Page 4 of 4 FirstFirst ... 234
Results 31 to 34 of 34
Thread: Seat Alhambra/ VW Sharan ACC retrofit
  1. #31
    Dec 2015
    Austria
    @ rhinopower: The ABS unit is mounted in a way, that I can't change the ecu without removing it. Therefore I thought I'll change the whole ABS block.
    @ all: Thanks a lot for your help! Everything is now working fine!
    It was a little bit tricky to do the basic Setting of the ABS in the end - I was only with ODIS-service able to do it.
    Here you can see the actual Autoscan:
    Monday,15,July,2019,18:39:49:24421
    VIN: VSSZZZ7NZGV708020   License Plate:
    Mileage: 151660km-94237mi   Repair Order:
    Chassis Type: 7N-VW36 (7N0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 25 2B 36 3C 42 44 46
              4C 4F 52 53 55 5F 61 62 69 6C 6D 72 A5 BE BF
    VIN: VSSZZZ7NZGV708020   Mileage: 151660km-94237miles
    BE-Slid. Door Rear Left -- Status: OK 0000
    BF-Slid. Door Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CUWA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 016 CK    HW: 04L 907 309 K
       Component: R4 2,0L EDC   H20 1737
       Revision: 8AH20---
       Coding: 011D001A047401083000
       Shop #: WSC 00020 999 12345
       ASAM Dataset: EV_ECM20TDI01104L906016CK 001004
       ROD: EV_ECM20TDI01104L906016BJ_001_VW36.rod
       VCID: 74B02B69AE3ED9F7DE1-8020
       Part No SW: 02E 300 063 C    HW: 02E 927 770 AL
       Component: GSG DSG AG6     531 4902
       Revision: 06253104    Serial number: 00001507232976
       Shop #: WSC 44551 111 44551
       VCID: 167431E194826BE7005-8042
    Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
       Part No SW: 5N0 614 109 CG    HW: 5N0 614 109 CK
       Component: ESC-EBC460iV1 H10 0013
       Serial number: A01BURS
       Coding: 12F0449A0920C2740877480222C39043103917F8F00B4895
       VCID: 72BC2D71D42AD7C7CCD-8026
       Revision: 00092000    Serial number: 0375621325
       Coding: 03100C
       Shop #: WSC 00020 999 39850
       VCID: 372ADC65FFC872EF3B3-8062
       Part No SW: 7N0 907 044 AC    HW: 7N0 907 044 AC
       Component: Clima-Sharan  H02 0606
       Revision: 00001K04
       Coding: 021010C549
       Shop #: WSC 00020 999 00000
       VCID: 71BE227DD12CECDF357-8024
       Slave 1:
       Subsystem 1 - Part No SW: 7N0 907 049 C    HW: 7N0 907 049 C
       Component: KBT-H  004 0103
       Serial number: 20150817000000016318
       Part No SW: 5K0 937 086 T    HW: 5K0 937 086 T
       Component: BCM PQ35 M    122 0183
       Revision: BC122001
       Coding: 60590A3B892508C4508800C8B400897403D50008676D2DB26484C720A2C1
       Shop #: WSC 00020 790 00000
       VCID: 45D6A6ADB5A4107FB9F-8010
       Subsystem 1 - Part No SW: 7N1 955 119 B    HW: 7N1 955 119 B  Labels: 1KX-955-119.CLB
       Component: WWS428 110715  024 0644
       Serial number: 15070906072131
       Coding: 004DBD
       Component: RLHS  037 0059
       Serial number: S2Y15M09D08H00M15S01
       Coding: 0228BB
       Part No SW: 1K8 919 472 B    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0479
       Revision: --------    Serial number: 39331524102160
       Coding: 0071155211
       ASAM Dataset: EV_EPHVA18VW364GP00 001006
       VCID: 3634D161F8C28BE7205-8062
       Part No SW: 7N0 907 572 B    HW: 7N0 907 572
       Component: ACC Bosch PQx H03 0120
       Serial number: 17111577091554
       Coding: 00001900FE0739
       ASAM Dataset: EV_ACCBEGVW361 001005
       ROD: EV_ACCBEGVW361_VW32.rod
       VCID: 3536D66DE5C480FF29F-8060
       Part No SW: 7N0 959 655 D    HW: 7N0 959 655 D
       Component: VW10Airbag10X H15 0016
