Sunday,09,June,2019,16:57:15:53575
VCDS Version: 19.6.0.2 (x64) HEX-V2 CB: 0.4505.4
VIN: VSSZZZAAZGD300027 License Plate: GK321P
Mileage: 25680km-15956mi Repair Order:
Chassis Type: AA-VW12 (1S0)
Scan: 01 02 03 09 10 15 17 19 25 44 47 56 61 AD
VIN: VSSZZZAAZGD300027 Mileage: 25680km-15956miles
AD-Brake Sensors -- Status: OK 0000
Address 01: Engine (J623-CHYB) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 020 DL HW: 04C 907 309 P
Component: R3 1.0l MPI H24 2105
Revision: UNH24---
Coding: 00140032022401000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM10MPI01104C906020DL 001004
ROD: EV_ECM10MPI01104C906020DK.rod
VCID: 68884892D2FECF37621-803C
Address 02: Auto Trans (J514) Labels:* None
Part No SW: 0CT 927 750 F HW: 0CT 927 750 C
Component: SQ100 H12 0130
Coding: 030120
ASAM Dataset: EV_TCMSQ101011 005013
ROD: EV_TCMSQ101011_005.rod
VCID: 4BC2971EA348042F6F3-801E
19941 - Transmission Friction Element / Clutch A
P07A3 00 [032] - Stuck On
Fault Frequency: 14
Mileage: 23603 km
Date: 2019.02.20
Time: 09:16:21
Engine speed: 1198.50 /min
Transmission input speed: 470 /min
Transmission output speed: 0 /min
Engine torque: 28 Nm
Transmission fluid temperature: 4 °C
Accelerator position: 0.0 %
Clutch status: 1
Unlearning counter according OBD: 16
selected gear-TEXT TABLE: GEAR: Neutral 1-2
Clutch status-Clutch State: Open
Clutch position in engaged state-Clutch position: 1025 INK
Clutch position in opened up state-Clutch position: 450 INK
Current current of clutch actuator-Motor current: 0.00 A
Maximum allowed PWM value-Duity cycle: 100 %
Actual position clutch 1 duty cycle factor 1-Duity cycle: 0 %
Overtemperature class of clutch-Clutch protection: --no display--
Excess temperature counter-Param to DOP_64079: 0
Duration overtemperature state clutch-Param to DOP_08916: 0.0 min
Maximum value energy input through clutch friction-Param to DOP_34971: 0
Clutch engagement point adaptation-Clutch position: 648 INK
Actual position of clutch motor-Param to DOP_44308: 460 INK
Clutch 1: spec. position in increments-Param to DOP_44308: 470 INK
Driving mode-Text Tabel: Drivng Situation: NEUTRAL_EINLERNEN_GW_BEENDET
Address 03: ABS Brakes (J104) Labels: 1S0-614-517.clb
Part No SW: 1S0 614 517 L HW: 1S0 614 517 L
Component: EBC 460 ESP H16 0023
Serial number: A00TESM
Coding: 22BF24712BAD02F144FA24F7D4B040505FB200
ASAM Dataset: EV_Brake1ESPEBC460TRW 002004
ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod
VCID: 3828D8D2C2DE9FB7321-806C
Address 09: Cent. Elect. (J519) Labels:. 1S0-937-09x-V1.clb
Part No SW: 1S0 937 090 D HW: 1S0 937 090 D
Component: PQ25 BCM H59 0584
Revision: -8------ Serial number: --------------
Coding: 7AB82BB000230000000007F07D6BBCC873C0426F7E871460200000060100
VCID: 3430ECE2DE367BD71E9-8060
Address 10: Park/Steer Assist (J446) Labels:| 1Sx-919-475.clb
Part No SW: 1SL 919 475 HW: 1Q0 919 475
Component: PARKHILFE 3K H03 0005
Revision: -------- Serial number: 32991512100838
Coding: 100101
ASAM Dataset: EV_EPHVA14SE1200000 001001
ROD: EV_EPHVA14SE1200000.rod
VCID: 13724F7EBBF89CEF673-8046
Part No SW: 1S0 959 655 B HW: 1S0 959 655 B
Component: VW10Airbag01Q H03 0006
Revision: -------- Serial number: 003MY00E4PV4
Coding: 000000000000000000000000000000003151
ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
VCID: 3D26C9C6EDFCBA9FE17-8068
Serial number: 3497ARB405B378CI9PMN
Serial number: 3507ARB4059378CIPH0%
Serial number: 3557BRB405D3627AGOE1
Address 17: Instruments (J285) Labels:| 1Sx-920-xxx-17.clb-SRI1
Part No SW: 1SL 920 861 H HW: 1SL 920 861 H
Component: KOMBI H52 0405
Revision: X0052001 Serial number: 00000000000000
Coding: 1148010000
ASAM Dataset: EV_KombiUDSMM9RM10 A05803
ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
VCID: 52FC8A7A446255E72C5-8006
Part No SW: 1S0 909 901 HW: 1S0 937 090 D
Component: GW-K-CAN TP20 H59 0584
Revision: -8------
Coding: 021200
VCID: 70B820F2EAAE07F73A1-8024
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 1SL 920 861 H
Component: IMMO H52 0405
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6A8C329ACCF2FD27745-803E
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R1 909 144 AJ HW: 6R1 909 144 E
Component: EPS_TRW_ALow 312 3132
Serial number: CF5H0261
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016029
ROD: EV_SteerAssisUDSTRW.rod
VCID: 7F5AF3CEA770688FB3B-802A
Part No SW: 5K0 035 456 E HW: 5K0 035 456 E
Component: KonzernAmp 8K H08 6631
Revision: -------- Serial number: EAA101C0040066
ASAM Dataset: EV_AudioVerst8KanalSTT4 001001
ROD: EV_AudioVerst8KanalSTT4.rod
VCID: 2C00F48206862317469-8078
Address 56: Radio (J503) Labels: None
Part No SW: 1SL 035 156 B HW: 1SL 035 156 B
Component: Radio H05 0033
Revision: R0000000 Serial number: SEZAZ1R0827174
Coding: 0001000801
VCID: 46D4A62AB8AAF947B0D-8012
Part No SW: 1S0 907 534 HW: 1S0 937 090 D
Component: Batt-regelung H59 0584
Coding: 032B7864
Subsystem 1 - Part No SW: 1S0 915 181 B HW: 1S0 915 181 B
Component: J367-BDM H08 0210
Address AD: Brake Sensors (J939) Labels: 1S0-907-201.clb
Part No SW: 1S0 907 201 A HW: 1S0 907 201 A
Component: CV-SENSOR H07 0460
ASAM Dataset: EV_CVSen 001001
ROD: EV_CVSen.rod
VCID: 28080892127E0F37A21-807C
End----------(Elapsed Time: 00:45, VBatt start/end: 12.1V/12.1V)-----------
Sunday,09,June,2019,17:19:55:53575
Revision: UNH24---
Readiness: 1110 0001
Coding: 030120
Coding: 100101
Coding: 114A010000
Revision: -8------
Coding: 021200
Coding: 000700
Coding: 0001000801
Coding: 032B7864
ROD: EV_CVSen.rod
