Results 1 to 7 of 7
Thread: A6 C6 ESP 8 coding problem after auto to manual conversion.
    Jun 2016
    Poland
    Hi. I replaced the broken auto gearbox with a manual, changed ecu to M one, but it seems like I can't recode ESP. I comes up with up with an error, tried literally all codings I could find over the internet, but none of them is fine. Attached scan. I don't mind about the runners error Could anyone post proper ecu and esp coding please? VIN WAUZZZ4F08N032362.
    Tuesday,25,June,2019,15:57:32:60351
    VCDS Version: 18.9.1.0 (x64)
    Dealer/Shop Name: Dash Solutions
    VIN: WAUZZZ4F08N032362   License Plate:
    Chassis Type: 4F (4F0)
    Scan: 01 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55 56
              61 62 72
    VIN: WAUZZZ4F08N032362   Mileage: 185290km-115133miles
    0E-Media Player 1 -- Status: Malfunction 0010
    Address 01: Engine        Labels: 059-907-401-BPP.clb
       Part No SW: 4F5 910 401 M    HW: 4F0 907 401 C
       Component: 2.7L V6TDI  G000SG  0010
       Revision: --H04---    Serial number:
       Coding: 0011322
       Shop #: WSC 10580 123 45725
       VCID: 2B5562A68AEE8F1258-807E
    012597 - Intake Manifold Runner Control
                   P3135 - 001 - Lower Stop not Reached
                        Fault Status: 01100001
                        Mileage: 185294 km
                        Date: 2019.06.25
                        Time: 15:43:53
                        RPM: 756 /min
                        Torque: 31.2 Nm
                        Voltage: 13.53 V
                        Duty Cycle: 88.8 %
                        Duty Cycle: 88.8 %
                        Duty Cycle: 80.9 %
    004120 - Intake Manifold Runner (Bank 2)
                   P1018 - 001 - Lower limit not reached
                        Mileage: 185294 km
                        Date: 2019.06.25
                        Time: 15:43:53
                        RPM: 756 /min
                        Torque: 31.2 Nm
                        Voltage: 13.53 V
                        Duty Cycle: 88.8 %
                        Duty Cycle: 88.8 %
                        Duty Cycle: 80.9 %
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 002 -
                        Fault Status: 01100010
                        Mileage: 185294 km
                        Date: 2019.06.25
                        Time: 15:43:53
                        RPM: 756 /min
                        Duty Cycle: 1.0 %
                        Voltage: 13.60 V
                        Bin. Bits: 00101100
                        Torque: 136.5 Nm
                        Bin. Bits: 00000100
    Readiness: 0 0 1 1 1
       Part No SW: 4F0 910 517 AC    HW: 4F0 614 517 T
       Component: ESP8 front      H01 0070
       Coding: 0020855
       Shop #: WSC 02325 785 00200
       VCID: 65C1D49EAC8A79624E-8030
                        Fault Status: 11100000
                        Reset counter: 230
                        Mileage: 185294 km
                        Date: 2019.06.25
                        Time: 15:50:49
                        Hex Value: 0x0000
                        Hex Value: 0x0782
                        Hex Value: 0x0014
                        Hex Value: 0x3191
                        Hex Value: 0x00FF
                        Reset counter: 230
                        Mileage: 185294 km
                        Date: 2019.06.25
                        Time: 15:50:49
                        Hex Value: 0x0000
                        Hex Value: 0x0782
                        Hex Value: 0x0014
                        Hex Value: 0x3091
                        Hex Value: 0x00FF
    18055 - Check Coding of ECUs on Powertrain Data Bus
                P1647 - 000 -
                        Reset counter: 230
                        Mileage: 185294 km
                        Date: 2019.06.25
                        Time: 15:50:49
                        Hex Value: 0x0000
                        Hex Value: 0x0782
                        Hex Value: 0x0014
                        Hex Value: 0x2391
                        Hex Value: 0x00FF
       Component: FBSAUDIC6 ELV   H31 0230
       Revision: 09010701    Serial number: 10601500840968
       Coding: 0000129
       Shop #: WSC 02323 758 00200
       VCID: 63C5CA86A2BE0752A0-8036
       Subsystem 1 - Part No: 4F0 910 131 D
       Component: FBSAUDIC6 EZS   H45 0070
       Component: FBSAUDIC6 IDG   H01 0040
       Part No SW: 4F0 910 732 A    HW: 4E0 035 729
