Results 1 to 5 of 5
Thread: MQB platform - Security Codes - work in progress
    May 2014
    I'm not sure if anyone else has done the same - but in an attempt to coalesce the community's knowledge of SA codes for MQB platform vehicles into a single reference source, I have collected the "known" SA codes in the table below. This has been (and it remains) a work-in-progress and the information has been "plagiarized" from various places (mostly on the net) over numerous years. I've tried where-ever possible to include data from reputable sources, but by definition the veracity of the information in the table cannot be guaranteed. That said, with time - many of the SA codes in the table have been "confirmed". I've also attempted where ever possible to assign attribution to the data - if I have erred, or if I have omitted a name, please advise and I will correct the error (and please accept my apology for the deficiency).
    I'm happy to include further SA s if more are known
    PS: For those who are unaware, control modules can be very temperamental where SA s are concerned. They tend to get cranky and they have a tendency to lock-out after a few incorrect attempts. If this happens - the clock count-down before any new entries are accepted is measured with the ignition turned-on (i.e. Terminal 15 active).
    Control Module Security Code Contributor Comments
    01 -Engine 27971
    79153
    DV52
    02-Auto Trans
    03- ABS Brakes 11966
    15081
    18573
    20103
    24435
    24990
    25004
    25757
    28183
    31857
    37202
    40168
    44595
    40304
    10505
    19249
    10815
    zloybob and
    acr2001 (RT forum)
    Rainesh
    kawzx7
    Morde
    Dana (RT)
    11966 - Hydraulic brake assist -Yomny (Golfmk7 forum)
    20103 - XDS changes*IPB-V1.lbl & ESP-V1.lbl
    24990 -"All ADP"*5Q0-907-379-IPB-V1.lbl
    25004 - Brake Booster
    25757 -Straight ahead brake stabilization
    31857 -"Adaptation/Basic Setting"??
    44595- Brake disk drying
    05 - ACC/Start Auth. 20103
    06-Seat Memory Passenger 20103 MasterTommy
    08-Auto HVAC 20103
    09-Cent. Elect. 31347
    20107
    zllekk-VWVortex
    20107 - MY19 Golf mk7.5
    10-Park/Steer Assist 71679
    20103
    13- Auto Dist. Reg (ACC) 14117?
    20103
    Morde
    14- Susp. Elect. 20103 NEtech
    15-Airbags
    16-Steering wheel
    17-Instruments 20103
    25327
    47115
    Zloybob
    djduese (RT forum)
    Applicable for pre-MY16 models
    Accepted on post-MY16 models, but no access to adaptation channels
    Applicable for post-MY16 models
    18-Aux Heat 20103
    19-CAN Gateway 20103
    22-All Wheel Drive
    29-Left Light 20103 MasterTommy
    32-Differential Locks
    36-Seat Memory Driver 20103 MasterTommy
    39-Right Light 20103 MasterTommy
    42-Door Elect, Driver 20103
    44-Steering Assist 19249
    28183
    44595
    DV52
    DV52
    19249 and 28183 included in 5Q0-909-144.lbl
    47-Sound System 20103 MasterTommy
    52-Door Elect, Pass. 20103
    55-Headlight Range 20103
    15284
    65-Tire Pressure 20103 MasterTommy
    69-Trailer Module 20103 MasterTommy
    75-Telematics 20103 Chillout
    82-Heads-Up Display 20103 MasterTommy
    2B-Steer. Col. Lock 20103
    3C-Lane Change 20103 LIJetta_18
    4B-Multifunction Module 20103 MasterTommy
    5F-Information Electr. 20103
    S12345
    6C-Back-up Camera 20103 MasterTommy
    6D-Truck Electronics 12345 Morde
    A5-Frt Sens. Drv. Assist 20103
    A9-Struct. Borne Sound
    BB-Rear Door Electronics Driver 20103 MasterTommy
    BC-Rear Door Electronics Passenger 20103 MasterTommy
    CA-Sunroof 20103 MasterTommy
    CF-Lane Change 2 20103 MasterTommy
    D6-Light Control Left 2 20103 MasterTommy
    D7-Light Control Right 2 20103 MasterTommy
    Last edited by DV52; 09-24-2019 at 12:22 AM. Reason: added 20107 to BCM (MY19 mk7.5 Golf)
    May 2014
    Uwe: please amend as you see fit and reposition into a suitable place
  3. Likes Uwe liked this post
    United States
    Hi Don, I changed the title from MQB platform - Security Codes (SA) - work in progress -to- MQB platform - Security Codes - work in progress because our fancy forum acronym addon was breaking links to your thread. (It must have been the letters SA that were causing the issue)
    Test URL https://forums.ross-tech.com/showthr...rk-in-progress
    Yep it works.
    P.S. I added lines above today: *5Q0-907-379-IPB-V1.lbl. That means I added those SA codes to that VCDS label file.
    I'll try to continue doing that as I update files but I might need to start change-log post here if my comment lengths start breaking your chart.
    Last edited by Dana; 08-06-2019 at 09:34 AM. Reason: Confirmed it can be linked now
  5. Likes Uwe, DV52 liked this post
    Dec 2016
    Amsterdam
    20103 is accepted by almost every module, including 65 and the rear door control modules (BB and BC if i’m correct)...
    EDIT:
    If we're talking MQB and not only Golf VII, the following modules (amongst others probably, these are Tiguan/Arteon) are missing from the list:
    - 06 Seat Memory Passenger SA Code: 20103
    - 22 All-Wheel Drive SA Code: unknown
    - 29 Left Light SA Code: 20103
    - 36 Seat Memory Driver SA Code: 20103
    - 39 Right Light SA Code: 20103
    - 47 Sound System SA Code: 20103
    - 4B Multifunctional Module SA Code: 20103
    - 65 Tire Pressure SA Code: 20103
    - 69 Trailer Module SA Code: 20103
    - 6C Back-Up Camera SA Code: 20103
    - 6D Truck Electronics SA Code: 12345
    - 82 Heads-Up Display SA Code: 20103
    - BB Rear Door Electronics Driver SA Code: 20103
    - BC Rear Door Electronics Passenger SA Code: 20103
    - CA Sunroof SA Code: 20103
    - CF Lane Change 2 SA Code: 20103
    - D6 Light Control Left 2 SA Code: 20103
    - D7 Light Control Right 2 SA Code: 20103
    Current:
  7. Likes Dana, DV52, Jacek, Somnus liked this post
  8. #5
    Dec 2016
    Amsterdam
    Thanks for adding my info! The SA code for 22 AWD is unknown to me, so its not 20103 by the way...
    Current:
  9. Likes DV52, Dana liked this post
