Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Audi A6 C7/4G Facelift : Enabling Green Menu with VCDS
    Nov 2019
    Having a same problem than described in the first message in this thread. Could anyone help?
    Thursday,21,November,2019,16:01:27:43746
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64(VMWare)
    VCDS Version 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
    VIN: WAUZZZ4G7FN09XXXX   License Plate: XXX-333
    Mileage: 98656km-61301mi   Repair Order:
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 08 09 13 15 16 17 18 19 28 34 3B 3C 42 44 46 52
              53 55 5F 62 69 6C 6D 72 82 85 8B 8E 8F 90 AC
    VIN: WAUZZZ4G7FN098204   Mileage: 98656km-61301miles
    17-Instruments -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CRTD)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G2 907 401 B    HW: 4G2 907 401
       Component: 3.0TDI EDC17  H34 0007
       Revision: 92H34---
       Coding: 1225401A057601030000
       Shop #: WSC 41314 002 1048576
       ASAM Dataset: EV_ECM30TDI0114G2907401B 001007
       ROD: EV_ECM30TDI0114G2907311C.rod
       VCID: 2411EC549E5151078DF-8071
       Part No SW: 4G0 927 166 C    HW: 0B5 927 156 K
       Component: 0B5 30 TDIRdW H03 0007
       Revision: --H03---
       Coding: 100001
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_TCMDL501021 001021
       ROD: EV_TCMDL501021.rod
       VCID: 2D070970CD9B904F521-8079
       Coding: 17A6DE49E8657B92BB00
       ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
       VCID: 41DF45C06103642F869-8015
       Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
       Component: BCM2 2.0      H36 0560
       Coding: 01A9700E000000000000
       VCID: 7AADF22C4CD5F7F7873-802F
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Serial number: 06051500042303
       Coding: 36121178350000
       VCID: 6393AF48DBDF163FB45-8037
    Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
       Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
       Revision: 15020001    Serial number: 00001066307202
       Coding: 0105801440348FE2C901408300001800CF9CE708AE08022100000894E10117020040003D030000
       VCID: 71BFD50011A3B4AF369-8025
       Component: WWS57X 150412  H37 0080
       Serial number:         150427123019
       Coding: 0045F7
       Serial number: 23949418
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
       Component: E1 - LDS  H07 0044
       Serial number: 27 04 2015  00001658
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R5DZ902
    03608 - Humidity Sensor in Fresh Air Intake Duct
                        Fault Status: 01100101
                        Reset counter: 229
                        Mileage: 98656 km
                        Date: 2019.11.21
                        Time: 15:56:06
       Component: ACC3          H21 0053
       Coding: 7F04010202
       ASAM Dataset: EV_AdaptCruisContrAU57X 002014
       VCID: 290FFD60F9738C6FBE9-807D
       Revision: --------    Serial number: 003P1004K6HX
       Coding: 30333130313730323536554A304C34473053
       VCID: 3B23372803EF0EFFDC5-806F
       Serial number: 3575HRB405R36CAO3OH
       Serial number: 3585HRB405F36RT428MT
       Serial number: 3515JRB400U54R1AA1UL
       Serial number: 3525JRB405L36OUMNGV%
       Serial number: 3554VRB400S54R1CDGH+
       Serial number: 3564VRB401654R1CA9UO
       Revision: --------    Serial number: 90372ODN00055
       Coding: 0000DD
       VCID: 372B2B183F472A9F38D-8063
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Serial number: 24 04 2015  C0077017
       Part No SW: 4G8 920 933 F    HW: 4G8 920 933 F
       Component: TDieRdwAcc    H08 0043
       Revision: 04001037    Serial number: 658060515596029
       Coding: 038612001F550008000000
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 33331F082BBFC6BF045-8067
    Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
       Part No SW: 4H0 265 105 G    HW: 4H0 265 105 G
       Component: Standheizung  H24 0260
       Revision: 66006006    Serial number: 20141113132105
       Coding: 553F01
       VCID: 2615F65CE8EDA31793B-8073
       Part No SW: 4G8 907 468 F    HW: 4G8 907 468
       Component: J533--Gateway H14 0083
       Revision: --------    Serial number: 00000001840286
       Coding: C0CD078118
       ASAM Dataset: EV_GatewPkoUDS 001028
       Serial number: 9594616303
       Voltage stabilizer:
       Serial number: 150307000000000002E2
       Component: KLIMA FOND    H08 0112
       Serial number: 07051500042317
       Coding: 21
       VCID: 3D2739301DFB00CFE21-8069
       Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
       Coding: 008003
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2F3B1378C797E25F60D-807B
       Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA8209FDGE
