Results 1 to 3 of 3
Thread: 2015 Passat TDI with 3x Coolant Pump Faults
    Verified VCDS User Rembrant's Avatar
    Nov 2014
    Canada
    Good day gentlemen,
    A good friend of mine has some codes popping up on his 2015 Passat TDI regarding the coolant pump. Autoscan below.
    Has anybody run into this one before?
    Can anybody confirm where this pump is located?
    By the looks of the 3 codes it almost looks like it has come unplugged/disconnected electrically...or that the plug is corroded, etc.
    Just looking for any additional info and advice before getting under the car. Thanks for the help.
    Wednesday,03,July,2019,09:15:16:24871
    VCDS Version: 19.6.0.2 (x64)
    VIN: 1VWCV7A34FC016626   License Plate:
    Mileage: 98360km-61118mi   Repair Order:
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
              52 56 62 72 77
    VIN: 1VWCV7A34FC016626   Mileage: 98360km-61118miles
    Address 01: Engine (J623-CVCA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 997 016 D    HW: 04L 907 309 K
       Component: R4 2.0l TDI   X20 9466
       Revision: 8AX20---
       Coding: 011D0012832410089000
       ASAM Dataset: EV_ECM20TDI01104L997016D 004002
       ROD: EV_ECM20TDI01104L997016D.rod
       VCID: 346733879F5A48EF45-8060
    28389 - Coolant Pump 3
              P26F7 00 [175] - Supply Voltage Malfunction
                        Mileage: 98324 km
                        Date: 2019.07.02
                        Time: 16:18:11
                        Engine speed: 1672.50 /min
                        Normed load value: 61.2 %
                        Vehicle speed: 24 km/h
                        Coolant temperature: 45 C
                        Intake air temperature: 37 C
                        Voltage terminal 30: 14.320 V
                        Heater support pump 1 bank 1 second.circuit: activat.: 94.79 %
                        Extern.temp.sens.1 bank 1: raw value: 20.0 C
                        Shut-off timer: last engine shut-off time: 7444 s
    28386 - Coolant Pump 3
              P26F5 00 [032] - Short to GND
                        Mileage: 98362 km
                        Date: 2019.07.03
                        Time: 06:33:49
                        Engine speed: 833.50 /min
                        Normed load value: 49.4 %
                        Coolant temperature: 24 C
                        Intake air temperature: 24 C
                        Voltage terminal 30: 14.120 V
                        Heater support pump 1 bank 1 second.circuit: activat.: 53.77 %
                        Extern.temp.sens.1 bank 1: raw value: 16.0 C
                        Shut-off timer: last engine shut-off time: 32827 s
    28388 - Coolant Pump 3
              P26F4 00 [032] - Electrical Malfunction / Open Circuit
                        Mileage: 98344 km
                        Date: 2019.07.02
                        Time: 16:50:26
                        Engine speed: 907.00 /min
                        Normed load value: 38.0 %
                        Coolant temperature: 25 C
                        Voltage terminal 30: 14.340 V
                        Heater support pump 1 bank 1 second.circuit: activat.: 10.00 %
    Readiness: 1 1 0 1 0
       Part No SW: 02E 300 061 T    HW: 02E 927 770 AL
       Component: GSG DSG AG6     521 4518
       Revision: 05652104    Serial number: 00001406011268
       Shop #: WSC 09003 957 00200
       VCID: 2541DEC3EC802167C2-8070
    28907 - No Communications with Cruise Control (Front) Distance Sensor
                U0235 - 000 -  - Intermittent
                        Reset counter: 39
                        Mileage: 98362 km
                        Date: 2019.07.03
                        Time: 06:33:46
       Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
       Component: ESP MK60EC1   H46 0164
       Revision: 00H46001
       Coding: C54BC0F549230000A31103E6921F0042A1100012
       VCID: 7EF3D1AFE99652BFE3-802A
       Revision: 00092000    Serial number: 0340172772
       Coding: 130C0C
       VCID: 377D048B8E2CA3F760-8062
       Part No SW: 561 907 044 AP    HW: 561 907 044 AP
       Component: Climatronic   H03 0707
       Revision: 00001K01
       Coding: 0010019012
       ROD: EV_ACClimaBHBVW411_VW41.rod
       VCID: 65C19EC36400E16702-8030
       Part No SW: 5K0 937 087 AE    HW: 5K0 937 087 AE
       Component: BCM PQ35 H+   122 0174
       Revision: BL122001
       Coding: EF200E3BEC2B2AD408880201360081C802F1A08645A005B064806000BC70
       VCID: 78FFC7B7CBB26C8FA9-802C
       Component: RLS 300514 05  54  0403
       Coding: 06300A
       Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
       Component: AirbagVW10    500 0975
       Serial number: 003LZD0199Y$
       Coding: 00004D34
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 72EBF59FA5CE06DF97-8026
       Serial number: 6940000Y14000176WY09
       Coding: 303047
       Serial number: 3572MSME27652D45ZZZ.
