Results 1 to 3 of 3
Thread: Throcking it ...
    Nov 2014
    New Zealand
    Throcking it ...
    Sometimes, you get so pissed off with something, you have to "go postal" on it's arse, if nothing else, to feel better! I have recovered from this a little, but it really got my goat!
    It was FAR more succesful than the time I got miffed with something in the garage and hit a bit of wood with a hammer... and it jumped up and hit me like a horsekick in the forehead...
    So, I got this scan from my Wifes Touran (While investigating the door lock fault):
    Saturday,29,June,2019,16:08:42:42165
    VCDS Version: 19.6.1.0 (x64)
    VIN: WVGZZZ1TZ6W165294   License Plate:
    Chassis Type: 1T (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72 76 7D
    VIN: WVGZZZ1TZ6W165294   Mileage: 176470km-109653miles
       Part No SW: 06F 906 056 EM    HW: Hardware No
       Component: MED9.5.10       G00 9156
       Revision: --H03---    Serial number: VWZ7Z0F3745828
       Coding: 0000075
       Shop #: WSC 06003 109 62583
       VCID: 78FFC7DA0B77FE8FA1-802C
       Part No: 09G 927 750 CS
       Component: AQ 250 6F           0847
       Coding: 0000072
       Shop #: WSC 12345 123 456789
       VCID: 0407A32A47BFAA6FBD-8050
    Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
       Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
       Component: ESP FRONT MK60-AT   0102
       Revision: 00H13001
       Coding: 0004806
       VCID: 68DF979A5BD76E0F31-803C
    00493 - ESP-Sensor Unit (G419)
                014 - Defective
       Part No: 1K0 907 044 BD
       Component: ClimatronicPQ35 090 0808
       VCID: 6ADBED9245DB5C1F27-803E
       Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
       Component: Bordnetz-SG     H37 1002
       Revision: 00H37000    Serial number: 00000005669446
       Coding: 838F0F01001E0F0000120C000000000000097F0732
       VCID: 2B5528968AA185171C-807E
       Subsystem 1 - Part No: 2K2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW357  012  0402
       Coding: 00063445
       Shop #: WSC 12345
    Address 15: Airbags        Labels: 1T0-909-605.lbl
       Part No SW: 1T0 909 605 C    HW: 1T0 909 605 C
       Component: 02 AIRBAG VW62 0506 1500
       Revision: 09025000    Serial number: 0038BD0J4ZPW
       Coding: 0012338
       Shop #: WSC 01324 785 00200
       VCID: 35610EEE5CE5C3E77A-8060
       Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
       Component: Lenksäulenmodul 034 0070
       Coding: 0010042
       VCID: 76E3C9E2016388FFB3-8022
       Part No: 1T0 920 872 E
       Component: KOMBIINSTRUMENT VDD 4312
       Coding: 0005601
       VCID: 366309E241E3C8FF73-8062
       Revision:   H42       Serial number: 230511F2002976
       Coding: 358003
       VCID: 35610EEE9CE5C3E77A-8060
       Component: IMMO            VDD 4312
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
       Part No: 1T0 959 701 C
       Component: Tuer-SG         024 2402
       Coding: 0000757
       VCID: 377D04E646E931F768-8062
       Part No: 1K2 909 144 K
       Component: EPS_ZFLS Kl.0   D06 1701
       VCID: 346733EA579FDAEF4D-8060
       Part No SW: 1K0 959 433 AT    HW: 1K0 959 433 AT
       Component: 01 KSG PQ35 G2  010 0101
       Revision: 00010000    Serial number: 00000000000000
       Coding: 00900A085103087F2D06840560085F01E0A500
       Shop #: WSC 12345 678 910111
       VCID: 020BA5325DABA45F8F-8056
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
       Part No: 1T0 959 702 C
       Coding: 0000757
       VCID: 387F07DA4BF73E8F61-806C
    01553 - Motor for Central Locking; Passenger Door (V57); Lock
    00106 - Signal Central Locking SAVE/LOCK Passenger Side
       Part No: 1T0 907 357
       VCID: 74E7F3EA171F9AEF8D-8020
       Part No SW: 6RD 035 187 A    HW: 6RD 035 187 A
       Component: MIB2-S-R-CN   025 0210
       Revision: -----001    Serial number: 10805GD2251942
       Coding: 00000400040005
       VCID: 45817E2ECC055367EA-8010
                        Reset counter: 164
                        Mileage: 166115 km
                        Time: 20:49:02
       Part No: 1K0 959 703 E
       Component: Tuer-SG         021 2428
       Coding: 0000144
       VCID: 326B35F2AD8BD4DF5F-8066
       Part No: 1K0 959 704 E
       Coding: 0000144
       VCID: 336530F65291DDD754-8066
    Address 76: Park Assist        Labels: 1K0-919-283.lbl
       Part No: 1K0 919 283 A
       Component: 02 Einparkhilfe     0101
       VCID: 2D51268EB4B58B2702-8078
       Revision: 00800000    Serial number:
    End-------------------------(Elapsed Time: 02:03)--------------------------
    The thing of note, is the ABS reporting:
    014 - Defective
    What the...??? No fault lights, everything seems to function as expected.
