Results 1 to 8 of 8
Thread: K03 Turbo wastegate adjustment?
    Oct 2016
    Minnesota USA
    the Turbo in my 14 CC is starting to trigger some P0299 underboost faults.
    I've read/watched some videos online that suggest that the turbo might need replacement if the wastegate plate and arm has some play in it, which mine does. I replaced the bypass valve with the piston style "D" revision unit a while back as a preventative measure.
    my question is- are we able to adjust the wastegate actuator arm to hold the plate closed more tightly when the turbo is building boost?
    I was able to adjust this in my old saab, but the turbo was front and center in that engine bay- easy to get to. Figured I would ask the community before getting the car up on ramps and crawling underneath.
    Any suggestions/info is greatly appreciated!
    https://forums.ross-tech.com/showthr...umble-Mechanic
    Isn't the turbo covered under useful life warranty possibly?
    Ever JPPSG?
    Dallas (McKinney) ,TX ,USA
    There is nothing to adjust, you have problem with turbo wastegate arm rod , there is a bearing there it fails all the time, So in other world you need to replace turbo.
    Very common problem on New VW with 2.0T engine.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  4. Likes Uwe liked this post
    Isn't this problem a free repair in this year and miles range under 15/150K & for useful life warranty?
    I do not think so Jack. They never announce any extension for this. Once you out of the Power-train warranty you are on your own. I even call my friend at dealer and he confirm it .
    Immobilizer/ECU
    Hey Marin,
    Than how come the the entire turbo charger is on the COC application & as a comprehensive part of the AECD's list for extended coverage of the Federal and CARB warranty as certified?
    What you think of the page 106 > & reiterated on page 108 of this mere example?
    https://iaspub.epa.gov/otaqpub/displ...d=32285&flag=1
  8. Likes Fredrick Awuor liked this post
    Jack I just told you what I was told by Vw Dealer here.
    OP can try and go to his local dealer and see what happens.
    Immobilizer/ECU
  10. Likes Jack@European_Parts liked this post
  11. #8
    NP Marin I just wanted you to see it for the words as written by the Feds, did you read them?
