All, I am really having a challenge finishing off the Active Lane assist on my facelift A6 2015 - it all works sort of but I have the following two issues.
The display recognises the road markings correctly! If I code the Image processing unit (8e) byte 1 to Lane Assist and Lane Change Assist (Coding 40) then the display flickers and the units shows missing messages (presumably from the side assist) but steering assistance works. If I select Lane Assist (which is what I think is Side Assist) not installed Coding 20 then the display works properly but steering assistance is unavailable and if I try to enable via adaption the command is rejected. There seems to be ambiguity between Active Lane Assist and what I call side assist.
I also cannot get the MMI to show active lane assist, just shows lane assist with incorrect sub menus?
I am so close but I cannot figure out the coding/adaptation. The scan below is with Coding 40 on byte 1 of the 8e unit - so steering assistance works but display flickers and sometimes locks up.
Any assistance would be appreciated.
Sunday,23,June,2019,16:10:23:55272
VCDS Version: 19.6.0.4 (x64)
VIN: WAUZZZ4G8FN068483 License Plate:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 3B 42 44 46 52 53 55 5F 62
69 6C 6D 72 85 8E AC
VIN: WAUZZZ4G8FN068483 Mileage: 108775km-67589miles
17-Instruments -- Status: Malfunction 0110
Address 01: Engine (J623-CRTD) Labels:. 059-907-401-V2.clb
Part No SW: 4G2 907 401 B HW: 4G2 907 401
Component: 3.0TDI EDC17 H33 0001
Revision: 92H33---
Coding: 12254012052601030000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TDI0114G2907401B 001001
ROD: EV_ECM30TDI0114G2907311C.rod
VCID: 244720EF2F0C176FD3-8070
Part No SW: 4G0 927 166 C HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0007
Revision: --H03---
Coding: 100001
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 2D51C5CB7CC6D6270C-8078
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Coding: 17A69E41E86579829B00
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_003.rod
VCID: 3F8D8F83A6AA54B7AE-806A
Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0560
Coding: 01B9704E000000000000
VCID: 7AFB3E97F508B19FD9-802E
Serial number: 3215000011387005
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 12021500040194
Coding: 36A21178250000
VCID: 63C563F36A825057EA-8036
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001008344002
Coding: 0105001440349FE041014083000018000F9DE7082F08020100000894E100130200400034030000
Shop #: WSC 53920 001 104857
VCID: 71E919BBA87EF2C768-8024
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 150111 H37 0080
Serial number: 150126014513
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23730186
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 13 02 2015 00000883
Serial number: F818C297000000000001
Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P100390YW
Coding: 30333130313730323737554A305234473053
VCID: 3B75FB93B2B2489782-806E
Serial number: 3575HRB401G52UQM71L
Serial number: 3585HRB405133PKM68CD
Serial number: 3515JRB40145358SI2AU
Serial number: 3525JRB40145358SP91-
Serial number: 3554VRB400Q534069H6.
Serial number: 3564VRB400M5340670PY
Revision: -------- Serial number: 90372OBC00036
Coding: 0004F5
VCID: 387FE49F8B84638F6F-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 06 01 2015 C0007902
Part No SW: 4G8 920 985 L HW: 4G8 920 985 L
Component: TDieGb H08 0043
Revision: 04001037 Serial number: 658180215596026
Coding: 33A612000B552600010000
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 408F8C7FDB542B4FD7-8014
1048578 - No Basic Setting
B2010 00 [009] - -
Reset counter: 230
Mileage: 108745 km
Date: 2019.06.23
Time: 11:04:58
16776980 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 16
Mileage: 108753 km
Date: 2019.06.23
Time: 12:20:17
Part No SW: 4G8 907 468 HW: 4G8 907 468
Component: J533--Gateway H13 0075
Revision: -------- Serial number: 00000001729380
Coding: C0CD078118
ASAM Dataset: EV_GatewPkoUDS 001024
VCID: 75E12DABD416DEE7B4-8020
Serial number: 1900125603
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 1412100000000000044B
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 14021500040455
Coding: 22
VCID: 3D71F58BACA646A7BC-8068
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA8208ZJ6T
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3663EAA7899095FF7D-8062
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011C16015001620002080002
VCID: 479D9763F67A1C7716-8012
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0016426092
Coding: 101001010001
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
VCID: 3365D3B39AE280D75A-8066
Revision: 00002001 Serial number: 0360799116
Coding: 013B0622A0B93080C320090420010F470000000000000000000000000000
Component: TSG BF H03 0507
VCID: 46839A67F170057FED-8012
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001368405
ROD: EV_ParkiBrake_VW51.rod
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 D HW: 7P6 907 357 B
Component: MxB-ECU 001 0081
Coding: 04FE02202A130200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
Coding: E01F00
Coding: E01F00
Matrix Headlamp Powermodule 1 Left:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H03 0031
Coding: E01F00
Matrix Headlamp Powermodule 1 Right:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0031
Coding: E01F00
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 021 D HW: 4G1 035 021
Component: MU-H-LND-EU 041 0389
Serial number: A588B0F7505471
Coding: 017502010000000013111102000A00132F0006E7F1700100DF
VCID: 1B351B131272289762-804E
Subsystem 1 - Part No SW: V03 959 801 FD HW: -----------
Component: ECE 2017/2018 --- 0161
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9EY800PTF
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Component: E380 BDT C7 H20 0250
Serial number: 90349OBD0006Q
Component: Gracenote2 --- 1012
7961 - Control module
B2001 00 [008] - Incorrect software version
Fault Frequency: 8
Reset counter: 17
Mileage: 108771 km
Date: 2019.06.23
Time: 15:53:53
Voltage terminal 30: 14.5 V
Part No SW: 4G8 959 795 D HW: 4G8 959 795
Component: TSG HL H03 0212
Coding: 01081C004001620000080002
Shop #: WSC 02312 785 00200
VCID: 43858373C2423057CA-8016
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4G8 907 383 B HW: 4G8 907 383 B
Component: Anhaenger H14 0113
Serial number: 0000454261
Coding: 0100000202000000
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Revision: --H04--- Serial number: 525 PA8J1XG2SO
Coding: 1030005
Shop #: WSC 98765 666 38384
VCID: 26433AE79130E57FCD-8072
Reset counter: 230
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0150
Revision: 14005001 Serial number: 030500754
Coding: 093205C010
ROD: EV_HDSGAu571.rod
Component: TSG HR H03 0212
Shop #: WSC 28100 141 104456
Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Component: DPC-SG H27 0081
Coding: 71160000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C57C8CF47DCDF2F1B-8078
Part No SW: 4H0 907 107 H HW: 4H0 907 107
Component: BV-SG H33 0090
Serial number: 005000621903157
Coding: 044239040111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
0025 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 230
Mileage: 108745 km
Date: 2019.06.23
Time: 11:50:49
Outside air temperature: 18.5 ∞C
Voltage terminal 15: 11.6 V
Control Module temperature: 30.0 ∞C
0061 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 230
Mileage: 108745 km
Date: 2019.06.23
Time: 11:50:48
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 150210145
ROD: EV_RDCMA00100_008.rod
End-------------------------(Elapsed Time: 05:51)--------------------------
