Results 1 to 10 of 17
Thread: 2011 Tiguan - Cylinder Misfire
    Mar 2018
    Need help/suggestions on fix..
    VagCom Dump below. Coil pack maybe? Thanks in advance
    Monday,08,July,2019,07:55:36:35695
    VCDS Version: 18.9.0.2 (x64)
    VIN: WVGBV7AX7BW525616   License Plate: RCPLT000
    Mileage: 244070km-151658mi   Repair Order: 0000887
    Chassis Type: AX-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 22 25 2E 37 42 44 46 4F 52 53 56
              62 65 69 72 77
    VIN: WVGBV7AX7BW525616   Mileage: 244070km-151658miles
    Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
       Part No SW: 06J 906 027 R    HW: 06J 907 309 A
       Component: MED17.5.2 TFSI 2 01 7786
       Revision: P3H06---    Serial number:
       Coding: 0423010A190F0160
       VCID: 3A7B178575D4F69ADB-806E
                   P0300 - 000 -
                        Mileage: 244071 km
                        Date: 2013.11.28
                        Time: 07:37:23
                        RPM: 3361 /min
                        Load: 82.3 %
                        Speed: 80.0 km/h
                        Temperature: 81.0°C
                        Temperature: 21.0°C
                        Absolute Pres.: 850.0 mbar
                        Voltage: 14.224 V
    000770 - Cylinder 2
                   P0302 - 000 - Misfire Detected - MIL ON
                        Fault Status: 11100000
                        Mileage: 244071 km
                        Date: 2013.11.28
                        Time: 07:37:23
                        RPM: 3361 /min
                        Load: 82.3 %
                        Speed: 80.0 km/h
                        Temperature: 81.0°C
                        Temperature: 21.0°C
                        Voltage: 14.224 V
    004874 - Cylinder Disabling
                   P130A - 000 -  - Intermittent
                        Mileage: 244072 km
                        Date: 2013.11.28
                        Time: 07:37:31
                        RPM: 3077 /min
                        Load: 52.1 %
                        Speed: 79.0 km/h
                        Temperature: 85.0°C
                        Temperature: 21.0°C
                        Voltage: 14.351 V
       Part No SW: 09G 927 750 LQ    HW: 09G 927 750 LQ
       Component: AQ 250 6F           1771
       Revision: 00H90000    Serial number:
       Coding: 0000840
       VCID: 0B1582416ACE3F12B0-805E
    Address 03: ABS Brakes        Labels: 5N0-614-109-C4.clb
       Part No SW: 5N0 614 109 Q    HW: 5N0 614 109 Q
       Component: J104    C4 450 V2C4 0006
       Revision: --H28---    Serial number: 00000003349576
       Coding: 0002336
       VCID: 3979088970D2FD82D2-806C
       Part No SW: 7N0 907 426 L    HW: 7N0 907 426 L
       Component: AC Manuell    H17 0202
       Revision: 00012001
       Coding: 0000001002
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 3D711C99ACFAC1A2FE-8068
       Part No SW: 5K0 937 087 Q    HW: 5K0 937 087 Q
       Component: BCM PQ35 H+   111 0148
       Revision: BL111001
       Coding: 6D580A3F80232EC4808800859000050440015186524D8D605C8000000040
       Shop #: WSC 26105 444 85824
       VCID: 43856A61C21EB75288-8016
       Subsystem 1 - Part No: 5N1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS 261010 03  32  0010
       Coding: 009795
    01259 - Fuel Pump Relay (J17)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 0
                        Mileage: 226597 km
                        Date: 2013.02.04
                        Time: 06:40:07
                            Term 15 Off
                        Voltage: 12.30 V
                        Fault Status: 00101010
                        Fault Frequency: 21
                        Reset counter: 208
                        Mileage: 241601 km
                        Date: 2013.10.20
                        Time: 20:29:55
                        Voltage: 13.95 V
       Part No SW: 5N0 959 655 P    HW: 5N0 959 655 P
       Component: J234__204 VW10 HI   1918
       Revision: 22014000    Serial number: 003GJPKRPJC.