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 3635261C38CDD39723B-8063
       Component: SWA Master    H06 0060
       Serial number: 0367657459
       Coding: 040321
       VCID: 392F2D2009D33CEFCE9-806D
       Component: SWA Slave  H06 0060
       Serial number: 0367833189
       Coding: 040321
       Component: TSG FA        H04 0507
       Coding: 011F17015C00628002080013
       VCID: 45D751D075AB480FBA1-8011
       Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
       Component: RCEPS         H43 0012
       Revision: 00001000    Serial number: 0027760348
       Coding: 101001010001
       ASAM Dataset: EV_RCEPS 009013
       ROD: EV_RCEPS_009.rod
       Revision: 00002001    Serial number: 0367646693
       Coding: 0100063820B97080C32009842C010F470000000000000000000000000000
       Component: GTO BF  H01 0081
       Serial number: 00000000000000346953
       Subsystem 2 - Part No SW: 4G0 947 135 C    HW: 4G0 947 135
       Serial number: 0000000AP00050946433
       Coding: 011F17015E00628002080002
       VCID: 46D556DC48AD4317B3B-8013
       Revision: --------    Serial number: 00000001457659
       ROD: EV_ParkiBrake_VW51.rod
       Coding: 04FA02202A170200
       VCID: 34311C142EB1C1871DF-8061
       Coding: E01F00
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Left:
       Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo li.  H03 0031
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Right:
       Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo re.  H03 0031
       Coding: E01F00
       Part No SW: 4G1 035 043 S    HW: 4G1 035 043
       Component: MU-H-N-EU     041 0389
       Serial number: A591E0F7532010
       Coding: 017502010000000213110002000A00032F0006E5F17001009F
       VCID: 2E050E7CC09DEB576BB-807B
       Subsystem 1 - Part No SW: V03 959 801 PR    HW: -----------
       Component: ECE 2018  --- 0166
       Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
       Serial number: AUZ8Z9FY8010XU
       Multimedia Operating Unit:
       Serial number: 90349OE40007Q
       Component: Gracenote2  --- 1012
    1543 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 229
                        Mileage: 98656 km
                        Date: 2019.11.21
                        Time: 15:56:11
                        Voltage terminal 30: 11.9 V
                        Byte_Coding_Condition-byte_0_condition: OK
                        Byte_Coding_Condition-byte_1_condition: OK
                        Byte_Coding_Condition-byte_10_condition: ERROR
                        Byte_Coding_Condition-byte_11_condition: ERROR
                        Byte_Coding_Condition-byte_12_condition: ERROR
                        Byte_Coding_Condition-byte_13_condition: ERROR
                        Byte_Coding_Condition-byte_14_condition: ERROR
                        Byte_Coding_Condition-byte_15_condition: ERROR
                        Byte_Coding_Condition-byte_16_condition: ERROR
                        Byte_Coding_Condition-byte_17_condition: ERROR
                        Byte_Coding_Condition-byte_18_condition: ERROR
                        Byte_Coding_Condition-byte_19_condition: ERROR
                        Byte_Coding_Condition-byte_2_condition: OK
                        Byte_Coding_Condition-byte_20_condition: ERROR
                        Byte_Coding_Condition-byte_21_condition: ERROR
                        Byte_Coding_Condition-byte_22_condition: ERROR
                        Byte_Coding_Condition-byte_23_condition: ERROR
                        Byte_Coding_Condition-byte_24_condition: ERROR
                        Byte_Coding_Condition-byte_25_condition: ERROR
                        Byte_Coding_Condition-byte_26_condition: ERROR
                        Byte_Coding_Condition-byte_27_condition: ERROR
                        Byte_Coding_Condition-byte_3_condition: OK
                        Byte_Coding_Condition-byte_4_condition: OK
                        Byte_Coding_Condition-byte_5_condition: OK
                        Byte_Coding_Condition-byte_6_condition: OK
                        Byte_Coding_Condition-byte_7_condition: ERROR
                        Byte_Coding_Condition-byte_8_condition: OK
                        Byte_Coding_Condition-byte_9_condition: OK
       Coding: 010F15004000628002080002
       VCID: 49CF5DE059B3AC6F5E9-801D
    Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
       Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
       Component: Anhaenger     H14 0137
       Revision: 7B001002    Serial number: 0367834132
       Coding: 0100000202000000
       Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
       Component: TopView       H09 0361
       Revision: 11001001    Serial number: 82330JG0157099
