2011 VW T5 remote fob buttons no longer working
piper1
C?ID=316036
Hi I hope somebody would be able to point me in the right direction to solving my problem, I have lost the functions to lock and unlock my VW T5 van by means of the key fob
Yesterday i decided to use VCDS to change the windows opening and closing function via remote fob inactive because one of my windows was sticking.
Not really sure what happen next but for some reason I decided to turn of the VCDS programme, deconnet and reconnect my battery and form there I noticed that I could no longer use the remote fob to lock not unlock my van plus my van had gone in to Transport mode, I was able to change the Transport mode back over via VCDS but still unable to use the buttons on the fob.
Thank you
 Tuesday,02,July,2019,12:29:39:32545
VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
VIN: WV1ZZZ7HZBH091138   License Plate:
Chassis Type: 7H-VN75 (7H - VW Transporter/Multivan (2003 > 2010))
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZBH091138   Mileage: 130890km-81331miles
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CH    HW: 03L 907 309 K
   Component: R4 2,0L EDC   X41 9126
   Revision: 26X41---    Serial number: 00000000000000
   Coding: 01194010230400080000
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_ECM20TDI01103L906022CH 002012
   ROD: EV_ECM20TDI01103L906022CH_002.rod
   VCID: 6D863B0CAD160C7F113-8038
9120 - EGR Sensor 1
          P046C 00 [096] - Implausible Signal
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 G    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0105
   Revision: 00H43001
   Coding: 708724AD89AD0E9624A39174A96610
   Shop #: WSC 02736 790 49152
   VCID: 3634D46098408FA7209-8062
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 087 F    HW: 7H0 937 087
   Component: BCM T5GP H+4  H47 0230
   Revision: BO047001    Serial number: 0396 017110499
   Coding: A8A0309A0E612431802048103C2B8C500000430F60060000300000000000
   Shop #: WSC 02734 790 12345
   VCID: 372AD9649F4A76AF3BF-8062
   Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3311
   Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3311
03301 - Response Closing Status of Drivers Door
            008 - Implausible Signal
                    Fault Status: 01101000
                    Reset counter: 227
03442 - Return Message Closing Status of Rear Lid
                    Fault Frequency: 114
                    Reset counter: 227
                    Mileage: 128059 km
                    Date: 2029.14.28
                    Time: 00:18:20
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag009 H06 0013
   Revision: --------    Serial number: 003HL003HRLN
   Coding: 000000000000000000000000000000003039
   Shop #: WSC 02734 790 50316
   VCID: 3536D36C85C684BF293-8060
   Part No SW: 7E0 920 960 C    HW: 7E0 920 960 C
   Component: KOMBI         H04 0204
   Coding: 460200
   Shop #: WSC 02736 790 50316
   VCID: 290E0F1C597ED05FBDB-807C
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 0230
   Coding: 042700
   VCID: 70B82278BAA4E1973A5-8024
                    Reset counter: 227
                    Mileage: 123158 km
                    Date: 2013.02.21
                    Time: 11:09:14
End----------(Elapsed Time: 06:17, VBatt start/end: 12.9V/12.6V)-----------
I think you should show us exactly what you changed.
See this thread and post those files please.
piper1
C?ID=316036
Hi thank you for the reply and sorry for the delay took to work out what i needed to do.
