We have 2017 5E5 Skoda Octavia and broken electric trunk motors which are now removed and changed to manual gas springs.
Trunk is functional, opens, closes and locks but we have two issues.
First, the car thinks trunk is open all a time, even its closed sometimes. Warning shows on instrument cluster.
Second, soft closing function is disabled. Probably because of faults on control module and wrong coding.
Can anyone help with this, thanks.
Here is Trunk electric faults:
Here is full scan:
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 5E0 959 107 A HW: 5E0 959 107
Component: HDSG-Modul H01 0746
Revision: 42001001 Serial number: 318601465
Coding: 1213074000
Shop #: WSC 73430 790 00000
ASAM Dataset: EV_HDSGSk462 301136
ROD: EV_HDSGSk462_SK37.rod
VCID: 2A516A774DDFC11FE7-807E
0051 - Hall Sensors in Motor 1 for Rear Lid
B1211 12 [137] - Short to Plus
Reset counter: 228
Mileage: 256439 km
Date: 2019.06.10
Time: 19:34:27
Voltage terminal 30: 12.17 V
Here is full scan:
Sunday,07,July,2019,11:55:53:08424
VCDS Version: 19.6.1.0 (x64)
VIN: TMBLK7NE9H0131167 License Plate: PEPE
Mileage: 257631km-160084mi Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 20 22 2B 36 42 44 52
55 5F 6D
VIN: TMBLK7NE9H0131167 Mileage: 257631km-160084miles
Address 01: Engine (J623-CUNA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 BT HW: 04L 907 309 R
Component: R4 2,0L EDC H23 1542
Revision: B5H23---
Coding: 011D001A032601081000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM20TDI01104L906026BT 002003
ROD: EV_ECM20TDI01104L906026BS_002.rod
VCID: 7DFB912BECD186A7F2-8028
28253 - Coolant Pump 3
P26F8 00 [032] - Stuck
Mileage: 256713 km
Date: 2019.06.16
Time: 09:12:58
Engine speed: 769.00 /min
Normed load value: 52.9 %
Coolant temperature: 19 °C
Intake air temperature: 23 °C
Voltage terminal 30: 13.340 V
Unlearning counter according OBD: 23
Engine status: COENG_RUNNING
Part No SW: 0D9 300 014 K HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5005
Revision: 06454104 Serial number: TFK01610271444
Shop #: WSC 73430 031 00063
ROD: EV_TCMDQ250021.rod
VCID: 2045885F3BE30B4FB9-8074
Address 03: ABS Brakes (J104) Labels:* 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AQ HW: 5Q0 614 517 AF
Component: ESC H62 0400
Revision: 00000000 Serial number: 63186000000697
Coding: 1C0762913423096D4078070640CA2938462C9002E002947410615070C009430000010312121212B435351919323200
ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
ROD: EV_Brake1UDSContiMK100ESP_036.rod
VCID: 0005E8DF9B23EB4F99-8054
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0423170175
Coding: 032C0C
VCID: 3B7F5F33B24548978C-806E
Part No SW: 5E0 907 044 AH HW: 5E0 907 044 AH
Component: Climatronic H04 1601
Revision: 00001K07
Coding: 02010104004111011005000100101002
VCID: 6BDFAF7382A518175C-803E
Air quality sensor:
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Revision: -------- Serial number: 8658161116003D
Coding: 0C011B76C24722FB0FA44086B11C17280C00000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 030FE7D38A35F05784-8056
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 161019 041 0570
Serial number: 161107005347
Coding: 065DDD
Component: RLHS 042 0105
Serial number: S7Y16M11D17H19M39S54
Coding: 00885D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY162351Z0H
Serial number: 00000000000067507158
Revision: -------- Serial number: 39331632304290
Coding: 0031051051
Shop #: WSC 73430 790 00063
VCID: 438F27D3CAB53057C4-8016
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 K HW: 5Q0 907 572 K
Component: ACC Bosch MQB H05 0402
Serial number: 15111604510635
Coding: 00001200FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001016
VCID: 3F872B23A65D54B7A0-806A
Part No SW: 3Q0 959 655 AK HW: 3Q0 959 655 AK
Component: Airbag VW21 004 0305
Revision: -------- Serial number: 003R6PP371Z3
Coding: 98CCC000000000005C5400CC000800000065
ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 0717F3C3BE0DDC77D8-8052
Subsystem 1 - Part No SW: ----------- HW: 454 000 311 16
Serial number: 35700000000FA81C2C1X
Subsystem 2 - Part No SW: ----------- HW: 454 000 211 16
Serial number: 358000000005D819EE1
Subsystem 3 - Part No SW: ----------- HW: 454 803 010 16
Serial number: 3510072F65A0D000000O
Subsystem 4 - Part No SW: ----------- HW: 454 803 110 16
Serial number: 35200A46F550D000000P
Subsystem 5 - Part No SW: ----------- HW: 454 801 610 16
Serial number: 3550095BD4C0D000000.
