Results 1 to 7 of 7
Thread: 1st autoscan 2012 vw cc
    Jun 2019
    HI folks,
    This is my first post here and I hope I have done it correctly. I"m an old guy just getting used to this tech stuff. I'm just a shade tree mechanic. Usually perform most maintenance myself however, this is now well above my pay grade for diagnostics.
    Any help would be much appreciated.
    2012 VW CC R-line
    All stock
    Been having a time with occasional dash lights going crazy. At times car would not start with all interior lights flashing, clock resetting, etc.. Just recently it did it again and the negative batt cable was extremely hot to touch. Disconnected batt and let set for few minutes - reconnected and car started. Just got VCDS this week.
    Friday,28,June,2019,14:39:51:59694
    VCDS Version: 19.6.0.6  HEX-V2 CB: 0.4505.4
    VIN: WVWMN7AN5CE500071   License Plate:
    Chassis Type: AN-VW46 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 53 56 62
              65 72 77
    VIN: WVWMN7AN5CE500071   Mileage: 134780km-83748miles
    Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
       Part No SW: 06J 906 027 FE    HW: 06J 907 309 B
       Component: MED17.5.2 TFSI 2    3952
       Revision: PAH04---    Serial number: VWZCZ000000000
       Coding: 0404010A1C070160
       Shop #: WSC 05110 444 99599
       VCID: 73B3DFEAE7BBBA7FC77-8026
                   U1017 - 000 -
    Readiness: 1110 0101
       Part No SW: 02E 300 058 N    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 3522
       Revision: 05351112    Serial number: 00001010021281
       Shop #: WSC 44551 111 44551
       VCID: 2517F1B219EF94CF993-8070
    18255 - Please check DTC Memory of ABS Controller
                P1847 - 000 -  - Intermittent
       Part No SW: 3AA 614 109 M    HW: 3AA 614 109 M
       Component: J104   C2 450M V4DB 0005
       Revision: --H07---    Serial number: 00000003294873
       Coding: 0000399
       Shop #: WSC 05311 000 00000
       VCID: 372B2BFAB343165F3BF-8062
    00532 - Supply Voltage B+
       Part No SW: 7N0 907 426 L    HW: 7N0 907 426 L
       Component: AC Manuell    H17 0202
       Revision: 00012001
       Coding: 0000001002
       Shop #: WSC 00015 115 00000
       ROD: EV_ClimaBasis_VW46.rod
       VCID: 3D2739D29DFF3C0FE13-8068
       Part No SW: 3AA 937 087 B    HW: 3AA 937 087 B
       Component: BCM PQ47 H+   413 0452
       Revision: BC413001
       Coding: 0000000000000000009802259400840440517C8840600D605C8060200040
       VCID: 392F2DC28957002FCDB-806C
       Subsystem 1 - Part No SW: 3C8 955 119 D    HW: 3C8 955 119 D  Labels: 1KX-955-119.CLB
       Component: Wischer 07101  10  0603
       Coding: 00B795
       Component: RLS 221010 05  54  0403
       Coding: 0330ED
    01598 - Drive Battery Voltage
       Part No SW: 5N0 959 655 Q    HW: 5N0 959 655 Q
       Component: J234__30S VW10 HI   1918
       Revision: 22014000    Serial number: 003JZPL6YMXQ
       Coding: 0012371
       VCID: 4BC3670ADFCB82BF6F7-801E
       Subsystem 1 - Part No: 3C8 959 339 A
       Subsystem 2 - Serial number: 00000000001XS4
       Subsystem 3 - Serial number: 0025.09.100000300000850063†63
       Subsystem 4 - Serial number: 850063†6332MTS659692770 †63
       Subsystem 5 - Serial number: 92770 †6342MTS605672780 †63
       Subsystem 6 - Serial number: 72780 †6351HTS610D7F6KJ †63
       Subsystem 7 - Serial number: 7F6KJ †6361HTS6UOIHF9KR †63
       Subsystem 8 - Serial number: HF9KR †63727TS649OFE9KR †63
       Subsystem 9 - Serial number: FE9KR †63827TS67SPDF9KR
       Subsystem 10 - Serial number: DF9KR
    03551 - Functional Restriction of Seat Occupied Recognition
                000 - - - MIL ON
       Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
       Component: LENKS.MODUL   009 0136
       Revision: FF010039    Serial number: 20101025300307
       Coding: 098A270000
       VCID: 6B83C78AB30B62BF0F7-803E
       Coding: E20000
    114178 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
    136194 - Supply voltage
    147464 - Terminal 15
              B1148 29 [008] - Signal Implausible
       Part No SW: 3C8 920 970 Q    HW: 3C8 920 970 Q
       Component: KOMBI         H20 0420
       Coding: 240F00
       Shop #: WSC 05314 115 00000
       VCID: 3A2D32CE8CD10B37C41-806E
    13635840 - Supply voltage
              [Supply voltage too low]
       Part No SW: 7N0 907 530 G    HW: 1K0 907 951
       Component: J533  Gateway H41 1614
       Revision:   H41       Serial number: 201010F2000883
       Coding: 469006
