Results 1 to 10 of 10
Thread: Audi tt 8n Stops cheating
    Apr 2018
    Norway
    Hi i am struggling to find the error on my Audi tt 8n. Yesterday the stopped car got some error codes, it stopped coughing and jumping. I unplugged lmm it starts then. Purchased new lmm hooked it on and the blen was left foolish again. So the car goes into distress when the switch is off and runs fine at idle. Anybody have any good advice.
    Tuesday,06,August,2019,20:38:13:36574
    VCDS Version: 19.6.1.0 (x64)  HEX-V2 CB: 0.4505.4
    VIN:    License Plate: BP843
    Mileage: 253510km-157523mi   Repair Order:
    Chassis Type: 8N - Audi TT (1999 > 2007)
    Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
       Mileage: 253510km-157523miles
    Address 01: Engine        Labels: 06A-906-032-AJQ.clb
       Part No: 8N0 906 018 AB
       Component: 1.8L R4/5VT         0002
       Coding: 05500
       Shop #: WSC 00082
       VCID: 71BF281208B1F76F357-5160
    Address 03: ABS Brakes        Labels: 8N0-907-379-MK20-E.clb
       Part No: 8N0 907 379 D
       Component: ESP     20    CAN  V006
       Coding: 23049
       Shop #: WSC 06435
       VCID: 3D27C4220469430FE1F-4B00
    Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
       Part No: 8N0 820 043
       Component: TT-KLIMAVOLLAUTOMAT D02
       Coding: 00040
       Shop #: WSC 06435
       VCID: 678B464A367539DF6B3-2580
    Address 15: Airbags        Labels: 8N8-909-601.lbl
       Part No: 8N8 909 601
       Component: Airbag Front+Seite 1008
       Coding: 10102
       Shop #: WSC 01236
       VCID: 77AB160A66D5A95FFB3-513C
    Address 17: Instruments        Labels: 8Nx-919-xxx-17.lbl
       Part No: 8N1 919 860 C
       Component: KOMBI+WEGFAHRS. M73 D30
       Coding: 00144
       Shop #: WSC 00530
       VCID: 3B23CA3A1A7D4D3FDFB-4B1E
       Subsystem 1 - Part No: Ident
       Component: Nr. Wegfahrs.:AUZ5Z0F2106041
       Ident.-Nr. Wegfahrs.:AUZ5Z0F2106041
    Address 35: Centr. Locks        Labels:. 8Nx-962-267.lbl
       Part No: 8N8 962 267
       Component: Zentralverrieg.     D04
       Coding: 04672
       Shop #: WSC 01236
       VCID: 7EA5032E49EF9817B85-4EEA
    01366 - Opened Due to Crash Signal
                35-00 - -
    Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
       Part No: 4B0 907 357
       Component: LEUCHTWEITEREGLER  D003
       Coding: 00009
       Shop #: WSC 06435
       VCID: 65974C42CC792BCF59F-513C
    End----------(Elapsed Time: 02:46, VBatt start/end: 12.4V/12.3V)-----------
    Tuesday,06,August,2019,16:28:51:36574
    Control Module Part Number: 8N0 906 018 AB
      Component and/or Version: 1.8L R4/5VT         0002
               Software Coding: 05500
                Work Shop Code: WSC 00082
    17521 - Oxygen (Lambda) Sensor; B1 S1
                P1113 - 35-10 - Internal Resistance too High - Intermittent
    17743 - Engine Torque Monitor 2
                P1335 - 35-10 - Control Limit Exceeded - Intermittent
    16487 - Mass Air Flow Sensor (G70)
                P0103 - 35-10 - Signal too High - Intermittent
    Where did you buy the new MAF (LMM in German)?
    You can look at what your ECU is seeing from the MAF in MVB 003.2
  3. Likes cleo liked this post
    Apr 2018
    Norway
    At this shop when the car was standing along the road, I had to have one quickly, so see if I get a new one which is better tomorrow.
    But this type that should be similarly original. Must buy another brand and try.
    https://www.biltema.no/reservedelsso...er--2000024502
    FLOW METER
    Art No: 52-840
    from chassis number: 8N..Y..050 001
    from year model: 199911
    from year model: 199912
    Engine Code: AJQ
    Engine Code: APP
    for year model: 200008
    for year model: 200009
    Corresponding Bosch: 0 280 218 032
    Corresponding Bosch: 0 280 218 033
    Similar Bosch: 0 986 280 210
    Apr 2018
    Norway
    Have hosted now at the vw audi store here they couldn't get any longer lmm to my car. It has gone out of production and is no longer available. So have to find out if anyone else sells the original..
    What part do you need?
    The OXS oxygen sensor heaters appear to be shorting in addition to the signal line from being faulty.
    Unplug them to see if this isolates condition.
    Your ecu appears to be running deleted code too is that right?
    Please post an auto-scan after clearing codes immediately.
  7. Likes Uwe, cleo liked this post
    Apr 2018
    Norway
    Then I got hold of an airflow meter, not original bosch. It got a little better but it goes in distress and doesn't go as it should. I have an open air filter on the car. Maybe that is what is doing this, I do not have original air box. Can it help and replace the lambda probe on the car? Will be down to buy new lambda and try to replace it
    Wednesday,14,August,2019,12:34:17:36574
    Fault Codes have been Erased
    16486 - Mass Air Flow Sensor (G70)
                P0102 - 35-00 - Signal too Low
    Wednesday,14,August,2019,12:40:08:36574
    Mileage: 253630km-157598mi   Repair Order:
       Mileage: 253630km-157598miles
       Coding: 05500
       Shop #: WSC 00082
       Coding: 23049
       Shop #: WSC 06435
       Coding: 00040
       Shop #: WSC 06435
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
       Coding: 10102
       Shop #: WSC 01236
       Coding: 00144
       Shop #: WSC 00530
       VCID: 3B23CA3A1A7D4D3FDFB-4B00
       Coding: 04672
       Shop #: WSC 01236
                35-00 - -
       Coding: 00009
       Shop #: WSC 06435
    End----(Elapsed Time: 02:52, VBatt start/end: 12.3V/11.8V. VIgn 11.8V)-----
    Apr 2018
    Norway
    Then I changed the lambda probe. without help on the problem. still coming up lmm. Deletes the error then it disappears but when I start it comes up again,
    I get this lamp every time I start when I delete the lmm code then it disappears again when the car starts and when the lmm error code comes up
    https://imgur.com/a/XTejVNP
  10. #8
    Check fuel PSI and volume and for air leak at boot to intake maybe Bad/Wrong MAF or FOD in tail light circuit maybe wrong bulbs or wattage ............cross check and TQ request offset fails to add up!
    Correct the FOD!
  11. Likes cleo liked this post
  12. #9
    Apr 2018
    Norway
    Then what the problem solved. I have now switched back to the old lmm switched lamb.
    The was hose for intake slid down a little and did not sit as it should what cut then came a lot of air. Got put in the hose erased all the bugs and the car goes properly. Jack @ European_Parts. That's what som you said a leak that created all the trouble.
    Thanks a lot for all the help and answers from everyone
  13. Likes Jack@European_Parts liked this post
  14. #10
    Induced FOD wins yay!
  15. Likes cleo liked this post
