Results 1 to 4 of 4
Thread: Install the homelink
    Verified VCDS User rammstein's Avatar
    Jul 2019
    Belgium
    hello everyone
    I install the kit homelink all and ok I think,
    now i have to go with the vcds in
    - Activation of the green menu
    Module 5F → Adaptation (10) → Channel 6 → Set new value to 1
    impossible to go?
    my question would not be on
    - Address 07 "Control head" connect Select setting (10) - - Channel number "08",
    select, note the current value (!!!) - Set the value to "1"
    on channel 00 I have to put 01? or I have to click on until 08? then?
    I thank you for your help
    Got an Auto-Scan so we know what car this is and how it's equipped?
    Jul 2019
    Belgium
    Saturday,06,July,2019,10:47:51:00103
    VIN: WAUZZZ8K79N074262   License Plate:
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 03 05 07 08 09 0E 10 15 16 17 19 37 42 46 47 52 53 55 56
              62 69 72
    VIN: WAUZZZ8K79N074262   Mileage: 160130km-99500miles
    Address 01: Engine (J623-CAGB)       Labels:| 03L-906-022-CAG.clb
       Part No SW: 03L 906 022 ML    HW: 03L 906 022 B
       Component: R4 2.0l TDI   H01 9978
       Revision: 11H01---
       Coding: 0104002C18072920
       Shop #: WSC 00606 002 1048576
       ASAM Dataset: EV_ECM20TDI03L906022ML A01008
       ROD: EV_ECM20TDI03L906022.rod
       VCID: 7BA3F66BF36566AF9FB-802E
       Part No SW: 8K0 907 379 AE    HW: 8K0 907 379 AE
       Component: ESP8 front    H04 0240
       Coding: 168500
       Shop #: WSC 02391 823 56573
       VCID: 7CA1F577F6EB6197961-8028
       Part No SW: 8K0 907 064 BC    HW: 8K0 907 064 BC
       Component: BCM2 1.1      H90 0247
       Coding: 030100
       Shop #: WSC 02399 823 56573
       VCID: 72BDDB4FA4AF27E7CCD-8026
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Serial number: 0509000017017020
       Component: J764 ELV MLB  H36 0042
       Serial number: 0209000020198005
    Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
       Part No SW: 8T0 035 729 T    HW: 4E0 035 729
       Component: Interfacebox    H43 5570
       Revision: 00000000    Serial number: 329D-097644259
       Coding: 0000006
       VCID: 4ACD63AFE0BF0F2754D-801E
       Subsystem 1 - Part No: 8T0 919 609
       Component: E0380 BedienteilH08 0100
       Subsystem 2 - Serial number: 00000000267861
       Subsystem 3 - Serial number: 0107.04.090000000100010004˙
       Subsystem 4 - Serial number: 010004˙
    00003 - Control Module
                        Fault Status: 01100101
                        Reset counter: 58
                        Mileage: 159800 km
                        Date: 2019.06.30
                        Time: 18:20:52
                        Reset counter: 58
                        Mileage: 159800 km
                        Date: 2019.06.30
                        Time: 18:35:59
                        Bin. Bits: 00000001 10000000
                        Bin. Bits: 00000000 00000000
       Part No SW: 8T1 820 043 T    HW: 8T1 820 043 T
       Component: KLIMA 1 ZONE  H06 0150
       Revision: A0000000    Serial number: 01140420092030
       Coding: 34000000
       VCID: 42DD4B8FD48FD7679CD-8016
       Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
       Component: BCM1 1.0      H24 0253
       Revision: 04024001    Serial number: 00000000235459
       Coding: 260050914034AF000001000000001D0D001C230880010121000000
       VCID: 2F3B123B771D4A0F633-807A
       Component: WWS 030409  H06 0070
       Serial number: SWF09040035739
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10436445
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 Q    HW: 8K0 941 531 Q
       Component: E1 - LDS  H07 0090
       Serial number: 00000000002503090403
       Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
       Component: HOMELINK  H01 0010
       Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
       Component: MP3-Changer     H43 0390
       Revision: 00043003    Serial number: AUZ5ZBI8784220
       VCID: 2A0D032F40FF2F27B4D-807E
       Part No SW: 8K0 919 475 F    HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0040
       Revision: 11001001    Serial number: 40140909618545
       Coding: 110003
       VCID: 3C213577B66BA197D61-8068
       Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
       Component: AirbagVW-AU10 H27 0410
       Serial number: 0038JD1FDW5N
       Coding: 30343435363030303030554A304C384B3053
       Shop #: WSC 02135 785 00200
       VCID: 3C213577B6EBA197D61-8068
       Serial number: 6334MSME4736206EF
       Serial number: 6344MSME46537779M
       Serial number: 6352QSME67064A18J
       Serial number: 6362QSME54201E004
       Serial number: 63732SME59234130Q
       Serial number: 63832SME6C232732.