    I have 2 spare sensors, so tried them both... no change... WHUT??? Decided to check the wiring (yes Jack!)... I recently "upgraded" to windows 10... so after MANY hours a pissing about reinstalling "software" to check the wiring diagrams, I finally got them up. Wiring is direct from ABS to G419, no external fuses or bifucated (yes Jack!) wires.
    WHUT?
    So after a bit of head scratching and brain thrashing (and checking the ABS long codings), I remebered I tried to enable hill-hold assist months ago! Of course the G419 needs to be a 4Motion type to even have the G251! How could I be so stupid?!?! I've even helped someone with a retrofit of HHA!
    So, I changed the coding to turn it off, which would (of course!) remove the requirement for the G251 to be integrated into the G419... right?
    So, coding changed, no HHA, then:
    Sunday,30,June,2019,18:31:31:42165
    VIN: WVGZZZ1TZ6W165294   Mileage: 176500km-109672miles
       Coding: 0000075
    Readiness: 1110 0101
       Coding: 0000072
       Revision: 00H13001
       Coding: 0004806
       Coding: 00063445
       Shop #: WSC 12345
       Coding: 0012338
       Coding: 0010042
       Coding: 0005601
       Coding: 358003
       Coding: 0000757
       Coding: 0000757
                        Reset counter: 164
                        Mileage: 166115 km
                        Time: 20:49:02
       Coding: 0000144
       Coding: 0000144
    End-------------------------(Elapsed Time: 02:01)--------------------------
    Note the Automagic Transmission reports:
    What the...?
    I won't even tell you the hours I spent faffing about checking coding and cross-referencing, looking at old scans and double checking things...
    So this is where I fix it:
    Monday,01,July,2019,20:18:01:42165
    VIN: WVGZZZ1TZ6W165294   Mileage: 176530km-109690miles
       Coding: 0000075
    Readiness: 0000 0001
       Coding: 0000072
       Revision: 00H13001
       Coding: 0004806
       Coding: 00063445
       Shop #: WSC 12345
       Coding: 0012338
       Coding: 0010042
       Coding: 0005601
       Coding: 358003
       Coding: 0000757
       Coding: 00900A085103087F0006840560081F01E0A100
       Coding: 0000757
       Coding: 00000400040007
                        Reset counter: 126
                        Mileage: 176501 km
                        Time: 18:37:59
       Coding: 0000144
       Coding: 0000144
    End-------------------------(Elapsed Time: 01:59)--------------------------
    Note in this scan the fault is gone! Other than some "Convenience tweaks" I did, the only thing that made a difference is:
    I went into the ABS module and gave the "Clear codes" button a good and repeated Throcking*
    I must have pressed it 10 or 15 times, while swearing "magic" words and threatening the soul of the departed madman* who inhabits the ECU of the autotragic transmission.
    I know this has come up before... but...
    IT FUCKING WORKED.
    *Blatantly paraphrased/stolen from Douglas Adams - "The Meaning of Liff":
    Throcking (participial vb.)
    The action of continually pushing down the lever on a pop-up toaster in the hope that you will thereby get it to understand that you want it to toast something.
    Also: a style of drum-playing favoured by Nigel Olsson of the Elton John Band, reminiscent of the sound of someone slapping a frankfurter against a bucket. An excellent example of this is to be heard on 'Someone Saved My Life Tonight' from the album Captain Fantastic and the Brown Dirt Cowboy.
    Throckmorton (n.)
    The soul of a departed madman: one of those now known to inhabit the timing mechanism of pop-up toasters.
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
  2. Likes Zenerdiode, NEtech, PetrolDave, jyoung8607, Uwe liked this post
  3. #2
    Quote Originally Posted by NZDubNurd View Post
    I can't remember where I saw it, but that's a documented (by ze Germans in zeir vite lab coats) procedure for at least one control module. Of course, they don't say, "Throck it!", they say something like, "Clear fault codes five times in rapid succession".
  4. Likes PetrolDave, jyoung8607, NZDubNurd liked this post
  5. #3
    Nov 2014
    New Zealand
    That's a bit like the owners manual for Dads old BMW E30 325i. It said something like: After a period of low speed driving, such as in the city, it may be necessary to drive in a lower gear for a short period of higher speed driving, such as on the motorway.
    What they meant to say was: Give it an italian tuneup occasionally. Which I did.
    Allan
    The R32ran Thread
  6. Likes Uwe, jyoung8607, PetrolDave, Da Tow'd liked this post
