Results 1 to 10 of 11
Thread: Cannot update
    Dec 2015
    Greece
    Cannot update
    My HEX-NET interface cannot update ASAM!
    Also stucks when I try to access Engine!
    I post an auto scan here!
    #hndoc:?docid=000051E7&xt=hnh:17A2E2902D933650D85838A5C18FFA16EF1E95AF3EEEF915335A82B0209B0168
    VCDS Mobile 0.4508.0.4
    Scan: 01 02 03 08 09 10 15 17 19 25 44 55
    08-Auto HVAC -- Status: OK 16000
    09-Cent. Elect. -- Status: OK 16000
    19-CAN Gateway -- Status: OK 16000
    Address 01: Engine  (CAVE J623)	Labels: 03C-907-309-V1.clb
    	Part No SW: 03C 906 027 AR	HW: 03C 906 027 AR
    	Component: 1.4l R4 TSI   H15 9971
    	Revision: L2H15---
    	Coding: 00250012002400000000
    	Shop #: WSC 00017 666 02801
    	ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
    	ROD: N/A
    	VCID: 71A546C70477922CD57C42-8024
    	No ASAM data for: "EV_ECM14TSI01103C906027AR"
    No fault codes found.
    Address 02: Auto Trans	Labels: 0AM-927-769.clb
    	Part No SW: 0AM 300 050 K	HW: 0AM927769D
    	Component: GSG DSG AG7     403  9032
    	Revision: 00040034	Serial Number: TFK01012130269
    	Shop #: WSC 22643 000 1048576
    	VCID: 312586C7C4F74B2C95FC82-513C
    Address 03: ABS Brakes  (J104)	Labels: 6R0-907-37x-ESP82.clb
    	Part No SW: 6R0 907 379 AK	HW: 6R0 907 379 AF
    	Revision: --------
    	Coding: 210248E3417602BB842512E682D640411700
    	Shop #: WSC 00788 648 00255
    	VCID: 8751881F9AF3209CEB584C-80D2
    Address 08: Auto HVAC  (J255)	Labels: 6R0-907-044.clb
    	Part No SW: 6R0 907 044 N	HW: 6R0 907 044 N
    	Component: Climatronic   H12 0812
    	Revision: V0000000
    	Shop #: WSC 00000 000
    	VCID: 3E3FADFB05A92554187E31-806B
    Address 09: Cent. Elect.  (J519)	Labels: 7H0-937-08x-09.clb
    	Part No SW: 7H0 937 089 D	HW: 7H0 937 089
    	Component: BCM T5GP Li4  H47 0230
    	Revision: BS047001
    	Coding: 3DB029BF48F324009B280EB17CEB0FD05AC0670F60053041200000000000
    	Shop #: WSC 124697 483 00190
    	VCID: 3731B8DF2A93141CDB38FC-8062
    	Subsystem 1 - 	Part No SW: 1K0-955-559-AH	Labels: 1K0-955-559-AG.clb
    	Component: RLS 140111 0554  0403
    	Coding: 06302D
    	Subsystem 2 - 	Part No SW: 6R0-959-801-AB	Labels: 6R0-959-801.clb
    	Component: J386__TSG_FT 007 1621
    	Coding: 08BC30
    	Subsystem 3 - 	Part No SW: 6R0-959-802-AD	Labels: 6R0-959-802.clb
    	Component: J387__TSG_BT 007 1621
    	Coding: 08BC30
    	Subsystem 4 - 	Part No SW: 1K8-951-171-A
    	Component: DWA-Sensor 00001 0103
    	Subsystem 5 - 	Part No SW: 1K8-951-605-B
    	Component: LIN BACKUP HOH11 9005
    	Subsystem 6 - 	Part No SW: 6R0-959-591-A
    	Component: J245 PS72.015H05 0006
    	Coding: 081001
    	Subsystem 7 - 	Part No SW: 1K8-951-171-A
    	Subsystem 8 - 	Part No SW: 5K0-959-542
    	Component: E221__MFL-TASH06 0010
    	Coding: 830000
    Address 10: Park/Steer Assist  (J446)	Labels: 6R0-919-475.clb
    	Part No SW: 6R0 919 475 B	HW: 7E0 919 475
    	Component: PARKHILFE 4K  H10 0012
    	Revision: --------
    	Coding: 108104
    	ASAM Dataset: EV_VW250ParkiAssis2 S01008
    	ROD: N/A
    	VCID: 3D3DAAF708AF264C01743E-8068
    	No ASAM data for: "EV_VW250ParkiAssis2"
    Address 15: Airbags  (J234)	Labels: 5K0-959-655.clb
    	Part No SW: 6R0 959 655 M	HW: 6R0 959 655 M
