I have a 2017 RS3 and have installed the TPMS retrofit. It came off of a friends 2018 RS3 that he sold so I know that the module etc was working properly on his car. I have done the coding that was posted on Audizine here https://www.audizine.com/forum/showthread.php/824425-Direct-TPMS-Installation-Guide but have run into a few errors when I do the following:
I get an error saying "Sorry, no coding information is available for this ECU
If I click OK the long coding helper comes up and I can make changes but when I try to save them I get a message saying "Coding regected Error 31:Request out of range
Here is a video of what happens, the display shows for a few seconds and then shuts off. When driving it shows the correct pressure and temperature I just can't get it to stay on. The same thing happens when I'm driving but it was easier and safer to shoot the video with the car parked.
- When I enter 03-ABS Module, you need to do this first thing to disable passive TPMS system.
- And go to Enter Coding - 07 menu, select Long Coding Helper.
Saturday,06,July,2019,11:49:58:24295
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 29 2B 39 3C 42 44 47
52 55 5F 65 6C BB BC CF D6 D7
VIN: WUABWGFF9H1900173 Mileage: 41260km-25637miles
29-Left Light -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Cannot be reached 0100
Address 01: Engine (------DAZA) Labels:. 07K-907-309-V1.clb
Part No SW: 8V0 907 404 G HW: 07K 907 309 E
Component: R5 2.5l TFSI X21 0004
Revision: 53X21000
Coding: 0A250032242600053620
ASAM Dataset: EV_ECM25TFS0118V0907404G 001004
ROD: EV_ECM25TFS0118V0907404G.rod
VCID: 3D27C5225DF4409FE1F-8068
10537 - Evap System Leak Detection or Fuel Vapor Temp Sensor
P2026 00 [032] - Signal too Low
Mileage: 40804 km
Time: 00:00:00
Coolant temperature: 78 °C
Intake air temperature: 72 °C
Voltage terminal 30: 12.080 V
Unlearning counter according OBD: 28
Engine status: COENG_READY
10064 - Fuel Pump
P308D 00 [096] - RPM too Low
Mileage: 40669 km
Date: 2019.06.24
Time: 09:36:05
Engine speed: 7015.50 /min
Normed load value: 65.1 %
Vehicle speed: 198 km/h
Coolant temperature: 94 °C
Intake air temperature: 57 °C
Ambient air pressure: 960 mbar
Voltage terminal 30: 13.860 V
Unlearning counter according OBD: 23
Fuel pump: specified value: 73.155 %
Low fuel pressure: specified value: 500.0 kPa
Fuel temperature: 45.0 °C
Adaptation of Fuel Pump (FP): -19.9 kPa
High fuel pressure: specified value: 24.0000 MPa
2635 - Low Pressure Fuel regulation
P310B 00 [096] - Fuel Pressure Outside Specification
Mileage: 40669 km
Date: 2019.06.24
Time: 09:36:06
Engine speed: 7295.00 /min
Normed load value: 63.1 %
Vehicle speed: 206 km/h
Intake air temperature: 58 °C
Voltage terminal 30: 13.900 V
Engine status: COENG_RUNNING
2636 - Low Pressure Fuel regulation
Mileage: 40673 km
Date: 2019.06.24
Time: 09:37:45
Engine speed: 5280.50 /min
Normed load value: 5.5 %
Vehicle speed: 151 km/h
Coolant temperature: 95 °C
Intake air temperature: 50 °C
Voltage terminal 30: 14.340 V
2838 - Fuel Rail/System Pressure
P0087 00 [096] - Too Low
Mileage: 40673 km
Date: 2019.06.24
Time: 09:37:44
Engine speed: 5856.50 /min
Normed load value: 67.8 %
Vehicle speed: 164 km/h
Intake air temperature: 49 °C
Voltage terminal 30: 12.660 V
Readiness: 0010 0001
Part No SW: 0DL 300 012 H HW: 0GC 927 711 G
Component: GSG DQ500 H06 2112
Revision: 00H06V07
VCID: 2E05F26E8092AB07685-807A
Part No SW: 8V0 614 517 C HW: 8V0 614 517 C
Component: ESC H25 0621
Revision: 00000000 Serial number: 60457000000243
Coding: 2EAA6B7DD4990BA989920B6B81946974D62BD091D081963602 4150D4828812
