Results 11 to 20 of 24
Thread: Lane Assist Coding
    Jan 2016
    More information it appears that the issues revolve around these two adaptations.
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning (to active)
    ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold _high (to active)
    If neither are activated I get both Lane Assist and Active Lane Assist menus in Grey - adding the others sometimes brings up Active Lane Assist but then I could end up with no menu at all. However sometimes the Lane Assist Icon flickers, and I even had a situation where the lane assist button toggles the vibration check box!
  2. #12
    Jun 2017
    Your maps were measurement maps, not adaptation.
    You have to hit the adaptation check box...
  3. #13
    Jan 2016
    Sorry 5F was correct 8e below, hope it helps!
    ;SW:4H0-907-107-H   HW:4H0-907-107 ---  Image Processing
    ;Component:BV-SG         H33 0090	 Coding:044229040111
    ;EV_BC7	1001	EV_BC7.rod
    ;Saturday	6	July
    ;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
    ;VCID: 2C57C8CF47DCDF2F15-8078
    IDE00820-Activating and deactivating all development messages	0	1
    IDE01958-Steering wheel vibration factory setting	activated 	1
    IDE02005-EMC test mode	not activated 	1
    IDE03462-Menu for time of assisted steering	activated 	1
    IDE03463-Menu for steering wheel vibration	activated 	1
    IDE03465-Steering wheel vibration active	activated 	1
    IDE03466-Steering assistance active	not activated 	1
    IDE04160-Direct. stab. assist speed threshold during towing mode	325 km/h	2
    IDE04725-Intervention moment factory setting	Late 	1
    IDE04726-Intervention moment	Early 	1
    IDE04729-Direct. stab. assist.: acoustic warn when driving w/o hands	Gong 1 	1
    IDE04733-Road sign detection fusion mode	Road sign fusion 	1
    IDE04734-Display general maximum speed	Always 	1
    IDE04735-Display invalid commands	111	1
    IDE04736-Display end of speed limit symbol	1	1
    IDE04737-Display no passing allowed	activated 	1
    IDE04738-Predictive route data run time	0 ms	1
    IDE04815-Display valid additional signs	activated 	1
    IDE04816-Prioritize additional wetness signs	activated 	1
    IDE04817-Sort valid traffic signs	174 km/h	2
    IDE04841-Sorting alternatives	425 km/h	2
    IDE04908-Factory setting f activation stat of directional stab assist	On 	1
    IDE05984-Directional stabilization assist driver inact deactiv threshold	Late 	1
    IDE05985-Directional stab. assist.: intensity: steering wheel vibration	Strong 	1
    IDE05986-Directional stab. assist.: intensity: power steering support	Strong 	1
    IDE07596-Personalization of lane dept. warning Cl. 15 on	activated 	1
    IDE80006-Analysis 6	not activated 	1
    IDE80007-Analysis 7	not activated 	1
    IDE80010-Analysis 10	activated 	1
    IDE80015-MAS00138-Analysis 15-1	0	3
    IDE80015-MAS00139-Analysis 15-2	0	3
    IDE80015-MAS00140-Analysis 15-3	0	3
    IDE80015-MAS00141-Analysis 15-4	0	3
    IDE80016-MAS00138-Analysis 16-1	0	15
    IDE80016-MAS00139-Analysis 16-2	0	15
    IDE80016-MAS00140-Analysis 16-3	0	15
    IDE80016-MAS00141-Analysis 16-4	0	15
    IDE80016-MAS00142-Analysis 16-5	0	15
    IDE80016-MAS00143-Analysis 16-6	0	15
    IDE80016-MAS00144-Analysis 16-7	0	15
    IDE80016-MAS01338-Analysis 16-8	0	15
    IDE80016-MAS03035-Analysis 16-9	0	15
    IDE80016-MAS03036-Analysis 16-10	0	15
    IDE80016-MAS03037-Analysis 16-11	0	15
    IDE80016-MAS03038-Analysis 16-12	0	15
    Elapsed Time: 00:11
  4. #14
    Jun 2017
    What about activating this?
  5. Likes Uwe liked this post
  6. #15
    Jan 2016
    Pressing the lane assist button enables this activation?
  7. #16
    Jun 2017
    I can't figure out what is wrong with your retrofit.
    Can you make a video of this phenomenon described?
  8. #17
    Jan 2016
    Video links attached 1 shows turning on and off vibration using the lane assist button on the stalk. Note also the menu changes across all three from Audi Lane Assist to Active Lane Assist? Also shows flickering instrument indication with no button presses???
    https://www.dropbox.com/s/1jh2bp984m...t%201.mp4?dl=0
    https://www.dropbox.com/s/lzv29pv9u8...t%202.mp4?dl=0
    https://www.dropbox.com/s/gh1afy2mv7...t%203.mp4?dl=0
  9. #18
    Jun 2017
    I've never seen something like that.
    Are you able to COMPLETELY revert all changes made since you retrofitted the stalk?
  10. #19
    Jan 2016
    I have a "friendly" dealer who is going to take a look on Sunday - there is suggestion of firmware issues on the 5F on early FL models. Odd the Traffic Sign Coded perfectly with menus no problem. Thanks for your help.
  11. #20
    Jan 2016
    Hello again, I think the issue is more than the 5F as I seem to have picked up the flickering issue described elsewhere. Can you (or anyone confirm) if they have done FL lane assist without side assist - I don't have any errors so I am thinking it is probably still adaptation. I have "unpicked" all the changes one by one and then reapplied and get the same issue. I am surprised the car "allows" it to work when the whole display is flickering.
