Results 1 to 10 of 14
Thread: 2011 VW T5 remote fob buttons no longer working
    Dec 2017
    Hi I hope somebody would be able to point me in the right direction to solving my problem, I have lost the functions to lock and unlock my VW T5 van by means of the key fob
    Yesterday i decided to use VCDS to change the windows opening and closing function via remote fob inactive because one of my windows was sticking.
    Not really sure what happen next but for some reason I decided to turn of the VCDS programme, deconnet and reconnect my battery and form there I noticed that I could no longer use the remote fob to lock not unlock my van plus my van had gone in to Transport mode, I was able to change the Transport mode back over via VCDS but still unable to use the buttons on the fob.
    Thank you
     Tuesday,02,July,2019,12:29:39:32545
    VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
    VIN: WV1ZZZ7HZBH091138   License Plate:
    Chassis Type: 7H-VN75 (7H - VW Transporter/Multivan (2003 > 2010))
    Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
              57 6E 76 77 78 7D
    VIN: WV1ZZZ7HZBH091138   Mileage: 130890km-81331miles
    Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
       Part No SW: 03L 906 022 CH    HW: 03L 907 309 K
       Component: R4 2,0L EDC   X41 9126
       Revision: 26X41---    Serial number: 00000000000000
       Coding: 01194010230400080000
       Shop #: WSC 01286 386 08256
       ASAM Dataset: EV_ECM20TDI01103L906022CH 002012
       ROD: EV_ECM20TDI01103L906022CH_002.rod
       VCID: 6D863B0CAD160C7F113-8038
    9120 - EGR Sensor 1
              P046C 00 [096] - Implausible Signal
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 G    HW: 7E0 907 379 E
       Component: ESP MK25A XT  H43 0105
       Revision: 00H43001
       Coding: 708724AD89AD0E9624A39174A96610
       Shop #: WSC 02736 790 49152
       VCID: 3634D46098408FA7209-8062
       Part No SW: 7H0 937 087 F    HW: 7H0 937 087
       Component: BCM T5GP H+4  H47 0230
       Revision: BO047001    Serial number: 0396 017110499
       Coding: A8A0309A0E612431802048103C2B8C500000430F60060000300000000000
       Shop #: WSC 02734 790 12345
       VCID: 372AD9649F4A76AF3BF-8062
       Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
       Component: J386__TSG_FT  002 3311
       Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
       Component: J387__TSG_BT  002 3311
    03301 - Response Closing Status of Drivers Door
                        Reset counter: 227
    03442 - Return Message Closing Status of Rear Lid
                        Fault Frequency: 114
                        Reset counter: 227
                        Mileage: 128059 km
                        Date: 2029.14.28
                        Time: 00:18:20
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag009 H06 0013
       Revision: --------    Serial number: 003HL003HRLN
       Shop #: WSC 02734 790 50316
       VCID: 3536D36C85C684BF293-8060
       Part No SW: 7E0 920 960 C    HW: 7E0 920 960 C
       Component: KOMBI         H04 0204
       Coding: 460200
       Shop #: WSC 02736 790 50316
       VCID: 290E0F1C597ED05FBDB-807C
       Part No SW: 6N0 909 901     HW: 7H0 937 087
       Component: GW-K-CAN TP20 0230
       Coding: 042700
       VCID: 70B82278BAA4E1973A5-8024
                        Reset counter: 227
                        Mileage: 123158 km
                        Date: 2013.02.21
                        Time: 11:09:14
    End----------(Elapsed Time: 06:17, VBatt start/end: 12.9V/12.6V)-----------
    I think you should show us exactly what you changed.
    See this thread and post those files please.
    Dec 2017
    Hi thank you for the reply and sorry for the delay took to work out what i needed to do.