       Serial number: 003PWPHJML0Z
       Coding: 003058
       ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
       ROD: EV_AirbaVW10TS6VW428.rod
       VCID: 40D8B7B9AA0635578A9-8014
       Subsystem 1 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.V  --- ---
       Serial number: 3493ETS60DA6FB11B9DE
       Subsystem 2 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.V  --- ---
       Serial number: 3503ETS605DEDB41B9DA
       Subsystem 3 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.H  --- ---
       Serial number: 3513ETS600D8BB21B9D$
       Subsystem 4 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.H  --- ---
       Serial number: 3523ETS60B5E7B11B9D1
       Subsystem 5 - Part No SW: ---            HW: ---
       Component: F.Sens.Fahr  --- ---
       Serial number: 35540TS6094A8A31BDDX
       Part No SW: 5K0 953 501 DQ    HW: 5K0 953 569 AP
       Revision: FF010042    Serial number: 20150902100965
       Coding: 3112A40000
       VCID: 7CA00349866E91B7961-8028
       Subsystem 1 - Part No SW: 7N5 919 719     HW: 7N5 919 719   Labels: 3C8-959-537.CLB
       Component: E221__MFL-PR6  H04 0130
       Serial number: 000000000B0049300715
       Coding: 011000
       Part No SW: 7N5 920 880 A    HW: 7N5 920 880 A
       Component: KOMBI         H04 1007
       Coding: 140F010000
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 7N0 963 271 G
       Component: Standheizer     051 3041
       Revision: 00051000    Serial number: 09028242000000
       Coding: 0001042
       VCID: 3828DF59FE567D97329-806C
    02245 - Connection; RF Remote Control
                        Reset counter: 31
                        Mileage: 151629 km
                        Date: 2019.07.15
                        Time: 01:43:14
       Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1663
       Revision:   H56       Serial number: 230815F1001301
       Coding: 468232
       Shop #: WSC 00020 790 12345
       VCID: 72BC2D71D4AAD7C7CCD-8026
       Component: IMMO          H04 1007
       Coding: 000007
       VCID: 6A8C3511FCFA1F0774D-803E
       Revision: 00000000    Serial number: 15000190810005
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 3038E7791AA6A5D77A9-8064
       Part No SW: 3C8 959 760 F    HW: 3C8 959 760 F
       Component: Sitzmemory    H02 1301
       Revision: 00H02000
       Coding: 000018
       Shop #: WSC 12336 024 394758
       VCID: 3828DF59F2567D97329-806C
       Component: HRE_Master    H11 0071
       Serial number: 0378307517
       Coding: 02011102
       ROD: EV_HREntryHella_VW32.rod
       VCID: 3C20C349C6EE51B7D61-8068
       Component: HRE_Slave  H11 0071
       Serial number: 0378415333
       Coding: 020111
       Part No SW: 7N0 959 793 J    HW: 7N0 959 793 G
       Component: TSG FA        H04 0561
       Revision:             Serial number: 0000163734024
       Coding: 01112F209E00411001
       VCID: 49CEAA9D99BCF41F5D7-801C
       Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
       Component: J500__APA-BS KL.325 1401
       Revision: 1BH04739    Serial number: 00152040223701
       Coding: 0000258
       Shop #: WSC 00046 000 00000
       VCID: 41DEB2BDAD8C3C5F857-8014
       Component: EZE_2         H56 1663
       Coding: 050B0501
       VCID: 6FBA2405C798FA2F233-803A
       Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J245EE04SKB03  H04 0090
       Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J394EE04SKB03  H04 0090
       Part No SW: 7N0 959 792 J    HW: 7N0 959 792 G
       Component: TSG BF        H04 0561
       Revision:             Serial number: 0000163681524