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
VCID: 392FD13249DC7CBFCD7-806C
14 Faults Found:
8222 - Databus
[FCAN : Getriebe_11 message is not received]
Reset counter: 99
Mileage: 39950 km
Date: 2019.06.13
Time: 17:51:45
8226 - Databus
[FCAN : Getriebe_14 message is not received]
Reset counter: 99
Mileage: 39950 km
Date: 2019.06.13
Time: 17:51:46
8246 - Databus
[FCAN: Motor_Code_01 message is not received]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:25
8250 - Databus
[FCAN: Motor_07 message is not received]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:26
8252 - Databus
[FCAN: Motor_11 message is not received]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:21
8254 - Databus
[FCAN: Motor_12 message is not received]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:21
8256 - Databus
[FCAN: Motor_14 message is not received]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:22
8258 - Databus
[FCAN: Motor_20 message is not received]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:22
8264 - Databus
[FCAN: Tsk_06 message is not received]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:22
8351 - Databus
[FCAN: Motor_17_alt veraltet bit is set]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:24
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 101
Mileage: 40029 km
Date: 2019.06.13
Time: 23:37:05
16409 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:31
16410 - Display for Tire Pressure Monitoring
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:31
16416 - Display for Tire Pressure Monitoring
Reset counter: 99
Mileage: 39950 km
Date: 2019.06.13
Time: 17:51:55
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0434002464
Coding: 030C0C
VCID: 3B23CB3A43E04EAFDFB-806E
12716804 - Databus
[Ausfall Motor_14 - Botschaft - kein Signal/Kommunikation]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:22
Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
Component: AC Automat H03 0130
Revision: 20002000 Serial number: 00000001172916
Coding: 03000015010000000000000000001400
ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
VCID: 40D9BCD62A062D778A9-8014
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: EF08869800PAG0MUFU03
459023 - Databus
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:21
Part No SW: 5Q0 937 085 BF HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H34 0236
Serial number: 02001705300865
Coding: 00000000000000000000000000000000000000000000000000 0000000000
ROD: EV_BCMBOSCH_017.rod
VCID: 7EA5022E10729B87B85-802A
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 170117 043 0585
Serial number: 170201053603
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 62658002
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 22 12 2016 00001718
Serial number: 00000000000068746455
Sun Roof:
Component: J245 PS73.404 H03 0004
Serial number: 0000FST001GD2NJ00000
Coding: 101F00
8 Faults Found:
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 19
Mileage: 30189 km
Date: 2019.02.18
Time: 14:14:44
541973 - Databus
[Motor_04 Datenbus fehlende Botschaft]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:21
542229 - Databus
[Motor_14 Datenbus fehlende Botschaft]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:21
542485 - Databus
[Motor_18 Datenbus fehlende Botschaft]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:22
555541 - Databus
[Motor_12_alt aktiv]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:21
555797 - Databus
[Getriebe_11_alt aktiv]
Reset counter: 99
Mileage: 39950 km
Date: 2019.06.13
