Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: 2014 Audi RS7 ABS/ESP madness... sorry for long windedness
    Jun 2018
    HELLO to all of you masters of the hexadecimal/binary matrix and you Vag Com wizards!!!!
    PLEASE trust that I wouldn't be here asking for help if I didn't, for one second, think that I'd exhausted all possible scenarios my pea-brain could come up with.
    I've turned to these forums for help on a similar vehicle.....we were trying to completely delete the DRC system on a 2014 RS7, and with the help of you all, we succeeded AND gained some valuable insight.
    Well, here we are again in a similar yet very different situation...….This time we are trying to delete the factory air suspension (34 level control) on another 2014 RS7 (our shop project car). We've made great progress with this conversion using knowledge gained from our last outing.....however, we find ourselves stuck trying to gain security access to the ABS/ESP unit in order to change the coding and adaptations on this car. At this point I believe the fault we are receiving (see auto scan) is telling us why the car is not allowing us to turn off our traction control off(via switch) ….. which is a vital step in order to drag-race one of these vehicles and engage the AMAX shifting strategy in the TCU.,
    It seems as if the recommended access code "61378" (so nicely provided by Ross-Tech)does not play well with our control unit. We receive "Controller refused the key! Error 35: invalid key" message.
    Does anyone have any other suggestions for said security access key so we can implement changes in our code?
    PS, please ignore faults in ECM related to mods we've made.... As well as faults in range control and night vision which SHOULD be rectified by some pin changes and jumper wires to satisfy height sensor inputs.
    Thank you in advance!!!!!
    Saturday,06,July,2019,16:13:25:27499
    Dealer/Shop Name: SES
    VIN: WUAW2BFC1EN902414   License Plate:
    Chassis Type: FC-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 28 36 3B 3C 42 44 46
              47 52 53 55 56 5F 62 65 6C 6D 72 82 84 85 8B 8E 8F 90 BA
    VIN: WUAW2BFC1EN902414   Mileage: 88389km-54922miles
    84-Night Vision -- Status: Malfunction 0010
    BA-Motor Mounts -- Status: Malfunction 0010
    Address 01: Engine (------CRDB)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G0 906 560 B    HW: 4H0 906 014
       Component: 4.0l V8TFSI / H62 0004
       Revision: NCH62---
       Coding: 1A2A003265460A0E1000
       ASAM Dataset: EV_ECM40TFS0114G0906560B 001008
       ROD: EV_ECM40TFS0114G0906560B.rod
       VCID: 271E009B5E867F77F8-8072
    17875 - Exhaust Pressure Control Valve
              P0475 00 [039] - Electrical Malfunction
                        Mileage: 88389 km
                        Date: 2019.07.06
                        Time: 16:08:26
                        Coolant temperature: 87 °C
                        Intake air temperature: 73 °C
                        Voltage terminal 30: 13.052 V
                        Engine status: COENG_READY
    17876 - Exhaust Pressure Control Valve 2
              P049F 00 [039] - Malfunction
                        Mileage: 88389 km
                        Date: 2019.07.06
                        Time: 16:08:26
    12352 - Coolant Pump for Intercooler
              P023A 00 [039] - Open Circuit
                        Mileage: 88389 km
                        Date: 2019.07.06
                        Time: 16:08:26
    Readiness: 1110 1100
       Part No SW: 4G0 927 158 BE    HW: 0BK 927 156 AM
       Component: 0BK 40TFSIUSA H16 1006
       Revision: --H16---
       Coding: 000001
       VCID: 72A821CFA5C44ADF9F-8026
       Part No SW: 4G0 907 379 P    HW: 4G0 907 379 P
       Component: ESP PREMIUM   H09 0100
       Coding: 61B7530386EDCAC04B00
       ASAM Dataset: EV_ESPPremiAU57X 004036
       VCID: 3E30C5FFA11CDEBFAB-806A
    0055 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ComScl_PDU_Fahrwerk_02_Timeout]
                        Reset counter: 44
                        Mileage: 88389 km
                        Date: 2019.07.06
                        Time: 16:08:24
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: BD
                        Uz: AA
       Part No SW: 4H0 907 064 DR    HW: 4H0 907 064 DR
       Component: BCM2 2.0      H35 0510
       Coding: 0D8A2046000000000000
       VCID: 7CB40FF7FF800CAFC5-8028
       Serial number: 0213000372472003
       Part No SW: 4G0 820 043 AM    HW: 4G0 820 043 AM
       Component: KLIMA 4 ZONEN H14 0093
       Serial number: 12111300040320
       Coding: 680320785D
       ASAM Dataset: EV_AirCondiComfoUDS 004003
       ROD: EV_AirCondiComfoUDS_004.rod
       VCID: 6A9839AF8D14821F27-803E
       Revision: 11012002    Serial number: 00000001497574