       Coding: 0213000001010102010102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
       ROD: EV_CamerSysteTopViewAUDI.rod
    9617993 - Proximity Camera
              B145C 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 229
                        Mileage: 98656 km
                        Date: 2019.11.21
                        Time: 15:56:09
                        Voltage terminal 30: 11.5 V
    9616786 - Surroundings Camera Front
              B127C F0 [009] - Calibration Failed
                        Reset counter: 229
                        Mileage: 98656 km
                        Date: 2019.11.21
                        Time: 15:56:08
    10489856 - No Basic Setting
              B2010 00 [009] - -
              [TopView system not calibrated]
                        Reset counter: 229
                        Mileage: 98656 km
                        Date: 2019.11.21
                        Time: 15:56:08
       Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
       Component: HDSG-Modul    H05 0151
       Revision: 14005001    Serial number: 114500981
       Coding: 093205C011
       ROD: EV_HDSGAu571.rod
    Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
       Part No SW: 4G0 919 604 M    HW: 4G0 919 604 M
       Component: HeadUpDisplay H07 0304
       Coding: 470000
       ASAM Dataset: EV_HUDContiC7 001025
       ROD: EV_HUDContiC7.rod
       VCID: 3537211025CBD88F2A1-8061
       Component: DPC-SG        H27 0081
       Coding: EA160000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C010474F681994745F-8079
       Coding: 7F04010202
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
       VCID: 270BFB58EF67BA1FA8D-8073
       Component: BV-SG         H33 0090
       Serial number: 005000620205157
       Coding: 04C0BB1C1111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Coding: 0066E608031F0376070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313F1500D1A3F4AF769-8065
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 323D1A0CD4A5CFB70F3-8067
       Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0012
       Revision: 00000000    Serial number: 151050916
       ROD: EV_RDCMA00100_008.rod
    End----(Elapsed Time: 02:06, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
  2. #12
    Dec 2016
    DE
    @santti: Please try this Redirect-Label - https://ufile.io/f2kaqxbf
    It should be placed in your C:\Ross-Tech\VCDS\Labels\User directory.
    It redirects all module 5F part numbers that start with
    • 4G1-035-020
    • 4G1-035-021
    • 4G1-035-024
    • 4G1-035-025
    • 4G1-035-034
    • 4G1-035-043
    • 4G1-035-044
    • 4G1-035-046
    • 4G1-035-047
    • 4G1-035-049
    to the 4G1-035-MIB-HGH2.CLB label, which contains the required logic to switch to the engineering session.
    P.S.: File is available for 30 days, so grab it while it's there.
  3. Likes MartinsX, Uwe, santti liked this post
  4. #13
    Nov 2019
    Using the redirect label and new security access code I was able to set 'developer mode' to activated. Thanks a lot @TBAx! Even the green menu should be activated now, a was unable to access to the menu. I tried all known combinations (menu + car, nav + radio, car + radio) but no success. Three finger salute to mmi works fine and rebooted mmi before trying access to green menu.
  5. #14
    Nov 2019
    Finally found correct key combination to enter the green menu. In my case it was 'back - lower left softkey'. In comparison to older ones (mmi 3gp) the functionality seems very limited, so couldn't find what I was looking for.
  6. #15
    Mar 2020
    New York, USA
    Hey I have a c7.5 and im having the same problem .. cant seem to access the green menu .. any help would be great .. I got as far as 5F on VCDS but its asking me to pick from a list of channels I cant just pick channel 6 like what is shown in youtube videos
  7. #16
    Dec 2016
    DE
    There is no channel 6 in your 5F, but rather one named "Developer Mode".
  8. Likes Uwe liked this post
  9. #17
    Mar 2020
    New York, USA
    Thanks im going to try that today .. I see you helped alot of ppl on this post .. much appreciated !!
  10. #18
    Mar 2020
    New York, USA
    Hey check your pm please
  11. #19
    Verified VCDS-Lite User
    Jun 2018
    I also had a problem with enabling the developer menu, got "request of of range" on a 2016 RS6. I then just renamed 4G1-035-MIB-HGH2.CLB file to match the 5F partnumber that I had on my car "4G1-035-020", e.g. renamed 4G1-035-MIB-HGH2.CLB to 4G1-035-020.CLB. Then no problem setting 5F > Adaptoion > Developer mode to Active and it works fine.
  12. #20
    Apr 2020
    Anyone found any other tricks in these menus?????
  13. Likes TWs/VW liked this post