Time: 17:51:44
558100 - Databus
[Airbag_02 Datenbus empfangener Fehlerwert]
Fault Frequency: 6
Reset counter: 111
Mileage: 39770 km
Date: 2019.06.08
Time: 14:05:58
559125 - Databus
[Motor_07 Datenbus fehlende Botschaft]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:22
Part No SW: 5QA 919 294 A HW: 5QA 919 294
Component: PDC 8 KanalH07 0038
Serial number: 000308418617056
Coding: 0470155011
ASAM Dataset: EV_EPHVA18AU3700000 009031
VCID: 4ACD9EFE1C3AE72754D-801E
12648465 - Databus
[Motorsteuergerät - Motor_12 - kein Signal/keine Kommunikation]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:22
12648721 - Databus
[Getriebesteuergerät - Getriebe_11 - kein Signal/keine Kommunikation]
Reset counter: 99
Mileage: 39950 km
Date: 2019.06.13
Time: 17:51:45
13637426 - Databus
Fault Frequency: 13
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:52:01
12648468 - Databus
[Motorsteuergerät - Motor_20 - kein Signal/keine Kommunikation]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:22
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 G HW: 8V0 907 376 F
Component: DAEMPFUNGS-SG H11 0082
Serial number: 090117040
ASAM Dataset: EV_AudiMagneRide 002008
ROD: EV_AudiMagneRide.rod
VCID: 45D7ADC23524085FB9F-8010
7 Faults Found:
6291467 - Terminal 15
U1405 00 [008] - Implausible signal
[Ignition plausibility error]
Reset counter: 112
Mileage: 39681 km
Date: 2019.06.07
Time: 18:26:34
COM: 0D 19 0D 28 00 01 1B C5 00 00
Voltage terminal 30: 14.2 V
Terminal 15 status via CAN: Terminal 15 off
AMR state: 0
Damping adjustment indicator lamp: OFF
ESP automatic engagement: not activated
Fall-back level: 00 00 00 00
10506241 - Databus
[Motor_07_Timeout]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:26
COM: 05 E6 06 05 00 01 5D B4 00 00
Voltage terminal 30: 11.9 V
Terminal 15 status via CAN: Terminal 15 on
Engine run: Not available
Engine torque: Not available
AMR state: 6
Fall-back level: 01 B8 20 00
10510337 - Databus
[Motor_11_Timeout]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:22
COM: 05 D7 05 D7 00 01 4D 92 00 00
Voltage terminal 30: 12.0 V
Engine run: 0
Engine torque: -11 Nm
AMR state: 0
10510339 - Databus
[init value Moment Ist Sum]
Reset counter: 95
Mileage: 39632 km
Date: 2019.06.07
Time: 12:51:49
COM: 06 F0 07 0F 00 03 63 84 00 00
Voltage terminal 30: 12.1 V
AMR state: 6
10510343 - Databus
[init value Raw Soll Moment]
Reset counter: 95
Mileage: 39632 km
Date: 2019.06.07
Time: 12:51:49
COM: 06 F0 07 0F 00 03 63 85 00 00
AMR state: 6
10514433 - Databus
[Motor_14_TimeOut]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:22
COM: 05 E6 05 D7 00 01 4F 4A 00 00
AMR state: 6
Fall-back level: 00 30 00 00
10518529 - Databus
[Motor_Code_01_Timeout]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:25
COM: 05 D7 05 F6 00 01 5B 5C 00 00
AMR state: 6
Fall-back level: 01 B0 20 00
Serial number: 003GCR07ENV4
Coding: 9DCCFCC0008000005000001AC24800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 47CBA7CA0F281A4F4B3-8012
Belt Pretensioner left:
Serial number: 34230167A28021750057
Coding: 333135
Belt Pretensioner right:
Serial number: 34230168A01031740816
Coding: 333135
Occupant Detection:
Serial number: 694000000000001KJ98X
Coding: 303337
Subsystem 4 - Part No SW: ----------- HW: 480 002 602 17
Serial number: 3570000000040B44E12C
Subsystem 5 - Part No SW: ----------- HW: 480 002 602 17
Serial number: 358000000009FA44E12W
Subsystem 6 - Part No SW: ----------- HW: 480 401 502 17
Serial number: 351000199247F13265F2
Subsystem 7 - Part No SW: ----------- HW: 480 401 502 17
Serial number: 352000199247F136536