       Coding: 0D073811013E9FE2A10000C7A0003820CF94D208A2090221800308457B00
       VCID: 6FAE28BBBEF6673770-803A
       Component: WWS57X 131030  H36 0080
       Serial number:         131101034755
       Coding: 0045F7
       Serial number: 21948910
       Coding: 02006E
       Subsystem 3 - Part No SW: 4G0 941 531 H    HW: 4G0 941 531 H
       Component: E1 - LDS  H07 0044
       Serial number: 29 10 2013  00001034
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R8MSB03
       Subsystem 5 - Part No SW: 4G0 907 472     HW: 4G0 907 472
       Component: A31 LED Mod1L  H02 0002
       Serial number: 00000000001311141262
       Subsystem 6 - Part No SW: 4G0 907 472     HW: 4G0 907 472
       Component: A27 LED Mod1R  H02 0002
       Serial number: 00000000001311141293
       Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA106973000005340362
       Coding: 020300
       Serial number: 04E889D6000000000001
       Subsystem 9 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
       Component: A32 LED Mod2L  H02 0002
       Serial number: 00000000001311090388
       Subsystem 10 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
       Component: A28 LED Mod2R  H02 0002
       Serial number: 00000000001311090393
       Part No SW: 4H0 919 475 AC    HW: 4H0 919 475 AG
       Component: PARKHILFE ACC H01 0091
       Revision: 11001001    Serial number: 61061330403472
       Coding: A8E90D
       VCID: 73A624CBDADE43D794-8026
       Part No SW: 4G0 907 561 A    HW: 4G0 907 561
       Component: ACC3          H19 0410
       Coding: 7601010101
       ASAM Dataset: EV_AdaptCruisContrAU57X 002010
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 281C03A75398700FF1-807C
       Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
       Component: Airbag10.43   H33 0033
       Revision: --------    Serial number: 003D8003PEYE
       Coding: 303145313131303030344A55304C34473853
       VCID: 3326E4CB9A5E03D754-8066
       Serial number: 6940000Y130000YC6Z0F
       Serial number: 3575HRB400M50O5UBA0E
       Serial number: 3585HRB401250LNGG1MF
       Serial number: 3515JRB400250OCCE10G
       Serial number: 3525JRB401450OM6A1O1
       Serial number: 3554VRB40532FFOAGGBZ
       Serial number: 3564VRB40532FFOA6OI+
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Revision: --------    Serial number: 90372MK8000A9
       Coding: 0000FC
       VCID: 373ED0DB8626EFF768-8062
       Serial number: 21 10 2013  E0270632
       Part No SW: 4G8 920 984 C    HW: 4G8 920 984 C
       Component: TBenUsaAccNv  H58 0621
       Revision: 29460235    Serial number: 658071113596001
       Coding: 03CF010C8F53D705020500
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 3620DDDF892C16FF73-8062
       Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
       Revision: --------    Serial number: 00000001182164
       Coding: 00E1034800
       Serial number: 1566931603
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H16 0200
       Serial number: 000311130001928
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
       Part No SW: 4G0 919 158 M    HW: 4G0 919 158 M
       Component: KLIMA FOND    H08 0093
       Serial number: 13111300042089
       Coding: 20
       ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
       VCID: 393AD6E3B832F9879E-806C
       Revision: AA000000    Serial number: 00000081288874
       Coding: 00581B0000002001000001010101102030303232203232
       VCID: 77BE10DBC6A62FF7A8-8022
       Component: SARA 6D red   H03 0056
       Revision: --------    Serial number: EJ1BPA7E00S2HJ
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 373ED0DB8E26EFF768-8062
       Part No SW: 4G0 907 566 L    HW: 4G0 907 566
       Component: J769  SWA MasterH04 0010
       Revision: 00H04000    Serial number: 6PZ 010 287-10
       Coding: 0000006
       VCID: 383CD3E74B38E08F61-806C
       Subsystem 1 - Part No: 4G0 907 568 L
       Component: J770  SWA Slave H04 0010
       Subsystem 2 - Serial number: 6PZ 010 287-30
       Subsystem 3 - Serial number: 5F10.10.1300H04000AMS14795ÿ
       Subsystem 4 - Serial number: S14795ÿ
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0507
       Coding: 011F57025E00628002000413
       VCID: 45C2AA13CCCA8D67EA-8010
       Component: RCEPS         H39 0010
       Revision: 00001000    Serial number: 0008023935
       Coding: 101001010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 3228E1CF65440ADF5F-8066
       Revision: 00002001    Serial number: 0320281437
       Coding: 0126063A20FAF08580B00A80020114000000000000000000000000000000
       Component: GTO BF  H01 0081
       Serial number: 00000000000000191218
       Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
       Component: J245 PS40.039  H01 0008
       Serial number:     WOO2512280.