       Coding: 0012340
       VCID: 4A9B47452534661A4B-801E
       Subsystem 1 - Part No: 5N0 959 339 B
       Subsystem 2 - Serial number: 00000000001ZJ2
       Subsystem 3 - Serial number: 0029.09.100000300000630098ÿ†63
       Subsystem 4 - Serial number: 630098ÿ†6332MTS617252860 ÿ†63
       Subsystem 5 - Serial number: 52860 ÿ†6342MTS610762870 ÿ†63
       Subsystem 6 - Serial number: 62870 ÿ†6351HTS61P8RF9KJ ÿ†63
       Subsystem 7 - Serial number: RF9KJ ÿ†6361HTS6JI0HG9KR ÿ†63
       Subsystem 8 - Serial number: HG9KR ÿ†63727TS6QKR0G9KR ÿ†63
       Subsystem 9 - Serial number: 0G9KR ÿ†63827TS6RD01G9KJ ÿ
       Subsystem 10 - Serial number: 1G9KJ ÿ
       Part No SW: 5K0 953 501 AT    HW: 5K0 953 569 H
       Component: LENKS.MODUL   009 0136
       Revision: FF010039    Serial number: 20101029300456
       Coding: 198A140000
       VCID: 7CF7D19DF76008AA89-8028
       Component: E221__MFL-TAS  H07 0013
       Coding: 820000
       Part No SW: 5N0 920 972 B    HW: 5N0 920 972 B
       Component: KOMBI         H20 0420
       Coding: 210F00
       VCID: 326B3FA565A40EDA13-8066
       Part No SW: 7N0 907 530 D    HW: 1K0 907 951
       Component: J533  Gateway H35 0614
       Revision:   H35       Serial number: 231010F1002600
       Coding: 356002
       VCID: 316930A968A235C26A-8064
       Part No SW: 0AY 907 554 D    HW: 0AY 907 554 D
       Component: Haldex 4Motion      0042
       Coding: 0000005
       VCID: 4C97415D2F40782A79-8018
       Component: IMMO          H20 0420
       VCID: 6ADBE7C58DF4861A6B-803E
       Revision: A1001003    Serial number: 7668860609
       Coding: 020000
       VCID: 275DDEF156667B72B4-8072
       Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
       Component: RNS315-NAR    H53 0319
       Serial number: VWZAZ2M4237898
       Coding: 0401042104000C000000100A
       ROD: EV_RNS315NARV2UDS_VW32.rod
       VCID: 2541D4F9246A696286-8070
    1048625 - Front Left Audio Signal Output
              B1105 F0 [008] - Short Circuit Between Poles
                        Reset counter: 235
                        Mileage: 225599 km
                        Date: 2018.08.25
                        Time: 07:23:05
    1048626 - Front Right Audio Signal Output
              B1106 F0 [009] - Short Circuit Between Poles
                        Reset counter: 196
                        Mileage: 224767 km
                        Date: 2018.08.10
                        Time: 06:49:16
       Part No SW: 5N0 959 701 D    HW: 5N0 959 701 D
       Component: Tuer-SG         009 2101
       Coding: 0001205
       VCID: 366303B541CC12FA3F-8062
       Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.286 0802
       Revision: 1AH03831    Serial number: 00102990065601
       Coding: 0000258
       Shop #: WSC 00000 028 00001
       VCID: 3B7512817AEECF92C0-806E
       Component: EZE_2         H35 0614
       Coding: 050B0500
       VCID: 6FEDF6D1BE1663323C-803A
       Part No SW: 5N0 959 702 D    HW: 5N0 959 702 D
       Coding: 0001204
       VCID: 377D0EB146C6EBF224-8062
       Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
       Component: J540 EPB4  VW-55183 0007
       Revision:   H18       Serial number: 00000000020761
       Coding: 0023057
       VCID: 33653AA152BE07D218-8066
       Part No SW: 5N0 959 703 E    HW: 5N0 959 703 E
       Component: Tuer-SG         007 2102
       Coding: 0001168
       Shop #: WSC 01357 011 1012552
    Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
       Component: RDK           111 0821
       Coding: 018704
       Shop #: WSC 26105 444 100088
    02903 - Hard Warning 2
                        Mileage: 229944 km
                        Date: 2013.04.08
                        Time: 07:06:02
                        Text: 3454809797
                        Pressure: 1.90 bar
                        Pressure: 2.30 bar
                        Temperature: -6.0°C
                        Text: 00
                        Speed: 34.0 km/h
       Component: Anhaenger     H12 0100
       Revision: 3A001001    Serial number: 00000426625905
       Coding: 030D000100000000
       Shop #: WSC 01357 444 00001
       VCID: 306F35AD63A83CCA65-8064
       Part No SW: 5N0 959 704 E    HW: 5N0 959 704 E
       Coding: 0001168
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Revision: 1B001001    Serial number: 00007663952338
       Coding: 0A10040000010100
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3A7B1785BDD4F69ADB-806E
    End-------------------------(Elapsed Time: 03:05)--------------------------
    Last edited by ronin4740; 07-08-2019 at 11:07 AM. Reason: wrapped diag dump with Code tag
    It certainly couldn't hurt to swap the #2 coil pack with one from a different cylinder to see if the problem moves with it, but at 151,000 miles, I wonder: When was the last time this engine got new spark plugs? How badly carboned up are the intake valves?
  3. Likes Jack@European_Parts, ronin4740 liked this post
    Mar 2018
    It got spark plugs within the past 10 days. Had carbon walnut blasted out at around 90K miles... Intakes are probably pretty carboned up again and I'll start to set aside the $$$ to get that job done as it's not something I think I can accomplish in my garage with the limited tools I have on hand.
    I'll try swapping the coil pack from #2 to #1 when I get home and see if the problem follows the coil pack or stays put.
    Thanks Uwe!
  6. #4
    Always good to recognize limitations..........
  7. Likes Uwe, ronin4740 liked this post
  8. #5
    Mar 2018
    I swapped the coil packs - 2 to 3 and 3 to 2, cleared the codes, cycled power to the car, started it and observed that the misfire fault followed the coil pack to cylinder 3.
    Ordered coil packs. Should be here today and will hopefully fix the issue.
  9. Likes Jack@European_Parts, Uwe liked this post
  10. #6
    Excellent........ OP
    Be sure to verify the grounds to the coil packs are good otherwise you will burn up another one.
  11. Likes Uwe liked this post
  12. #7
    Mar 2018
    Thanks Jack. I presume I can do that with an Volt meter on ohm setting and testing continuity from the housing to the engine block?
    For reference these are the coil packs I purchased.
    https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    This will be the third set in the Tiguan with the second set being installed at around 80K miles.
  13. #8
    Quote Originally Posted by ronin4740 View Post
    Chinese Replacement Auto Parts!
  14. Likes Jack@European_Parts, PetrolDave liked this post
  15. #9
    Some Chinese stuff is good just like some German stuff that is re-boxed on the German port & being purported in some shipping container on the dock and called "Made like technology in Germany that used to be produced" is absolute shit typically or of origin unknown or sometimes China's sloppiest work!
    Beware many German & US companies are now owned OUTRIGHT by the Chinese.
    Nope load light or be sure the tracks can carry current........beep beep tests are not worth a shit outside finding a track.
  16. #10
    All true. But read the reviews on Amazon for that item.
  17. Likes Jack@European_Parts liked this post