Subsystem 8 - Part No SW: ----------- HW: 480 401 601 17
Serial number: 3550002C523C4E32E2EG
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 401 601 17
Serial number: 3560002C323C4E35B245
1053952 - Databus
[NWD: 0x121 Motor_20 Timeout]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:22
9445929 - Seat occupied recognition control module
B1022 29 [008] - Signal Implausible
Fault Frequency: 6
Reset counter: 111
Mileage: 39770 km
Date: 2019.06.08
Time: 14:06:02
9577755 - Sensor Mat for Seat Occupied Detection
B1225 1B [008] - Resistance Too High
Fault Frequency: 6
Reset counter: 111
Mileage: 39770 km
Date: 2019.06.08
Time: 14:05:57
Part No SW: 8V0 953 521 KK HW: 5Q0 953 549 E
Revision: -------- Serial number: 02031704401807
Coding: A018
VCID: 0D4755E22DD4B01FB1F-8058
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 890 HW: 8V0 920 890
Component: FBenUSA H14 0046
Coding: 086D18D33B88CF050204EE041800001000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001023
ROD: EV_DashBoardFPKAU37X.rod
VCID: 7AAD0E3E0C5AB7A784D-802E
U1014 00 [008] - -
[ECU incorrectly coded]
Fault Frequency: 145
Reset counter: 128
Mileage: 39380 km
Date: 2019.05.27
Time: 21:11:04
16777014 - Tire Pressure Monitoring Module
U0127 00 [008] - No Communications
[RDK_0x07 communication error bap_error_timeout heartbeat]
Fault Frequency: 134
Reset counter: 129
Mileage: 39380 km
Date: 2019.05.27
Time: 21:12:55
16776971 - Databus
[Motor_04 communication error can_error_timeout]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:22
16777072 - Databus
[WBA_03 communication error can_error_timeout]
Reset counter: 99
Mileage: 39950 km
Date: 2019.06.13
Time: 17:51:46
Component: GW MQB High 515 5286
Serial number: 28021710522664
Coding: 03010004340860005B00822CB80B0000000101000000000000 0000000000
ROD: EV_GatewNF.rod
VCID: 2F3BEF6A8798A20F633-807A
Subsystem 2 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20170210175324 22168
Subsystem 3 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 1384521504
131689 - Rear View Camera System Control Module
U104C 00 [009] - No communication
[Timeout Knoten 0x69 / 6C - Steuergerät für Rückfahrkamerasystem]
Reset counter: 89
Mileage: 32107 km
Date: 2019.04.21
Time: 12:02:32
Supply voltage: Terminal 30: 12.4 V
Terminal 15: OFF
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [008] - -
[Timeout Knoten 0x76 / 01 - Motorsteuergerät]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:24
Supply voltage: Terminal 30: 11.9 V
Terminal 15: On
131703 - No Communication with Transmission Control Module
U0101 00 [008] - -
[Timeout Knoten 0x77 / 02 - Steuergerät für Getriebe]
Reset counter: 99
Mileage: 39950 km
Date: 2019.06.13
Time: 17:51:47
Terminal 15: On
8531970 - Quiescent Current
U1406 00 [008] - Too High
[Ruhestrom oberer Grenzwert überschritten]
Reset counter: 91
Mileage: 39455 km
Date: 2019.05.29
Time: 13:31:06
Supply voltage: Terminal 30: 12.5 V
Terminal 15: OFF
Part No SW: 0CQ 907 554 K HW: 0CQ 525 130
Component: Haldex4Motion H52 7762
Serial number: HA1-00001.09.16
Coding: 0601
VCID: 4DC795E2ED54F01F71F-8018
8 Faults Found:
16652 - Databus
[Getriebe - TO -- Get_11]
Reset counter: 99
Mileage: 39950 km
Date: 2019.06.13
Time: 17:51:45
17497 - Databus
[Getriebe - TO -- mGetriebe_02]
Fault Priority: 8
Reset counter: 99
Mileage: 39950 km
Date: 2019.06.13
Time: 17:51:45
17506 - Databus
[Motorsteuergerät - TO -- Mot_07]
Fault Priority: 8
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:25
17473 - Databus
[Motorsteuergerät - TO -- Mot_11]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:21