Address 01,074 906 018 AK,channel 4,adapted from,33268,to,33268,Tuesday,29,May,2018,16:16:38:32545
Address 01,074 906 018 AK,channel 4,adapted from,33268,to,32768,Tuesday,29,May,2018,17:09:37:32545
Address 01,074 906 018 AK,channel 4,adapted from,32768,to,33065,Tuesday,29,May,2018,17:43:56:32545
Address 01,074 906 018 AK,channel 4,adapted from,33065,to,33000,Tuesday,29,May,2018,17:51:28:32545
Address 09,7H0 937 087 F,channel 0,adapted from,---,to,000,Tuesday,02,July,2019,12:59:09:32545
Address 09,7H0 937 087 F,channel 0,adapted from,---,to,000,Tuesday,02,July,2019,13:03:57:32545
Address 09,7H0 937 087 F,channel 0,adapted from,---,to,000,Tuesday,02,July,2019,13:34:40:32545
Address 09,7H0 937 087 F,channel 0,adapted from,---,to,000,Tuesday,02,July,2019,13:36:12:32545
Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A0303A0E612431802048103C2B8C500000430F60060000300000000000,to,A8A0301A0E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Tuesday,02,July,2019,11:22:46:32545
Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A0301A0E612431802048103C2B8C500000430F60060000300000000000,to,A8A0303A0E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Tuesday,02,July,2019,11:31:51:32545
Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A0303A0E612431802048103C2B8C500000430F60060000300000000000,to,A8A030BA0E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Tuesday,02,July,2019,11:48:38:32545
Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A030BA0E612431802048103C2B8C500000430F60060000300000000000,to,A8A0309A0E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Tuesday,02,July,2019,11:52:15:32545
Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A0309A0E612431802048103C2B8C500000430F60060000300000000000,to,A8A0303A0E612439802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Tuesday,02,July,2019,12:33:28:32545
Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A0303A0E612439802048103C2B8C500000430F60060000300000000000,to,A8A0341A0E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Tuesday,02,July,2019,12:35:50:32545
Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A0341A0E612431802048103C2B8C500000430F60060000300000000000,to,A8A0301A0E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Tuesday,02,July,2019,12:37:05:32545
Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A0301A0E612431802048103C2B8C500000430F60060000300000000000,to,A8A030B20E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Tuesday,02,July,2019,13:03:24:32545
Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A030B20E612431802048103C2B8C500000430F60060000300000000000,to,A8A030B22E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Wednesday,03,July,2019,11:55:47:32545
Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A030B22E612431802048103C2B8C500000430F60060000300000000000,to,A8A030B20E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Wednesday,03,July,2019,12:15:50:32545
Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A030B20E612431802048103C2B8C500000430F60060000300000000000,to,A9A030B20E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Wednesday,03,July,2019,12:16:26:32545
Looks like you wiped out the Remote matching here:
You'll need to re-match them in Channel 001. Unfortunately, I don't have a detailed procedure for that.
piper1
C?ID=316036
Thank you once again for your support.
Is this something that VW would be able to sort out for me?
I think you can sort it yourself. Hopefully someone will come along with an authortitative procedure for that BCM.
Normally it's something like enter the number of remotes to be matched into Channel 001, click [Test] and [Save] and then press the one of the buttons on the remote until you get a confirmation. The question generally is exactly at which point in the process to press the button and which button to press.
piper1
C?ID=316036
Thank you i will sit tight and keep my fingers crossed.
NEtech
C?ID=56995
I have documented this procedure:
[Adaption-10]
Channel 01
  1. New value 0
  2. [Test] > [Save]
  3. Press "Lock" min. 1 sec. on remote to learn (max 15 sec. time for each key)
Start at 1. again for next key.
I think it should be done without key in ignition (take it out before adaptation).
Other procedure says Press "Unlock".
Try out what works.
piper1
C?ID=316036
Hi thank you very much for the help it worked a "treat"
The key was removed from the ignition as suggested.
Thank you.
piper1
C?ID=316036
Cheers Uwe
piper1
C?ID=316036
Thanks grant
Dana
Western PA, USA
invernesspl
C?ID=345478
I'm having an issue with my 2006 T5.
The remote just stopped working this morning, I tried the spare key which also didn't work. I plugged in the laptop and initially found this fault code stored:
Tuesday,14,June,2022,09:13:42:41168
VCDS Version: Release 22.3.1 (x64) Running on Windows 8.1 x64
Address 46: Central Conv. Labels: 7H0-959-433.lbl
Control Module Part Number: 7H0 959 433 B
Component and/or Version: CX5 Komfortgerát 0004
Software Coding: 00021
Work Shop Code: WSC 02736
VCID: 323D19A0AD356C9B09B-4B1E
00955 - Key 1
09-00 - Adaptation Limit Surpassed
I have tried clearing the code and it hasn't come back.
I then followed the instructions on Ross-tech, and as per thread above to try and code both keys back to the van. However, when I select the new value as 2 and press TEST, the value remains at 1? It says there is only 1 key stored and I cannot get it to change to 2.
Neither key is working still.
Any ideas?
Thank you.
