Results 1 to 10 of 10
Thread: 2009 Passat, can't get rid of P2015; I have tried everything.
    Jun 2019
    California, USA
    Hi to all, I bought a 2009 Passat and been fixing the car one thing at a time; but I got to the point that I cant figure how to fix the P2015 and the P300 codes; I have tried moving the coils, moving the injectors, cleaning the carbon buildup; new intake (OEM); new plugs, checked for vacuum leaks (couldn't find any); check for rips in the wires at the injunction below the air box and I repair a rip in the connector at the flap sensor and car still slow in acceleration and shakes bad, really bad around 1800 rpm.
    Theres something that Im missing but I can't figure it.
    Here's the scan, any help will be greatly appreciated, thanks
    Chassis Type: 3C-N/A (3C0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65
              72
    VIN: WVWJK73C89P051618   Mileage: 218780km-135943miles
    Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
       Part No SW: 06J 906 026 AG    HW: 06J 906 026 AF
       Component: MED17.5 TFSI 2,0    3319
       Revision: AAH03---    Serial number: VWZCZ000000000
       Coding: 0404010A19070160
       Shop #: WSC 00028 067 57207
       VCID: 6FBBD3A87B9BE4DF233-803A
    9 Faults Found:
                   P0300 - 000 -  - MIL ON
                        Fault Status: 11100000
                        Mileage: 211747 km
                        Date: 2013.08.05
                        Time: 23:16:13
                        RPM: 989 /min
                        Load: 54.9 %
                        Temperature: 62.0C
                        Temperature: 39.0C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 13.716 V
    000772 - Cylinder 4
                   P0304 - 000 - Misfire Detected - MIL ON
                        Fault Frequency: 30
                        Mileage: 211747 km
                        Date: 2013.08.05
                        Time: 23:16:13
                        RPM: 989 /min
                        Load: 54.9 %
                        Temperature: 62.0C
                        Temperature: 39.0C
                        Voltage: 13.716 V
    004874 - Cylinder Disabling
                   P130A - 000 -  - Intermittent
                        Mileage: 211747 km
                        Date: 2013.08.05
                        Time: 23:29:59
                        RPM: 1858 /min
                        Load: 19.6 %
                        Speed: 40.0 km/h
                        Temperature: 93.0C
                        Temperature: 30.0C
                        Voltage: 13.716 V
    000770 - Cylinder 2
                   P0302 - 000 - Misfire Detected - Intermittent - MIL ON
                        Fault Status: 10100000
                        Fault Frequency: 39
                        Mileage: 211765 km
                        Date: 2013.08.06
                        Time: 03:03:47
                        RPM: 889 /min
                        Load: 27.4 %
                        Temperature: 93.0C
                        Temperature: 39.0C
                        Absolute Pres.: 970.0 mbar
                        Voltage: 13.716 V
    001286 - Idle Control System
                   P0506 - 000 - RPM Lower than Expected - Intermittent
                        Fault Frequency: 25
                        Mileage: 218565 km
                        Date: 2013.11.11
                        Time: 05:30:37
                        RPM: 777 /min
                        Load: 37.2 %
                        Temperature: 42.0C
                        Temperature: 21.0C
                        Absolute Pres.: 960.0 mbar
                        Voltage: 14.097 V
    000771 - Cylinder 3
                   P0303 - 000 - Misfire Detected - MIL ON
                        Mileage: 215424 km
                        Date: 2013.10.05
                        Time: 18:15:09
                        RPM: 1241 /min
                        Load: 38.0 %
                        Temperature: 51.0C
                        Temperature: 37.0C
                        Voltage: 13.843 V
    008213 - Intake Manifold Flap Position Sensor (Bank 1)
                   P2015 - 000 - Implausible Signal - MIL ON
                        Mileage: 215668 km
                        Date: 2013.10.10
                        Time: 17:01:56
                        RPM: 1040 /min
                        Load: 34.9 %
                        Temperature: 30.0C
                        Temperature: 20.0C
                        Voltage: 13.970 V
                        Mileage: 217935 km
                        Date: 2013.10.31
                        Time: 15:35:15
                        RPM: 527 /min
                        Load: 69.0 %
                        Temperature: 72.0C
                        Temperature: 45.0C
