Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: 2003 A6 Quattro Central locking unit flooded.
    Jul 2019
    Leak in sun roof seal flooding driver footwell.
    Runs. Windows will not work. Sun rood will not open. Flashers/Tuens not working NO sound from radio etc. etc
    Pulled control unit. +12 v lead to connector burned off. Inside controller, strap connecting +12 v to PCB burned off.
    20 amp fuse not blown.
    Changed unit (used on eBay). Hooked it up.
    Flashers and turns now working. No sound from radio (on). Interior courtesy lights not workling
    Catch 22. Can't open sun roof to stop leaks.
    Are all thise things related to some coding with Central Locking Unit?
    Have VCDS
    Don't see anything under select control module that relates to Central Locking Unit
    Need a little insight about where to go with this?
    2003 A6 should still be 35-Central Locks -- I think -- as opposed to 46-Cent. Conv.
    Jul 2019
    Hi:
    Thanks for response. Let me first say that I have never used the VCDS as I bought it just for an "in case" which has not occurred until now. So here I am.
    I have looked at the following but don't know where to start. Like I said my existing key start and run vehicle both with damaged controller and with the new one.
    Am I required to code my existing keys to this "new" controller (as if coding to a new key?) to get all the functions back or is this indicative of a bigger problem?
    Seems strange that the turn signals/flasher would return to correct function but not other items.
    Audi A6 (4B) Central Locking
    Contents
    1 Coding
    2 Adaptation
    2.1 Channel 021: Remote Control Matching
    2.2 Special Notes
    Coding
    VCDS will display a coding chart a pop-up balloon while connected to the vehicle.
    Add the sum of the options to configure the correct coding.
    Adaptation
    [Select]
    [35 - Centr. Locks]
    [Adaptation - 10]
    Channel 021.
    [Read]
    Choose the memory position you want the new key be matched on by entering it's number (e.g. "3" for memory position 3). Make sure to TYPE IN the number instead of scrolling up to it, otherwise you will not be able to click [Test].
    [Test]
    Now press any button on the remote you want to match.
    The meas. block field above will change from Not Recogn. to Recognized.
    [Save]
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    Note: You can check the current memory positions using Meas. Block 007.
    Special Notes
    The 4B platform comfort system module has assigned positions, like parking spots 1, 2, 3 and 4, for each remote. This is critical when matching new remotes.
    If you are having problems with the Remote Control Matching, please pay special attention to the instructions above:
    If Adaptation Channel 21 is not available the control module does NOT support matching remotes with VCDS (or any scan tool). In those cases the remote matching procedure as per the Repair Manual and/or vehicle Owner's Manual will need to be completed.
    In those cases, Measuring Block group 007 can still be used to verify the positions.
    Quote Originally Posted by tultalk View Post
    OK, step 1 with VCDS is to run and post an Auto-Scan.
    Jul 2019
    Ran auto scan (attached pdf) and also for controller etc
    oops. Don't see how to attach pdf file?? Nor jpg File
    oops. Don't seevhow to attach file??
    We do not allow attachments here. Please see the link I posted above for instructions how to post a scan.
  7. #7
    Jul 2019
    Central Locking flooded
    Windows Based VAGN AS Emulator Running on Windows 10 x64
    VCDS Version: Release 19.6.1 (x64) Data version: 20190529 DS308.0
    Dealer/Shop Name:
    Workshop Code: 000 00000 000000
    Self-Diagnosis Log
    Thursday,04,July,2019, 14:32:42:29746
    ~ VIN: WAUML64B43N104356 License Plate:
    Mileage: Repair Order:
    Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998> 2005
    Scan: 01 02030608151617182234353637455556576567
    757677
    	Address 01: Engine 	Labels: None
    Part No: 400 907 560 CL
    	Component: 4.2L V8/5V 	G 0001
    Coding: 07752
    Shop #: WSC 02325
    VCID: 72EBF47B3EDB13DF9F-5140
    WAUML64B43N 1 04356 AUZ7Z0C2386232
    7 Faults Found:
    17831 - Secondary Air Injection System; Bank 1
    P1423 - 35-00 - Insufficient Flow
    17819 - Secondary Air Injection System; Bank 2
    P1411 - 35-00 -Insufficient Flow
    17983 - Right Engine Mount Solenoid Valve (N145)
    P1575 - 35-10 - Short to Plus - Intermittent
    17931 - Crash Signal from Airbag Controller
    P1523 - 35-10 - Implausible Signal- Intermittent
    P0300 - 35-00 -
    16688 - Cylinder 4
    P0304 - 35-00 - Misfire Detected
    16686 - Cylinder 2
    P0302 - 35-00 - Misfire Detected
    	Address 02: Auto Trans 	Labels: 01L-927-156.lbl
    Part No: 4BO 927 156 FG
    Component: AG5 01L 4.215V USA 1014
    Coding: 01002
    Shop #: WSC 02325
    VCID: 71E9FB773BDD28C766-5140
    Self-Diagnosis Log
    Thursday,04,July,2019,14:32:42:29746
    Page 2
    	Address 03: ABS Brakes 	Labels: 4BO-614-517.lbl
