I have a 2013 VW CC 2.0 tdi. Since owner ship i have noticed that the headlights only work if you hold the stalk back manually, the windscreen washers dont work (motor is fine), the rear fog light doest work (bulb fine), reverse lights dont work (bulb fine), front fogs dont work (bulbs fine), parking sensors dont come on when reverse selected (button needs to be manually pressed)
I have a suspicion that someone has had a mess around with some coding and now i have all the above issues.
Any help on the matter would be greatly appreciated.
here is a scan of the vehicle
Wednesday,03,July,2019,22:20:02:60782
VCDS Version: 19.6.1.0 (x64)
VIN: WVWZZZ3CZDE556052 License Plate:
Mileage: 122750km-76273mi Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 4C 4F 52 53
55 56 61 62 72
VIN: WVWZZZ3CZDE556052 Mileage: 122750km-76273miles
Address 01: Engine (J623-CFGC) Labels: None
Part No SW: 03L 906 018 TL HW: 03L 907 309 AE
Component: R4 2.0l TDI X28 9978
Revision: 41X28--- Serial number: 00000000000000
Coding: 00190012042501080000
Shop #: WSC 00604 210 00000
ASAM Dataset: EV_ECM20TDI01103L906018TL 003002
ROD: EV_ECM20TDI01103L906018RK.rod
VCID: 071C101FBEC05A77D8-8052
Readiness: 0 0 0 0 X
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AQ HW: 3AA 614 109 AQ
Component: J104 C2 450M VDE2 0030
Revision: --H07--- Serial number: 00000006661433
Coding: 0004025
Shop #: WSC 05311 000 00000
VCID: 7CF67FF33F0609AFC5-8028
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Frequency: 26
Reset counter: 226
Mileage: 122407 km
Date: 2013.11.19
Time: 18:19:51
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 11.75 V
Bin. Bits: 00011111
Count: 185
Hex Value: 0x0000
03841 - RPM Sensor Rear Left: Incorrect Signal
Fault Frequency: 18
Reset counter: 9
Mileage: 122407 km
Date: 2013.11.19
Time: 18:19:52
Hex Value: 0x0000
Voltage: 11.75 V
Bin. Bits: 00011111
Count: 156
Hex Value: 0x0000
Fault Frequency: 20
Reset counter: 9
Mileage: 122407 km
Date: 2013.11.19
Time: 18:20:02
Hex Value: 0x0000
Voltage: 11.75 V
Bin. Bits: 00011111
Count: 191
Hex Value: 0x0000
Part No SW: 3AA 907 044 AK HW: 3AA 907 044 AK
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0018004849
Shop #: WSC 00015 115 12345
VCID: 79F866E7F8343C87DE-802C
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 J HW: 3AA 937 087 J
Component: BCM PQ47 H++ 421 0465
Revision: BD421001
Coding: 00080000000000000098008C95002B242375008862228720E48C4E2000C1
Shop #: WSC 05311 123 12345
VCID: 4188CE07D864A447D6-8014
Subsystem 1 - Part No SW: 3C8 955 119 G HW: 3C8 955 119 G Labels: 1KX-955-119.CLB
Component: WWS464 121012 010 0604
Serial number: 121012
Coding: 00B795
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M02D05H00M50S17S4
Coding: 0228DD
02723 - Control Circuit for Power Supply Relay (Terminal 50)
Reset counter: 220
Mileage: 122407 km
Date: 2013.11.19
Time: 17:39:06
Term 15 Off
Voltage: 12.35 V
03395 - Control Module for High Beam Assistant
Reset counter: 216
Mileage: 122407 km
Date: 2013.11.19
Time: 17:26:31
Voltage: 12.20 V
Address 10: Park/Steer Assist (J446) Labels:| 3AE-919-475.clb
Part No SW: 3AE 919 475 C HW: 7N0 919 475
Component: PARKHILFE 8K H06 0018
Revision: -------- Serial number: 28261301503773
Coding: 108004
ASAM Dataset: EV_EPHVA18VW47X0000 001006
ROD: EV_EPHVA18VW47X0000.rod
VCID: 3F8CC8FFA690D2B7A0-806A
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Revision: 00000000 Serial number: 21011304280002
Coding: 010180
Shop #: WSC 05314 000 00000
VCID: 275C709F56007A77F8-8072
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__70J VW10 HI 2118
Revision: 25018000 Serial number: 003L7P21G3JB
Coding: 0012362
Subsystem 1 - Serial number: 6332MTS664260073
Subsystem 2 - Serial number: 6342MTS614450073
Subsystem 3 - Serial number: 6351HTS6JGR7LBKJ
Subsystem 4 - Serial number: 6361HTS607PQIBKR
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
008 - Implausible Signal - Intermittent - MIL ON
Fault Status: 10101000
Mileage: 122446 km
Date: 2013.11.20
Time: 14:11:20