                        Voltage: 12.065 V
    000769 - Cylinder 1
                   P0301 - 000 - Misfire Detected - Intermittent - MIL ON
                        Mileage: 218605 km
                        Date: 2013.11.11
                        Time: 17:49:19
                        RPM: 843 /min
                        Load: 44.7 %
                        Temperature: 62.0C
                        Temperature: 29.0C
                        Voltage: 13.462 V
    Readiness: 0110 0001
       Part No SW: 09G 927 750 GP    HW: 09G 927 750 GP
       Component: AQ 250 6F           1391
       Revision: 00H76000    Serial number:
       Coding: 0000840
       Shop #: WSC 00028 028 00001
       VCID: 055791004927CE8FF9F-8050
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 T    HW: 3C0 614 109 T
       Component: J104    C4 440 V2   0013
       Revision: --025---    Serial number: 00000786382439
       Coding: 0000376
       VCID: 2F3B13A8BB1BA4DF633-807A
       Part No SW: 1K0 820 047 JJ    HW: 1K0 820 047 JJ
       Component: Climatic PQ35   143 1313
       Revision: 00143033    Serial number: 00000000000000
       VCID: 75B7E1C019C7DE0FE9F-8020
       Revision: 00H54000    Serial number: 00000006016552
       Coding: 15848F0340041A00470000000F00000000285D435C000120000000000000
       VCID: 33331FD85733803F07B-8066
       Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
       Component: Wischer 260908 004  0206
       Coding: 00046997
       Shop #: WSC 00028
       Revision: 00000000    Serial number: AUZ4Z7H0467065
       Coding: 0000100
                        Fault Frequency: 9
                        Reset counter: 10
                        Mileage: 216656 km
                        Date: 2013.10.21
                        Time: 15:03:34
       Part No SW: 5N0 959 655     HW: 5N0 959 655
       Component: J234__01F VW10 HI   1815
       Revision: 19013000    Serial number: 0039BPN4LW65
       Coding: 0012614
       VCID: 7AADF2FC30D9B17784D-802E
       Subsystem 1 - Part No: 3C0 959 339 D
       Component: BF-Gewichtsens. 001 0002
       Subsystem 2 - Serial number: 000000000029T8
       Subsystem 3 - Serial number: 0030.10.08000010000065006063
       Subsystem 4 - Serial number: 6500606333FTS614512908 63
       Subsystem 5 - Serial number: 12908 6343FTS609522748 63
       Subsystem 6 - Serial number: 22748 6353ETS6LIKOU5KJ 63
       Subsystem 7 - Serial number: OU5KJ 6363ETS6BBGOU5KJ 63
       Subsystem 8 - Serial number: OU5KJ 6374CTS6M52KVVNR 63
       Subsystem 9 - Serial number: KVVNR 6384CTS6H2HMVVNR
       Subsystem 10 - Serial number: MVVNR
    Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
       Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
       Component: J0527               0030
       Revision: 00032000    Serial number: 3C5953507CN
       Coding: 0001111
       VCID: 74B1DCC412BDC707DE1-8020
       Part No SW: 3C0 920 971 S    HW: 3C0 920 971 S
       Component: KOMBI         H04 0110
       Coding: 260F00
       Shop #: WSC 00028 028 00021
       VCID: 353721C055C79E0F29F-8060
       Part No SW: 3C0 907 530 L    HW: 3C0 907 951
       Component: J533__Gateway   H13 0152
       Revision:   H13       Serial number: 3300P08A3002DA
       Coding: FD807F07001302001002
       VCID: 2A0D02BC80F9C1F7B4D-807E
       Part No SW: 3C8 919 965     HW: 3C8 919 965
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1614128T06YQ02
       Part No SW: 3C0 959 433 AP    HW: 3C0 959 433 AP
       Component:    IMMO         052 0383
       Revision: 00052000    Serial number: VWZCZ000000000
       Shop #: WSC 22138 444 999999
       VCID: 78A9E8F40ED5A367F29-802C
       Subsystem 1 - Part No: 3C0 905 861 H
       Component:    ELV          028 0380
       3C0905861H     ELV          028 0380
    01176 - Key
                        Reset counter: 181
                        Mileage: 198245 km
                        Date: 2012.09.23
                        Time: 06:50:56
    02823 - Requirements for Locking the Steering Column Lock not met
                        Reset counter: 86
                        Mileage: 218063 km
                        Date: 2013.11.03
                        Time: 14:57:27
    02827 - Wake-Up request via ESP
                        Reset counter: 86
                        Mileage: 218063 km
                        Date: 2013.11.03
                        Time: 14:57:28
       Component: J386  TUER-SG FT    1517
       Revision: 72009005    Serial number: 00000768489007
       Coding: 0001205
       Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
       Component: J500__APA-BS KL.082 0502
       Revision: 1AH02240    Serial number: 00082170130502
       Coding: 0000258
       VCID: 392F2DF0755F7A6FCD7-806C
    01312 - Powertrain Data Bus
                        Reset counter: 86