    	Component: VW10Airbag012 H09 0020
    	Revision: --------
    	Coding: 003132
    	ROD: N/A
    	VCID: 4CDBF73343159FC486EADB-8019
    	No ASAM data for: "EV_AirbaVW10BPAVW250"
    	Subsystem 1 - 	Serial Number: 3575HRB406509RECAH8F
    	Subsystem 2 - 	Serial Number: 3585HRB406109REC297
    	Subsystem 3 - 	Serial Number: 3515RRB405709GGUGHB
    Address 17: Instruments  (J285)	Labels: 5K0-920-xxx-17.clb
    	Part No SW: 6R0 920 870	HW: 6R0 920 870
    	Component: KOMBI         H20 0320
    	Coding: 140E00
    	ROD: N/A
    	VCID: F2A7C9CB81712934AC66F5-80A7
    	No ASAM data for: "EV_Kombi_UDS_VDD_RM09"
    Address 19: CAN Gateway  (J533)	Labels: 6N0-909-901-19.lbl
    	Part No SW: 6N0 909 901	HW: 7H0 937 089
    	Component: GW-K-CAN TP20 0230
    	Coding: 002000
    	VCID: F0A3C3C38F7D03245A72CF-80A5
    Address 25: Immobilizer  (J334)	Labels: 5K0-920-xxx-25.clb
    	Part No SW: 5K0 953 234	HW: 5K0 953 234
    	Component: IMMO          H20 0320
    	ROD: N/A
    	VCID: EA97D1ABA9A1E1F414368D-80BF
    	No ASAM data for: "EV_Immo_UDS_VDD_RM09"
    Address 44: Steering Assist	Labels: 6Q0-423-156.clb
    	Part No SW: 6R0 423 156 B
    	Coding: 11241
    	Shop #: WSC 00788 000
    	VCID: 2F2180BFD2C348DC83C894-807A
    Address 55: Xenon Range  (J431)	Labels: 6R0-907-357.clb
    	Part No SW: 6R0 907 357	HW: 6R0 907 357
    	Component: LWR-ECU       H02 0070
    	Revision: --------
    	Coding: 0110000001000000
    	ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
    	ROD: N/A
    	VCID: F7B1F8DFEA134C1C9BB83C-80A2
    	No ASAM data for: "EV_HeadlRegulVWLWRPt"
    End--(Elapsed Time: 02:03, VBatt start/end: 13.3/13.3 Vign: 0.0)-
    Moving to HEX-NET support.
    I've switched your interface to the alpha channel, where there is a new update. Please download this update and then try again and see if that helps.
  4. Likes Uwe liked this post
    Dec 2015
    Greece
    Did the update!
    Although I see a message getvin timeout!
    Quote Originally Posted by skoukiadakis View Post
    I've been seeing that message for as long as I can remember, but my HEX-NET works OK
  7. Likes Uwe liked this post
    Dec 2015
    Greece
    Do I have to switch my interface to beta channel or not?
    No. Alpha is an update channel you can't switch to yourself. When someone from Ross-Tech tells you they've put you on Alpha, switching back down to Beta or Release just is counter-productive! I see you've done exactly that, but without updating your interface.
    I've just put you back on Alpha again. Please check for updates. You should get CB version 4513. Once you have that, please try updating your ROD/ASAM data again.
  10. Likes Eric, gawied liked this post
  11. #8
    Dec 2015
    Greece
    Thanks for helping!
    Did the update.Now i have CB version 4513.
    Now when I will plug it to the car,if any updates,i must install them with VCDS mobile or with VCDS configurator?
  12. #9
    Jun 2014
    Newcastle, England
    Use either. But remember, don’t touch the Beta or Release channel switcher in VCI-Config.
  13. Likes gawied, Uwe liked this post
  14. #10
    Dec 2015
    Greece
    Use either. But remember, donít touch the Beta or Release channel switcher in VCI-Config.
    Thank you!