Part No SW: 5Q0 953 507 HQ HW: 5Q0 953 549 E
Revision: -------- Serial number: 19111604221294
Coding: 1410
VCID: 0C1DCCEFA76BBF2FF5-8058
Part No SW: 5E0 920 751 C HW: 5E0 920 751 C
Component: KOMBI 305 8311
Coding: 07A40818A980000801882A011000000000000000
VCID: 254B994B24C1EE67CA-8070
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 G HW: 5Q0 963 272 G
Component: STH-MQB 008 0075
Coding: 9309
VCID: 3A715A37BD7F719F97-806E
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000145481
Component: GW MQB High 418 4286
Revision: -------- Serial number: 0005579412
Coding: 030100045F087300EB00024A1C0F00010001050000000000000000000000
ROD: EV_GatewNF.rod
VCID: 2F677B63763DA43730-807A
Subsystem 2 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000A2252281016
Serial number: 75410803001611164774
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 3G0 857 511 G HW: 3G0 857 511 G
Component: FLA H10 0003
Revision: AA001001
Coding: 0202000700000000000000
ASAM Dataset: EV_HighBeamAssisAU33X 001017
ROD: EV_HighBeamAssisAU33X_VW37.rod
VCID: 2C5D6C6F472BDF2F15-8078
Serial number: HA1-00025.10.16
Coding: 0001
VCID: 4A910AF7ED9FE11F07-801E
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000188019010
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 346D740F9F1B87EF4D-8060
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H08 0020
Serial number: Y0006PJE16303
Coding: 0010000000000500018480808080000000008181000000D400
ASAM Dataset: EV_SeatMemorDriveSide 002021
VCID: 3C7D5C2FB74B4FAF85-8068
Component: TSG FS 010 0032
Serial number: 0000229021492
Coding: 00110820DE00040000001100
VCID: 479733C3FE8D1C7718-8012
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000012334055
Coding: 010200
65588 - Motor for Window Regulator
B1487 54 [009] - Missing Calibration / Basic Setting
Reset counter: 228
Mileage: 256439 km
Date: 2019.06.10
Time: 19:46:09
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 129 1072
Coding: 8107
ROD: EV_SteerAssisMQB_013.rod
VCID: 458B39CBC4810E67EA-8010
Component: TSG BFS 010 0032
Serial number: 0000229223590
Coding: 00110020DE00040000001100
VCID: 46893EC7F987057FE3-8012
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000012145531
Coding: 190200
Component: AFS-ECU H07 0090
Coding: 03EA00003F000000
VCID: 408528DFDBA32B4FD9-8014
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 840 B HW: 5Q0 035 840 B
Component: MU-S--ER H30 0359
Serial number: SKZAZ2S5279449
Coding: 03730200FF00000011110001000800002F0100C40120810002
ROD: EV_MUStd4CTSAT_VW41.rod
Subsystem 1 - Part No SW: 5E0 919 605 H HW: 5E0 919 605 H
Component: ABT_Std-2 H43 1031
Serial number: SKZ8Z9SLG01U88
Coding: 1213074000
Reset counter: 228
Mileage: 256439 km
Date: 2019.06.10
Time: 19:34:27
End-------------------------(Elapsed Time: 05:11)--------------------------
