Results 1 to 7 of 7
Thread: Changes to speed alert function - tones and MFD message
    Jun 2019
    I have a Volkswagen Transporter (first registered December 2018 so it's a new model).
    Here's the autoscan. I hope I got this right as I haven't done it before.
    Saturday,06,July,2019,19:13:30:57566
    VIN: WV1ZZZ7HZKH045XXX   License Plate: XXXXXXX
    Mileage: 26380km-16391mi   Repair Order:
    Chassis Type: 7H-VN75 (7E0)
    Scan: 01 03 04 08 09 10 13 15 17 19 25 5F 61 0B
    VIN: WV1ZZZ7HZKH045729   Mileage: 26380km-16391miles
    Address 01: Engine (2D2D2-CXGB)       Labels:. 04L-907-309-V2.clb
       Part No SW: 04L 906 056 KA    HW: 04L 907 445
       Component: R4 2.0l TDI   H02 4047
       Revision: 23002001
       Coding: 00114014430401090000
       Shop #: WSC 00012 790 50316
       ASAM Dataset: EV_ECM20TDI03004L906056KA 004003
       ROD: EV_ECM20TDI03004L906056KA.rod
       VCID: 76B5E7C998493057E05-8022
    31103 - SCR NOx Catalyst Bank 1
              P20EE 00 [096] - Efficiency too Low
    30540 - Throttle Position Sensor (G69)
              P0121 00 [032] - Implausible Signal
                        Mileage: 25854 km
                        Date: 2007.01.13
                        Time: 20:49:41
                        Coolant temperature: 29 C
                        Intake air temperature: 41 C
                        Voltage terminal 30: 12.039 V
                        Unlearning counter according OBD: 32
                        Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
                        Throttl.valve adapt. 1 bank 1: posit feedback - Spec.value: 4.46 %
                        Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 100.00 %
                        Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed: 0.27 %
                        Throttl.valve adapt. 1 bank 1: posit feedback - Uncnd vlt: 4.745 V
    Readiness: N/A
    Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
       Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
       Component: ESC           H06 0133
       Revision: 00000000    Serial number: 62958000002401
       Coding: 557E409825668483AA7C0278A48B21E679F100
       ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
       VCID: 3FDB42EDF7F3B11FF33-806A
       Component: LENKW.SENSOR  H07 0070
       Serial number: 16101813471746
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EA5FFE9B0797817B85-802A
    Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
       Part No SW: 7E0 907 047 AK    HW: 7E0 907 047 AK
       Component: Climatic-T5   H22 0708
       Revision: 00001002
       Coding: 0000000003
       ROD: EV_ClimaT5Basis.rod
       VCID: 73B3DEDD8B3B257FC7B-8026
    Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
       Part No SW: 7E0 937 090 D    HW: 7E0 937 090 D
       Component: BCM PQ25 Max4 H82 0762
       Revision: B9082001    Serial number: 8601 299180734
       Coding: A0A4303A0A613431922049742C2B8C540F00708F60464D60330400220800
       Shop #: WSC 66305 512 174625
       VCID: 2C0105A116053A87461-8078
       Subsystem 1 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P
       Component: J386__TSG_FT  004 0653
       Serial number: KU0KU017101882902192
       Coding: 1400B0
       Subsystem 2 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P
       Component: J387__TSG_BT  004 0653
       Serial number: KU0KU019101882921415
       Coding: 0400A0
       Subsystem 3 - Part No: 7E1 951 172
       Subsystem 4 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0009
       Subsystem 5 - Part No: 7E1 951 172
    Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
       Part No SW: 7E0 919 475 T    HW: 1Q0 919 475
       Component: PARKHILFE 4K  H03 0212
       Revision: --------    Serial number: 32961821504077
       Coding: 10800A
       ASAM Dataset: EV_VW75XParkAssis4K 001013
       ROD: EV_VW75XParkAssis4K_001.rod
       VCID: 43D34E1D9B1BD5FF97B-8016
    Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
       Part No SW: 7N0 907 572 C    HW: 7E0 907 572
       Component: ACC Bosch PQx H03 0211
       Serial number: 1110180453B2E5
       Coding: 00004000FE1779
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_ACCBEGVW361 001006
       ROD: EV_ACCBEGVW361_VW32.rod
       VCID: 363527C9D8C97057205-8062
       Part No SW: 7E0 959 655 J    HW: 7E0 959 655 J
       Component: VW10Airbag021 010 0018
