROD: EV_AST.rod
VCID: 3828DF59F2D67D9766D-806C
Adresse BF: Schiebetür hinten rechts (J731) Labeldatei: 7N0-959-244.clb
Bauteil: Schiebetuer_r 005 2414
Seriennummer: 15335197
ROD: EV_AST.rod
