Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Charge Air Pressure Issue
    Jun 2019
    Canberra, AU
    I have a Golf R 7 with stage 3 hardware and recently the car has started running super rich and the EPC light comes on when a moderate amount of boost is used. The light has gradually started coming on earlier and earlier from startup over the last few weeks.
    VCDS is reading the actual charge air pressure static at just about 1 bar, even though the specified value changes as it should. If I disconnect the lower MAP sensor the actual starts measuring as it should, but this process triggers the engine light. It continues measuring correctly if I plug the sensor back in but reverts to flatline 1 bar if I clear the fault or restart the car.
    What on earth is going on?
    Could someone also help me out with what the two MAP sensors actually do, and which of these is measuring the Actual Charge Air Pressure?
    Post an auto scan please....
    JPPSG and TTYT?
    Jun 2019
    Canberra, AU
    Sorry, I’m a complete VCDS noob, will do a scan tomorrow and post it and the other JPPSG info.
  4. Likes Uwe, Jack@European_Parts liked this post
    Jun 2019
    Canberra, AU
    Below is the scan, this is before the car was run today and no unplugging of sensors etc. The EPC light was triggered on the previous drive.
    The car is a 2016 Golf R with BOSS 600 turbo, dump pipe and high flow cat, standard mufflers and rear exhaust, upgraded HPFP, intake pipes, intercooler and custom tune to 25psi boost and 275kW atw.
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 52 55
    5F A9
    VIN: WVWZZZAUZGW147296 Mileage: 49489km-30751miles
    Address 01: Engine (J623-CJXB) Labels:. 06K-907-425-V1.clb
    Part No SW: 5G0 906 259 F HW: 06K 907 425 B
    Component: 2.0l R4 TFSI H13 0002
    Revision: --H13---
    Coding: 091D00122466050B3004
    ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
    ROD: EV_ECM20TFS0205G0906259F.rod
    VCID: 313F14F7C1AA0DEF75B-8064
    14846 - Turbocharger Boost Control Position Sensor Circuit
    P2563 00 [109] - Implausible Signal
    Mileage: 49412 km
    Date: 2019.06.29
    Time: 15:11:00
    Engine speed: 3657.00 /min
    Normed load value: 23.9 %
    Vehicle speed: 30 km/h
    Coolant temperature: 93 °C
    Intake air temperature: 33 °C
    Ambient air pressure: 940 mbar
    Voltage terminal 30: 14.101 V
    Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000001
    Charge air pressure control valve uncond voltage sensor: 4.5386 V
    Charge air pressure control valve position: target value: 0.00 %
    Charge air pressure control valve position: actual value: 0.00 %
    Charge air pressure control valve activation pulse duty factor: -20.15 %
    Charge air pressure control valve voltage: position closed: 4.4482 V
    STATE_BPA[0]: AD
    Readiness: 0010 0000
    Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
    Component: DQ250-6A MQB H53 4911
    Revision: 06253104 Serial number: TFK01509211648
    ROD: EV_TCMDQ250021.rod
    VCID: 53F37E7F9B761FFF277-8006
    Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
    Component: ESC H42 0723
    Revision: 00000000 Serial number: 62665000000441
    Coding: 01FA93A1542429730779070941C96980C92A94E0E08296F718 4250B8C209
    VCID: 7AADF3DB5C5C0EB7841-802E
    Revision: 00021000 Serial number: 0382103910
    Coding: 030C0C
    VCID: 3A2D33DB1CDCCEB7C41-806E
    Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
    Component: Climatronic H03 1001
    Revision: 00001K08
    Coding: 00120004200100001005000012101402
    VCID: 6A8DC39B2CFCBE37741-803E
    Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
    Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
    Component: BCM MQBAB H H24 0175
    Serial number: 01061527902828
    Coding: 03011A46C24122F30BA44080B10C0728180000000000000000 0000000000
    ROD: EV_BCMBOSCH_015.rod
    VCID: 094F9C1709BA152F9DB-805C
    Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
    Component: WWS 150820 042 0551
    Serial number: 150922125759
    Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
    Component: RLHS 037 0059
    Serial number: S5Y15M10D13H10M36S50
    Coding: 06A8DD
    Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
    Serial number: 000000000ZY152363GME
    Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
    Component: Sirene, DWA 004 0311
    Serial number: 00000000000063621735
    Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
    Component: PARKHILFE 8K H03 0054
    Revision: -------- Serial number: 39331528100210
    Coding: 0071155011
    VCID: 43D34E3F6B168F7F977-8016
    Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
    Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
    Component: ACC Bosch MQB H05 0400
    Serial number: 23081503212727
    Coding: 001C1300FE0739
    ASAM Dataset: EV_ACCMRRBoschVW372 001016
    1043 - Automatic Distance Control
    B10E7 F0 [008] - Disconnected
    [FAULT_CIS_TSK_IRREV_FAIL]
    Reset counter: 220
    Mileage: 49166 km
    Date: 2019.06.22
    Time: 13:11:48
    Control Module temperature: 17 °C
    Voltage terminal 15: 12.6 V
    Vehicle speed: 0.00 m/s
    Acceleration: 0.00 m/s²
    Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
    Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
    Component: DAEMPFUNGS-SG H17 0120
    Serial number: 09101541350449
    ROD: EV_DRCONTITEMIC_VW37.rod