       Shop #: WSC 05314 000 00000
       VCID: 34311CF6AE35FD471ED-8060
       Part No SW: 3C8 919 965     HW: 3C8 919 965
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1614128R28N603
       VCID: 75B7E1F2E9CFA44FE93-8020
       Part No SW: 3AA 959 433 A    HW: 3AA 959 433 A
       Component:    IMMO         042 0399
       Revision: 00042000    Serial number: VWZCZ000000000
       Shop #: WSC 27291 002 1048576
    02827 - Wake-Up request via ESP
    02861 - Electronic Steering Column Lock Check Sum Error
    02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
    02813 - Function of Steering Column Lock Limited due to Insufficient Voltage
       Revision: A1001003    Serial number: 7668799122
       VCID: 270BFBBA6FE386DFABF-8072
       Part No SW: 1T0 959 701 AG    HW: 3C0 959 793 A
       Component: TUER-SG FT    002 0307
       Revision: 12101005    Serial number: 0001694035
       Coding: 0004B7
       Shop #: WSC 05311 115 00000
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide_VW36.rod
       VCID: 7CA1F4D6C665F50796D-8028
       Slave Driver:
       Subsystem 1 - Part No SW: 3C8 959 703 C    HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0401
       Serial number: 00000001731247
       Coding: 000490
              B11EC 54 [008] - Missing Calibration / Basic Setting
    65793 - Supply voltage
              [Front DCU undervoltage]
    131329 - Rear Door Control Module
              B11ED F0 [008] - Supply Voltage too Low
    131584 - Motor for Rear Window Regulator
              B11EE 54 [008] - Missing Calibration / Basic Setting
       Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.303 0802
       Revision: 1AH03729    Serial number: 00102930274701
       Coding: 0000258
       VCID: 3B2337CA8F6B323FDF7-806E
       Component:    KSG PQ47 ELV 042 0631
       Coding: 13910F8001862E521204141FF08A0F0E085801
       Component: EZE_2         H41 1614
       Coding: 00000008
       VCID: 6FBBD39A87939E9F23F-803A
       Subsystem 1 - Part No SW: 3AA 919 204     HW: 3AA 919 204
       Component: Analoguhr  003 0003
       Part No SW: 1T0 959 702 AC    HW: 3C0 959 792 A
       Component: TUER-SG BT    002 0307
       Revision: 14101005    Serial number: 0001690119
       Coding: 0004B6
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide_VW32.rod
       VCID: 79AFEDC2C957C02F8DB-802C
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C8 959 704 C    HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0401
       Serial number: 00000001709702
       Coding: 000490
       Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
       Component: J540 EPB4  VW-55183 0007
       Revision:   H18       Serial number: 00000000002777
       Coding: 0022057
       VCID: 33331FEAA73BFA7F077-8066
       Part No SW: 1K0 035 180 AD    HW: 1K0 035 180 AD
       Component: Radio Prem-8  H04 0013
       Revision: -----12S    Serial number: VWZ4Z7K1159009
       Coding: 0100040004
       VCID: 629DAAAE444123F7BC1-8036
       Part No SW: 3AA 907 273 B    HW: 3AA 907 273 B
       Component: RDKBERU30     H08 0008
       Serial number: 10000000005316
       ASAM Dataset: EV_RDKBERU30 003010
       ROD: EV_RDKBERU30_003.rod
       VCID: 33331FEAABBBFA7F077-8066
    8397570 - Rear Left TPMS Sensor
              C1052 31 [009] - No Signal
       Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
       Component: TELEFON       H05 0440
       Revision: 1B001001    Serial number: 00007668789619
       Coding: 0A00000000010100
       ASAM Dataset: UHVNA A01007
       ROD: UHVNA.rod
       VCID: 323D1AEE54A1F3770C1-8066
    End------(Elapsed Time: 01:38, VBatt start/end: 12.0V/12.0V, udsna)--------
    HQ
    I think you need to sort out the battery cable issue ASAP. It should not be getting hot. This is a sign of resistance, which in turn is a voltage drop issue.... and you've got low voltage codes.
    Odds are you will need to replace the cable. IMHO, if you can get a "clean" junk yard one it will be OK. Most cables at the battery fail due to leaking battery+time.
    Jef
  3. Likes Jack@European_Parts, Uwe liked this post
    Have you verified the battery connection is good and not loose or corrosion disrupted?
    What about battery age or for internal float short if Cells?
    Try wire brush of connections/re tighten and when you say heat like how many amp's of heat or degree's of temperature?
    Is car internally free of water ingress?
    Have you bifurcated tracks by pulling fuses to find respective current draws?
