2019 VW TIGUAN BW2 RVC HIGHLINE REAR CAMERA RETROFIT
confra7
Ecuador
C?ID=359891
I just installed the camera and now I have the following DTC
Saturday,29,June,2019,13:25:37:29972
VIN: WVGAG65N5KM002115   License Plate:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 42 44 52 5F 6C
VIN: WVGAG65N5KM002115   Mileage: 5601km-3480miles
Address 01: Engine (J623-DGVA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 5NA 907 115 E    HW: 06L 907 309 B
   Component: 2.0 R4 TFSI   H31 0002
   Revision: 1DH31000
   Coding: 012500122406002824000000000000000000000000000000
   Shop #: WSC 00066 790 00452
   ASAM Dataset: EV_ECM20TFS0115NA907115E 001004
   ROD: EV_ECM20TFS0115NA907115E.rod
   VCID: 40CC42CDDBF6D74FD9-8014
   Part No SW: 0DL 300 012 M    HW: 0DE 927 711 B
   Component: GSG DQ500     H16 2107
   Revision: 00H16V33
   VCID: 33261D019A407CD754-8066
   Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0643
   Revision: 00000000    Serial number: 51748000000452
   Coding: 0BEE6B9A54201B6E4778070162C849D0D62AD8E2E046923D20405038C20A4200002864121A1C230935351919323200
   Shop #: WSC 01383 790 50316
   VCID: 78BCEA2DC3A65F8FA1-802C
   Part No SW: 5NA 907 426 M    HW: 5NA 907 426 M
   Component: AC Manuell el H34 4401
   Revision: 20K02000    Serial number: 00000D00189995
   Coding: 00020004200100000000000000000002
   ASAM Dataset: EV_ACManuePrehVW37X 002022
   ROD: EV_ACManuePrehVW37X_002_VW37.rod
   VCID: 4DD26BF91CA40A2722-8018
   Part No SW: 5Q0 937 086 BK    HW: 5Q0 937 086 BF
   Component: BCM PQ37BOSCH 034 0246
   Revision: --------    Serial number: C86426071801NR
   ROD: EV_BCMBOSCH_018.rod
   VCID: 04448EDD8F6E0B6FBD-8050
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 180615  034 0373
   Serial number: 18060522201010
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: S7Y18M05D31H13M24S41
   Coding: 00A8EE
   Serial number: 000000000ZY181450KZZ
   Serial number: 00000000000099489837
   Part No SW: 5QA 919 294 E    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0443
   Serial number: 000145450R18204
   Coding: 0471551011
   VCID: 4ED06CF511A2313F5B-801A
   Part No SW: 5Q0 959 655 BG    HW: 5Q0 959 655 BG
   Serial number: 003VUM01TKRY
   Coding: 88CCC000000000005C0000CF000800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 064094D5B952397FA3-8052
   Subsystem 1 - Part No SW: -----------    HW: 480 001 007 18
   Serial number: 3570000000013B89903G
   Subsystem 2 - Part No SW: -----------    HW: 480 000 607 18
   Serial number: 35800000000707D8503G
   Subsystem 3 - Part No SW: -----------    HW: 480 401 106 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001C329DCEF203AJ
   Subsystem 4 - Part No SW: -----------    HW: 480 401 106 18
   Component: SideSensor_Pr  004 6149
   Serial number: 35200011A2AF12F6063$
   Subsystem 5 - Part No SW: -----------    HW: 480 403 006 18
   Component: FrontSensor_D  004 6149
   Serial number: 35500010E2B6CEC586FX
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 18051820240112
   Coding: 0410
   VCID: 024888C5957A055F8F-8056
   Part No SW: 5NA 920 740 B    HW: 5NA 920 740 B
   Component: KOMBI         280 0310
   Coding: 07A40808A380000801082B001401000000000000
   VCID: 3C34363DB71EB3AF85-8068
   Part No SW: 3Q0 907 530 K    HW: 3Q0 907 530 B
   Component: GW MQB Mid    517 5323
   Serial number: 15071800841302
   Coding: 0105000830085900FB0720081E0F00000001070000000000000000000000
   Shop #: WSC 00066 790 00444
   ROD: EV_GatewNF.rod
   VCID: 373E29118E3890F768-8062
   Subsystem 2 - Part No SW: 5TA 959 442     HW: 5TA 959 442   Labels: 3C8-959-537.CLB
   Serial number: 1081814214000968AJ1B
   Coding: 250000
   Component: Haldex4Motion H52 7084