       Component: Interfacebox    H43 4220
       Revision: 00000000    Serial number: 350GM077811056
       Coding: 0011001
       Shop #: WSC 02335 758 00200
       VCID: 2149808EF8225542F2-8074
       Subsystem 2 - Serial number: 00000000819019
       Subsystem 3 - Serial number: 0124.07.070000000100010377˙
       Subsystem 4 - Serial number: 010377˙
    00003 - Control Module
                        Fault Status: 01100101
                        Reset counter: 230
                        Mileage: 185294 km
                        Date: 2019.06.25
                        Time: 15:34:59
       Part No SW: 4F0 910 043 B    HW: 4F2 820 043 AA
       Component: KLIMABETAETIGUNGH30 0080
       Revision: 00000077    Serial number: 00000000798690
       Coding: 0524646
       VCID: 1D31BC7EC45A71A2D6-8048
    6 Faults Found:
    00018 - Motor for Cold-Air Flap (V197)
                003 - Mechanical Failure
                        Fault Status: 01100011
                        Fault Frequency: 11
                        Reset counter: 230
                        Mileage: 185284 km
                        Date: 2019.06.13
                        Time: 15:40:03
                        Voltage: 13.70 V
                        Temperature: 27.0°C
                        (no units): 95.0
                        (no units): 42.0
                        Temperature: 26.0°C
    00715 - Rear Footwell Vent Positioning Motor (V112)
                        Fault Frequency: 11
                        Reset counter: 230
                        Mileage: 185284 km
                        Date: 2019.06.13
                        Time: 15:40:03
                        Voltage: 13.70 V
                        Temperature: 27.0°C
                        (no units): 128.0
                        (no units): 215.0
                        Temperature: 26.0°C
                        Reset counter: 229
                        Mileage: 185284 km
                        Date: 2019.06.13
                        Time: 15:40:03
    00796 - Fan for Interior Temp Sensor (V42)
                        Fault Frequency: 17
                        Reset counter: 230
                        Mileage: 185284 km
                        Date: 2019.06.13
                        Time: 15:40:18
                        Voltage: 13.60 V
                        Temperature: 27.0°C
    00355 - Left Front Upper Body Outlet Motor (V237)
                        Fault Status: 00100011
                        Reset counter: 15
                        Mileage: 185294 km
                        Date: 2019.06.24
                        Time: 16:35:58
                        Voltage: 13.60 V
                        Temperature: 49.0°C
                        (no units): 37.0
                        (no units): 213.0
                        Temperature: 34.0°C
                        Reset counter: 15
                        Mileage: 185294 km
                        Date: 2019.06.25
                        Time: 15:41:42
       Part No SW: 4F0 910 279 K    HW: 4F0 907 279
       Component: ILM Fahrer      H15 0240
       Coding: 0001121
       Shop #: WSC 31574 000 104857
       VCID: 316970CEA8C2E5C262-8064
       Subsystem 1 - Part No: 4F1 910 113 C  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H06 0210
       Coding: 00064784
       Shop #: WSC 31574
       Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH13 0100
       Coding: 00146221
       Shop #: WSC 31574
    01835 - Bulb for Side-Blinkers; Right (M19)
                        Reset counter: 230
                        Mileage: 185280 km
                        Date: 2019.06.03
                        Time: 13:45:00
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 230
                        Mileage: 185280 km
                        Date: 2019.06.03
                        Time: 13:21:00
                        Reset counter: 230
                        Mileage: 185280 km
                        Date: 2019.06.03
                        Time: 13:21:00
    01024 - Rain Sensor (G213)
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 230
                        Mileage: 185292 km
                        Date: 2019.06.25
                        Time: 15:54:00
                014 - Defective
                        Reset counter: 230
                        Mileage: 185280 km
                        Date: 2019.06.03
                        Time: 13:19:00
       Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