       Part No SW: 8K0 953 568 E    HW: 8K0 953 568 E
       Revision: --------    Serial number: 90315ICV0000X
       Coding: 000006
       Part No SW: 8K0 920 930 C    HW: 8K0 920 930 C
       Component: KOMBIINSTR.   H18 0224
       Revision: 00200000    Serial number: 9E232U149
       Coding: 0F4D080002010108010000
       VCID: 2D0708337D11381F51F-8078
                        Reset counter: 58
                        Mileage: 159800 km
                        Date: 2019.06.30
                        Time: 18:21:52
       Part No SW: 8T0 907 468 P    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0095
       Revision: EB500046    Serial number: 4600E0932880AA
       Coding: 000303
       VCID: 4EC56FBF10D72307085-801A
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H06 0160
       Serial number: 190728E6250309
    02256 - Quiescent Current
                        Fault Status: 00100001
                        Reset counter: 102
                        Mileage: 159800 km
                        Date: 2019.06.30
                        Time: 22:07:00
                        Fault Frequency: 24
                        Reset counter: 102
                        Mileage: 159800 km
                        Date: 2019.07.01
                        Time: 02:07:00
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
       Component: MNS ECE         H52 1060
       Revision: 00000000    Serial number: 333DV097655176
       Shop #: WSC 03051 202 93215
       VCID: 3B23366BBF65A6AFDFB-806E
       Part No SW: 8K0 959 793 E    HW: 8K0 959 793 E
       Revision:             Serial number: 0000008616964
       Coding: 011602204000410001
       Revision: 00002001    Serial number: 0115861355
       Coding: 011E1620003940400120010000000000
       Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
       Component: GTO BF  H06 0050
       Serial number: 00000000000000281157
       Subsystem 2 - Part No: 8K0 951 177
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 58
                        Mileage: 159802 km
                        Date: 2019.07.02
                        Time: 18:02:54
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 58
                        Mileage: 159802 km
                        Date: 2019.07.02
                        Time: 18:16:25
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-BAM.clb
       Part No SW: 8T0 035 223 AE    HW: 8T0 035 223 R
       Component: DSP Basic     H08 0300
       Revision: S2600000
       Coding: 010101
       VCID: 71BFD443A1A91CFF357-8024
       Part No SW: 8K0 959 792 E    HW: 8K0 959 792 E
       Revision:             Serial number: 0000008747377
       Coding: 011602204C00410001
       VCID: 41DF4483D189CC7F857-8014
       Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
       Component: EPB Audi B8   H08 0080
       Revision: 00000003    Serial number: 00000000343156
       VCID: 33331E4B9B356EEF07B-8066
       Part No: 8K5 907 357
       Coding: 0000004
       Shop #: WSC 02145 785 00200
       VCID: 77ABEA5BC3CD42CFFB3-8022
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 N
       Revision: 00000000    Serial number: 379D/097591626
       VCID: 313F14436D295CFF757-8064
       Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
       Revision:             Serial number: 0000100937799
       Coding: 010602204000210001
       VCID: 44D14D97CE9BD957AE1-8010
    Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
       Part No SW: 8K0 907 383 B    HW: 8K0 907 383 B
       Component: Anhaenger     H08 0080
       Revision: 1A002002    Serial number: 00000117879660
       Coding: 0100000000000000
       Revision:             Serial number: 0000100937795
    End----(Elapsed Time: 01:50, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
    Moved to Retrofits.