   Serial number: HA1-00012.04.18
   Coding: 0101
   VCID: 4CD466FDE7BE032F35-8018
   Serial number: 5038821300306
   Coding: 00310220D000028000001000
   VCID: 47DE59D1FED8E07718-8012
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000000585967
   Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  173 1081
   Coding: 810A0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50EC728D0B9627CF49-8004
   Serial number: 6038821201425
   Coding: 00310220DE00028000001000
   VCID: 46C054D5F9D2F97FE3-8012
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000000566455
   Coding: 090000
   Part No SW: 3Q0 035 824 C    HW: 3Q0 035 824 C
   Component: MU-S--ER      722 0867
   Coding: 02730600FF00000051220001001828001F0500C40120010002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2D120B797C642A2702-8078
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H52 8130
   Serial number: VWZ6ZJV1735953
   Coding: 0123060123002017000040
   VCID: 393A2F29B82C86879E-806C
13705483 - Databus
          [Oldbit-monitoring Gateway_72.Anhaenger_01_alt]
                    Reset counter: 206
                    Mileage: 5601 km
                    Date: 2019.06.29
                    Time: 13:33:12
                    passive
End----------(Elapsed Time: 01:14, VBatt start/end: 12.7V/12.6V)-----------
Thanks,
Since you have no trailer module, why do you have your back-up cam coded for one? See Byte 4.
confra7
Ecuador
C?ID=359891
Thank you very much, the DTC is gone
there is some way to turn off the camera while shift to drive, because it turns off at 20 - 25 kph
I bought the module 5NN055203 for trailer hitch 5NA092135 and kufatec trailer hitch wiring harness since there was no wiring loom installed to power the module
right now there is no fuse in the fuse box to power the trailer module because i was afraid to have more DTC's
Do i have to code the module? since it has the trailer hitch 4 pin connector
thank you
Spacewalker
Poland
C?ID=159607
I think you can change "camera shut off speed" .... you can changes it to 3-5km/h
did you try ?
confra7
Ecuador
C?ID=359891
did you try ?
Hi, thanks for reply, where is that option?
regards,
did you try ?
I'm not finding that in the channels for either 10 or 6C in that car. Perhaps the OP should post adaptation maps?
DV52
C?ID=194404
regards,
It's in the park assist module @ address hex10
look for IDE03782-Switch-off speed for parking assist
Edit: Oops... sorry Uwe, I didn't see your post - it's in my hex10 module (details below)
;SW:5QA-919-294-B   HW:5QA-919-294 ---  Park/Steer Assist
;Component:PDC 8 KanalH07 0044
;EV_EPHVA18AU3700000
has the channel been removed in SW: 5QA 919 294 E ?
My bad. I just did a cursory search for "shut". :facepalm:
Looking closer, 6C has:
ENG119212 -- camera_off (km/h)
and 10 does indeed have:
IDE03782 -- Switch-off speed for parking assist (km/h)
confra7
Ecuador
C?ID=359891
Hi, thanks for replies, the ENG119212 has 35 km/h but I can’t store 0, 15, 30 even 50, all of them says “out of range”
Regards,
So how about IDE03782 in the Park Assist module?
DV52
C?ID=194404
^^^^^ Arrrhhh............ you have a MY19 MQB vehicle!!!
My apology - but I (and I'm in good company - because I suspect that Uwe did the same) forgot about the secret key that the wacky, zany Burghers @ VW have embedded into the latest model vehicles .
I'm not kidding, but first open the bonnet - then try again!!
At this point, I believe the "diagnostic firewall" is mainly an Audi thing. I also don't think it produces an "Out of Range" error.
DV52
C?ID=194404
^^^^ hmm..... OK - perhaps a simple case of rush of too much blood to the brain box (mine)!! Off to the naughty corner again!
