I've been with Ross-Tech for many years but this is my first post, hello everyone.
I just leased a VW 2019 Passat R-Line (A3 chassis) and I also upgraded to the HEX-V2 interface running the 19.6 software on a Windows 7 Toshiba machine.
One of the first things I do with a new car is run the Auto-Scan and then turn off the seat belt warning, unfortunately I cannot find where to make that seat belt change. I have search the forum and only found older versions to make this change and don't seem to find it on my code 17 instrument section. If there is already instructions for this please reply with the link and hopefully I'm not being so dumb that is was right in front of my face
Thanks for your help,
Gregg
Gregg
Sunday,30,June,2019,01:37:17:34676
VCDS Version: 19.6.0.6 (x64) HEX-V2 CB: 0.4505.4
Dealer/Shop Name: Biffwell Productions
VIN: 1VWMA7A30KC001230 License Plate: 336
Mileage: 2240km-1391mi Repair Order: 06302019
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 25 2B 3C 42 44 46 47 4F
52 5F 61 62 72 75 A5
VIN: 1VWMA7A30KC001230 Mileage: 2240km-1391miles
Address 01: Engine (J623-DDSA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 906 016 D HW: 06K 907 309
Component: R4 2.0l TSI H31 6243
Revision: 1EH31000
Coding: 411A00922444000F9000
Shop #: WSC 06050 062 00200
ASAM Dataset: EV_ECM20TFS01106K906016D 003003
ROD: EV_ECM20TFS01106K906016D.rod
VCID: 2B0307BCB38D471F4F7-807E
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 DQ HW: 09G 927 158
Component: AISIN AG6 G3 202 3517
ROD: EV_TCMAQ250031_002_VW31.rod
VCID: 0557910475A9516FF93-8050
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: C54BC0F5492200FBA30D03E79219004100F0F01A
VCID: 75B7E1C425C941EFE93-8020
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 K HW: 5K0 959 434
Component: VWKESSYPQ35GP 093 1403
Revision: 00093000 Serial number: 0473393844
Coding: 132C0C
VCID: 3D2739E45DF9D9AFE13-8068
Part No SW: 561 907 044 BD HW: 561 907 044 BD
Component: Climatronic H08 0910
Revision: 00001K05
Coding: 0050019092
VCID: 5AED9278AC970E97E41-800E
9496609 - Sunlight Photo Sensor
B10E8 11 [009] - Short to Ground
Reset counter: 90
Mileage: 24 km
Date: 2019.05.17
Time: 11:26:20
Part No SW: 5K0 937 087 AS HW: 5K0 937 087 AS
Component: BCM PQ35 H++ 122 0193
Revision: BN122001
Coding: EF200E1B982B08D4098806013400044800F1000645A00DB0E4806200BC70
VCID: 06559608482F5A77F09-8052
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 170718 05 50 0106
Coding: 0038DD
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 55501822913730
Coding: 0071155011
ASAM Dataset: EV_EPHVA18VW364GP00 001007
VCID: 372B2BCC7FC5F3FF3BF-8062
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7N0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 2108187453A157
Coding: 01001002FE0739
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361_VW32.rod
VCID: 363526C878CF0AF7209-8062
Address 15: Airbags (J234) Labels:* 561-959-655.clb
Part No SW: 561 959 655 HW: 561 959 655
Component: AirbagVW11 008 0210
Serial number: 003RXM0G0F7.
