Results 1 to 5 of 5
Thread: 2019 Passat R-Line (A3)
    Jun 2019
    Smile 2019 Passat R-Line (A3)
    I've been with Ross-Tech for many years but this is my first post, hello everyone.
    I just leased a VW 2019 Passat R-Line (A3 chassis) and I also upgraded to the HEX-V2 interface running the 19.6 software on a Windows 7 Toshiba machine.
    One of the first things I do with a new car is run the Auto-Scan and then turn off the seat belt warning, unfortunately I cannot find where to make that seat belt change. I have search the forum and only found older versions to make this change and don't seem to find it on my code 17 instrument section. If there is already instructions for this please reply with the link and hopefully I'm not being so dumb that is was right in front of my face
    Thanks for your help,
    Gregg
    Sunday,30,June,2019,01:37:17:34676
    VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
    Dealer/Shop Name: Biffwell Productions
    VIN: 1VWMA7A30KC001230   License Plate: 336
    Mileage: 2240km-1391mi   Repair Order: 06302019
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 25 2B 3C 42 44 46 47 4F
              52 5F 61 62 72 75 A5
    VIN: 1VWMA7A30KC001230   Mileage: 2240km-1391miles
    Address 01: Engine (J623-DDSA)       Labels:. 06K-907-425-V2.clb
       Part No SW: 06K 906 016 D    HW: 06K 907 309
       Component: R4 2.0l TSI   H31 6243
       Revision: 1EH31000
       Coding: 411A00922444000F9000
       Shop #: WSC 06050 062 00200
       ASAM Dataset: EV_ECM20TFS01106K906016D 003003
       ROD: EV_ECM20TFS01106K906016D.rod
       VCID: 2B0307BCB38D471F4F7-807E
       Part No SW: 09G 927 158 DQ    HW: 09G 927 158
       Component: AISIN AG6 G3  202 3517
       Coding: 010200000C000000000000000000000000000000
       ASAM Dataset: EV_TCMAQ250031 002009
       ROD: EV_TCMAQ250031_002_VW31.rod
       VCID: 0557910475A9516FF93-8050
       Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
       Component: ESP MK60EC1   H46 0175
       Revision: 00H46001
       Coding: C54BC0F5492200FBA30D03E79219004100F0F01A
       VCID: 75B7E1C425C941EFE93-8020
       Part No SW: 5K0 959 434 K    HW: 5K0 959 434
       Component: VWKESSYPQ35GP 093 1403
       Revision: 00093000    Serial number: 0473393844
       Coding: 132C0C
       VCID: 3D2739E45DF9D9AFE13-8068
       Part No SW: 561 907 044 BD    HW: 561 907 044 BD
       Component: Climatronic   H08 0910
       Revision: 00001K05
       Coding: 0050019092
       ROD: EV_ACClimaBHBVW411_VW41.rod
       VCID: 5AED9278AC970E97E41-800E
    9496609 - Sunlight Photo Sensor
              B10E8 11 [009] - Short to Ground
                        Reset counter: 90
                        Mileage: 24 km
                        Date: 2019.05.17
                        Time: 11:26:20
       Part No SW: 5K0 937 087 AS    HW: 5K0 937 087 AS
       Component: BCM PQ35 H++  122 0193
       Revision: BN122001
       Coding: EF200E1B982B08D4098806013400044800F1000645A00DB0E4806200BC70
       VCID: 06559608482F5A77F09-8052
       Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
       Component: RLS 170718 05  50  0106
       Coding: 0038DD
       Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0480
       Revision: --------    Serial number: 55501822913730
       Coding: 0071155011
       ASAM Dataset: EV_EPHVA18VW364GP00 001007
       VCID: 372B2BCC7FC5F3FF3BF-8062
    Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
       Part No SW: 7N0 907 572 C    HW: 7N0 907 572
       Component: ACC Bosch PQx H03 0211
       Serial number: 2108187453A157
       Coding: 01001002FE0739
       ASAM Dataset: EV_ACCBEGVW361 001006
       ROD: EV_ACCBEGVW361_VW32.rod
       VCID: 363526C878CF0AF7209-8062
    Address 15: Airbags (J234)       Labels:* 561-959-655.clb
       Part No SW: 561 959 655     HW: 561 959 655
       Component: AirbagVW11    008 0210
       Serial number: 003RXM0G0F7.