16657 - Databus
[Motorsteuergerät - TO -- Mot_12]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:21
17474 - Databus
[Motorsteuergerät - TO -- Mot_14]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:21
16727 - Databus
[Motorsteuergerät - TO -- Mot_20]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:21
17475 - Databus
[Motorsteuergerät - TO -- Mot_Code]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:24
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 8S0 907 397 D HW: 8S0 907 397 D
Component: LCM_MQB H06 0017
VCID: 42DDB6DE240A3F679CD-8016
0279 - Databus
[databus - message missing]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:23
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000608488008
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3431E0066EBE81D71E1-8060
12666369 - Databus
[Timeout Message Motor_14]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:21
ELV State: 04
Information Clamps: 77 60
CoCo State: A0 01
WFS State: 17 06
Vehicle speed: 0.00 km/h
Voltage: 66
AD-Value H-bridge: 32
Clamp15 flip flop: SSTx: button contacts: 06
CAN signals: 00
12666381 - Databus
[Timeout Message Motor_09]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:22
ELV State: 04
CoCo State: A0 01
WFS State: 17 06
Voltage: 66
CAN signals: 00
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
0279 - Databus
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:22
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 D HW: 3Q0 907 566
Component: MRR1Rear H16 0410
Revision: --------
Coding: 040002
1183750 - Databus
[databus message missing - Motor]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:23
Control Module temperature: 32 °C
Voltage terminal 30: Measured value not available
Terminal 15 status: Measured value not available
Voltage terminal 15: 11.60 V
Component: TSG FS 020 0041
Serial number: 310117EAV06361
Coding: 005D1B205C00048000000002
VCID: 43D3B3DA3B10366F97B-8016
458803 - Databus
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:22
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8106
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A2DCE3E4CDA77A7C4D-806E
23040 - Databus
[MOTOR_20 Botschaft - CAN-Timeout]
Fault Frequency: 30
Reset counter: 108
Mileage: 16447 km
Date: 2018.07.25
Time: 12:18:32
Motor status: 00
Supply voltage: 12.00 V
Temperature: 37.0 °C
KFC: 5A
KFA: 00 00
Environmental conditions: 20
uioUdNotFilt_xdu16: 12.08 V
uAdSensI_SwitchedKl30_xdu16: 12.06 V
NoInitCause_AsicSens: [0x00] ASC_CTRL_SAS_NO_ERR
NoInitCause_RackPos_Rohwert: 00 00
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_KMN_RACKPOS_SET: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_WHLSPDPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: not activated
22272 - Databus
[KFC_MOTOR_11 Botschaft - CAN-Timeout]
Fault Frequency: 30
Reset counter: 108
Mileage: 16447 km
Date: 2018.07.25
Time: 12:18:32
Motor status: 00
KFC: 57
KFA: 00 00
uioUdNotFilt_xdu16: 12.20 V
uAdSensI_SwitchedKl30_xdu16: 12.24 V
22528 - Databus
[MOTOR_12 Botschaft - CAN-Timeout]
Fault Frequency: 30
Reset counter: 108
Mileage: 16447 km
Date: 2018.07.25
Time: 12:18:32
Motor status: 00
KFC: 58
KFA: 00 00
22784 - Databus
[MOTOR_14-Botschaft - CAN-Timeout]
Fault Frequency: 30
Reset counter: 108
Mileage: 16447 km
Date: 2018.07.25
Time: 12:18:33
Motor status: 03
System status: Driving mode
KFC: 59
KFA: 00 00
uAdSensI_SwitchedKl30_xdu16: 12.21 V
23296 - Databus
[MOTOR_CODE_01 Botschaft - CAN-Timeout]
Fault Frequency: 30
Reset counter: 108
Mileage: 16447 km