Coding: 8CCCCC00000000005000001A020800000065
ASAM Dataset: EV_AirbaVW11SMEVW411 001002
ROD: EV_AirbaVW11SMEVW411_VW41.rod
VCID: 6393AF9C9BDDCF5FB77-8036
Component: BF-Gewichtss. H13 0022
Serial number: IBH00000000000A51EKA
Coding: 30324C
Subsystem 2 - Part No SW: ----------- HW: 480 003 006 18
Serial number: 357000000006B4F8803R
Subsystem 3 - Part No SW: ----------- HW: 480 003 006 18
Serial number: 3580000000001A74EE2P
Subsystem 4 - Part No SW: ----------- HW: 480 022 804 18
Component: SideSensor_Dr 000 0148
Serial number: 3510001C9298DB428215
Subsystem 5 - Part No SW: ----------- HW: 480 021 207 18
Component: SideSensor_Pr 004 0148
Serial number: 3520001062B7224203CJ
Subsystem 6 - Part No SW: ----------- HW: 480 022 905 18
Component: FrontSensor_D 000 0189
Serial number: 3550001B1267FA34A658
Subsystem 7 - Part No SW: ----------- HW: 480 022 905 18
Component: FrontSensor_P 000 0189
Serial number: 3560001B1267FA365263
Part No SW: 1K5 953 521 CS HW: 5K0 953 569 BF
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20180722200131
Coding: 2012C40008
ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 005980106A8B7447CA5-8054
Subsystem 1 - Part No SW: 6C0 959 442 B HW: 6C0 959 442 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0023
Serial number: 1941804412900386AE1B
Coding: 2D0000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 981 D HW: 561 920 981 D
Component: KOMBI H03 2030
Coding: 221E010000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
VCID: 1D67D964FD39B9AFC13-8048
Part No SW: 7N0 907 530 BQ HW: 7N0 907 530 AN
Component: J533 Gateway H56 1691
Revision: H56 Serial number: 19081803000038
Coding: 461010
VCID: 005980106A0B7447CA5-8054
Component: IMMO H03 2030
Coding: 000007
VCID: 6A8DC2B87CF79E17741-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 D HW: 5K0 905 861 D
Component: ELV-PQ35 H22 0240
Revision: 00000000 Serial number: 18000227600001
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 313F15D491A12DCF75B-8064
Component: HRE_Master H12 0071
Serial number: 0486102438
Coding: 02011102
ROD: EV_HREntryHella_VW27.rod
VCID: 3C2134E046E3D0A7D6D-8068
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0489833856
Coding: 020111
Part No SW: 561 959 701 C HW: 3C0 959 793 J
Component: TUER-SG FT 002 0637
Revision: 12100010 Serial number: 0011137050
Coding: 0404BD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1E65DE68F03FA2B7D89-804A
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 C HW: 561 959 811 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 022 1472
Serial number: 14102746180730134253
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 313 3501
Revision: 00H22000
Shop #: WSC 19460 666 12345
VCID: 392F2DF44551E58FCDB-806C
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H09 6831
Revision: -------- Serial number: EAA098C0162588
VCID: 2809F8B0A27B6C07A25-807C
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1691
Coding: 01030100
VCID: 6FBBD3AC47957B3F23F-803A
Subsystem 1 - Part No SW: 561 959 591 A HW: 561 959 591 A
Component: J245 P05 9BA3 H08 0005
Serial number: 53388786011815400291
Coding: 181100
Part No SW: 561 959 702 C HW: 3C0 959 792 J
Component: TUER-SG BT 002 0637
Revision: 14100010 Serial number: 0011131013
Coding: 0405BC
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1F1BE36CF735ABBFD3F-804A
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 C HW: 561 959 812 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 022 1472
Serial number: 14102747180723075727
Part No SW: 5C0 035 684 D HW: 5C0 035 684 D
Component: MU-S-NS-US H42 0472
Serial number: VWZAZ2U0992674
Coding: 02140102AA00000041220003001808009F0106D400200105C6
ROD: EV_MUStd4CTSAT_VW41.rod
VCID: 2615F688A86F7A77909-8072
Subsystem 1 - Part No SW: 5NA 919 866 E HW: -----------
Component: NAR 2018/19 --- 0810
6720 - Rear View Camera
B1102 31 [008] - No Signal
Reset counter: 120
Mileage: 504 km
Date: 2019.05.31
Time: 09:31:18
Voltage terminal 30: 12.3 V
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1691
Coding: E1200859
VCID: 71BFD5D451A16DCF35B-8024
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 024 0160
Serial number: 000003554140568
Coding: 02140102C24232107F1606000000
ASAM Dataset: EV_OCULow 002010
ROD: EV_OCULow_002.rod
VCID: 1471BC400EF3F8E77ED-8040
Part No SW: 3QD 980 654 HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 1272
Serial number: 07051841K22859
Coding: 0004010100010201002213468080480080000E200100
ROD: EV_MFKBoschMQBB_001_VW27.rod
VCID: 0849983042BB4C07825-805C
End----------(Elapsed Time: 01:26, VBatt start/end: 13.4V/13.5V)-----------