    VCID: 372B2AEF2FCED3DF3BF-8062
    Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
    Component: AirbagVW20 015 0388
    Serial number: 003MLR138CZ3
    Coding: 98CCC000000000005C00000000C800000065
    ROD: EV_AirbaVW20SMEVW37X.rod
    VCID: 7F5B02CF477E2B9FB3F-802A
    Belt Pretensioner left:
    Component: BeltPretRevFL H36 0350
    Serial number: 34169677B07101540181
    Coding: 333135
    Belt Pretensioner right:
    Component: BeltPretRevFR H36 0350
    Serial number: 34169676B06101590769
    Coding: 333135
    Subsystem 3 - Part No SW: ----------- HW: 480 002 809 15
    Serial number: 3576700000054790B61S
    Subsystem 4 - Part No SW: ----------- HW: 480 002 809 15
    Serial number: 35867000000D5941961Y
    Subsystem 5 - Part No SW: ----------- HW: 480 403 009 15
    Serial number: 3516502C31CF2D7141EL
    Subsystem 6 - Part No SW: ----------- HW: 480 403 009 15
    Serial number: 3526502B91CF2DA4030H
    Subsystem 7 - Part No SW: ----------- HW: 480 403 009 15
    Serial number: 3556502AB1CF2D75030J
    Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
    Component: Lenks. Modul 003 0110
    Revision: -------- Serial number: 03101504220493
    Coding: 0C10
    ROD: EV_SMLSKLOMQB_010_VW37.rod
    Part No SW: 5G1 920 758 A HW: 5G1 920 758 A
    Component: KOMBI 302 6420
    Coding: 272D08183F88000801886A095400000000000000
    VCID: 2D070887DD92690F513-8078
    Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
    Component: GW MQB High 128 1223
    Revision: -------- Serial number: 0004017225
    Coding: 030100043F085900FB00027E9C0F0001000105000000000000 0000000000
    ROD: EV_GatewLear_013.rod
    VCID: 75B7E0E7754261CFE93-8020
    Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
    Component: E221__MFL-DC1 H10 0040
    Serial number: 29150001765000105382
    Coding: 2DFFFF
    Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
    Component: J367-BDMHella H04 8050
    Serial number: 7462318003
    Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
    Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
    Serial number: HA1-00014.08.15
    Coding: 0001
    VCID: 4ACD631B4C3C5E37541-801E
    Component: ELV-MQBA H01 0120
    Revision: 00000000 Serial number: 15000219118010
    Coding: 5D00000000000000
    ROD: EV_ELVMarquMQB.rod
    VCID: 34311DE33EB838C71ED-8060
    Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
    Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
    Component: HRE_Master H11 0071
    Serial number: 0381851243
    Coding: 02011203
    ROD: EV_HREntryHella_VW37.rod
    VCID: 3C2135C316E8F087D6D-8068
    Lane Change Assistant 2:
    Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
    Component: HRE_Slave H11 0071
    Serial number: 0381863340
    Coding: 020112
    Component: TSG FS 020 0041
    Serial number: 220915BIL04483
    Coding: 003E12208001048000001000
    Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
    Serial number: 00000000000007600373
    Coding: 0D0000
    Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
    Component: EPS_MQB_ZFLS 505 5063
    Coding: 8103
    VCID: 392F2CD719DAC5AFCDB-806C
    Component: TSG BFS 020 0041
    Serial number: 250915BIO13175
    Coding: 003E10208E01048000801000
    VCID: 42DD4B3B740C86779C1-8016
    Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
    Serial number: 00000000000007468013
    Coding: 150000
    Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
    Component: AFS-ECU H07 0090
    Coding: 02A602000B000200
    VCID: 40D941337A0094678A5-8014
    Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
    Component: LeiMo links H01 0002
    Coding: 2E0000
    Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
    Component: LeiMo rechts H01 0002
    Coding: 2E0000
    Part No SW: 3Q0 035 846 HW: 3Q0 035 846
    Component: MU-S-N-ER 820 0627
    Coding: 02730008FF00000051510001000828001F0207D601200102C7
    ROD: EV_MUStd4CDELP_VW37.rod
    VCID: 6E85CF8B10145217289-803A
    Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
    Component: ABT_Std-2_Nav H43 4064
    Serial number: VWZ6Z9R2790762
    Subsystem 2 - Part No SW: 3G0 919 866 K HW: -----------
    Component: MRM2 2015/16 --- 0420
    Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
    Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
    Component: SAS-GEN 2 H07 0001
    Serial number: 150908201126
    VCID: 2F3B128FD79E1B1F63F-807A
    End----------(Elapsed Time: 04:09, VBatt start/end: 12.1V/12.0V)-----------
    Clear faults and then immediately re-post the scan please.
    Repair harness or check/clean/change G31
    Jun 2019
    Canberra, AU
    Will do this afternoon.
    What is G31? (Again, sorry I’m a noob!)
    RTFB the WD and search it, than you will be enlightened.
  9. #8
    G31 is one of the MAP or "boost" or "charge air" pressure sensors.
    See also:
    https://forums.ross-tech.com/showthread.php?3066
  11. #9
    You would think that someone which is to modify a car to "Stage III dog dukers" would have a better understanding of what or how their car operates.
    OP in addition to RTFB I recommend you read SSP on this engine for design and function.
    It will illustrate in simple detail things you should know.
  12. #10
    If they did it themselves, sure. But what if the just took the car (and a big wad of money) to a tuner and said: "Make it really fast!" ?? I'd suppose there are also some in-between scenarios.