Date: 2018.07.25
Time: 12:18:37
Motor status: 03
KFC: 5B
KFA: 00 00
19460 - Databus
[ESP_05 Botschaft - SNA-Check]
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:23
Motor status: 03
Supply voltage: 11.75 V
Temperature: 20.0 °C
KFC: 4C
KFA: 00 04
Environmental conditions: 21
uioUdNotFilt_xdu16: 11.78 V
uAdSensI_SwitchedKl30_xdu16: 11.79 V
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 466 HW: 81A 035 466
Component: MIB2_amp_P_A3 H10 0100
Revision: 00000001 Serial number: AUZ8ZAGHX00H2MK
Coding: 0173030000AAAA2AAA0000010000
ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
ROD: EV_AMPMst16C9Gen2ALPI.rod
VCID: 629D565E84CA5F67BCD-8036
0579 - Rear Right Bass Speaker
B1067 F0 [008] - Short Circuit Between Poles
[Verbindungen zu Lautsprechern Kanal 10: elektrischer Fehler im Stromkreis]
Reset counter: 127
Mileage: 20358 km
Date: 2018.09.09
Time: 14:31:11
Voltage terminal 30: 12.2 V
Component: TSG BFS 020 0041
Serial number: 030217EB326689
Coding: 005D13205E00048000000002
458803 - Databus
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:22
Address 55: Headlight Range (J745) Labels:* None
Part No SW: 8V0 907 357 A HW: 7P6 907 357 B
Component: MxB-ECU 001 0230
Coding: 0E62021123200400
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
VCID: 3E25C22E50F25B87F85-806A
13705475 - Databus
[Motor_20 Datenbus fehlende Botschaft]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:22
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 8V1 035 880 A HW: 8V1 035 880
Component: MU-P-LNS-US 053 0906
Serial number: A702B0HS002089
Coding: 017361020000000011220002041A00102F0028E5017001047E
VCID: 3829D43672D665B7329-806C
Subsystem 1 - Part No SW: V03 959 801 PS HW: -----------
Component: NAR 2018 --- 0063
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9G1Y00Y85
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BK HW: 8V0 919 614 BK
Component: ControlUnit_H H85 0855
Serial number: ALJAL112011700010068
Component: Gracenote2--- --- 3011
0020 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Reset counter: 187
Mileage: 15666 km
Date: 2018.07.10
Time: 12:58:41
Voltage terminal 30: 13.0 V
Satellite radio tuner status-Satellite radio antenna status: Electrical OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Not available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: Not available
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
6708 - Databus
[Engine: no communication]
Fault Frequency: 11
Reset counter: 108
Mileage: 30904 km
Date: 2019.03.30
Time: 15:55:26
Network diagnosis-Status: Enabled
6696 - Instrument Cluster Control Module on Optical Bus
U10C0 00 [008] - No Communication
[Control module for instrument cluster display: no communication]
Reset counter: 111
Mileage: 40573 km
Date: 2019.06.23
Time: 22:16:52
Voltage terminal 30: 13.2 V
U1111 00 [008] - -
Reset counter: 127
Mileage: 39380 km
Date: 2019.05.27
Time: 21:36:45
BAP-BAP_Function_ID: 01
7179 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Rear-view camera (0x0B) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 253
Mileage: 32107 km
Date: 2019.04.26
Time: 17:13:19
Voltage terminal 30: 13.1 V
BAP-BAP_Function_ID: 02
Address 65: Tire Pressure (J502) Labels: None
Part No SW: 8S0 907 273 HW: 4M0 907 273 B
Component: RDKHUFAU736 H04 0002
Serial number: 40000000004695
ROD: EV_RDKHUFAU736_AU37.rod
VCID: 77AB170A3F48AACFFB3-8022
7 Faults Found:
8397058 - Front Left TPMS Sensor
C1050 31 [008] - No Signal
Reset counter: 101
Mileage: 40009 km
Date: 2019.06.13
Time: 23:21:18
Expanded ambient data 6-Vehicle speed: 61.43 km/h