    Before you just change a cable due to being hot, find out why it is hot and remember, a hot cable is not usually from corrosion; it is the corrosion from a hot cable & causing the heat transition, which brings condensates to induce corrosion from the underlined condition.
    NostraJackASS Has Spoken!
    Jun 2019
    Thank you Jack & Jeff
    Thank you so much for your replies.
    Have you verified the battery connection is good and not loose or corrosion disrupted? Yes - connection are clean.
    What about battery age or for internal float short if Cells? Battery is less than 3mos. old. Reads 12.6v when off and alternator is charging properly.
    Try wire brush of connections/re tighten and when you say heat like how many amp's of heat or degree's of temperature? Wife had car in parking lot and I just touched cable and very -ouch- hot.
    Is car internally free of water ingress? No water ingress.
    Have you bifurcated tracks by pulling fuses to find respective current draws? I'll need to read up on how this is done.
    Invalid test method...........
    Indeed.........
    https://forums.ross-tech.com/showthr...final-version)
    Ever JPPSG?
    Jun 2019
    Update to repairs completed
    Checked and confirmed all fuses good. I went thru engine compartment grnd connections. Checked batt connections for V-drop. Cleaned and re-connected all. Batt cables look and tested good. Have not had the heat issue reappear after a week or so of driving.
    Replace RR abs sensor. I got a NGK sensor and that proved not to be compatible with my VW.
    Headed over to VW and picked up an OEM. Installed new sensor and all seems to be fine.<<-lesson learned.
    I've still to track down the radio speaker issue-a job for next week.
    Thank you for the help & insight.
    Auto-scan
          Friday,19,July,2019,10:01:57:59694
              65 72 77
    VIN: WVWMN7AN5CE500071   Mileage: 134920km-83835miles
       VCID: 73B3DFEAE7BBBA7FC7B-8026
       VCID: 2517F1B219EF94CF99F-8070
       Component: J104   C2 450M V4E5 0005
       Coding: 0000399
       VCID: 372B2BFAB343165F3B3-8062
       Revision: 00012001
       Coding: 0000001002
       VCID: 3D2739D29DFF3C0FE1F-8068
       Revision: BC413001
       VCID: 392F2DC28957002FCD7-806C
       Coding: 00B795
       Coding: 0330ED
       Coding: 0012371
       VCID: 4BC3670ADFCB82BF6FB-801E
       Subsystem 3 - Serial number: 0025.09.10000030000085006363
       Subsystem 4 - Serial number: 8500636332MTS659692770 63
       Subsystem 5 - Serial number: 92770 6342MTS605672780 63
       Subsystem 6 - Serial number: 72780 6351HTS610D7F6KJ 63
       Subsystem 7 - Serial number: 7F6KJ 6361HTS6UOIHF9KR 63
       Subsystem 8 - Serial number: HF9KR 63727TS649OFE9KR 63
       Subsystem 9 - Serial number: FE9KR 63827TS67SPDF9KR
       Coding: 098A270000
       VCID: 6B83C78AB30B62BF0FB-803E
       Coding: E20000
       Coding: 240F00
       VCID: 3A2D32CE8CD10B37C4D-806E
       Coding: 469006
       VCID: 34311CF6AE35FD471E1-8060
       VCID: 75B7E1F2E9CFA44FE9F-8020
       VCID: 270BFBBA6FE386DFAB3-8072
       Coding: 0004B7
       VCID: 7CA1F4D6C665F507961-8028
       Slave Driver:
       Coding: 000490
       Coding: 0000258
       VCID: 3B2337CA8F6B323FDFB-806E
       Coding: 00000008
       VCID: 6FBBD39A87939E9F233-803A
       Coding: 0004B6
       VCID: 79AFEDC2C957C02F8D7-802C
       Slave Passenger:
       Coding: 000490
       Coding: 0022057
       VCID: 33331FEAA73BFA7F07B-8066
       Coding: 0100040004
       VCID: 629DAAAE444123F7BCD-8036
       VCID: 33331FEAABBBFA7F07B-8066
                        Fault Frequency: 23
                        Reset counter: 37
                        Mileage: 129408 km
                        Date: 2019.07.04
                        Time: 02:16:42
                        Vehicle speed: 68 km/h
                        Outside air temperature: 29.5 C
                        Reception level antenna 1: 310 mV
                        Offset level antenna 1: 270 mV
       ROD: UHVNA.rod
       VCID: 323D1AEE54A1F3770CD-8066
    9457425 - Left audio channel for speech/telephone
              B104F 11 [001] - Short to GND
    9457169 - Right audio channel for speech/telephone
              B104E 11 [001] - Short to GND
    End----------(Elapsed Time: 01:32, VBatt start/end: 12.0V/12.0V)-----------
  8. Likes Jack@European_Parts, Uwe liked this post
    FOD never sleeps..........
