Passat B8 trailer assist without PLA 3
lukkii
Czech Republic
C?ID=337474
Ho Guys, I have areaview and retrofitted PLA unit 5QAxxx298, coded on 8k. I coded trailer assist im add 17,6c and 10, everything OK. But when tried, there came message “trailer assist not available now”. There is only one fault code, like “I am afraid Dave I cant do it, I am sorry”! EPS error.. Any idea? Thank you, Lukas
downtime
C?ID=280813
ABS coding and adaptations. Did you change those? Please provide an autoscan from your car.
lukkii
Czech Republic
C?ID=337474
please see coding below with error in adresse 10.
please ignor error regardin 5F.
Lukas
Sunday,30,June,2019,19:52:16:32726
VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
Dealer/Shop Name: LF
Workshop Code: 444 00000 000000
VIN: xxxxxxxFP407265   License Plate:
Mileage: 197717km-122855mi   Repair Order:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 3C 42 44 52 55 5F
          69 6C A5 CA CF
VIN: WVWZZZ3CZFP407265   Mileage: 197717km-122855miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
   Component: R4 2.0l TDI   X21 1990
   Revision: B5X21---
   Coding: 011D001A04741D083000
   Shop #: WSC 10000 444 00002
   ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
   ROD: EV_ECM20TDI01104L906026ES_002_VW48.rod
   VCID: 005870D10A84FE67CA1-8054
   Part No SW: 0D9 300 041 A    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4802
   Revision: 05853104    Serial number: TFK01411260629
   Shop #: WSC 00028 028 00024
   ROD: EV_TCMDQ250021.rod
   VCID: 16743689780060D700D-8042
   Part No SW: 3Q0 907 379 H    HW: 3Q0 907 379 H
   Component: ESC           H34 0906
   Revision: 00000000    Serial number: 42904000000356
   Coding: 0FEC6A8F34200B730779060641C849F0562CD0E0608292F13862F078CAA9
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034001
   VCID: 3FDAB32D37FA419FF3B-806A
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0355060936
   Coding: 000F0F0703
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   VCID: 77AA1B0D5F4AB9DFFBB-8022
   Part No SW: 5G0 907 044 CQ    HW: 5G0 907 044 CQ
   Revision: 00001K10
   Coding: 12020124604101012115505001100402
   Shop #: WSC 07790 995 07790
   VCID: 78A818315254B6A7F21-802C
   Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86580112141660
   Coding: 00971E46C2410AFF4BE44004201407081C80000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 7DA609257D76938FA17-8028
   Component: WWS    141124  042 0607
   Serial number:         141201070426
   Coding: 1F4DFD
   Component: RLHS  037 0059
   Serial number: S4Y14M12D11H14M52S31
   Coding: 06A8DD
   Light switch:
   Serial number: 17 10 2014  00001092
   Sun Roof:
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Serial number: 000308417617164
   Coding: 0C71257911
   Shop #: WSC 12781 001 104857
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 50F880919A64CEE71A1-8004
13697025 - Control Module
          U110F 00 [009] - I'm sorry Dave; I'm afraid I can't do that!
          [Steuergerät für Lenkhilfe-J500 - LH_EPS_01.EPS_PLA_Status - PLA-Codierung in Lenkhilfe prüfen]
                    Reset counter: 78
                    Mileage: 197717 km
                    Date: 2019.06.30
                    Time: 19:48:40
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 A
   Component: ACC BOSCH MQB H04 0196
   Coding: B21E677955FFFF28949C8065
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3536D10505C68BCF297-8060
   Part No SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R1PP7RFCD
   Coding: 98FCC0C0008000005C5400CC000800000065
   Shop #: WSC 00028 028 00012
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 015E75D5018EF76FC5F-8054
   Belt Pretensioner left:
   Component: BeltPretRevFL  105 1032
   Serial number: 3G1857705E0328O00083
   Coding: 80000A
   Belt Pretensioner right:
   Component: BeltPretRevFR  105 1032
   Serial number: 3G1857706E0328O00396
   Coding: 80000A
   Subsystem 3 - Part No SW: -----------    HW: 454 000 112 14
   Serial number: 3576U0000001B4691210
   Subsystem 4 - Part No SW: -----------    HW: 454 000 112 14
   Serial number: 3586U000000FA391C11I
   Subsystem 5 - Part No SW: -----------    HW: 454 800 312 14
   Serial number: 3516R73374B05000000$
   Subsystem 6 - Part No SW: -----------    HW: 454 800 312 14
   Serial number: 3526R5F224B050000001
   Subsystem 7 - Part No SW: -----------    HW: 454 800 112 14
   Serial number: 3556V14FC3F05000000J
   Part No SW: 3Q0 953 521 R    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20141127500777
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 3G0 920 751     HW: 3G0 920 751
   Component: KOMBI         308 4311
   Coding: 0BB512186F8C000808887E2B7003000000000000
   VCID: 629C5A59E4C84C77BC5-8036
   Part No SW: 5Q0 963 272 C    HW: 5Q0 963 272 C
   Component: STH-MQB       006 0069
   Coding: 9309
   VCID: 3634D60918C080D720D-8062
   Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000001027933
   Revision: --------    Serial number: 29111410800846
   Coding: 0B0300345F017300FB00025E1C0F00010001070000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72BC2A193428DCF7CC5-8026