    Part No: 4BO 614 517 H
    	Component: ABS/ESP allrad 	3428
    Coding: 06397
    Shop #: WSC 02325
    VCID: 2643D82BC2933F7FC3-5124
    	Address 08: Auto HVAC 	Labels: 4BO-820-043-MY2.lbl
    Part No: 4BO 820 043 AM
    Component: A6-Klimavollautomat 0105
    Coding: 00010
    Shop #: WSC 02325
    VCID:65C19F27FF15F4670A-2580
    	Address 15: Airbags 	Labels: 4BO-959-655-AI84.1bl
    Part No: 4BO 959 655 Q
    	Component: Airbag 8.4EP 	2001
    Coding: 0000607
    Shop #: WSC 02325 785 00200
    VCID: 3E73104B6A0387BFAB-5140
    	Address 16: Steering wheel 	Labels: 4BO-907-487.lbl
    Part No: 4BO 907 487 F
    Component: Lenkradelektronik D01
    Coding: 01005
    Shop #: WSC 02325
    VCID: 2F6D3DOFED697E3730-5140
    00480 - Control Module in Instruments for Infotainment CAN (J285)
    27-10 - Implausible Signal- Intermittent
    01304 - Radio
    49-10 - No Communications -Intermittent
    Self-Diagnosis Log
    ThursdaY,04,July,2019,14:32:42:29746
    Page 3
    VIN: WAUML64843N104356 License Plate:
    	Address 17: Instruments 	Labels: 480-920-xxx-17.1bl
    Part No: 480 920 981 P
    Component: KOM81+WEGFAHRS. VDO D12
    Coding: 03283
    Shop #: WSC 02805
    VCID: 3365317F01415AD754-5140
    WAUML64843N104356 AUZ7Z0C2386232
    01304 - Radio
    	Address 35: Centro Locks 	Labels:. 480-962-258.clb
    Part No: 480 962 258 M
    Component: Central Lock/Alarm D38
    Coding: 15885
    Shop #: WSC 02116
    VCID: 3365317F01415AD754-4F22
    12 Faults Found:
    35-00 --
    35-00 --
    35-00 --
    35-00 --
    01373 - Alarm triggered by Radio Ground Contact
    35-00 --
    01570 - Turn-Off Delay; Terminal 15
    29-00 - Short to Ground
    01561 - Rear left door
    59-00 - Can't Unlock
    01562 - Rear right door
    01574 - Alarm triggered by Door Contact Switch; Rear Right
    35-10 - - - Intermittent
    01573 - Alarm triggered by Door Contact Switch; Rear Left
    01482 - Motors for Central Locking
    29-10 - Short to Ground -Intermittent
    Self-Diagnosis Log
    Page 4
    	Address 36: Seat Mem. Drvr 	Labels: None
    Part No: 4BO 959 760 B
    	Component: Sitzmemory R1 F 	0102
    Coding: 00001
    VCID: 2C572A03DC7F052F15-4AES
    	Address 55: Headlight Range 	Labels: 427-907-357.1bl
    Part No: 427 907 357
    	Component: dynamische LWR 	009
    Coding: 00050
    Shop #: WSC 02325
    VCID: 0407 A2A3146F2D6FBD-4B 1A
    00774 - Level Control System Sensor; Rear Left (G76)
    2S-10 - Short to Plus - Intermittent
    00776 - Level Control System Sensor; Left Front (G7S)
    	Address 56: Radio 	Labels: SEO-035-1xx-56.lbl
    Part No: 4BO 035 195 S
    Component: symphony II NP2 0011
    Coding: 00225
    Shop #: WSC 02101
    VCID: 306F3E73F05761 CF29-4E96
    00S56 - Radio Antenna
    36-00 - Open Circuit
    	Address 75: Telematics 	Labels: SEO-035-616.lbl
    Part No SW: SEO 035 616A HW: SEO 035 616A1
    Component: Telematik USA 1
    	Coding: 0002303 	.
    Shop #: WSC 02325 7S5 00200
    VCID: 2345C13FE1A1CA57A4-5140
    01656 - Crash Signal
    01304 - Radio
    E nd-----------------------fElaosed Ti me: 05: 29)--------------------------
    Dealer/Shop Name:
    Diagnostic Trouble Code Report
    ThursdaY,04,JulY,2019, 14:58:46:29746
    Control Module Part Number: 4BO 035 195 S
    Component and/or Version: symphony II NP2 0011
    Software Coding: 00225
    Work Shop Code: WSC 02101
    VCID: 306F3E73F05761CF29-4E96
    00856 - Radio Antenna
    www.Ross~Tech.com
    Dealer/Shop Name:
    Workshop Code: 00000000
    Thursday,04,July,2019,14:55:03:29746
    Control Module Part Number: 4BO 962 258 M
    Component and/or Version: Central Lock/Alarm D38
    Software Coding: 15885
    Work Shop Code: WSC 02116
    12 Faults Found:
    35-00 --
    35-00 --
    35-00 --
    35-00 --
    35-00 --
    29-10 - Short to Ground - Intermittent
  8. #8
    OK, this car is so full of fault codes that there's a very low signal-to-noise ratio in what you've posted.
    Please clear all fault codes from modules that have fault codes, then do a new scan, and please post the native scan text, not something that's been run through the [Print] function in VCDS. That function is optimized for a sheet-fed printer, but makes things much harder to read here than the original text would be.
  9. #9
    Jul 2019
    Save instead of print? Going to Holland MI so won't be back until Sunday. Not aure I understand stored faults.
    Would the used controller have faults from the previous installed car?
    Is the format just the txt in the log dir which I assume the "save" button refers to?
    Maybe I will rerun tonight.
    Things like no radio antenna threw me back. Radio turns on but no sound. Wirring diagrams indicate no connection of antenna with replaced controller.
    Are any of my problems related to key matching to the "new" controller?
  10. #10
    Correct. [Save] or even just [Copy]
    Yes, that's entirely possible. Fault codes are stored in non-volatile memory.
    Like I said, please clear all the fault codes out of this car and then let's see what comes back.
