Results 1 to 4 of 4
Thread: 2011 CAEB fault 4113 (p0341)
    Verified VCDS User hans j's Avatar
    Mar 2014
    Utah
    I'm trying to find more information on this fault. I know I have seen a chart that explains the [104] before, but I'm finding little information on the 4113 fault.
    Car comes in last week with the fault and a concern for having a hesitation in stop and go traffic when he goes to accelerate. I drive it and am able to repeat the concern. I scope the cam sensor and it's dropping out completely while it's running. Replace the cam sensor and the hesitation is gone, but the fault code remains.
    I scope it again and find a split second drop out in the signal and then it picks back up. There is no timing change when this happens. I caught the drop out during an acceleration period at about 1370 rpm, and it's pretty random, although it happens often.
    You can see the glitch in this photo:
    https://ibb.co/Fn12t4Q
    I looked up the fault in my autoscans and turns out I do have a friend who had the exact same fault with his 2011 Q5. The dealer did a bunch of work when it was in for an oil consumption recall, including replacing the intake cam. I'm trying hard not to condemn the camshaft because to me it looks like an electrical fault.
    So I'm wondering if anyone has any more ideas on things I can test before recommending a camshaft!
    Thursday,27,June,2019,15:25:34:05
    VCDS Version: 18.9.1.0 (x64)
    Dealer/Shop Name: hans j
    VIN: WAUFFAFL7BN007465   License Plate:
    Mileage: 186040km-115599mi   Repair Order:
    Chassis Type: FL-AU48 (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 5F 62
              6C 72
    VIN: WAUFFAFL7BN007465   Mileage: 186040km-115599miles
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 AD    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H17 0002
       Revision: E1H17---
       Coding: 0104010A290F0160
       Shop #: WSC 02145 785 00200
       ASAM Dataset: EV_ECM20TFS0118K2907115AD 001005
       ROD: EV_ECM20TFS0118K2907115AD.rod
       VCID: F1AA955A20BFFCC2A2-80A4
    4113 - Camshaft Position Sensor (G40)
              P0341 00 [104] - Implausible Signal
                        Fault Frequency: 61
                        Mileage: 185780 km
                        Date: 2010.12.23
                        Time: 12:17:29
                        Engine speed: 1256.00 /min
                        Normed load value: 11.4 %
                        Vehicle speed: 82 km/h
                        Coolant temperature: 84 °C
                        Intake air temperature: 27 °C
                        Ambient air pressure: 800 mbar
                        Voltage terminal 30: 14.182 V
       Part No SW: 8K0 927 158 K    HW: 0BK 927 156 N
       Component: 0BK 20TFSIUSA H08 0004
       Revision: --H08---
       Coding: 001102
       ASAM Dataset: EV_TCMAL551211 001012
       ROD: EV_TCMAL551211_001.rod
       VCID: BE307E66216153BA6F-80EA
       Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
       Component: ESP8 quattro  H04 0050
       Coding: 1D0518
       Shop #: WSC 02391 823 56573
       VCID: 8248CA961D19F75A4B-80D6
       Part No SW: 8K0 907 064 CF    HW: 8K0 907 064 CF
       Component: BCM2 2.0      H04 0430
       Coding: 090100
       Shop #: WSC 02399 823 56573
       VCID: F6A0A64641D1DBFA77-80A2
       Subsystem 1 - Part No SW: 8K0 959 754 B    HW: 8K0 959 754 B
       Serial number: 0815000041109008
       Serial number: 0210000102478004
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0180
       Revision: C1000000    Serial number: 01110620101773
       Coding: 64102000
       VCID: 804CC09E1315E54A5D-80D4
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H29 0392
       Revision: 10029001    Serial number: 00000000568161
       Coding: 26001091063CAF010000000300003D0D0F1C520802010161000000
       VCID: BC34746E3F7D41AA41-80E8
       Component: WWS 150610  H06 0070
       Serial number: SWF10060150429
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10948698
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
       Serial number: 00000000001406100445
       Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
       Component: HOMELINK  H01 0010
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 80
                        Mileage: 176119 km
                        Date: 2010.08.10
                        Time: 14:50:00
       Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0070
       Revision: 11001001    Serial number: 51231017005444
       Coding: 200103
       VCID: C7DE1B8276BB1272DC-8092
       Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
       Component: AirbagVW-AU10 H41 0610
       Serial number: 003GLD0G6UN%
       Coding: 303837354230303030304A55304C384B3053