       Coding: 8CCCCC00000000005000001A020800000065
       ASAM Dataset: EV_AirbaVW11SMEVW411 001002
       ROD: EV_AirbaVW11SMEVW411_VW41.rod
       VCID: 6393AF9C9BDDCF5FB77-8036
       Serial number: IBH00000000000A51EKA
       Coding: 30324C
       Subsystem 2 - Part No SW: -----------    HW: 480 003 006 18
       Serial number: 357000000006B4F8803R
       Subsystem 3 - Part No SW: -----------    HW: 480 003 006 18
       Serial number: 3580000000001A74EE2P
       Subsystem 4 - Part No SW: -----------    HW: 480 022 804 18
       Component: SideSensor_Dr  000 0148
       Serial number: 3510001C9298DB428215
       Subsystem 5 - Part No SW: -----------    HW: 480 021 207 18
       Component: SideSensor_Pr  004 0148
       Serial number: 3520001062B7224203CJ
       Subsystem 6 - Part No SW: -----------    HW: 480 022 905 18
       Component: FrontSensor_D  000 0189
       Serial number: 3550001B1267FA34A658
       Subsystem 7 - Part No SW: -----------    HW: 480 022 905 18
       Component: FrontSensor_P  000 0189
       Serial number: 3560001B1267FA365263
       Part No SW: 1K5 953 521 CS    HW: 5K0 953 569 BF
       Component: LENKS.MODUL   018 0230
       Revision: FF010042    Serial number: 20180722200131
       Coding: 2012C40008
       ROD: EV_SMLSNGVOLWSR8C.rod
       VCID: 005980106A8B7447CA5-8054
       Subsystem 1 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B  Labels: 3C8-959-537.CLB
       Serial number: 1941804412900386AE1B
       Coding: 2D0000
    Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
       Part No SW: 561 920 981 D    HW: 561 920 981 D
       Component: KOMBI         H03 2030
       Coding: 221E010000
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
       VCID: 1D67D964FD39B9AFC13-8048
       Part No SW: 7N0 907 530 BQ    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1691
       Revision:   H56       Serial number: 19081803000038
       Coding: 461010
       VCID: 005980106A0B7447CA5-8054
       Component: IMMO          H03 2030
       Coding: 000007
       VCID: 6A8DC2B87CF79E17741-803E
       Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
       Component: ELV-PQ35      H22 0240
       Revision: 00000000    Serial number: 18000227600001
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 313F15D491A12DCF75B-8064
       Component: HRE_Master    H12 0071
       Serial number: 0486102438
       Coding: 02011102
       ROD: EV_HREntryHella_VW27.rod
       VCID: 3C2134E046E3D0A7D6D-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0071
       Serial number: 0489833856
       Coding: 020111
       Part No SW: 561 959 701 C    HW: 3C0 959 793 J
       Component: TUER-SG FT    002 0637
       Revision: 12100010    Serial number: 0011137050
       Coding: 0404BD
       ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 1E65DE68F03FA2B7D89-804A
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811 C    HW: 561 959 811 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  022 1472
       Serial number: 14102746180730134253
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 313    3501
       Revision: 00H22000
       Shop #: WSC 19460 666 12345
       VCID: 392F2DF44551E58FCDB-806C
       Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
       Component: KonzernAmp10K H09 6831
       Revision: --------    Serial number: EAA098C0162588
       VCID: 2809F8B0A27B6C07A25-807C
       Component: EZE_2         H56 1691
       Coding: 01030100
       VCID: 6FBBD3AC47957B3F23F-803A
       Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
       Component: J245 P05 9BA3  H08 0005
       Serial number: 53388786011815400291
       Coding: 181100
       Part No SW: 561 959 702 C    HW: 3C0 959 792 J
       Component: TUER-SG BT    002 0637
       Revision: 14100010    Serial number: 0011131013
       Coding: 0405BC
       ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 1F1BE36CF735ABBFD3F-804A
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812 C    HW: 561 959 812 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  022 1472
       Serial number: 14102747180723075727
       Part No SW: 5C0 035 684 D    HW: 5C0 035 684 D
       Component: MU-S-NS-US    H42 0472
       Serial number: VWZAZ2U0992674
       Coding: 02140102AA00000041220003001808009F0106D400200105C6
       ROD: EV_MUStd4CTSAT_VW41.rod
       VCID: 2615F688A86F7A77909-8072
       Subsystem 1 - Part No SW: 5NA 919 866 E    HW: -----------
       Component: NAR 2018/19  --- 0810
    6720 - Rear View Camera
              B1102 31 [008] - No Signal
                        Reset counter: 120
                        Mileage: 504 km
                        Date: 2019.05.31
                        Time: 09:31:18
                        Voltage terminal 30: 12.3 V
       Component: Batt.regelung H56 1691
       Coding: E1200859
       VCID: 71BFD5D451A16DCF35B-8024
       Part No SW: 561 035 285 A    HW: 561 035 285 A
       Component: OCULowUSA     024 0160
       Serial number: 000003554140568
       Coding: 02140102C24232107F1606000000
       ASAM Dataset: EV_OCULow 002010
       ROD: EV_OCULow_002.rod
       VCID: 1471BC400EF3F8E77ED-8040
       Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H08 1272
       Serial number: 07051841K22859
       Coding: 0004010100010201002213468080480080000E200100
       ROD: EV_MFKBoschMQBB_001_VW27.rod
       VCID: 0849983042BB4C07825-805C
    End----------(Elapsed Time: 01:26, VBatt start/end: 13.4V/13.5V)-----------
  2. Likes Uwe liked this post
  3. #2
    It's in the 17-Instruments, Coding -> Long Coding Helper.
    Byte 1 (the second byte) should have a bit labelled "Seatbelt Warning active/installed".
    Jun 2019
    And just like that the Seat Belt warning is gone, thank you for the assist, I'm not use to this section of the program.
    Another question:
    Can the 'the vehicle is moving so settings can't be changed' be made to go away. That (to me) is so stupid of a thing. There is so much other things to adjust and change while the car is moving but the settings screen is locked out (along with the Sirius settings section) while the car is moving. Just dumb.
    thanks again,
    Gregg
    Dec 2016
    DE
    Not possible via coding or adaption. There are people however, who can make it go. I donít know, if they modify the EEPROM or whatever...
  6. Likes Uwe liked this post
    Jun 2019
    Thx for the update about the 'moving cant change the settings' thing, this car is a lease so I don't want to go that far to mess with the EEPROMS but I'll keep a look out for something.
    Thx
    Gregg