       Coding: 101F00
       Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
       Serial number: 0000000AP00005169296
       Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H11 0029
       Serial number: WA107207000005343701
       Part No SW: 4G0 035 465 C    HW: 4G0 035 465 B
       Component: BO G3 C7      H09 0160
       Revision: 11000000    Serial number: 0018200
       VCID: 25020A932C8A6D67CA-8070
       Subsystem 1 - Part No SW: 4G0 035 466     HW: 4G0 035 466
       Component: BO C7 SLAVE  H51 0100
       Serial number: 02809130025434
       Coding: 011F57025E00628002000402
       VCID: 46C0AD1FF1CC867FE3-8012
       Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
       Component: EPB-4         H03 0014
       Revision: --------    Serial number: 00000000887695
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2C14FFB747605C2F15-8078
       Serial number: 131118-0001-016
       Coding: 1223A6601002A400
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2D12F2B37C7A552702-8078
    126986 - Front Left Ride-Height Sensor
              C1034 15 [137] - Open or Short to Plus
                        Reset counter: 44
                        Mileage: 88389 km
                        Date: 2019.07.06
                        Time: 16:08:25
    127242 - Rear Left Ride-Height Sensor
              C1036 15 [137] - Open or Short to Plus
                        Reset counter: 44
                        Mileage: 88389 km
                        Date: 2019.07.06
                        Time: 16:08:25
    393989 - Headlight
                        Reset counter: 44
                        Mileage: 88389 km
                        Date: 2019.07.06
                        Time: 16:08:24
       Component: Radio U SIRIU H60 0133
       Revision: AB001007    Serial number: 156K50D7936506
       Coding: 020007010000000001
       VCID: 2404179727B0946FDD-8070
       Part No SW: 4G0 035 746 F    HW: 4G0 035 746 E
       Component: H-BNT-NA      H41 0757
       Revision: --------    Serial number: 194KF0D7595594
       Coding: 0B0200040303EDEF7D16CB3E00000003100001000000000000
       VCID: 2A18F9AF4594421FE7-807E
       Subsystem 1 - Part No: 8R0 060 884 BL
       Component: NAR 2014  0902
       Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
       Component: DU8 C7 SV  H43 0021
       Serial number: AUZ8ZDDD0032FUZ
       Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
       Serial number: 90349MK800087
       Component: CD-Database  5571
       Coding: 010F17024000628002000002
       VCID: 49DAA623E0D269070E-801C
    Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
       Part No SW: 4H0 907 273     HW: 4H0 907 273
       Component: RDKBERU25     H09 0700
       Serial number: 10000000005070
       ROD: EV_RDKBERU25_AU57.rod
       VCID: 689C43A79318B00F31-803C
       Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
       Component: TopView       H05 0220
       Revision: 11001001    Serial number: 82330JF0118189
       Coding: 0206000001010100000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
       ROD: EV_CamerSysteTopViewAUDI_007_AU57.rod
       Part No SW: 4G8 959 107 R    HW: 4G8 959 107 G
       Component: HDSG-Modul    H13 0043
       Revision: 12013001    Serial number: 290300178
       Coding: 0A3305C102
       ASAM Dataset: EV_HDSGAu573 001022
       ROD: EV_HDSGAu571.rod
       VCID: 44C4B717CFF0B46FFD-8010
       Part No SW: 4G8 919 604 K    HW: 4G8 919 604 K
       Component: HeadUpDisplay 004 0201
       Coding: D60000
       ASAM Dataset: EV_HUDContiC7 001023
       ROD: EV_HUDContiC7.rod
       VCID: 3B36CCEBB20ECB978C-806E
    Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
       Part No SW: 4H0 907 547 F    HW: 4H0 907 547
       Component: NV-ECU-Gen1   H10 0042
       Serial number: 0K84AE40103446
       Coding: 1411
       ASAM Dataset: EV_NightVisioGen1 001002
       ROD: EV_NightVisioGen1.rod
       Night vision system camera:
       Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
       Component: NV-CAM-Gen1  H09 0008
       Serial number: 00000000001231200086
    9986 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [LWR_AFS: Fehlerspeicher auslesen]
                        Reset counter: 44