       Component: MP3-Changer     H46 0350
       Revision: 00046006    Serial number: AUZ5ZBG3445490
       VCID: 183FAD6A2B78148A05-804C
                        Reset counter: 13
                        Mileage: 185280 km
                        Date: 2019.05.31
                        Time: 15:57:56
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 43 AIRBAG AUDI8RH30 0280
       Revision: 09H30000    Serial number: 0037LD0X6GHU
       Coding: 0013363
       VCID: 295998AE80129D02AA-807C
       Subsystem 1 - Serial number: 6332CSME105B3932
       Subsystem 2 - Serial number: 6342CSME39432F0FD
       Subsystem 3 - Serial number: 6352QSME590D1105B
       Subsystem 4 - Serial number: 6362QSME590D0F29V
       Subsystem 5 - Serial number: 63734SME1569084D4
       Subsystem 6 - Serial number: 63834SME59293803+
    01219 - Rear Side Airbag Igniter; Driver Side (N201)
    01220 - Rear Side Airbag Igniter; Passenger Side (N202)
    01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
                009 - Open or Short to Ground - MIL ON
       Revision: 00H02000    Serial number: 90054071430273
       Coding: 0002042
       Shop #: WSC 00000 758 00200
       VCID: 275D9E969606AB72BC-8072
       Component: E0221           H02 0100
       Part No SW: 4F0 910 930 C    HW: 4F0 920 933 J
       Component: KOMBIINSTR. M73 H21 0220
       Revision: 00600000    Serial number: 6IN10EG77
       Coding: 3076058
       Shop #: WSC 11111 111 11111
       VCID: 23458A86E23E4752E0-8076
    Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
       Component: Gateway         H11 0070
       Revision: 11          Serial number: 13008077098098
       Coding: 6CEE73C41B2104
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 230
                        Mileage: 185294 km
                        Date: 2019.06.25
                        Time: 15:32:40
       Part No SW: 4E0 910 887 T    HW: 4E0 919 887 M
       Component: MNS ECE         H50 1030
       Revision: 00000000    Serial number: 364GR077700671
       Shop #: WSC 21240 142 87008
       VCID: 3E735BF2699C0ABAEF-806A
                        Reset counter: 13
                        Mileage: 185280 km
                        Date: 2019.06.03
                        Time: 14:19:22
                        Bin. Bits:     1100
       Component: TSG FA          H12 0210
       Revision: 00000000    Serial number: H
       Coding: 0003690
       Shop #: WSC 02327 758 00200
       VCID: 2C5761BA8FE0882A51-8078
       Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
       Component: Komfortgeraet   H25 0200
       Revision: 02000025    Serial number: 01056221610000
       Coding: 0139909
                        Fault Status: 01101001
                        Fault Frequency: 89
                        Reset counter: 230
                        Mileage: 185261 km
                        Date: 2007.03.04
                        Time: 05:20:09
    01696 - Footwell Lighting; Rear Left (W45)
                        Reset counter: 230
                        Mileage: 185245 km
                        Date: 2007.03.06
                        Time: 08:27:29
    01697 - Footwell Lighting; Rear Right (W46)
                        Reset counter: 230
                        Mileage: 185245 km
                        Date: 2007.03.06
                        Time: 08:27:29
    00834 - Signal for Activation of Heated Rear Window
                        Reset counter: 225
                        Mileage: 185255 km
                        Date: 2007.06.21
                        Time: 06:25:52
    01503 - Bulb for 3rd Brake Light (M25)
                        Fault Status: 00101001
                        Reset counter: 14
                        Mileage: 185289 km
                        Date: 2019.06.15
                        Time: 13:38:28
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 4F0 910 223 K    HW: 4F0 035 223 L
       Component: Amp.-ASK-RD   H07 0250
       Revision: S0900000
       Coding: 020001
       Shop #: WSC 02399 823 56573
       VCID: 26439392510CB27A87-8072
       Part No SW: 4F0 910 280     HW: 4F0 907 280
       Component: ILM Beifahrer   H12 0100
       Revision:             Serial number: 00000000238860
       Coding: 0001003
       VCID: 5EB3FB7289DC2ABA8F-800A
       Component: TSG BF          H12 0210
       Revision: 00000000    Serial number: Qb1
       Coding: 0003610
                        Reset counter: 228
