Good day gentlemen,
A good friend of mine has some codes popping up on his 2015 Passat TDI regarding the coolant pump. Autoscan below.
Has anybody run into this one before?
Can anybody confirm where this pump is located?
By the looks of the 3 codes it almost looks like it has come unplugged/disconnected electrically...or that the plug is corroded, etc.
Just looking for any additional info and advice before getting under the car. Thanks for the help.
Wednesday,03,July,2019,09:15:16:24871
VCDS Version: 19.6.0.2 (x64)
VIN: 1VWCV7A34FC016626 License Plate:
Mileage: 98360km-61118mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 77
VIN: 1VWCV7A34FC016626 Mileage: 98360km-61118miles
Address 01: Engine (J623-CVCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 997 016 D HW: 04L 907 309 K
Component: R4 2.0l TDI X20 9466
Revision: 8AX20---
Coding: 011D0012832410089000
ASAM Dataset: EV_ECM20TDI01104L997016D 004002
ROD: EV_ECM20TDI01104L997016D.rod
VCID: 346733879F5A48EF45-8060
28389 - Coolant Pump 3
P26F7 00 [175] - Supply Voltage Malfunction
Mileage: 98324 km
Date: 2019.07.02
Time: 16:18:11
Engine speed: 1672.50 /min
Normed load value: 61.2 %
Vehicle speed: 24 km/h
Coolant temperature: 45 °C
Intake air temperature: 37 °C
Voltage terminal 30: 14.320 V
Heater support pump 1 bank 1 second.circuit: activat.: 94.79 %
Extern.temp.sens.1 bank 1: raw value: 20.0 °C
Shut-off timer: last engine shut-off time: 7444 s
28386 - Coolant Pump 3
P26F5 00 [032] - Short to GND
Mileage: 98362 km
Date: 2019.07.03
Time: 06:33:49
Engine speed: 833.50 /min
Normed load value: 49.4 %
Coolant temperature: 24 °C
Intake air temperature: 24 °C
Voltage terminal 30: 14.120 V
Heater support pump 1 bank 1 second.circuit: activat.: 53.77 %
Extern.temp.sens.1 bank 1: raw value: 16.0 °C
Shut-off timer: last engine shut-off time: 32827 s
28388 - Coolant Pump 3
P26F4 00 [032] - Electrical Malfunction / Open Circuit
Fault Frequency: 8
Mileage: 98344 km
Date: 2019.07.02
Time: 16:50:26
Engine speed: 907.00 /min
Normed load value: 38.0 %
Coolant temperature: 25 °C
Voltage terminal 30: 14.340 V
Heater support pump 1 bank 1 second.circuit: activat.: 10.00 %
Readiness: 1 1 0 1 0
Part No SW: 02E 300 061 T HW: 02E 927 770 AL
Component: GSG DSG AG6 521 4518
Revision: 05652104 Serial number: 00001406011268
Shop #: WSC 09003 957 00200
VCID: 2541DEC3EC802167C2-8070
28907 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 000 - - Intermittent
Reset counter: 39
Mileage: 98362 km
Date: 2019.07.03
Time: 06:33:46
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: C54BC0F549230000A31103E6921F0042A1100012
VCID: 7EF3D1AFE99652BFE3-802A
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Revision: 00092000 Serial number: 0340172772
Coding: 130C0C
VCID: 377D048B8E2CA3F760-8062
Part No SW: 561 907 044 AP HW: 561 907 044 AP
Component: Climatronic H03 0707
Revision: 00001K01
Coding: 0010019012
VCID: 65C19EC36400E16702-8030
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0174
Revision: BL122001
Coding: EF200E3BEC2B2AD408880201360081C802F1A08645A005B064806000BC70
VCID: 78FFC7B7CBB26C8FA9-802C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 300514 05 54 0403
Coding: 06300A
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10 500 0975
Serial number: 003LZD0199Y$
Coding: 00004D34
ASAM Dataset: EV_AirbaVW10SMEVW360 001030
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 72EBF59FA5CE06DF97-8026
Serial number: 6940000Y14000176WY09
Coding: 303047
Serial number: 3572MSME27652D45ZZZ.