       Revision: --------    Serial number: 003EK002Y31Y
       Coding: 000000000000000000000000000000003231
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       VCID: 3D2738E5FDFFA30FE1F-8068
       Part No SW: 7E0 920 971 A    HW: 7E0 920 971 A
       Component: KOMBI         H02 2030
       Coding: 1509010300
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
       VCID: 290FFCB519772FAFBD7-807C
    Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
       Part No SW: 7E0 909 901     HW: 7E0 937 090 D
       Component: GW-K-CAN TP20 H82 0762
       Revision: B9082001
       Coding: 042305
       VCID: 6889B9B1C27DD6A7629-803C
       Component: IMMO          H02 2030
       Coding: 000002
       VCID: 6A8DC3B9DCF1E4B774D-803E
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
       Part No SW: 1K8 035 150 L    HW: 1K8 035 150 L
       Component: MU-E-D-ER     056 7205
       Serial number: 01101800011568
       Coding: 065700003C00000041111101008000001F0000C60000010001
       ASAM Dataset: EV_MUEnt4CGen2LGE 001032
       ROD: EV_MUEnt4CGen2LGE_VW12.rod
       VCID: 2E050FA920994897685-807A
    0001 - Antenna 1 for Radio
              B1119 13 [009] - Open Circuit
                        Reset counter: 174
                        Mileage: 25482 km
                        Date: 2019.06.29
                        Time: 14:56:46
                        Voltage terminal 30: 12.3 V
    0003 - Antenna 2 for radio
              B111A 13 [009] - Open Circuit
                        Reset counter: 174
                        Mileage: 25482 km
                        Date: 2019.06.29
                        Time: 14:56:46
       Part No SW: 7E0 907 534     HW: 7E0 937 090 D
       Component: Batt.regelung H82 0762
       Coding: 030B7A73
       Shop #: WSC 00012 790 00034
       Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
       Serial number: 7588570100180928092A
    End----------(Elapsed Time: 01:33, VBatt start/end: 12.1V/12.1V)-----------
    The speed alert function is useful for keeping me from getting a speeding ticket, but I would like to alter it to make it more effective.
    Here are the details of what I'd like to change.
    When I exceed the set speed it chimes once and the speed limit exceeded message comes up on the MFD and stays up until I drop below the set speed.
    Since I have the big digital speedo enabled (courtesy of VCDS) I would like to no longer have the speed limit exceeded text stay on the screen, as it blocks my view of the digital speed readout.
    Instead I'd like to have the chime repeat at a set interval (say every 5 to 10 seconds) until I drop below the speed limit I've set.
    Can the above be done??
    I doubt it. The only thing that strikes me as relevant in your instrument cluster is this Adaptation channel:
    IDE03348-ENG98597 -- Speed warning - Speed warning (not active, active, Not available)
    Jun 2019
    Ok thanks for replying. Remember I'm new so looking for confirmation of what seems obvious.
    That means my only options are to have it switched on or switched off?
    Quote Originally Posted by n70 View Post
    That's the only option that's obvious to me.
    But I don't claim to know everything.
    Jun 2019
    I'm sure if that's all you can see, that's all there is.
    Can I just check something so I understand. VCDS will give me the option to change any option that the manufacturer coded in, but it won't allow you to do anything they completely did not intend?
    What I mean is, you couldn't use it to take a piece of their hardware and completely recode (hack it I suppose) to do something very different. I am not any kind of programmer anyway, I'm just trying to understand the capabilities of the VCDS system, as when I first looked at guides I read much about coding and thought it was maybe as free as someone writing new code when creating an android app, windows program, etc.
    Yes, the car and control module manufacturers make certain things configurable via the diagnostic API, generally via the Coding or Adaptation functions. VCDS can change those values. But it cannot change things that the manufacturers did not intend to be configurable, i.e. it cannot make arbitrary changes to the function of a module.
    Jun 2019
    Thanks for clarifying. I just wanted to understand a bit more about what can and cannot be done.