       Serial number: 3582MSME3F336A45ZZZ0
       Serial number: 3516KSME0943262FZZZU
       Serial number: 3526KSME295D262FZZZ1
       Serial number: 3556LSME0777182FZZZ+
       Serial number: 3566LSME595E182FZZZB
       Part No SW: 1K5 953 521 BR    HW: 5K0 953 569 AH
       Revision: FF010042    Serial number: 20140505300166
       Coding: 0002140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7EF3D1AFE19652BFE3-802A
       Component: E221__MFL-YVJ  H07 0022
       Coding: E20000
    Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
       Part No SW: 561 920 870 E    HW: 561 920 870 E
       Component: KOMBI         H04 0813
       Coding: 331E01
       VCID: 1B35F83B12C4E79764-804E
       Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
       Component: J533  Gateway H55 1653
       Revision:   H55       Serial number: 24061403000105
       Coding: 461000
       VCID: 000FAF579362244F91-8054
       Component: IMMO          H04 0813
       Coding: 000007
       VCID: 6ADBEDFF8D1ECE1F2F-803E
       Revision: 00000000    Serial number: 14000144473003
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 306F3F976B4274CF21-8064
    Address 2E: Media Player 3
       Part No SW: 561 959 760 B    HW: 561 959 760 B
       Component: MEM-FS        H04 0182
       Revision: AA000000    Serial number: 00000105455408
       Coding: 00581B0000000000000021010100202020202120202020
       VCID: 224BC5DF3DAED65FA7-8076
       Part No SW: 3C0 035 684 Q    HW: 3C0 035 684 N
       Component: RNS-MID       H26 5382
       Revision: AB001001    Serial number: VWZ6Z7P5182018
       Coding: 24090042010000A4000B
       VCID: 31693A9368487DC72E-8064
       Subsystem 1 - Part No: 7L6 919 859
       Component: NAR V12  8534
                        Reset counter: 142
                        Mileage: 90792 km
       Part No SW: 561 959 701 A    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0525
       Revision: 12110009    Serial number: 0008685814
       Coding: 0405FD
       ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 1C37FB2717CAE0AF6D-8048
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  006 5470
       Serial number: 14102630140721214854
       Coding: 800000
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 215    3501
       Revision: 00H22000
       VCID: 397902B37038B58796-806C
       Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
       Component: KonzernAmp10K H08 6815
       Revision: --------    Serial number: EAA098A0155191
       VCID: 2643D9CF59862A7FCB-8072
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
       Component: EZE_2         H55 1653
       Coding: 01030108
       VCID: 6FEDFCEBBEFC2B3778-803A
       Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
       Component: J245 P05 9BA3  H08 0005
       Serial number: 53388786011407703793
       Coding: 181100
       Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  008 0005
       Part No SW: 561 959 702 A    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0525
       Revision: 14110009    Serial number: 0008646629
       Coding: 0405FC
       ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 1D31F6230CD0E9A79A-8048
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  006 5470
       Serial number: 14102631140729190133
       Coding: 800000
                        Reset counter: 142
                        Mileage: 90792 km
       Component: TELEFON       H05 0592
       Revision: 1B001001    Serial number: 00007666010661
       Coding: 0A10030080010110
       Shop #: WSC 00237 002 1048576
       ROD: EV_UHVUMI.rod
       VCID: 2E5321EF7176623F33-807A
    End-------------------------(Elapsed Time: 03:39)--------------------------
    Wednesday,03,July,2019,09:21:56:24871
              52 56 62 72 77
       Revision: 8AX20---
                        Mileage: 98324 km
                        Date: 2019.07.02
                        Time: 16:18:11
                        Mileage: 98362 km
                        Date: 2019.07.03
                        Time: 06:33:49
                        Mileage: 98344 km
                        Date: 2019.07.02
                        Time: 16:50:26
                        Reset counter: 39
                        Mileage: 98362 km
                        Date: 2019.07.03
                        Time: 06:33:46
       Revision: 00H46001
       Coding: 130C0C
       Revision: 00001K01
       Coding: 0010019012
       Revision: BL122001
       Coding: 06300A
       Coding: 00004D34
       Coding: 303047
       Coding: 0002140000
       Coding: E20000
       Coding: 331E01
       Coding: 461000
       Coding: 000007
                        Reset counter: 142
                        Mileage: 98368 km
       Coding: 0405FD
       Slave Driver:
       Coding: 800000
       Revision: 00H22000
       Coding: 01030108
       Coding: 181100
       Coding: 0405FC
       Slave Passenger:
       Coding: 800000
                        Reset counter: 142
                        Mileage: 98368 km
       ROD: EV_UHVUMI.rod
    End-------------------------(Elapsed Time: 03:26)--------------------------
    Late build 2006 White Jetta BRM 5spd. Mile eater.
    Dallas (McKinney) ,TX ,USA
    What happens if you clear codes?
    Immobilizer/ECU
    email : marinmm2001@gmail.com
    Coolant pump 3 is most likely in possible failure and should be determined for location by RTFB and observed WD.
    This way you will know where it is and what tracks to test or fuse to address. Watch out!, pumps can and do catch on fire without blowing a fuse!