Serial number: 3582MSME3F336A45ZZZ0
Serial number: 3516KSME0943262FZZZU
Serial number: 3526KSME295D262FZZZ1
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME0777182FZZZ+
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME595E182FZZZB
Part No SW: 1K5 953 521 BR HW: 5K0 953 569 AH
Revision: FF010042 Serial number: 20140505300166
Coding: 0002140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7EF3D1AFE19652BFE3-802A
Component: E221__MFL-YVJ H07 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 870 E HW: 561 920 870 E
Component: KOMBI H04 0813
Coding: 331E01
VCID: 1B35F83B12C4E79764-804E
Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM
Component: J533 Gateway H55 1653
Revision: H55 Serial number: 24061403000105
Coding: 461000
VCID: 000FAF579362244F91-8054
Component: IMMO H04 0813
Coding: 000007
VCID: 6ADBEDFF8D1ECE1F2F-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 14000144473003
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 306F3F976B4274CF21-8064
Address 2E: Media Player 3
Part No SW: 561 959 760 B HW: 561 959 760 B
Component: MEM-FS H04 0182
Revision: AA000000 Serial number: 00000105455408
VCID: 224BC5DF3DAED65FA7-8076
Part No SW: 3C0 035 684 Q HW: 3C0 035 684 N
Component: RNS-MID H26 5382
Revision: AB001001 Serial number: VWZ6Z7P5182018
Coding: 24090042010000A4000B
VCID: 31693A9368487DC72E-8064
Component: NAR V12 8534
Reset counter: 142
Mileage: 90792 km
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0008685814
Coding: 0405FD
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1C37FB2717CAE0AF6D-8048
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14102630140721214854
Coding: 800000
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 215 3501
Revision: 00H22000
VCID: 397902B37038B58796-806C
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H08 6815
Revision: -------- Serial number: EAA098A0155191
VCID: 2643D9CF59862A7FCB-8072
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1653
Coding: 01030108
VCID: 6FEDFCEBBEFC2B3778-803A
Subsystem 1 - Part No SW: 561 959 591 A HW: 561 959 591 A
Component: J245 P05 9BA3 H08 0005
Serial number: 53388786011407703793
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0008646629
Coding: 0405FC
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D31F6230CD0E9A79A-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14102631140729190133
Coding: 800000
Reset counter: 142
Mileage: 90792 km
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0592
Revision: 1B001001 Serial number: 00007666010661
Coding: 0A10030080010110
Shop #: WSC 00237 002 1048576
ROD: EV_UHVUMI.rod
VCID: 2E5321EF7176623F33-807A
End-------------------------(Elapsed Time: 03:39)--------------------------
Wednesday,03,July,2019,09:21:56:24871
52 56 62 72 77
Revision: 8AX20---
Mileage: 98324 km
Date: 2019.07.02
Time: 16:18:11
Mileage: 98362 km
Date: 2019.07.03
Time: 06:33:49
Fault Frequency: 8
Mileage: 98344 km
Date: 2019.07.02
Time: 16:50:26
Reset counter: 39
Mileage: 98362 km
Date: 2019.07.03
Time: 06:33:46
Revision: 00H46001
Coding: 130C0C
Revision: 00001K01
Coding: 0010019012
Revision: BL122001
Coding: 06300A
Coding: 00004D34
Coding: 303047
Coding: 0002140000
Coding: E20000
Coding: 331E01
Coding: 461000
Coding: 000007
Reset counter: 142
Mileage: 98368 km
Coding: 0405FD
Slave Driver:
Coding: 800000
Revision: 00H22000
Coding: 01030108
Coding: 181100
Coding: 0405FC
Slave Passenger:
Coding: 800000
Reset counter: 142
Mileage: 98368 km
ROD: EV_UHVUMI.rod
End-------------------------(Elapsed Time: 03:26)--------------------------
