Results 11 to 20 of 28
Thread: 2003 A6 Quattro Central locking unit flooded.
    Manual hex key to close or open sunroof as per RTFB?
  2. #12
    Jul 2019
    My DSL wen t out for the 50th time. Really bad company. In restaurant right now.
    Will clar and rerun. Thanks
  3. #13
    Jul 2019
    Did not realize hex key would open. Mia culpa.
    Thx
  4. #14
    Jul 2019
    Cleared and reran auto can three time as I did not trust. It showed no errors in engine while my small little read out tool showed leaks in air injection
    17831 - Secondary Air Injection System; Bank 1
    P1423 - 35-00 - Insufficient Flow
    17819 - Secondary Air Injection System; Bank 2
    P1411 - 35-00 -Insufficient Flow
    Any way, this no longer appear and only one fault in headlight leveling transmitter. So what is next: Audi A6 (4B) Central Locking Remote Control Matching?
    Wednesday,10,July,2019,20:22:34:29746
    VCDS Version: 19.6.1.0 (x64)
    VIN: WAUML64B43N104356   License Plate:
              75 76 77
    Address 01: Engine        Labels: None
       Part No: 4D0 907 560 CL
       Component: 4.2L V8/5V      G   0001
       Coding: 07752
       Shop #: WSC 02325
       VCID: 72EBF47B3EDB13DF9F-5124
       WAUML64B43N104356     AUZ7Z0C2386232
    Readiness: 0110 1101
    Address 02: Auto Trans        Labels: 01L-927-156.lbl
       Part No: 4B0 927 156 FG
       Component: AG5 01L 4.2l5V  USA 1014
       Coding: 01002
       Shop #: WSC 02325
       VCID: 71E9FB773BDD28C766-5140
    Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
       Part No: 4B0 614 517 H
       Component: ABS/ESP allrad      3428
       Coding: 06397
       Shop #: WSC 02325
       VCID: 2643D82BC2933F7FC3-5124
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AM
       Component: A6-Klimavollautomat 0105
       Coding: 00010
       Shop #: WSC 02325
       VCID: 65C19F27FF15F4670A-257A
                27-00 - Implausible Signal
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4B0 959 655 Q
       Component: Airbag 8.4EP        2001
       Coding: 0000607
       Shop #: WSC 02325 785 00200
       VCID: 3E73104B6A0387BFAB-5140
    Address 16: Steering wheel        Labels: 4B0-907-487.lbl
       Part No: 4B0 907 487 F
       Component: Lenkradelektronik   D01
       Coding: 01005
       Shop #: WSC 02325
       VCID: 2F6D3D0FED697E3730-5140
    Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
       Part No: 4B0 920 981 P
       Component: KOMBI+WEGFAHRS. VDO D12
       Coding: 03283
       Shop #: WSC 02805
       VCID: 3365317F01415AD754-5140
    Address 35: Centr. Locks        Labels: 4B0-962-258.clb
       Part No: 4B0 962 258 M
       Component: Central Lock/Alarm  D38
       Coding: 15885
       Shop #: WSC 02116
       VCID: 3365317F01415AD754-4F22
       Part No: 4B0 959 760 B
       Component: Sitzmemory R1 F     0102
       Coding: 00001
       VCID: 2C572A03DC7F052F15-4AE8
       Part No: 4Z7 907 357
       Coding: 00050
       Shop #: WSC 02325
       VCID: 0407A2A3146F2D6FBD-4B1A
       Part No: 4B0 035 195 S
       Component: symphony II NP2    0011
       Coding: 00225
       Shop #: WSC 02101
       VCID: 306F3E73F05761CF29-4E96
    Address 75: Telematics        Labels: 8E0-035-616.lbl
       Part No SW: 8E0 035 616 A    HW: 8E0 035 616 A
       Component: Telematik USA1
       Coding: 0002303
       VCID: 2345C13FE1A1CA57A4-5140
    End-------------------------(Elapsed Time: 05:47)--------------------------
  5. #15
    Jul 2019
    Another quetion. I thought 2003 A6 quatttro used CAN bus? Inquiry says not available???
  6. #16
    Quote Originally Posted by tultalk View Post
    It uses CAN buses internally for communications between modules, but external diagnostic communications are all via K-Lines, so "CAN Not Ready" from VCDS is normal on that car.
  7. #17
    Jul 2019
    Have you looked at my auto-scan after clearing codes?
  8. #18
    Jul 2019
    I did and evidently posted response in another thread. Here it i0s again
              75 76 77
       Coding: 07752
       Shop #: WSC 02325
       Coding: 01002
       Shop #: WSC 02325
       Coding: 06397
       Shop #: WSC 02325
       Coding: 00010
       Shop #: WSC 02325
       Coding: 0000607
       Coding: 01005
       Shop #: WSC 02325
       Coding: 03283
       Shop #: WSC 02805
       Coding: 15885
       Shop #: WSC 02116
       Coding: 00001
       Coding: 00050
       Shop #: WSC 02325
       Coding: 00225
       Shop #: WSC 02101
       Coding: 0002303
              75 76 77
       Coding: 07752
       Shop #: WSC 02325
       VCID: 72EBF47B3EDB13DF9F-5140
    Readiness: 0010 1101
       Coding: 01002
       Shop #: WSC 02325
       Coding: 06397
       Shop #: WSC 02325
       Coding: 0000607
       Coding: 01005
       Shop #: WSC 02325
       VCID: 2F6D3D0FED697E3730-5124
       Coding: 03283
       Shop #: WSC 02805
    Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
       Coding: 15885
       Shop #: WSC 02116
       Coding: 00001
       VCID: 2C572A03DC7F052F15-4B00
       Coding: 00050
       Shop #: WSC 02325
       VCID: 0407A2A3146F2D6FBD-4B00
       Coding: 00225
       Shop #: WSC 02101
       Coding: 0002303
    End-------------------------(Elapsed Time: 05:22)--------------------------
  9. #19
    Jul 2019
  10. #20
    Jul 2019
    I have been posting in wrong thread I think since no response to rerun of Auto Scan
              75 76 77
       Coding: 07752
       Shop #: WSC 02325
       Coding: 01002
       Shop #: WSC 02325
       Coding: 06397
       Shop #: WSC 02325
       Coding: 00010
       Shop #: WSC 02325
       Coding: 0000607
       Coding: 01005
       Shop #: WSC 02325
       Coding: 03283
       Shop #: WSC 02805
       Coding: 15885
       Shop #: WSC 02116
       Coding: 00001
       Coding: 00050
       Shop #: WSC 02325
       Coding: 00225
       Shop #: WSC 02101
       Coding: 0002303
              75 76 77
       Coding: 07752
       Shop #: WSC 02325
       Coding: 01002
       Shop #: WSC 02325
       Coding: 06397
       Shop #: WSC 02325
       Coding: 0000607
       Coding: 01005
       Shop #: WSC 02325
       Coding: 03283
       Shop #: WSC 02805
       Coding: 15885
       Shop #: WSC 02116
       Coding: 00001
       Coding: 00050
       Shop #: WSC 02325
       Coding: 00225
       Shop #: WSC 02101
       Coding: 0002303