                        Mileage: 185280 km
                        Date: 2019.06.03
                        Time: 13:44:59
       Part No SW: 4F0 910 801     HW: 4F0 907 801
       Component: EPB  C63C0030   H03 0030
       Revision: C63C0030
       Coding: 0000311
       Shop #: WSC 02334 785 00200
       VCID: 5DB1FC7E84DA31A296-8008
    00650 - Clutch Pedal Switch (F36)
                014 - Defective
                        Fault Frequency: 169
                        Reset counter: 228
                        Voltage: 10.77 V
                        Count: 73
       Part No: 8P0 907 357 H
       Coding: 0000003
       Shop #: WSC 02325 758 00200
       VCID: 3F8D26F66E9603B2E4-806A
       Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
       Revision: 00000000    Serial number: 394G%077795183
       VCID: 2E536BB2B9FCFA3A7F-807A
       Revision: 00000000    Serial number: 00000000129131
       Shop #: WSC 40380 123 59342
       Subsystem 1 - Part No: 4F0 915 105 A
       Component: von VA0  7922110398
       Coding: 344630393135313035412056413037393232313130333938
       Shop #: WSC 21033 146 56200
    02254 - Interface to Generator
                        Fault Frequency: 16
                        Reset counter: 228
                        Mileage: 185280 km
                        Date: 2019.06.03
                        Time: 13:41:50
    02479 - Partial Consumer Shut-Off Active
                000 -  -  - Intermittent
                        Fault Frequency: 9
                        Mileage: 185280 km
                        Date: 2019.06.03
                        Time: 14:01:26
                        Reset counter: 13
                        Mileage: 185280 km
                        Date: 2019.06.03
                        Time: 14:19:14
    02272 - Quiescent Current Stage 1
                        Mileage: 185280 km
                        Date: 2019.06.10
                        Time: 14:48:14
    02256 - Quiescent Current
                        Fault Status: 00100001
                        Reset counter: 15
                        Mileage: 185294 km
                        Date: 2019.06.24
                        Time: 05:28:06
       Component: TSG HL          H21 0210
       Coding: 0003114
       Shop #: WSC 02327 785 00200
    02123 - Door Warning Light / Entry Light
                        Reset counter: 228
                        Mileage: 185280 km
                        Date: 2019.06.03
                        Time: 13:34:08
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Component: TSG HR          H21 0210
       Coding: 0003114
                        Reset counter: 228
                        Mileage: 185280 km
                        Date: 2019.06.03
                        Time: 13:34:59
    End-------------------------(Elapsed Time: 02:21)--------------------------
  2. Likes Boki Ar liked this post
  3. #2
    Jun 2016
    Poland
    Anyone, please?
    Quote Originally Posted by Oski View Post
    Anyone, please?
    The ABS ECU is complaining about faults on the engine ECU and airbag ECU, so it looks like you need to correct those first
  5. Likes Oski, Dana liked this post
  6. #4
    Jun 2016
    Poland
    I'm pretty sure, it's complaining because the coding is messed. I've been fiddling with a few coding I found on the internet, and with some of them esp doesn't throw "01314 - Engine Control Module" fault. I haven't changed airbag coding too, Is anyone able to get coding for this vin number, please?
  7. Likes Dana liked this post
  8. #5
    United States
    Wow! I didn't know Audi made CVT (G0Z Variable gearing ratio) TDIs in the 4F chassis. I can see why putting a manual trans in this made sense.
    Please see if the coding of 0020875 is accepted.
  9. Likes jyoung8607, Uwe, NEtech, Oski liked this post
  10. #6
    United States
    P.S. If the ABS accepts 0020875 that was based on theses PR codes:
    1ZL Silver caliper
    1KW Disc brakes in rear
    1X0 Front-wheel drive
    G0K 6-speed manual transmission
    TA1 6-cylinder diesel engine 2.7 l unit 059.F
    1BV Sports suspension/shock absorption
    1D0 without trailer towing
    Some of those may be relevant to the mentioned Airbag ADP channels.
  11. Likes jyoung8607, Uwe, Oski liked this post
  12. #7
    Jun 2016
    Poland
    Dana, you're a star It worked, I was able to clear the faults. Adaptations channel 51 was set wrong too. All sorted, thank you!
  13. Likes Uwe, Dana liked this post