       Coding: 01112D209E00411001
       VCID: 48C8AF9982B60D17429-801C
       Component: AFS-ECU       H05 0111
       Coding: 068200000B000000
       Subsystem 1 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
       Subsystem 2 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
    Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
       Part No SW: 7N5 035 680 B    HW: 7N5 035 680 B
       Component: MU-S-N-ER     H20 0240
       Serial number: SEZAZ2R0241952
       Coding: 04240801FF00000011110001000808001F0100840020010086
       ROD: EV_MUStd4CTSAT_VW36.rod
       VCID: 323CED7114AA97C70CD-8066
       Subsystem 1 - Part No SW: 5F0 060 884 BN    HW: -----------
       Component: ECE AS 19/20  --- 1115
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AN
       Component: Batt.regelung H56 1663
       Coding: 030F7873
       VCID: 71BE227DD1ACECDF357-8024
       Component: J367-BDM  H07 0180
       Serial number: 42242M55401491566675
    Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
       Part No SW: 7N0 959 794 L    HW: 7N0 959 794 H
       Component: TSG HL        H02 0561
       Revision:             Serial number: 0000163856216
       Coding: 01006D200000411001
       VCID: 4CC0938996CEE137661-8018
    Address 69: Trailer (J345)       Labels:. 7N0-907-383.clb
       Part No SW: 7N0 907 383     HW: 7N0 907 383
       Component: Anhaenger     H09 0101
       Revision: 3I001002    Serial number: 00008130005327
       Coding: 410C040001000000
       Shop #: WSC 00049 770 00119
       VCID: 73B22875ABB0DECFC7B-8026
       Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
       Component: VW428 RVC Mid H04 0040
       Coding: 012408012301000700
       ASAM Dataset: EV_CamSysRearPANAVW428 002002
       ROD: EV_CamSysRearPANAVW428.rod
    Address 6D: Trunk Elect. (J605)       Labels:| 7N0-959-107.clb
       Part No SW: 7N0 959 107 G    HW: 7N0 959 107 A
       Component: HDSG-Modul    H11 0250
       Revision: 41011001    Serial number: 222500791
       Coding: 0733334002
       ASAM Dataset: EV_HDSGVW428 201138
       ROD: EV_HDSGVW428_VW36.rod
       VCID: 3B22C055C3E0568FDFB-806E
    Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
       Component: TSG HR        H02 0561
       Revision:             Serial number: 0000163856444
       Part No SW: 3Q0 980 654     HW: 3Q0 980 654
       Component: MQB_B_MFK     H04 0010
       Serial number: 24081511P10705
       Coding: 0304020800000401002613068080400090000E100020
    Address BE: Slid. Door Rear Left (J558)       Labels: 7N0-959-244.clb
       Part No SW: 7N0 959 244 B    HW: 7N0 959 244 B
       Component: Schiebetuer_l 005 2414
       Serial number: 15334958
       ASAM Dataset: EV_AST A03704
       ROD: EV_AST.rod
       VCID: 3828DF59F2D67D97329-806C
    Address BF: Slid. Door Rear Right (J731)       Labels: 7N0-959-244.clb
       Component: Schiebetuer_r 005 2414
       Serial number: 15335197
       ROD: EV_AST.rod
    End----------(Elapsed Time: 02:09, VBatt start/end: 12.7V/12.4V)-----------
  2. Likes Uwe, dnoermann liked this post
  3. #32
    Jan 2019
    Congratulations
    I did send you a PM, can you look into it please.
    Greetings
    Dennis
  4. #33
    Dec 2015
    Austria
    It would be interesting what's the difference between the ABS ecu's.
    Maybe I'll try to flash the CG Software over my old ABS ecu, when I've time ...
  5. #34
    Võru, Estonia
    Quote Originally Posted by andy_911 View Post
    Most likely a bit somewhere in eeprom or flash like with Passat ABS.
    The world is my oyster...
