Results 1 to 3 of 3
Thread: VW Golf 2004 UK Car - Aircon Issue
    Windsor UK
    We replaced the Engine ECU on this car this week with a used unit.
    All is well now except the Aircon.
    The compressor wont cut in. Reason for Compressor Shut off is Either 12 or 15 not sure now but came up as Engine ECU.
    As it was working fine before we are hoping it may just be a coding issue but we don't know for sure.
    I see refrigerant pressure at 8 bar, it is the same if I put Gauges on it.
    The Fans can be activated via Output tests - this car has 2 fans, front wheel drive, has ABS & Airbags. 5 speed manual
    Sunday,07,July,2019,16:00:14:36704
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4505.4
    VIN: WVWZZZ1KZ4W120626   License Plate: CHRIS
    Mileage: 284830km-176985mi   Repair Order: 123
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
    VIN: WVWZZZ1KZ4W120626   Mileage: 284830km-176985miles
    Address 01: Engine        Labels: 03G-906-016-BKC.clb
       Part No SW: 03G 906 016 B    HW: 028 101 147 8
       Component: R4 1,9L EDC 0000SG  5645
       Revision: 12345678    Serial number: XXXXXXXXXXXXXX
       Coding: 0000031
       Shop #: WSC 00000 028 00001
       VCID: 221D16CDD8C70717A89-8076
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0103
       Coding: 0021121
       Shop #: WSC 01279 785 00200
       VCID: 3A2DCEAD50576FD7909-806E
       Part No: 1K0 820 047 CB
       Component: Climatic PQ35   080 0201
       VCID: 66954ADD746F3B37041-8032
       Part No SW: 1K0 937 049 S    HW: 1K0 937 049 S*
       Component: Bordnetz-SG 1.0 H30 0704
       Revision: 00030000    Serial number: 00000000604041
       Coding: E4890F0600041800001400001400000000
       VCID: 3FDBBFB94B754AFFA77-806A
       Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0401
       Coding: 00065493
       Subsystem 2 - Part No: 1K0 955 559 K  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 002  0505
       Coding: 00217125
       Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
       Component: 0M AIRBAG VW8   022 0500
       Revision: 04022000    Serial number: 0033FD0A6W51
       Coding: 0012365
       Shop #: WSC 01268 785 00200
       VCID: 2A0DFEEDA0F7DF57E09-807E
       Subsystem 1 - Serial number: 6332MSME1E053302
       Subsystem 2 - Serial number: 6342MSME6D633602
       Subsystem 3 - Serial number: 6351HSME7A407C01
       Subsystem 4 - Serial number: 6361HSME77510102
       Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
       Component: Lenksäulenmodul 012 0030
       Coding: 0000022
       VCID: 3039EC85862BA5872ED-8064
       Part No: 1K0 920 950 L
       Component: KOMBIINSTRUMENT VDD 3556
       Coding: 0001401
       Shop #: WSC 12345 123 45725
       VCID: 313FE9818D21AC8F213-8064
       Part No SW: 1K0 907 530 C    HW: 1K0 907 951
       Component: Gateway         H08 0080
       Revision: 08          Serial number: 2600104304069D
       Coding: 3D0F0B40070003
       VCID: 270B07D9B3E5E23FFF7-8072
       Component: IMMO                3556
       Shop #: WSC 06402 785 00200
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1K0 959 701 E
       Component: Tuersteuergeraet 09 0116
       Coding: 0000052
       Part No: 1K2 909 144 F
       Component: EPS_ZFLS Kl.2       1301
       VCID: 2F3BEFF99B15BA7F377-807A
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AK
       Coding: 01C802087F2D8405485BC69010CC
       Shop #: WSC 01236 785 00200
       VCID: 79AF11A115D1A4CFD93-802C
       Subsystem 1 - Component:   Sounder No Answer
       Subsystem 2 - Part No: 1K0 907 719
       Component: Neigungssensor  003 0003
       Subsystem 3 - Part No: 1K0 951 177
       Component: Innenraumueberw.004 0101
    01134 - Alarm Horn (H12)
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1K0 959 702 E
       Coding: 0000052
       Part No: 1K0 035 186 J
       Component: Radio BNO           0016
       Coding: 0040400
       VCID: 2D07F5F19119C86F05B-8078
                000 -  -
       Part No SW: 1K0 963 235 D    HW: 1K0 963 235 D
       Revision: 00700000    Serial number:
       VCID: 2C01F8F5AA03C167125-8078
    End----(Elapsed Time: 00:59, VBatt start/end: 12.1V/12.1V. VIgn 12.0V)-----
    Any help or pointers will be gratefully received
    thank you.
    Gets activated by SVM or adaptation/coding?
    This is why data transfer!
    How about 0000032
    Windsor UK
    Hi ~Jack and thank you for the prompt reply.
    Had a good look this morning and 0000071 is the magic number.
    Climatronic all singing & dancing now. Superb start to the week !!!
    Once again thank you.
  4. Likes Uwe liked this post