                        Mileage: 218063 km
                        Date: 2013.11.03
                        Time: 14:57:16
                            Term 15 Off
                        (no units): 7.0
                        Voltage: 12.50 V
       Component:    KSG PQ46 RDK 052 0412
       Coding: 13910F8001862E521004141FF08A0F0E085801
       Component: J387  TUER-SG BT    1517
       Revision: 72009005    Serial number: 00000626489004
       Coding: 0001204
       VCID: 70B9D0D466A5FB273A9-8024
       Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
       Component: J540 EPB3  VW-10498 0003
       Revision:   009       Serial number: 00000000189094
       Coding: 0000057
       VCID: 2809F8B49EF5F3E7A29-807C
       Part No SW: 1K0 035 180 N    HW: 1K0 035 180 N
       Component: Radio PM6       130 0046
       Revision: 00130000    Serial number: VWZ5Z7H2282132
       Coding: 0040402
       VCID: 2B0307B88F03D8FF4FB-807E
       Part No SW: 1K0 959 703 AD    HW: 1K0 959 795 P
       Component: J388   TUER-SG HL   0308
       Revision: 42004101    Serial number: 00000000708029
       Coding: 0001168
       VCID: 72BDDADC68A9C937CCD-8026
       Component:    RDK              0453
       Coding: 0100101
       Part No SW: 1K0 959 704 AD    HW: 1K0 959 794 P
       Component: J389   TUER-SG HR   0308
       Revision: 42004101    Serial number: 00000000712342
       Coding: 0001168
       VCID: 73B3DFD817B3C03FC7B-8026
    End----(Elapsed Time: 01:30, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
  3. Likes Uwe liked this post
    Jun 2019
    California, USA
    I look into your post but my car doesn't have the motor that you have in your pictures.
    Correct its different but they all do the same type failure even if air motor.
    It's about limiting travel.
  6. Likes Zenerdiode liked this post
    Jun 2019
    California, USA
    I tried this and it didn't solve my problem, however, I notice the following: with car in park I give it gas pass the 3000 rpm and the arm that moves the flaps will move but wont go back not even if I try to manually move it back.
    I did the following:
    1.- Unplugged the vacuum line to the vacuum solenoid (PN 037 906 628 C) -under the "air motor"- and the arm did not move at all after rev'n the engine pass the 3000 rpm mark.
    2.- Connected the vacuum line in to the solenoid.
    3.- Rev the car pass the 3000 rpm, the arm moved again, but did not move back.
    4.- Unplugged the line that goes from the "air motor" to the solenoid and the arm moved back.
    This tells me that either I'm not getting signal to the ECU from the flap sensor or not getting signal to the solenoid from the ECU.
    Any ideas?
    Any ideas?
    Jun 2019
    California, USA
    I solved the P2015 code, first, I try everything that Jack suggested but it didn't work on my case, second of all a HUGE correction as follows
    Quote Originally Posted by Temo View Post
    The correct part number is 06H 906 283 B, THIS IS VERY IMPORTANT, I'll explain:
    Old intake manifold had the vacuum solenoid PN 037906628C and the new manifold had the vacuum solenoid PN 06H906283B; the difference is that one have 2 vacuum ports (037906628C) and the other (06H906283B) have 3 vacuum ports.
    I did this test
    http://wiki.ross-tech.com/wiki/index...anifold_Runner
    and the result was an error in the field 4, I swapped the old vacuum solenoid for the new one and the P2015 is gone and the arm moves and go back as it supposed to do.
    To recap, IN MY CASE the OEM Intake Manifold that I bought had a vacuum solenoid with 3 ports and it end up being the culprit for my P2015 code.
    Hope that this helps somebody else!
  10. Likes jyoung8607, Jack@European_Parts liked this post
  11. #8
    I did this test
    037906628C <<<<<<<<<<<<<<<<<< Nein invalid part number but I think you meant below!
    Well induced
    FOD is unfair but part of the JPPSG!
    This is what happens when you fail to verify a part or mix with a run change!
    No sir verified you didn't check RTFB and TSB or TPI's
    REF# 2043944
    Vehicle Identification No. WVWJK73C89P051618
    Model passat sedan
    PA
    Date of production 20.11.2008
    Model year 2009
    Sales type 3C25L6
    Engine Code CCTA
    Transmission Code KGU
    Emission standard 7GB Emission standard ULEV 2
    PART NUMBER DESCRIPTION REMARK
    037 906 283 C solenoid valve 06J 133 201 G
    06J 133 201 AL
    06J 133 201 AS
    06J 133 201 BD
    2043944
    06H 906 283 B solenoid valve 06J 133 201 BH
    2043944
  12. #9
    Jun 2019
    California, USA
    Guilty. I assumed that the new part was going to be exactly as the original one.
  13. Likes Jack@European_Parts liked this post
  14. #10
    Yeah, well I should of told you to JPPSG first.....that stupid asshole that wrote that thing WTF was he thinking!