Expanded ambient data 6-Outside air temperature: 13.50 °C
Left front tire pressure sensor: remaining oper. life: 127 m
Left front tire pressure sensor: identification-Manufacturer code: numerical value: no text
Left front tire pressure sensor: identification-Sensor identification number (sensor ID): 691391293
8397314 - Front Right TPMS Sensor
C1051 31 [008] - No Signal
Reset counter: 101
Mileage: 40009 km
Date: 2019.06.13
Time: 23:21:18
Right front tire pressure sensor: remaining oper. life: 127 m
Right front tire pressure sensor: identification-Manufacturer code: numerical value: no text
Right front tire pressure sensor: identification-Sensor identification number (sensor ID): 691388705
8397570 - Rear Left TPMS Sensor
C1052 31 [008] - No Signal
Reset counter: 101
Mileage: 40009 km
Date: 2019.06.13
Time: 23:21:18
Left rear tire pressure sensor: remaining oper. life: 127 m
Left rear tire pressure sensor: identification-Manufacturer code: numerical value: no text
Left rear tire pressure sensor: identification-Sensor identification number (sensor ID): 692634682
8397826 - Rear Right TPMS Sensor
C1053 31 [008] - No Signal
Reset counter: 101
Mileage: 40009 km
Date: 2019.06.13
Time: 23:21:18
Right rear tire pressure sensor: remaining oper. life: 127 m
Right rear tire pressure sensor: identification-Manufacturer code: numerical value: no text
Right rear tire pressure sensor: identification-Sensor identification number (sensor ID): 691389745
8390147 - Tire Pressure Monitoring
C10DC 54 [008] - Missing Calibration / Basic Setting
Reset counter: 103
Mileage: 39686 km
Date: 2019.06.07
Time: 19:41:53
Expanded ambient data 1-Left front tire pressure sensor: identification: 691391293
Expanded ambient data 1-Right front tire pressure sensor: identification: 691388705
Expanded ambient data 1-Left rear tire pressure sensor: identification: 692634682
Expanded ambient data 1-Right rear tire pressure sensor: identification: 691389745
8400898 - Tires 01: Tire Pressure Warning
C111B 00 [008] - Pressure too Low
Reset counter: 127
Mileage: 40662 km
Date: 2019.06.24
Time: 09:25:08
Expanded ambient data 6-Vehicle speed: 0.00 km/h
Expanded ambient data 6-Outside air temperature: 21.50 °C
Expanded ambient data 2-Left front tire pressure sensor: nominal pressure: 2.93 bar
Expanded ambient data 2-Left front tire pressure sensor: actual pressure: 2.15 bar
Expanded ambient data 2-Left front tire pressure sensor: temperature: 29 °C
Expanded ambient data 2-Left front tire pressure sensor: identification: 691391293
8400901 - Tires 02: Tire Pressure Warning
C111D 00 [008] - Pressure too Low
Reset counter: 115
Mileage: 40663 km
Date: 2019.06.24
Time: 09:33:22
Expanded ambient data 6-Vehicle speed: 61.64 km/h
Expanded ambient data 3-Right front tire pressure sensor: nominal pressure: 2.95 bar
Expanded ambient data 3-Right front tire pressure sensor: actual pressure: 2.25 bar
Expanded ambient data 3-Right front tire pressure sensor: temperature: 31 °C
Expanded ambient data 3-Right front tire pressure sensor: identification: 691389745
Address 6C: Back-up Cam.
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 240117EAN1063C
Coding: 000C13204000048000000002
Component: TSG HBFS 020 0041
Serial number: 240117EAN10638
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 D HW: 3Q0 907 590
Revision: --------
Coding: 040002
VCID: 3635DA0E78C293C7205-8062
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
VCID: 176B378A1F084ACF1B3-8042
Component: LED1R H09 0008
End----------(Elapsed Time: 02:13, VBatt start/end: 12.0V/12.0V)-----------