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C5 953 501 BN HW: 5K0 953 569 AB
Component: LENKS.MODUL 016 0140
Revision: FF010041 Serial number: 20130122301758
Coding: 0182270002
Shop #: WSC 00015 115 00000
VCID: 72EA51CBA5424FDF9F-8026
Component: E221__MFL-TK6 H07 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
Part No SW: 3C8 920 971 A HW: 3C8 920 971 A
Component: KOMBI H05 0705
Coding: 440D00
Shop #: WSC 05314 115 12345
VCID: 2B548CAF42E85E171C-807E
Part No SW: 7N0 907 530 AJ HW: 7N0 907 530 AJ
Component: J533 Gateway H51 1634
Revision: H51 Serial number: 091212F2003281
Coding: 469007
VCID: 78FE63E3CB3E258FA1-802C
Part No SW: 3AA 959 433 B HW: 3AA 959 433 B
Component: IMMO 043 0404
Revision: 00043000 Serial number: VWZCZ000000000
VCID: 387EA3E34BBEE58F61-806C
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664219504
Coding: 020100
VCID: 2A5A89AB4512471FE7-807E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C8 035 279 B HW: 3C8 035 279 B
Component: RNS315-EU H59 0319
Serial number: VWZAZ2N0097367
Coding: 0400040104000F0000019002
ROD: EV_RNS315EUV2UDS.rod
VCID: 2A5A89AB4D12471FE7-807E
Component: EUR_W_V4 0050
1048595 - Rear Left Bass Speaker
B1065 13 [009] - Open Circuit
Reset counter: 226
Mileage: 122533 km
Date: 2019.07.01
Time: 17:36:12
1048596 - Rear Right Bass Speaker
B1067 13 [009] - Open Circuit
Reset counter: 218
Mileage: 122407 km
Date: 2019.06.29
Time: 17:26:42
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0556
Revision: 12110009 Serial number: 0006426221
Coding: 0012BF
Shop #: WSC 05311 115 12345
VCID: 6DD042B7BC7C902742-8038
Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 704 D HW: 3C8 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0501
Serial number: 00000003309688
Coding: 010090
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 207 3305
Revision: 00H22000
VCID: 377CA0DF46A0EAF768-8062
Fault Status: 00101101
Reset counter: 9
Mileage: 122407 km
Date: 2013.11.19
Time: 18:19:52
Voltage: 12.00 V
DD
Temperature: 31.0°C
Component: KSG PQ47 ELV 043 0638
Coding: 01910A0001860E763604941570085FCE105C04
Component: Neigungssensor 004 0611
Part No SW: 7N0 907 532 HW: 7N0 907 530 AJ
Component: EZE_2 H51 1634
Coding: 00000008
VCID: 6FEC58BFBE70623770-803A
Subsystem 1 - Part No SW: 3C8 919 204 A HW: 3C8 919 204 A
Component: Analoguhr 005 0004
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0556
Revision: 14110009 Serial number: 0006405215
Coding: 0013BF
VCID: 6ED245BBB17A6B3F7B-803A
Slave Passenger:
Subsystem 1 - Part No SW: 3C8 959 703 D HW: 3C8 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0501
Serial number: 00000003314751
Coding: 010090
66821 - Position Sensor for Mirror Adjustment
B11FA 29 [009] - Signal Implausible
Reset counter: 216
Mileage: 122407 km
Date: 2019.06.29
Time: 17:26:57
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000739745
Coding: 0022167
VCID: 3662ADDB41AA13FF73-8062
Fault Frequency: 109
Reset counter: 8
Mileage: 121657 km
Date: 2013.11.08
Time: 08:30:56
Voltage: 14.70 V
Count: 104
Speed: 54.0 km/h
Hex Value: 0x1268
Hex Value: 0x8004
Hex Value: 0x0101
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 B HW: 6R0 907 357 A
Component: LWR-ECU 005 0030
Coding: 079A020001000000
ASAM Dataset: EV_HeadlRegulVWLWRCC 002004
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 3978A6E7B8B4FC879E-806C
5275220 - Headlight
Reset counter: 226
Mileage: 122752 km
Date: 2019.07.03
Time: 21:57:00
5256213 - Front Left Ride-Height Sensor
C1034 15 [137] - Open or Short to Plus
Reset counter: 226
Mileage: 122752 km
Date: 2019.07.03
Time: 21:57:00
5256725 - Rear Left Ride-Height Sensor
C1036 15 [137] - Open or Short to Plus
Reset counter: 226
Mileage: 122752 km
Date: 2019.07.03
Time: 21:57:00
Part No SW: 7N0 907 534 HW: 7N0 907 530 AJ
Component: Batt.regelung H51 1634
Coding: 030F1859
VCID: 71E85EC7A84474C766-8024
Component: J367-BDM H07 0180
Serial number: 00000000001490746284
End-------------------------(Elapsed Time: 03:20)--------------------------