    Address 01,074 906 018 AK,channel 4,adapted from,33268,to,33268,Tuesday,29,May,2018,16:16:38:32545
    Address 01,074 906 018 AK,channel 4,adapted from,33268,to,32768,Tuesday,29,May,2018,17:09:37:32545
    Address 01,074 906 018 AK,channel 4,adapted from,32768,to,33065,Tuesday,29,May,2018,17:43:56:32545
    Address 01,074 906 018 AK,channel 4,adapted from,33065,to,33000,Tuesday,29,May,2018,17:51:28:32545
    Address 09,7H0 937 087 F,channel 0,adapted from,---,to,000,Tuesday,02,July,2019,12:59:09:32545
    Address 09,7H0 937 087 F,channel 0,adapted from,---,to,000,Tuesday,02,July,2019,13:03:57:32545
    Address 09,7H0 937 087 F,channel 0,adapted from,---,to,000,Tuesday,02,July,2019,13:34:40:32545
    Address 09,7H0 937 087 F,channel 0,adapted from,---,to,000,Tuesday,02,July,2019,13:36:12:32545
    Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A0303A0E612431802048103C2B8C500000430F60060000300000000000,to,A8A0301A0E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Tuesday,02,July,2019,11:22:46:32545
    Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A0301A0E612431802048103C2B8C500000430F60060000300000000000,to,A8A0303A0E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Tuesday,02,July,2019,11:31:51:32545
    Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A0303A0E612431802048103C2B8C500000430F60060000300000000000,to,A8A030BA0E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Tuesday,02,July,2019,11:48:38:32545
    Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A030BA0E612431802048103C2B8C500000430F60060000300000000000,to,A8A0309A0E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Tuesday,02,July,2019,11:52:15:32545
    Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A0309A0E612431802048103C2B8C500000430F60060000300000000000,to,A8A0303A0E612439802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Tuesday,02,July,2019,12:33:28:32545
    Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A0303A0E612439802048103C2B8C500000430F60060000300000000000,to,A8A0341A0E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Tuesday,02,July,2019,12:35:50:32545
    Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A0341A0E612431802048103C2B8C500000430F60060000300000000000,to,A8A0301A0E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Tuesday,02,July,2019,12:37:05:32545
    Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A0301A0E612431802048103C2B8C500000430F60060000300000000000,to,A8A030B20E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Tuesday,02,July,2019,13:03:24:32545
    Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A030B20E612431802048103C2B8C500000430F60060000300000000000,to,A8A030B22E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Wednesday,03,July,2019,11:55:47:32545
    Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A030B22E612431802048103C2B8C500000430F60060000300000000000,to,A8A030B20E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Wednesday,03,July,2019,12:15:50:32545
    Address 09,7H0 937 087 F,recoded (Long Coding),from,A8A030B20E612431802048103C2B8C500000430F60060000300000000000,to,A9A030B20E612431802048103C2B8C500000430F60060000300000000000,(02734/790/12345),Wednesday,03,July,2019,12:16:26:32545
    Looks like you wiped out the Remote matching here:
    You'll need to re-match them in Channel 001. Unfortunately, I don't have a detailed procedure for that.
    Dec 2017
    Thank you once again for your support.
    Is this something that VW would be able to sort out for me?
    Quote Originally Posted by piper1 View Post
    I think you can sort it yourself. Hopefully someone will come along with an authortitative procedure for that BCM.
    Normally it's something like enter the number of remotes to be matched into Channel 001, click [Test] and [Save] and then press the one of the buttons on the remote until you get a confirmation. The question generally is exactly at which point in the process to press the button and which button to press.
  7. Likes grant@gendan liked this post
    Dec 2017
    Thank you i will sit tight and keep my fingers crossed.
  9. #8
    Sep 2014
    This link shows several procedures to try:
    https://www.ross-tech.com/vag-com/ca...-matching.html
  10. Likes piper1 liked this post
  11. #9
    Quote Originally Posted by grant@gendan View Post
    Unfortunately, none of them are directly applicable to his van, which does not have a module at 35 or 46. All that stuff has been integrated into 09 in his vehicle.
    -Uwe0-
  12. Likes piper1, grant@gendan liked this post
  13. #10
    I have documented this procedure:
    [Adaption-10]
    Channel 01
    1. New value 0
    2. [Test] > [Save]
    3. Press "Lock" min. 1 sec. on remote to learn (max 15 sec. time for each key)
    Start at 1. again for next key.
    I think it should be done without key in ignition (take it out before adaptation).
    Other procedure says Press "Unlock".
    Try out what works.
  14. Likes Viking, Uwe, piper1, Eric, DrPeter, Dana liked this post