   Component: E221__MFL-DC1  H16 0040
   Serial number: 27140003062100094494
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 7498745203
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: WECHSELRICHTE  H54 0033
   Serial number: 0015860
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 0212201400010310
          U1101 00 [009] - Active
                    Reset counter: 78
                    Mileage: 197717 km
                    Date: 2019.06.30
                    Time: 19:48:39
                    Supply voltage: Terminal 30: 12.3 V
                    Terminal 15: On
   Serial number: 14000249651010
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BE2515312EE7EF35F-8024
Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0510
   Revision: --------
   Coding: 16C000
   VCID: 3A2CC2392CD864B7C45-806E
   Part No SW: 5Q4 959 593 D    HW: 5Q4 959 593 B
   Component: TSG FS        009 0016
   Serial number: 0000127482581
   Coding: 00370B205800028000801000
   VCID: 46D4A6C968201057B0D-8012
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000535055
   Component: MQB_PP_APA    203 2051
   Revision: 00000000    Serial number: 0000092408
   Coding: 01000111005010
   ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
   VCID: 40D8B0D14A043E678A1-8014
   Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0015
   Serial number: 0000128541534
   Coding: 00350B205C00028000801000
   Shop #: WSC 44444 010 00001
   VCID: 44D0BCC15E1C2247AE9-8010
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000555770
   Coding: 090000
   Coding: 039A01004F210200
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 0001
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 0001
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
   Part No SW: 5Q0 907 383 D    HW: 5Q0 907 383 D
   Component: Anhaenger     H14 0137
   Revision: 8A001001    Serial number: 0354678309
   Coding: 0101010202020000
   VCID: 3828D83112D476A7321-806C
Address 6C: Back-up Cam. (J123)       Labels:* None
   Part No SW: 5Q0 907 556     HW: 5Q0 907 556
   Component: TopView       H11 0327
   Serial number: C854706JG000070
   Coding: 01840201E30F390000204C14
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 003011
   ROD: EV_CamSysRVAV2ARCE2MQBAB_003_VW37.rod
   VCID: 76B416095840C0D7E0D-8022
   Part No SW: 3Q0 980 653 E    HW: 3Q0 980 653
   Component: MQB_B_MFK     H08 0121
   Serial number: 26111411P10378
   Coding: 01040802050004010022235FC14A8100DB00B0300140
   Part No SW: 4M0 907 594 B    HW: 4M0 907 594
   Component: SAD_STG_1     009 0002
   Coding: 208040748202
   ASAM Dataset: EV_SunRoofCONTIAU736 004008
   ROD: EV_SunRoofCONTIAU736_004.rod
Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
   Revision: --------
   Coding: 16C000
   VCID: 372ADB0D1FCA79DF3BB-8062
End----------(Elapsed Time: 02:23, VBatt start/end: 12.4V/12.4V)-----------
Moving to Retrofits.
Please post a complete Auto-Scan for context.
lukkii
Czech Republic
C?ID=337474
Passat B8 - trailer assist without PLA3 - fault code, not working
Hello Guys,
I have areaview and retrofitted PLA unit 5QA919298 12K, coded on 8k. I coded trailer assist im add 17,6c and 10 and also PLA issue in ABS ( Byte 24 bit 5 enabled), everything OK. But when tried it with trailer, there came message “trailer assist not available now”. Since there is no fault like "missing message" I supouse everything is coded.
BUT - there is one mistake at add 10 - see posting.
P.S: please ignore missing 5F coding, is another issue.
          69 6C A5 CA CF
   Revision: B5X21---
   Coding: 000F0F0703
   Revision: 00001K10
   Coding: 1F4DFD
   Coding: 06A8DD
   Light switch:
   Sun Roof:
   Coding: 0C71257911
                    Reset counter: 78
                    Mileage: 197717 km
                    Date: 2019.06.30
                    Time: 19:48:40
   Coding: 80000A
   Coding: 80000A
   Coding: 0C10
   Coding: 9309
   Coding: 2DFFFF
   Analog clock:
                    Reset counter: 78
                    Mileage: 197717 km
                    Date: 2019.06.30
                    Time: 19:48:39
                    Terminal 15: On
   Revision: --------
   Coding: 16C000
   Coding: 090000
   Coding: E02400
   Coding: E02400
   Coding: E02400
   Coding: E02400
   Revision: --------
   Coding: 16C000
Fix the coding in 44: Steering Assist; it needs to be told that there's a Park Steer Assist active/installed. It should be documented in Byte 1.
PS: Threads merged. Please do not open duplicate threads for the same question.
lukkii
Czech Republic
C?ID=337474
Great Uwe - thanks a lot!!! Issues fixed)).
downtime
C?ID=280813
Try
0FEC6A8F34200B730779060641C849F0562CD0E0608292F1B862F078CAA9
to ABS module. It has byte 24 bit 7 enabled which is ARA trailer assist bit. Then you need to check that it is also enabled in ABS module adaptation channels.
hadez16
C?ID=289891
Try
There is no need to change ABS coding/adaptation when activating Trailer Assist via coding
downtime
C?ID=280813
Ok, good to know that :)