                        Mileage: 88389 km
                        Date: 2019.07.06
                        Time: 16:08:24
       Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H26 0038
       Coding: 6A060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 26000D9F598C667FC3-8072
       Part No SW: 4G0 907 541 A    HW: 4G0 907 541
       Component: ACC3          H19 0400
       Coding: 7601010101
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       Part No SW: 4G0 907 107 E    HW: 4H0 907 107
       Component: BV-SG         H32 0041
       Serial number: 005000121211137
       Coding: 03C19A1A0111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Coding: 0066E608031F0376070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 312AEEC3604231C726-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145     HW: 4H0 907 145
       Component: AEM - LEAR    H07 0006
       Revision: 00001001    Serial number: 97809002752200
       ASAM Dataset: EV_AEMLearAU64X 002014
       ROD: EV_AEMLearAU64X_AU57.rod
       VCID: 66804D9F990CA67F03-8032
    1294 - Actuator 1 for Drivetrain Mounts
              C1131 07 [009] - Mechanical Failure
                        Reset counter: 44
                        Mileage: 88389 km
                        Date: 2019.07.06
                        Time: 16:08:28
    End----------(Elapsed Time: 02:56, VBatt start/end: 13.6V/14.0V)-----------
  2. Likes Dana liked this post
  3. #2
    Since the source of this problem is a suspension retrofit, I'm moving this to the Retrofits section.
    Jun 2018
    Understood, thank you.
    Jun 2018
    Just wanted to add another thing that is strange....
    If I copy the coding that is already in the ABS control unit, and then paste it directly in the box for new coding, I get an error...
    Coding rejected
    error 13: incorrect message length or invalid format.
    Yet its the exact same long code!!
    Does that maybe help? Is there something Im missing? I feel like Im bashing my head against the wall.
    Thank you
    Quote Originally Posted by gillmotorsports View Post
    “Coding rejected
    error 13: incorrect message length or invalid format”.
    Yet it’s the exact same long code!!
    Did you do a Security Access first?
    Jun 2018
    Yes. Please see initial post. I receive an error when I enter the provided access key.
    Furthermore, I happen to have access to the other RS7 I mentioned in the original post.
    (One Ive already successfully done this conversion to) I just tried to enter security access in that car as well. Same errors as I receive with my RS7. Also, it gives me the same errors I received if I copy and paste the existing coding. That has me thinking that there is something going on with my interface.
    Thoughts?
    Sounds to me like some kind of divergence between the ABS modules used in these RS7s than the ones we've previously documented.
  9. #8
    Jun 2018
    Uwe, Im not sure I follow what youre saying, sorry. Could you please explain?
    Ive used this exactly computer and interface to successfully re-code the ABS/ESP in this EXACT RS7 a little over a year ago. Now, for some reason, something has changed and I cannot alter its coding or the coding in my RS7.
    Thank you
  10. #9
    I’ve used this exactly computer and interface to successfully re-code the ABS/ESP in this EXACT RS7 a little over a year ago. Now, for some reason, something has changed and I cannot alter it’s coding or the coding in my RS7.
    I'm not at all surprised that you can't alter the coding since you can't successfully get security access. My thought was that these RS7 modules might require a different one than more pedestrian modules, but if you've done it before, then I suppose that's not the case.
    Can you have a look at the following measuring value in the ABS module please and tell us what you see there?
    IDE00323 -- Security Access: Number of invalid keys
  11. #10
    Jun 2018
    Understood. Yes, has been done successfully. Unfortunately, I didnt bother to document the access key I used last year... perhaps the suggested key has been changed in one of the Vagcom software updates since last year? Random thought... probably not likely.
    Anyways, IDE00323 is showing 2.
    Thank you Sir!