       Shop #: WSC 02135 785 00200
       VCID: C5C2118A44B700622E-8090
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Serial number: 5810000R1000000ACW
       Serial number: 6334MSME5511234A4
       Serial number: 6344MSME55112779B
       Serial number: 6352QSME5F533F04R
       Serial number: 6362QSME6457083EP
       Serial number: 63732SME634A3A7CB
       Serial number: 63832SME4D64413A2
       Revision: --------    Serial number: 90315JFH0005W
       Coding: 000016
       VCID: BD32796A246748A276-80E8
       Component: E221 - MFL  H02 0010
    No Faults Found
       Part No SW: 8K0 920 981 C    HW: 8K0 920 981 C
       Component: KOMBIINSTR.   H21 0258
       Revision: 00000000    Serial number: EJB40U76A
       Coding: 8B1709000200D705020000
       VCID: B3265F5212238ED290-80E6
       Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0117
       Revision: EC000056    Serial number: 5600E1060703C4
       Coding: 00C303
       VCID: 8346CF920203FE5240-80D6
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H07 0170
       Serial number: 100204DE150610
    02256 - Quiescent Current
                        Fault Status: 00100001
                        Reset counter: 251
                        Mileage: 185360 km
                        Date: 2010.12.13
                        Time: 18:36:00
                000 -  -  - Intermittent
                        Reset counter: 249
                        Mileage: 185360 km
                        Date: 2010.12.13
                        Time: 22:36:00
                        Bin. Bits:    00000
                        Voltage: 12.40 V
                        Count: 17
       Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
       Component: TSG FA        H08 1401
       Coding: 011C03204000410001
       VCID: D3E63FD2B2E3AED2B0-8086
       Revision: 00002001    Serial number: 0131953813
       Coding: 0106023A00FA040480B0013200000000
       VCID: F6AA52E5D8C6DBD7341-FFFE
       Component: LIN BACKUP HO  1501
    No Faults Found
    Thursday,27,June,2019,16:57:41:05734
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4505.4
                    Address 01: Engine  (8K2 907 115 AD)
    16:57:33
      IDE00584   Distance driven since erasing DTC memory 671 km
      IDE00585   Dist. driven with exh. Malfunction Indicator Lamp activated 187 km
    Chains or oil PSI............or BOTH!
    Fuel in oil?
  3. Likes Uwe liked this post
    Jul 2017
    Kenya
    Quote Originally Posted by hans j View Post
              6C 72
       Revision: E1H17---
                        Fault Frequency: 61
                        Mileage: 185780 km
                        Date: 2010.12.23
                        Time: 12:17:29
       Revision: --H08---
       Coding: 001102
       Coding: 1D0518
       Coding: 090100
       Coding: 64102000
       Coding: 00FD11
       Coding: 025028
                        Reset counter: 80
                        Mileage: 176119 km
                        Date: 2010.08.10
                        Time: 14:50:00
       Coding: 200103
       Coding: 000016
    No Faults Found
       Coding: 00C303
                        Reset counter: 251
                        Mileage: 185360 km
                        Date: 2010.12.13
                        Time: 18:36:00
                        Reset counter: 249
                        Mileage: 185360 km
                        Date: 2010.12.13
                        Time: 22:36:00
                        Bin. Bits:    00000
                        Voltage: 12.40 V
                        Count: 17
    No Faults Found
    16:57:33
    I once had to battle a similar code on an A4 8K CDHB motor after the previous garage had replaced G40 twice,engine oil and ...etc,we went for a test drive,logged misfire counters....found out misfires would come,but below MIL triggering threshold,and G40 error would appear during the episode.....we replaced all coil packs,the error went away for good
  5. Likes Uwe liked this post
  6. #4
    Mar 2014
    Utah
    I never got to check the oil pressure due to time issues. The oil change had 5000 miles on it according to carfax. It was at minimum and a little dark, but didn't smell like fuel. We ended up changing the oil since it was due and used BG EPR and MOA along with it. The fault stayed away after several test drives! And theories on why it could cause that drop out in the signal? Maybe camshaft thrust? I measured the cam signal and it was pretty much right on compared to the next one in the engine revolution, so no timing change happened.
    I've also heard of a metallurgy issue in the reluctor that causes a drop out. That will be my next check if they decide to do anything on this salvage title car.
